[PATCH 1/2] m68k/mvme136: Remove
Aun-Ali Zaidi admin at kodeit.net
Tue Dec 8 16:35:59 UTC 2015
updates #2444.
 c/src/lib/libbsp/m68k/mvme136/Makefile.am          |  62 -------
 c/src/lib/libbsp/m68k/mvme136/bsp_specs            |  13 --
 c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c       | 114 ------------
 c/src/lib/libbsp/m68k/mvme136/configure.ac         |  20 ---
 c/src/lib/libbsp/m68k/mvme136/console/console.c    | 173 ------------------
 c/src/lib/libbsp/m68k/mvme136/include/bsp.h        |  81 ---------
 c/src/lib/libbsp/m68k/mvme136/include/coverhd.h    | 106 -----------
 c/src/lib/libbsp/m68k/mvme136/include/tm27.h       |  36 ----
 .../mvme136/make/custom/mvme136-testsuite.tcfg     |   7 -
 .../libbsp/m68k/mvme136/make/custom/mvme136.cfg    |  26 ---
 c/src/lib/libbsp/m68k/mvme136/preinstall.am        |  76 --------
 c/src/lib/libbsp/m68k/mvme136/shmsupp/addrconv.c   |  29 ---
 c/src/lib/libbsp/m68k/mvme136/shmsupp/getcfg.c     |  82 ---------
 c/src/lib/libbsp/m68k/mvme136/shmsupp/lock.c       |  71 --------
 c/src/lib/libbsp/m68k/mvme136/shmsupp/mpisr.c      |  39 ----
 c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c   |  46 -----
 c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c   |  39 ----
 c/src/lib/libbsp/m68k/mvme136/startup/linkcmds     | 199 ---------------------
 c/src/lib/libbsp/m68k/mvme136/timer/timer.c        |  85 ---------
 c/src/lib/libbsp/m68k/mvme136/timer/timerisr.S     |  36 ----
 c/src/lib/libbsp/m68k/mvme136/times                | 189 -------------------
 21 files changed, 1529 deletions(-)
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/Makefile.am
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/bsp_specs
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/configure.ac
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/console/console.c
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/include/bsp.h
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/include/coverhd.h
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/include/tm27.h
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136-testsuite.tcfg
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136.cfg
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/preinstall.am
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/shmsupp/addrconv.c
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/shmsupp/getcfg.c
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/shmsupp/lock.c
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/shmsupp/mpisr.c
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/startup/linkcmds
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/timer/timer.c
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/timer/timerisr.S
 delete mode 100644 c/src/lib/libbsp/m68k/mvme136/times
diff --git a/c/src/lib/libbsp/m68k/mvme136/Makefile.am b/c/src/lib/libbsp/m68k/mvme136/Makefile.am
deleted file mode 100644
index 2dbaef4..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/Makefile.am
+++ /dev/null
@@ -1,62 +0,0 @@
-ACLOCAL_AMFLAGS = -I ../../../../aclocal
-include $(top_srcdir)/../../../../automake/compile.am
-include_bspdir = $(includedir)/bsp
-dist_project_lib_DATA = bsp_specs
-include_HEADERS = include/bsp.h
-include_HEADERS += include/tm27.h
-nodist_include_HEADERS = include/bspopts.h
-nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
-DISTCLEANFILES = include/bspopts.h
-noinst_PROGRAMS =
-include_HEADERS += include/coverhd.h
-## Zilog component header files
-include_rtems_zilogdir = $(includedir)/rtems/zilog
-include_rtems_zilog_HEADERS = ../../shared/include/zilog/z8036.h
-noinst_LIBRARIES = libbspstart.a
-libbspstart_a_SOURCES = ../../m68k/shared/start/start.S
-project_lib_DATA = start.$(OBJEXT)
-dist_project_lib_DATA += startup/linkcmds
-noinst_LIBRARIES += libbsp.a
-libbsp_a_SOURCES =
-# startup
-libbsp_a_SOURCES += startup/bspclean.c ../../shared/bsplibc.c \
-    ../../shared/bsppost.c ../../shared/bsppredriverhook.c  \
-    startup/bspstart.c ../../shared/bootcard.c \
-    ../../shared/bsppretaskinghook.c ../../shared/bspgetworkarea.c \
-    ../../shared/sbrk.c ../../shared/setvec.c
-# gnatsupp
-libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
-# clock
-libbsp_a_SOURCES += clock/ckinit.c
-# console
-libbsp_a_SOURCES += console/console.c
-# debugio
-libbsp_a_SOURCES += ../../shared/dummy_printk_support.c
-# timer
-libbsp_a_SOURCES += timer/timer.c timer/timerisr.S
-if HAS_MP
-# shmsupp
-libbsp_a_SOURCES += shmsupp/addrconv.c shmsupp/getcfg.c shmsupp/lock.c \
-    shmsupp/mpisr.c
-endif
-libbsp_a_LIBADD = \
-    ../../../libcpu/@RTEMS_CPU@/shared/cache.rel \
-    ../../../libcpu/@RTEMS_CPU@/shared/misc.rel
-EXTRA_DIST = times
-include $(srcdir)/preinstall.am
-include $(top_srcdir)/../../../../automake/local.am
diff --git a/c/src/lib/libbsp/m68k/mvme136/bsp_specs b/c/src/lib/libbsp/m68k/mvme136/bsp_specs
index 5154de8..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/bsp_specs
+++ /dev/null
@@ -1,13 +0,0 @@
-%rename endfile old_endfile
-%rename startfile old_startfile
-%rename link old_link
-*startfile:
-%{!qrtems: %(old_startfile)} \
-%{!nostdlib: %{qrtems: start.o%s crti.o%s crtbegin.o%s -e start}}
-*link:
-%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N}
-*endfile:
-%{!qrtems: %(old_endfile)} %{qrtems: crtend.o%s crtn.o%s}
diff --git a/c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c b/c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c
index 02115c4..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c
+++ /dev/null
@@ -1,114 +0,0 @@
- *  This routine initializes the Z80386 1 on the MVME136 board.
- *  The tick frequency is 1 millisecond.
