[PATCH] rtems/bit_all_bsps: Remove ep1a reference
Aun-Ali Zaidi admin at kodeit.net
Wed Dec 9 04:02:05 UTC 2015
closes #2457.
 rtems/bit_all_bsps | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/rtems/bit_all_bsps b/rtems/bit_all_bsps
index d0bbb1a..5a6e024 100755
--- a/rtems/bit_all_bsps
+++ b/rtems/bit_all_bsps
@@ -146,7 +146,7 @@ get_bsps()
                all_bsps="${all_bsps} rbtx4925 rbtx4938" ;;
       nios2)   all_bsps="nios2_iss" ;;
       powerpc) all_bsps="psim mcp750 mvme2100 mvme2307 mvme3100"
-               all_bsps="${all_bsps} mpc8260ads ss555 mvme5500 ep1a"
+               all_bsps="${all_bsps} mpc8260ads ss555 mvme5500"
                all_bsps="${all_bsps} pm520_cr825 pm520_ze30"
                all_bsps="${all_bsps} mbx821_001 mbx821_002 mbx821_002b"
                all_bsps="${all_bsps} mbx860_1b mbx860_001b mbx860_002"
2.1.4
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
