[PATCH] Fix declaration of pthread-structs in s-osinte-rtems.ads (ada/68169)
    Jan Sommer
    soja-lists at aries.uberspace.de
    Tue Dec  1 19:56:59 UTC 2015
Am Monday 30 November 2015, 16:19:30 schrieb Jeff Law:
> On 11/30/2015 03:06 PM, Jan Sommer wrote:
> > Could someone with write access please commit the patch?
> > The paperwork with the FSF has gone through. If something else is missing, please tell me.
> > I won't be available next week.
> I'm not sure what you built your patches again, but I can't apply them
> to the trunk.  Can you resend a patch as a diff against the trunk.
> Often I can fix things by hand, but this is Ada and I'd be much more
> likely to botch something.
I updated the patches again. They should now fit with the heads of the respective branches again.
Maybe the Changelog will be out of synch again.
The patches are for the following branches:
ada-68169_4.9.diff   -->  gcc-4_9-branch
ada-68169_5.x.diff  -->   gcc-5-branch
ada-68169_trunk.diff --> trunk
Let me know if they apply this time. I used svn diff to create them and used patch -p0 to test if they apply locally.
Thank you,
  Jan
> jeff
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151201/88b6146d/attachment.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151201/88b6146d/attachment-0001.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151201/88b6146d/attachment-0002.bin>