- *  COPYRIGHT (c) 1989-1999.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#include <stdlib.h>
-#include <bsp.h>
-#include <rtems/zilog/z8036.h>
-#define MICRVAL     0xe2            /* disable lower chain, no vec */
-                                    /*  set right justified addr */
-                                    /*  and master int enable */
-#define MCCRVAL     0xc4            /* enable T1 and port B */
-                                    /*   timers independent */
-#define MS_COUNT    0x07d0          /* T1's countdown constant (1 ms) */
-#define T1MSRVAL    0x80            /* T1 cont. cycle/pulse output */
-#define T1CSRVAL    0xc6            /* enable interrupt, allow and */
-                                    /*   and trigger countdown */
-#define TIMER        0xfffb0000
-#define RELOAD       0x24            /* clr IP & IUS,allow countdown */
-#define CLOCK_VECTOR 66
-uint32_t         Clock_isrs;        /* ISRs until next tick */
-volatile uint32_t         Clock_driver_ticks; /* ticks since initialization */
-rtems_isr_entry  Old_ticker;
-void Clock_exit( void );
- *  ISR Handler
-static rtems_isr Clock_isr(
-  rtems_vector_number vector
-  Clock_driver_ticks += 1;
-  ((volatile struct z8036_map *) TIMER)->CT1_CMD_STATUS = RELOAD;
-  if ( Clock_isrs == 1 ) {
-    rtems_clock_tick();
-    Clock_isrs = rtems_configuration_get_microseconds_per_tick() / 1000;
-  else
-    Clock_isrs -= 1;
-static void Install_clock(
-  rtems_isr_entry clock_isr
-  volatile struct z8036_map *timer;
-  Clock_driver_ticks = 0;
-  Old_ticker = (rtems_isr_entry) set_vector( clock_isr, CLOCK_VECTOR, 1 );
-  timer = (struct z8036_map *) 0xfffb0000;
-  timer->MASTER_INTR        = MICRVAL;
-  timer->CT1_MODE_SPEC      = T1MSRVAL;
-  *((uint16_t*)0xfffb0016) = MS_COUNT;  /* write countdown value */
-   *  timer->CT1_TIME_CONST_MSB = (MS_COUNT >> 8);
-   *  timer->CT1_TIME_CONST_LSB = (MS_COUNT &  0xff);
-  timer->MASTER_CFG         = MCCRVAL;
-  timer->CT1_CMD_STATUS     = T1CSRVAL;
-   * Enable interrupt via VME interrupt mask register
-  (*(uint8_t*)0xfffb0038) &= 0xfd;
-  atexit( Clock_exit );
-  timer->MASTER_INTR        = 0x62;
-  timer->CT1_MODE_SPEC      = 0x00;
-  timer->MASTER_CFG         = 0xf4;
-  timer->CT1_CMD_STATUS     = 0x00;
-  /* do not restore old vector */
-rtems_device_driver Clock_initialize(
-  rtems_device_major_number major,
-  rtems_device_minor_number minor,
-  void *pargp
-  Install_clock( Clock_isr );
-  return RTEMS_SUCCESSFUL;
diff --git a/c/src/lib/libbsp/m68k/mvme136/configure.ac b/c/src/lib/libbsp/m68k/mvme136/configure.ac
index 2a714b6..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/configure.ac
+++ /dev/null
@@ -1,20 +0,0 @@
-## Process this file with autoconf to produce a configure script.
-AC_PREREQ([2.69])
-AC_INIT([rtems-c-src-lib-libbsp-m68k-mvme136],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
-AC_CONFIG_SRCDIR([bsp_specs])
-RTEMS_TOP(../../../../../..)
-RTEMS_CANONICAL_TARGET_CPU
-AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
-RTEMS_BSP_CONFIGURE
-RTEMS_PROG_CC_FOR_TARGET
-RTEMS_CANONICALIZE_TOOLS
-RTEMS_PROG_CCAS
-RTEMS_BSP_CLEANUP_OPTIONS(0, 0)
-# Explicitly list all Makefiles here
-AC_CONFIG_FILES([Makefile])
-AC_OUTPUT
diff --git a/c/src/lib/libbsp/m68k/mvme136/console/console.c b/c/src/lib/libbsp/m68k/mvme136/console/console.c
index ce8fa8d..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/console/console.c
+++ /dev/null
@@ -1,173 +0,0 @@
- *  This file contains the MVME136 console IO package.
- *  COPYRIGHT (c) 1989-2014.
-#include <bsp.h>
-#include <rtems/libio.h>
-volatile struct r_m681_info *_Read_m681;  /* M68681 read registers */
-volatile struct w_m681_info *_Write_m681; /* M68681 write registers */
-/*  console_initialize
- *  This routine initializes the console IO driver.
-rtems_device_driver console_initialize(
-  void                      *arg
-  rtems_status_code status;
-  _Write_m681 = ( struct w_m681_info * ) M681ADDR;
-  _Read_m681 = ( struct r_m681_info * ) M681ADDR;
-  status = rtems_io_register_name(
-    "/dev/console",
-    major,
-    (rtems_device_minor_number) 0
-  if (status != RTEMS_SUCCESSFUL)
-    rtems_fatal_error_occurred(status);
-/*  inbyte
- *  This routine reads a character from the UART.
-static char inbyte( void )
-  while ( !(_Read_m681->srb & RXRDYB) );
-  return _Read_m681->rbb;
-/*  outbyte
- *  This routine transmits a character out the M68681.  It supports
- *  XON/XOFF flow control.
-static void outbyte(
-  char ch
-  while ( ! (_Read_m681->srb & TXRDYB) ) ;
-  while ( _Read_m681->srb & RXRDYB )        /* must be an XOFF */
-    if ( _Read_m681->rbb == XOFF )
-      do {
-        while ( ! (_Read_m681->srb & RXRDYB) ) ;
-      } while ( _Read_m681->rbb != XON );
-  _Write_m681->tbb = ch;
-  if ( ch == '\n' )
-    outbyte( CR );
- *  Open entry point
-rtems_device_driver console_open(
-  void                    * arg
- *  Close entry point
-rtems_device_driver console_close(
-  void                    * arg
- * read bytes from the serial port. We only have stdin.
-rtems_device_driver console_read(
-  void                    * arg
-  rtems_libio_rw_args_t *rw_args;
-  char *buffer;
-  int maximum;
-  int count = 0;
-  rw_args = (rtems_libio_rw_args_t *) arg;
-  buffer = rw_args->buffer;
-  maximum = rw_args->count;
-  for (count = 0; count < maximum; count++) {
-    buffer[ count ] = inbyte();
-    if (buffer[ count ] == '\n' || buffer[ count ] == '\r') {
-      buffer[ count++ ]  = '\n';
-      break;
-  rw_args->bytes_moved = count;
-  return (count >= 0) ? RTEMS_SUCCESSFUL : RTEMS_UNSATISFIED;
- * write bytes to the serial port. Stdout and stderr are the same.
-rtems_device_driver console_write(
-  void                    * arg
-  int count;
-  int maximum;
-  char *buffer;
-    if ( buffer[ count ] == '\n') {
-      outbyte('\r');
-    outbyte( buffer[ count ] );
-  rw_args->bytes_moved = maximum;
-  return 0;
- *  IO Control entry point
-rtems_device_driver console_control(
-  void                    * arg
diff --git a/c/src/lib/libbsp/m68k/mvme136/include/bsp.h b/c/src/lib/libbsp/m68k/mvme136/include/bsp.h
index 3ea2101..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/include/bsp.h
+++ /dev/null
@@ -1,81 +0,0 @@
- *  This include file contains all MVME136 board IO definitions.
-#ifndef LIBBSP_M68K_MVME136_BSP_H
-#define LIBBSP_M68K_MVME136_BSP_H
-#include <bspopts.h>
-#include <bsp/default-initial-extension.h>
-#include <rtems.h>
-#include <rtems/clockdrv.h>
-#include <rtems/console.h>
-#include <rtems/iosupp.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
-/* Constants */
-#define RAM_START 0
-#define RAM_END   0x100000
-#define M681ADDR      0xfffb0040         /* address of the M68681 chip */
-#define RXRDYB        0x01               /* status reg recv ready mask */
-#define TXRDYB        0x04               /* status reg trans ready mask */
-#define PARITYERR     0x20               /* status reg parity error mask */
-#define FRAMEERR      0x40               /* status reg frame error mask */
-#define FOREVER       1                  /* infinite loop */
-/* Structures */
-struct r_m681_info {
-  char fill1[ 5 ];                       /* channel A regs ( not used ) */
-  char isr;                              /* interrupt status reg */
-  char fill2[ 2 ];                       /* counter regs (not used) */
-  char mr1mr2b;                          /* MR1B and MR2B regs */
-  char srb;                              /* status reg channel B */
-  char fill3;                            /* do not access */
-  char rbb;                              /* receive buffer channel B */
-  char ivr;                              /* interrupt vector register */
-struct w_m681_info {
-  char fill1[ 4 ];                       /* channel A regs (not used) */
-  char acr;                              /* auxillary control reg */
-  char imr;                              /* interrupt mask reg */
-  char csrb;                             /* clock select reg */
-  char crb;                              /* command reg */
-  char tbb;                              /* transmit buffer channel B */
-extern rtems_isr_entry M68Kvec[];   /* vector table address */
-/* functions */
-rtems_isr_entry set_vector(
-  rtems_isr_entry     handle,
-  rtems_vector_number vector,
-  int                 type
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/c/src/lib/libbsp/m68k/mvme136/include/coverhd.h b/c/src/lib/libbsp/m68k/mvme136/include/coverhd.h
index 025b9cd..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/include/coverhd.h
+++ /dev/null
@@ -1,106 +0,0 @@
- * @file
- * @ingroup m68k_mvme136
- * @brief C Overhead definitions
- *  This include file has defines to represent the overhead associated
- *  with calling a particular directive from C on this target.
-#ifndef __COVERHD_h
-#define __COVERHD_h
-#ifdef __cplusplus
-extern "C" {
-#endif
-#define CALLING_OVERHEAD_INITIALIZE_EXECUTIVE      2
-#define CALLING_OVERHEAD_SHUTDOWN_EXECUTIVE        1
-#define CALLING_OVERHEAD_TASK_CREATE               3
-#define CALLING_OVERHEAD_TASK_IDENT                2
-#define CALLING_OVERHEAD_TASK_START                2
-#define CALLING_OVERHEAD_TASK_RESTART              2
-#define CALLING_OVERHEAD_TASK_DELETE               1
-#define CALLING_OVERHEAD_TASK_SUSPEND              1
-#define CALLING_OVERHEAD_TASK_RESUME               2
-#define CALLING_OVERHEAD_TASK_SET_PRIORITY         2
-#define CALLING_OVERHEAD_TASK_MODE                 2
-#define CALLING_OVERHEAD_TASK_GET_NOTE             2
-#define CALLING_OVERHEAD_TASK_SET_NOTE             2
-#define CALLING_OVERHEAD_TASK_WAKE_WHEN            4
-#define CALLING_OVERHEAD_TASK_WAKE_AFTER           1
-#define CALLING_OVERHEAD_INTERRUPT_CATCH           2
-#define CALLING_OVERHEAD_CLOCK_GET                 5
-#define CALLING_OVERHEAD_CLOCK_SET                 4
-#define CALLING_OVERHEAD_CLOCK_TICK                1
-#define CALLING_OVERHEAD_TIMER_CREATE              2
-#define CALLING_OVERHEAD_TIMER_IDENT               1
-#define CALLING_OVERHEAD_TIMER_DELETE              2
-#define CALLING_OVERHEAD_TIMER_FIRE_AFTER          2
-#define CALLING_OVERHEAD_TIMER_FIRE_WHEN           5
-#define CALLING_OVERHEAD_TIMER_RESET               1
-#define CALLING_OVERHEAD_TIMER_CANCEL              1
-#define CALLING_OVERHEAD_SEMAPHORE_CREATE          3
-#define CALLING_OVERHEAD_SEMAPHORE_DELETE          1
-#define CALLING_OVERHEAD_SEMAPHORE_IDENT           2
-#define CALLING_OVERHEAD_SEMAPHORE_OBTAIN          2
-#define CALLING_OVERHEAD_SEMAPHORE_RELEASE         1
-#define CALLING_OVERHEAD_MESSAGE_QUEUE_CREATE      2
-#define CALLING_OVERHEAD_MESSAGE_QUEUE_IDENT       2
-#define CALLING_OVERHEAD_MESSAGE_QUEUE_DELETE      1
-#define CALLING_OVERHEAD_MESSAGE_QUEUE_SEND        2
-#define CALLING_OVERHEAD_MESSAGE_QUEUE_URGENT      2
-#define CALLING_OVERHEAD_MESSAGE_QUEUE_BROADCAST   2
-#define CALLING_OVERHEAD_MESSAGE_QUEUE_RECEIVE     3
-#define CALLING_OVERHEAD_MESSAGE_QUEUE_FLUSH       2
-#define CALLING_OVERHEAD_EVENT_SEND                2
-#define CALLING_OVERHEAD_EVENT_RECEIVE             2
-#define CALLING_OVERHEAD_SIGNAL_CATCH              2
-#define CALLING_OVERHEAD_SIGNAL_SEND               2
-#define CALLING_OVERHEAD_PARTITION_CREATE          3
-#define CALLING_OVERHEAD_PARTITION_IDENT           2
-#define CALLING_OVERHEAD_PARTITION_DELETE          1
-#define CALLING_OVERHEAD_PARTITION_GET_BUFFER      2
-#define CALLING_OVERHEAD_PARTITION_RETURN_BUFFER   2
-#define CALLING_OVERHEAD_REGION_CREATE             3
-#define CALLING_OVERHEAD_REGION_IDENT              2
-#define CALLING_OVERHEAD_REGION_DELETE             2
-#define CALLING_OVERHEAD_REGION_GET_SEGMENT        3
-#define CALLING_OVERHEAD_REGION_RETURN_SEGMENT     2
-#define CALLING_OVERHEAD_PORT_CREATE               3
-#define CALLING_OVERHEAD_PORT_IDENT                2
-#define CALLING_OVERHEAD_PORT_DELETE               1
-#define CALLING_OVERHEAD_PORT_EXTERNAL_TO_INTERNAL 2
-#define CALLING_OVERHEAD_PORT_INTERNAL_TO_EXTERNAL 2
-#define CALLING_OVERHEAD_IO_INITIALIZE             2
-#define CALLING_OVERHEAD_IO_OPEN                   2
-#define CALLING_OVERHEAD_IO_CLOSE                  3
-#define CALLING_OVERHEAD_IO_READ                   2
-#define CALLING_OVERHEAD_IO_WRITE                  2
-#define CALLING_OVERHEAD_IO_CONTROL                2
-#define CALLING_OVERHEAD_FATAL_ERROR_OCCURRED      1
-#define CALLING_OVERHEAD_RATE_MONOTONIC_CREATE     2
-#define CALLING_OVERHEAD_RATE_MONOTONIC_IDENT      2
-#define CALLING_OVERHEAD_RATE_MONOTONIC_DELETE     1
-#define CALLING_OVERHEAD_RATE_MONOTONIC_CANCEL     1
-#define CALLING_OVERHEAD_RATE_MONOTONIC_PERIOD     2
-#define CALLING_OVERHEAD_MULTIPROCESSING_ANNOUNCE  1
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/c/src/lib/libbsp/m68k/mvme136/include/tm27.h b/c/src/lib/libbsp/m68k/mvme136/include/tm27.h
index 66771bf..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/include/tm27.h
+++ /dev/null
@@ -1,36 +0,0 @@
- * @file
- * @brief Implementations for interrupt mechanisms for Time Test 27
-#ifndef _RTEMS_TMTEST27
-#error "This is an RTEMS internal file you must not include directly."
-#endif
-#ifndef __tm27_h
-#define __tm27_h
- *  Define the interrupt mechanism for Time Test 27
- *  NOTE: Use the MPCSR vector for the MVME136
-#define MUST_WAIT_FOR_INTERRUPT 0
-#define Install_tm27_vector( handler ) set_vector( (handler), 75, 1 )
-#define Cause_tm27_intr()  (*(volatile uint8_t*)0xfffb006b) = 0x80
-#define Clear_tm27_intr()  (*(volatile uint8_t*)0xfffb006b) = 0x00
-#define Lower_tm27_intr() /* empty */
-#endif
diff --git a/c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136-testsuite.tcfg b/c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136-testsuite.tcfg
index e8bff63..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136-testsuite.tcfg
+++ /dev/null
@@ -1,7 +0,0 @@
-# mvme136 RTEMS Test Database
-# Format is one line per test that is _NOT_ built.
-fsdosfsname01
diff --git a/c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136.cfg b/c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136.cfg
index c90a7a3..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136.cfg
+++ /dev/null
@@ -1,26 +0,0 @@
-#  Config file for the mvme136 BSP
-include $(RTEMS_ROOT)/make/custom/default.cfg
-RTEMS_CPU=m68k
-RTEMS_CPU_MODEL=m68020
-#  This contains the compiler options necessary to select the CPU model
-#  and (hopefully) optimize for it.
-CPU_CFLAGS = -mcpu=68020
-# optimize flag: typically -O2
-CFLAGS_OPTIMIZE_V = -Os -g -fomit-frame-pointer
-define bsp-post-link
-	$(OBJCOPY) -O srec $(basename $@)$(EXEEXT) $(basename $@).srec
-	sed -e 's/.$$//' -e '/^S0/d' $(basename $@).srec | \
-	    $(PACKHEX) > $(basename $@)$(DOWNEXT)
-	rm -f $(basename $@).srec
-	$(default-bsp-post-link)
-endef
diff --git a/c/src/lib/libbsp/m68k/mvme136/preinstall.am b/c/src/lib/libbsp/m68k/mvme136/preinstall.am
index 4f605dc..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/preinstall.am
+++ /dev/null
@@ -1,76 +0,0 @@
-## Automatically generated by ampolish3 - Do not edit
-if AMPOLISH3
-$(srcdir)/preinstall.am: Makefile.am
-	$(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
-endif
-PREINSTALL_DIRS =
-DISTCLEANFILES += $(PREINSTALL_DIRS)
-all-am: $(PREINSTALL_FILES)
-PREINSTALL_FILES =
-CLEANFILES = $(PREINSTALL_FILES)
-all-local: $(TMPINSTALL_FILES)
-TMPINSTALL_FILES =
-CLEANFILES += $(TMPINSTALL_FILES)
-$(PROJECT_LIB)/$(dirstamp):
-	@$(MKDIR_P) $(PROJECT_LIB)
-	@: > $(PROJECT_LIB)/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
-$(PROJECT_INCLUDE)/$(dirstamp):
-	@$(MKDIR_P) $(PROJECT_INCLUDE)
-	@: > $(PROJECT_INCLUDE)/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
-$(PROJECT_INCLUDE)/bsp/$(dirstamp):
-	@$(MKDIR_P) $(PROJECT_INCLUDE)/bsp
-	@: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-$(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
-PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
-$(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
-$(PROJECT_INCLUDE)/tm27.h: include/tm27.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
-$(PROJECT_INCLUDE)/bspopts.h: include/bspopts.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bspopts.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bspopts.h
-$(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
-$(PROJECT_INCLUDE)/coverhd.h: include/coverhd.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
-$(PROJECT_INCLUDE)/rtems/zilog/$(dirstamp):
-	@$(MKDIR_P) $(PROJECT_INCLUDE)/rtems/zilog
-	@: > $(PROJECT_INCLUDE)/rtems/zilog/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/zilog/$(dirstamp)
-$(PROJECT_INCLUDE)/rtems/zilog/z8036.h: ../../shared/include/zilog/z8036.h $(PROJECT_INCLUDE)/rtems/zilog/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/zilog/z8036.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/zilog/z8036.h
-$(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
-TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
-$(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
-PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds
diff --git a/c/src/lib/libbsp/m68k/mvme136/shmsupp/addrconv.c b/c/src/lib/libbsp/m68k/mvme136/shmsupp/addrconv.c
index 82ad28b..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/shmsupp/addrconv.c
+++ /dev/null
@@ -1,29 +0,0 @@
-/*  Shm_Convert_address
- *  This MVME136 has a "normal" view of the VME address space.
- *  No address range conversion is required.
- *  Input parameters:
- *    address - address to convert
- *  Output parameters:
- *    returns - converted address
-#include <rtems.h>
-#include <bsp.h>
-#include <shm_driver.h>
-void *Shm_Convert_address(
-  void *address
-  return ( address );
diff --git a/c/src/lib/libbsp/m68k/mvme136/shmsupp/getcfg.c b/c/src/lib/libbsp/m68k/mvme136/shmsupp/getcfg.c
index 7057369..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/shmsupp/getcfg.c
+++ /dev/null
@@ -1,82 +0,0 @@
-/*  void Shm_Get_configuration( localnode, &shmcfg )
- *  This routine initializes, if necessary, and returns a pointer
- *  to the Shared Memory Configuration Table for the Cyclone CVME961.
- *  INPUT PARAMETERS:
- *    localnode - local node number
- *    shmcfg    - address of pointer to SHM Config Table
- *  OUTPUT PARAMETERS:
- *    *shmcfg   - pointer to SHM Config Table
- *  NOTES:  The MPCSR interrupt on the MVME136 is used as an interprocessor
- *          interrupt.   The capablities of the MPCSR are used to generate
- *          interprocessor interrupts for up to eight nodes.
- *          The following table illustrates the configuration limitations:
- *                                   BUS     MAX
- *                          MODE    ENDIAN  NODES
- *                         POLLED   LITTLE  2+
- *                        INTERRUPT LITTLE  2-8
-#include <rtems.h>
-#include "shm_driver.h"
-#define INTERRUPT 1                   /* MVME136 target supports both */
-#define POLLING   0                   /* polling and interrupt modes  */
-shm_config_table BSP_shm_cfgtbl;
-uint32_t         *BSP_int_address()
-  uint32_t         id, offset;
-  id      = (uint32_t) *(uint8_t*)0xfffb0061;
-  offset  = ((id & 0x1f) << 5) | ((id & 0xe0) << 8);
-  offset |= 0xffff000b;
-  return( (uint32_t         * ) offset );
-void Shm_Get_configuration(
-  uint32_t           localnode,
-  shm_config_table **shmcfg
-   BSP_shm_cfgtbl.base         = (uint32_t*)0x20000000;
-   BSP_shm_cfgtbl.length       = 1 * MEGABYTE;
-   BSP_shm_cfgtbl.format       = SHM_BIG;
-   BSP_shm_cfgtbl.cause_intr   = Shm_Cause_interrupt;
-#ifdef NEUTRAL_BIG
-   BSP_shm_cfgtbl.convert      = NULL_CONVERT;
-#else
-   BSP_shm_cfgtbl.convert      = CPU_swap_u32;
-#endif
-#if (POLLING==1)
-   BSP_shm_cfgtbl.poll_intr    = POLLED_MODE;
-   BSP_shm_cfgtbl.Intr.address = NO_INTERRUPT;
-   BSP_shm_cfgtbl.Intr.value   = NO_INTERRUPT;
-   BSP_shm_cfgtbl.Intr.length  = NO_INTERRUPT;
-#else
-   BSP_shm_cfgtbl.poll_intr    = INTR_MODE;
-   BSP_shm_cfgtbl.Intr.address = BSP_int_address();
-   BSP_shm_cfgtbl.Intr.value   = 0x80;
-   BSP_shm_cfgtbl.Intr.length  = BYTE;
-#endif
-   *shmcfg = &BSP_shm_cfgtbl;
diff --git a/c/src/lib/libbsp/m68k/mvme136/shmsupp/lock.c b/c/src/lib/libbsp/m68k/mvme136/shmsupp/lock.c
index 129de01..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/shmsupp/lock.c
+++ /dev/null
@@ -1,71 +0,0 @@
-/*  Shared Memory Lock Routines
- *  This shared memory locked queue support routine need to be
- *  able to lock the specified locked queue.  Interrupts are
- *  disabled while the queue is locked to prevent preemption
- *  and deadlock when two tasks poll for the same lock.
- *  previous level.
-#include <rtems.h>
-#include <bsp.h>
- *  Shm_Initialize_lock
- *  Initialize the lock for the specified locked queue.
-void Shm_Initialize_lock(
-  Shm_Locked_queue_Control *lq_cb
-  lq_cb->lock = LQ_UNLOCKED;
-/*  void _Shm_Lock( &lq_cb )
- *  This shared memory locked queue support routine locks the
- *  specified locked queue.  It disables interrupts to prevent
- *  a deadlock condition.
-void Shm_Lock(
-  uint32_t         isr_level;
-  uint32_t         *lockptr = (uint32_t*)&lq_cb->lock;
-  rtems_interrupt_disable( isr_level );
-    Shm_isrstat = isr_level;
-    __asm__ volatile( "lockit:"    : : );
-    __asm__ volatile( "tas %0@"    : "=a" (lockptr) : "0" (lockptr) );
-    __asm__ volatile( "bne lockit" : : );
-/* should delay */
- *  Shm_Unlock
- *  Unlock the lock for the specified locked queue.
-void Shm_Unlock(
-  lq_cb->lock = SHM_UNLOCK_VALUE;
-  isr_level = Shm_isrstat;
-  rtems_interrupt_enable( isr_level );
diff --git a/c/src/lib/libbsp/m68k/mvme136/shmsupp/mpisr.c b/c/src/lib/libbsp/m68k/mvme136/shmsupp/mpisr.c
index 0788378..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/shmsupp/mpisr.c
+++ /dev/null
@@ -1,39 +0,0 @@
-/*  Shm_isr_mvme136()
- *  NOTE: This routine is not used when in polling mode.  Either
- *        this routine OR Shm_clockisr is used in a particular system.
-#include <rtems.h>
-#include <bsp.h>
-rtems_isr Shm_isr_mvme136()
-  Shm_Interrupt_count += 1;
-  rtems_multiprocessing_announce();
-  (*(volatile uint8_t*)0xfffb006b) = 0; /* clear MPCSR intr */
-/*  void _Shm_setvec( )
- *  This driver routine sets the SHM interrupt vector to point to the
- *  driver's SHM interrupt service routine.
- *  Input parameters:  NONE
- *  Output parameters: NONE
-void Shm_setvec()
-  /* may need to disable intr */
-  set_vector( Shm_isr_mvme136, 75, 1 );
diff --git a/c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c b/c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c
index 5d968b8..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c
+++ /dev/null
@@ -1,46 +0,0 @@
- *  This routine returns control to 135Bug.
-#include <bsp.h>
-#include <bsp/bootcard.h>
-void start(void);
-static rtems_isr bsp_return_to_monitor_trap(rtems_vector_number ignored)
-  register volatile void *start_addr;
-  m68k_set_vbr( 0 );                  /* restore 135Bug vectors */
-  __asm__ volatile( "trap   #15"  );  /* trap to 135Bug */
-  __asm__ volatile( ".short 0x63" );  /* return to 135Bug (.RETURN) */
-                                      /* restart program */
-  start_addr = start;
-  __asm__ volatile ( "jmp %0@" : "=a" (start_addr) : "0" (start_addr) );
-void bsp_fatal_extension(
-  rtems_fatal_source source,
-  bool is_internal,
-  rtems_fatal_code error
-   Z8x36_WRITE( TIMER, MASTER_INTR,    0x62 );   /* redo timer */
-   Z8x36_WRITE( TIMER, CT1_MODE_SPEC,  0x00 );
-   Z8x36_WRITE( TIMER, MASTER_CFG,     0xf4 );
-   Z8x36_WRITE( TIMER, CT1_CMD_STATUS, 0x00 );
-   M68Kvec[ 45 ] = bsp_return_to_monitor_trap;   /* install handler */
-   __asm__ volatile( "trap #13" );  /* insures SUPV mode */
diff --git a/c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c b/c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c
index 04d073d..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c
+++ /dev/null
@@ -1,39 +0,0 @@
- *  This routine does the bulk of the system initialization.
-#include <bsp.h>
-void bsp_start( void )
-  rtems_isr_entry *monitors_vector_table;
-  int             index;
-  monitors_vector_table = (rtems_isr_entry *)0;   /* 135Bug Vectors are at 0 */
-  m68k_set_vbr( monitors_vector_table );
-  for ( index=2 ; index<=255 ; index++ )
-    M68Kvec[ index ] = monitors_vector_table[ 32 ];
-  M68Kvec[  2 ] = monitors_vector_table[  2 ];   /* bus error vector */
-  M68Kvec[  4 ] = monitors_vector_table[  4 ];   /* breakpoints vector */
-  M68Kvec[  9 ] = monitors_vector_table[  9 ];   /* trace vector */
-  M68Kvec[ 47 ] = monitors_vector_table[ 47 ];   /* system call vector */
-  m68k_set_vbr( &M68Kvec );
-  (*(uint8_t*)0xfffb0067) = 0x7f; /* make VME access round-robin */
-  rtems_cache_enable_instruction();
diff --git a/c/src/lib/libbsp/m68k/mvme136/startup/linkcmds b/c/src/lib/libbsp/m68k/mvme136/startup/linkcmds
index ad4cba6..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/startup/linkcmds
+++ /dev/null
@@ -1,199 +0,0 @@
- *  This file contains directives for the GNU linker which are specific
- *  to the Motorola MVME136/MVME135 boards.
- *  COPYRIGHT (c) 1989-2007.
- * Declare some sizes.
-RamBase = DEFINED(RamBase) ? RamBase : 0x0;
-RamSize = DEFINED(RamSize) ? RamSize : 1M;
-HeapSize = DEFINED(HeapSize) ? HeapSize : 0x0;
-_StackSize = DEFINED(_StackSize) ? _StackSize : 0x1000;
-MEMORY
-	ram : org = 0x0, l = 1M
-SECTIONS
-	ram : {
-		. = 0x3000;
-	} >ram
-         * Text, data and bss segments
-        .text : {
-                *(.text*)
-		 * C++ constructors/destructors
-     		 * Various files can provide initialization and finalization
-		 * functions.  crtbegin.o and crtend.o are two instances. The
-		 * body of these functions are in .init and .fini sections. We
-		 * accumulate the bodies here, and prepend function prologues
-		 * from crti.o and function epilogues from crtn.o. crti.o must
-		 * be linked first; crtn.o must be linked last.  Because these
-		 * are wildcards, it doesn't matter if the user does not
-		 * actually link against crti.o and crtn.o; the linker won't
-		 * look for a file to match a wildcard.  The wildcard also
-		 * means that it doesn't matter which directory crti.o and
-		 * crtn.o are in.
-		*(.gnu.linkonce.t.*)
-		 * Initialization and finalization code.
-     		 * gcc uses crtbegin.o to find the start of the constructors
-		 * and destructors so we make sure it is first.  Because this
-		 * is a wildcard, it doesn't matter if the user does not
-		 * actually link against crtbegin.o; the linker won't look for
-		 * a file to match a wildcard.  The wildcard also means that
-		 * it doesn't matter which directory crtbegin.o is in. The
-		 * constructor and destructor list are terminated in
-		 * crtend.o.  The same comments apply to it.
-		PROVIDE (_init = .);
-		*crti.o(.init)
-		*(.init)
-		*crtn.o(.init)
-		PROVIDE (_fini = .);
-		*crti.o(.fini)
-		*(.fini)
-		*crtn.o(.fini)
-		 * Special FreeBSD sysctl sections.
-		. = ALIGN (16);
-		__start_set_sysctl_set = .;
-		*(set_sysctl_*);
-		__stop_set_sysctl_set = ABSOLUTE(.);
-		*(set_domain_*);
-		*(set_pseudo_*);
-		. = ALIGN (16);
-		*crtbegin.o(.ctors)
-		*(.ctors)
-		*crtend.o(.ctors)
-		*crtbegin.o(.dtors)
-		*(.dtors)
-		*crtend.o(.dtors)
-		 * Exception frame info
-		. = ALIGN (16);
-		*(.eh_frame)
-		 * Read-only data
-		. = ALIGN (16);
-		_rodata_start = .;
-		*(.rodata*)
-		*(.gnu.linkonce.r*)
-                 . = ALIGN (16);
-                PROVIDE (_etext = .);
-        } >ram
-	.tdata : {
-		_TLS_Data_begin = .;
-		*(.tdata .tdata.* .gnu.linkonce.td.*)
-		_TLS_Data_end = .;
-	} >ram
-	.tbss : {
-		_TLS_BSS_begin = .;
-		*(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
-		_TLS_BSS_end = .;
-	} >ram
-	_TLS_Data_size = _TLS_Data_end - _TLS_Data_begin;
-	_TLS_Data_begin = _TLS_Data_size != 0 ? _TLS_Data_begin : _TLS_BSS_begin;
-	_TLS_Data_end = _TLS_Data_size != 0 ? _TLS_Data_end : _TLS_BSS_begin;
-	_TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
-	_TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
-	_TLS_Alignment = MAX (ALIGNOF (.tdata), ALIGNOF (.tbss));
-        .data : {
-                PROVIDE (_copy_start = .);
-                *(.data*)
-		*(.gnu.linkonce.d*)
-		*(.gcc_except_table*)
-		*(.jcr)
-                . = ALIGN (16);
-                PROVIDE (_edata = .);
-                PROVIDE (_copy_end = .);
-        } >ram
-        .bss : {
-                _clear_start = .;
-                *(.dynbss)
-                *(.bss* .gnu.linkonce.b.*)
-                *(COMMON)
-                . = ALIGN (16);
-                PROVIDE (end = .);
-                . += _StackSize;
-                . = ALIGN (16);
-                _stack_init = .;
-                _clear_end = .;
-                WorkAreaBase = .;
-        } >ram
-  /* Stabs debugging sections.  */
-  .stab 0 : { *(.stab) }
-  .stabstr 0 : { *(.stabstr) }
-  .stab.excl 0 : { *(.stab.excl) }
-  .stab.exclstr 0 : { *(.stab.exclstr) }
-  .stab.index 0 : { *(.stab.index) }
-  .stab.indexstr 0 : { *(.stab.indexstr) }
-  .comment 0 : { *(.comment) }
-  /* DWARF debug sections.
-     Symbols in the DWARF debugging sections are relative to the beginning
-     of the section so we begin them at 0.  */
-  /* DWARF 1 */
-  .debug          0 : { *(.debug) }
-  .line           0 : { *(.line) }
-  /* GNU DWARF 1 extensions */
-  .debug_srcinfo  0 : { *(.debug_srcinfo) }
-  .debug_sfnames  0 : { *(.debug_sfnames) }
-  /* DWARF 1.1 and DWARF 2 */
-  .debug_aranges  0 : { *(.debug_aranges) }
-  .debug_pubnames 0 : { *(.debug_pubnames) }
-  /* DWARF 2 */
-  .debug_info     0 : { *(.debug_info) }
-  .debug_abbrev   0 : { *(.debug_abbrev) }
-  .debug_line     0 : { *(.debug_line) }
-  .debug_frame    0 : { *(.debug_frame) }
-  .debug_str      0 : { *(.debug_str) }
-  .debug_loc      0 : { *(.debug_loc) }
-  .debug_macinfo  0 : { *(.debug_macinfo) }
-  /* SGI/MIPS DWARF 2 extensions */
-  .debug_weaknames 0 : { *(.debug_weaknames) }
-  .debug_funcnames 0 : { *(.debug_funcnames) }
-  .debug_typenames 0 : { *(.debug_typenames) }
-  .debug_varnames  0 : { *(.debug_varnames) }
-  /* These must appear regardless of  .  */
diff --git a/c/src/lib/libbsp/m68k/mvme136/timer/timer.c b/c/src/lib/libbsp/m68k/mvme136/timer/timer.c
index a9bf322..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/timer/timer.c
+++ /dev/null
@@ -1,85 +0,0 @@
-#include <rtems/btimer.h>
-#include <bsp.h>
-#define TIMER 0xfffb0000   /* address of Z8036 on MVME136 */
-int Ttimer_val;
-bool benchmark_timer_find_average_overhead;
-rtems_isr timerisr(rtems_vector_number);
-void benchmark_timer_initialize(void)
-  (void) set_vector( timerisr, 66, 0 );       /* install ISR */
-  Ttimer_val = 0;                             /* clear timer ISR count */
-  Z8x36_WRITE( TIMER, MASTER_INTR, 0x01 ); /* reset */
-  Z8x36_WRITE( TIMER, MASTER_INTR, 0x00 ); /* clear reset */
-  Z8x36_WRITE( TIMER, MASTER_INTR, 0xe2 ); /* disable lower chain, no vec */
-  Z8x36_WRITE( TIMER, CT1_MODE_SPEC,  0x80 ); /* T1 continuous, and   */
-                                              /* cycle/pulse output   */
-  *((uint16_t*)0xfffb0016) = 0x0000; /* write countdown value */
-  Z8x36_WRITE( TIMER, CT1_TIME_CONST_MSB, 0x00 );
-  Z8x36_WRITE( TIMER, CT1_TIME_CONST_LSB, 0x00 );
-  Z8x36_WRITE( TIMER, MASTER_CFG,         0xc4 ); /* enable timer1        */
-  Z8x36_WRITE( TIMER, CT1_CMD_STATUS,     0xc6 ); /* set INTR enable (IE), */
-                                                 /*  trigger command      */
-                                                 /*  (TCB) and gate       */
-                                                 /* command (GCB) bits    */
-  *((uint8_t*)0xfffb0038) &= 0xfd;      /* enable timer INTR on  */
-                                                 /*    VME controller     */
-#define AVG_OVERHEAD      6  /* It typically takes 3.0 microseconds */
-                             /* (6 countdowns) to start/stop the timer. */
-#define LEAST_VALID       10 /* Don't trust a value lower than this */
-benchmark_timer_t benchmark_timer_read(void)
-  uint8_t          msb, lsb;
-  uint32_t         remaining, total;
-  Z8x36_WRITE( TIMER, CT1_CMD_STATUS,  0xce ); /* read the counter value */
-remaining = 0xffff - *((uint16_t*) 0xfffb0010);
-  Z8x36_READ(  TIMER, CT1_CUR_CNT_MSB, msb );
-  Z8x36_READ(  TIMER, CT1_CUR_CNT_LSB, lsb );
-  remaining = 0xffff - ((msb << 8) + lsb);
-  total = (Ttimer_val * 0x10000) + remaining;
-  if ( benchmark_timer_find_average_overhead == true )
-    return total;          /* in one-half microsecond units */
-  else {
-    if ( total < LEAST_VALID )
-      return 0;            /* below timer resolution */
-    return (total-AVG_OVERHEAD) >> 1;
-void benchmark_timer_disable_subtracting_average_overhead(
-  bool find_flag
-  benchmark_timer_find_average_overhead = find_flag;
diff --git a/c/src/lib/libbsp/m68k/mvme136/timer/timerisr.S b/c/src/lib/libbsp/m68k/mvme136/timer/timerisr.S
index dda8770..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/timer/timerisr.S
+++ /dev/null
@@ -1,36 +0,0 @@
-/*  timer_isr()
- *  This routine provides the ISR for the Z8036 timer on the MVME136
- *  board.   The timer is set up to generate an interrupt at maximum
- *  intervals.
-#include <rtems/asm.h>
-BEGIN_CODE
-.set CT1_CMD_STATUS,  0xfffb000a         | port A
-.set RELOAD,          0x24               | clr IP & IUS,allow countdown
-        PUBLIC (timerisr)
-SYM (timerisr):
-        movl    a0,a7 at -                  | save a0
-        movl    #CT1_CMD_STATUS,a0       | a0 = addr of cmd status reg
-        movb    #RELOAD,a0@              | reload countdown
-        addql   #1, SYM (Ttimer_val)     | increment timer value
-        movl    a7 at +,a0                  | save a0
-        rte
-END_CODE
-END
diff --git a/c/src/lib/libbsp/m68k/mvme136/times b/c/src/lib/libbsp/m68k/mvme136/times
index 527a3d2..0000000
--- a/c/src/lib/libbsp/m68k/mvme136/times
+++ /dev/null
@@ -1,189 +0,0 @@
-#  Timing Test Suite Results for the Motorola MVME136 BSP
-Board:                Motorola MVME136
-CPU:                  Motorola MC68020 + MC68881 FPU
-Clock Speed:          20 Mhz
-Memory Configuration: DRAM w/no cache
-Wait States:          1 wait state
-Times Reported in:    microseconds
-Timer Source:         Zilog Z8036
-Column A:             3.5.1 pre-release
-Column B:             3.5.17 pre-release
-#                          DESCRIPTION                                 A    B
- 1 rtems_semaphore_create                                               67   60
-   rtems_semaphore_delete                                               64   58
-   rtems_semaphore_obtain: available                                    46   38
-   rtems_semaphore_obtain: not available -- NO_WAIT                     45   38
-   rtems_semaphore_release: no waiting tasks                            51   44
- 2 rtems_semaphore_obtain: not available -- caller blocks              113  109
- 3 rtems_semaphore_release: task readied -- preempts caller             94   87
- 4 rtems_task_restart: blocked task -- preempts caller                 152  149
-   rtems_task_restart: ready task -- preempts caller                   145  142
-   rtems_semaphore_release: task readied -- returns to caller           71   66
-   rtems_task_create                                                   154  148
-   rtems_task_start                                                     82   76
-   rtems_task_restart: suspended task -- returns to caller              94   89
-   rtems_task_delete: suspended task                                   145  138
-   rtems_task_restart: ready task -- returns to caller                  97   92
-   rtems_task_restart: blocked task -- returns to caller               128  124
-   rtems_task_delete: blocked task                                     149  143
- 5 rtems_task_suspend: calling task                                     77   71
-   rtems_task_resume: task readied -- preempts caller                   74   67
- 6 rtems_task_restart: calling task                                    101   95
-   rtems_task_suspend: returns to caller                                50   43
-   rtems_task_resume: task readied -- returns to caller                 50   45
-   rtems_task_delete: ready task                                       151  144
- 7 rtems_task_restart: suspended task -- preempts caller               130  125
- 8 rtems_task_set_priority: obtain current priority                     38   31
-   rtems_task_set_priority: returns to caller                           71   64
-   rtems_task_mode: obtain current mode                                 16   14
-   rtems_task_mode: no reschedule                                       18   16
-   rtems_task_mode: reschedule -- returns to caller                     24   23
-   rtems_task_mode: reschedule -- preempts caller                       68   60
-   rtems_task_set_note                                                  39   33
-   rtems_task_get_note                                                  40   33
-   rtems_clock_set                                                      93   86
-   rtems_clock_get                                                       1    1
- 9 rtems_message_queue_create                                          207  200
-   rtems_message_queue_send: no waiting tasks                          103   97
-   rtems_message_queue_urgent: no waiting tasks                        103   96
-   rtems_message_queue_receive: available                               87   79
-   rtems_message_queue_flush: no messages flushed                       36   29
-   rtems_message_queue_flush: messages flushed                          46   39
-   rtems_message_queue_delete                                           85   80
-10 rtems_message_queue_receive: not available -- NO_WAIT                51   43
-   rtems_message_queue_receive: not available -- caller blocks         115  114
-11 rtems_message_queue_send: task readied -- preempts caller           129  123
-12 rtems_message_queue_send: task readied -- returns to caller         107  101
-13 rtems_message_queue_urgent: task readied -- preempts caller         130  123
-14 rtems_message_queue_urgent: task readied -- returns to caller       107  101
-15 rtems_event_receive: obtain current events                            0    1
-   rtems_event_receive: not available -- NO_WAIT                        33   23
-   rtems_event_receive: not available -- caller blocks                  92   84
-   rtems_event_send: no task readied                                    34   24
-   rtems_event_receive: available                                       36   28
-   rtems_event_send: task readied -- returns to caller                  67   60
-16 rtems_event_send: task readied -- preempts caller                    90   84
-17 rtems_task_set_priority: preempts caller                            110  106
-18 rtems_task_delete: calling task                                     175  170
-19 rtems_signal_catch                                                   23   15
-   rtems_signal_send: returns to caller                                 43   37
-   rtems_signal_send: signal to self                                    52   55
-   exit ASR overhead: returns to calling task                           37   37
-   exit ASR overhead: returns to preempting task                        65   54
-20 rtems_partition_create                                               77   70
-   rtems_region_create                                                  70   63
-   rtems_partition_get_buffer: available                                42   35
-   rtems_partition_get_buffer: not available                            40   33
-   rtems_partition_return_buffer                                        50   43
-   rtems_partition_delete                                               47   42
-   rtems_region_get_segment: available                                  58   52
-   rtems_region_get_segment: not available -- NO_WAIT                   55   49
-   rtems_region_return_segment: no waiting tasks                        60   54
-   rtems_region_get_segment: not available -- caller blocks            126  123
-   rtems_region_return_segment: task readied -- preempts caller        143  136
-   rtems_region_return_segment: task readied -- returns to caller      120  114
-   rtems_region_delete                                                  45   39
-   rtems_io_initialize                                                   6    4
-   rtems_io_open                                                         2    2
-   rtems_io_close                                                        1    1
-   rtems_io_read                                                         1    2
-   rtems_io_write                                                        1    3
-   rtems_io_control                                                      2    2
-21 rtems_task_ident                                                    353  350
-   rtems_message_queue_ident                                           344  341
-   rtems_semaphore_ident                                               369  367
-   rtems_partition_ident                                               344  341
-   rtems_region_ident                                                  350  348
-   rtems_port_ident                                                    343  340
-   rtems_timer_ident                                                   345  343
-   rtems_rate_monotonic_ident                                          344  341
-22 rtems_message_queue_broadcast: task readied -- returns to caller    115  111
-   rtems_message_queue_broadcast: no waiting tasks                      60   53
-   rtems_message_queue_broadcast: task readied -- preempts caller      138  133
-23 rtems_timer_create                                                   37   28
-   rtems_timer_fire_after: inactive                                     66   58
-   rtems_timer_fire_after: active                                       70   61
-   rtems_timer_cancel: active                                           42   34
-   rtems_timer_cancel: inactive                                         39   31
-   rtems_timer_reset: inactive                                          60   54
-   rtems_timer_reset: active                                            65   58
-   rtems_timer_fire_when: inactive                                      96   88
-   rtems_timer_fire_when: active                                        96   88
-   rtems_timer_delete: active                                           55   47
-   rtems_timer_delete: inactive                                         51   47
-   rtems_task_wake_when                                                125  117
-24 rtems_task_wake_after: yield -- returns to caller                    26   16
-   rtems_task_wake_after: yields -- preempts caller                     65   56
-25 rtems_clock_tick                                                     14   17
-26 _ISR_Disable                                                          0    0
-   _ISR_Flash                                                            0    0
-   _ISR_Enable                                                           0    0
-   _Thread_Disable_dispatch                                              0    0
-   _Thread_Enable_dispatch                                              19   11
-   _Thread_Set_state                                                    24   24
-   _Thread_Disptach (NO FP)                                             50   43
-   context switch: no floating point contexts                           41   35
-   context switch: self                                                  9    9
-   context switch: to another task                                       9   10
-   context switch: restore 1st FP task                                  46   39
-   fp context switch: save idle, restore idle                           75   68
-   fp context switch: save idle, restore initialized                    66   66
-   fp context switch: save initialized, restore initialized             65   66
-   _Thread_Resume                                                       18   19
-   _Thread_Unblock                                                      18   19
-   _Thread_Ready                                                        22   21
-   _Thread_Get                                                          12   14
-   _Semaphore_Get                                                       10   10
-   _Thread_Get: invalid id                                               2    2
-27 interrupt entry overhead: returns to interrupted task                 9    9
-   interrupt exit overhead: returns to interrupted task                  8    8
-   interrupt entry overhead: returns to nested interrupt                14   12
-   interrupt exit overhead: returns to nested interrupt                  0    0
-   interrupt entry overhead: returns to preempting task                  8    9
-   interrupt exit overhead: returns to preempting task                  62   54
-28 rtems_port_create                                                    44   35
-   rtems_port_external_to_internal                                      35   27
-   rtems_port_internal_to_external                                      34   26
-   rtems_port_delete                                                    46   39
-29 rtems_rate_monotonic_create                                          40   32
-   rtems_rate_monotonic_period: initiate period -- returns to caller    60   54
-   rtems_rate_monotonic_period: obtain status                           38   31
-   rtems_rate_monotonic_cancel                                          46   39
-   rtems_rate_monotonic_delete: inactive                                54   48
-   rtems_rate_monotonic_delete: active                                  57   51
-   rtems_rate_monotonic_period: conclude periods -- caller blocks       83   74
2.1.4
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
