[PATCH 1/2] bsps/sparc: Use default bsp_pretasking_hook()
Sebastian Huber
Wed Dec 9 08:15:29 UTC 2015
Move content to bsp_predriver_hook() functions of the BSPs.
Update #2408.
c/src/lib/libbsp/sparc/erc32/Makefile.am | 2 +-
.../lib/libbsp/sparc/erc32/startup/bsppredriver.c | 2 ++
c/src/lib/libbsp/sparc/leon2/Makefile.am | 2 +-
.../lib/libbsp/sparc/leon2/startup/bsppredriver.c | 2 ++
c/src/lib/libbsp/sparc/leon3/Makefile.am | 2 +-
.../lib/libbsp/sparc/leon3/startup/bsppredriver.c | 2 ++
c/src/lib/libbsp/sparc/shared/bsppretaskinghook.c | 26 ----------------------
7 files changed, 9 insertions(+), 29 deletions(-)
delete mode 100644 c/src/lib/libbsp/sparc/shared/bsppretaskinghook.c
diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am b/c/src/lib/libbsp/sparc/erc32/Makefile.am
index 8dcdd32..b00853a 100644
--- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
+++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
@@ -32,7 +32,7 @@ libbsp_a_SOURCES += ../../shared/bspclean.c
libbsp_a_SOURCES += ../../shared/bsplibc.c
libbsp_a_SOURCES += startup/bsppredriver.c
libbsp_a_SOURCES += ../../sparc/shared/startup/bspgetworkarea.c
-libbsp_a_SOURCES += ../../sparc/shared/bsppretaskinghook.c
+libbsp_a_SOURCES += ../../shared/bsppretaskinghook.c
libbsp_a_SOURCES += ../../shared/bsppost.c
libbsp_a_SOURCES += ../../shared/bspstart.c
libbsp_a_SOURCES += ../../shared/bootcard.c
diff --git a/c/src/lib/libbsp/sparc/erc32/startup/bsppredriver.c b/c/src/lib/libbsp/sparc/erc32/startup/bsppredriver.c
index 9cf73d9..6c6ea1e 100644
--- a/c/src/lib/libbsp/sparc/erc32/startup/bsppredriver.c
+++ b/c/src/lib/libbsp/sparc/erc32/startup/bsppredriver.c
@@ -21,6 +21,8 @@
void bsp_predriver_hook( void )
+ bsp_spurious_initialize();
/* Initialize shared interrupt handling, must be done after IRQ
* controller has been found and initialized.
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index 66c491d..7eada59 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -34,7 +34,7 @@ libbsp_a_SOURCES += ../../shared/bsplibc.c
libbsp_a_SOURCES += startup/bspstart.c
libbsp_a_SOURCES += ../../shared/sbrk.c
diff --git a/c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c b/c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c
index ad3694d..2cdf4da 100644
--- a/c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c
+++ b/c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c
@@ -85,6 +85,8 @@ void bsp_driver_level_hook( int level )
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index 72a074b..d261f99 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -35,7 +35,7 @@ libbsp_a_SOURCES =
libbsp_a_SOURCES += startup/bspclean.c
libbsp_a_SOURCES += ../../shared/bsplibc.c \
../../shared/bsppost.c ../../shared/bootcard.c startup/bspstart.c \
- ../../sparc/shared/bsppretaskinghook.c startup/bsppredriver.c \
+ ../../shared/bsppretaskinghook.c startup/bsppredriver.c \
../../sparc/shared/startup/bspgetworkarea.c ../../shared/sbrk.c \
startup/setvec.c \
startup/spurious.c startup/bspidle.S startup/bspdelay.c \
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bsppredriver.c b/c/src/lib/libbsp/sparc/leon3/startup/bsppredriver.c
index bdc1ab8..498c97b 100644
--- a/c/src/lib/libbsp/sparc/leon3/startup/bsppredriver.c
+++ b/c/src/lib/libbsp/sparc/leon3/startup/bsppredriver.c
@@ -32,6 +32,8 @@ static void leon3_interrupt_common_init( void )
#ifndef RTEMS_DRVMGR_STARTUP
leon3_interrupt_common_init();
#endif
diff --git a/c/src/lib/libbsp/sparc/shared/bsppretaskinghook.c b/c/src/lib/libbsp/sparc/shared/bsppretaskinghook.c
deleted file mode 100644
index 4c079c3..0000000
--- a/c/src/lib/libbsp/sparc/shared/bsppretaskinghook.c
+++ /dev/null
@@ -1,26 +0,0 @@
- * This set of routines are the BSP specific initialization
- * support routines.
- * COPYRIGHT (c) 1989-2009.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
- * Ported to ERC32 implementation of the SPARC by On-Line Applications
- * Research Corporation (OAR) under contract to the European Space
- * Agency (ESA).
- * ERC32 modifications of respective RTEMS file: COPYRIGHT (c) 1995.
- * European Space Agency.
-#include <bsp.h>
-#include <bsp/bootcard.h>
-void bsp_pretasking_hook(void)
- bsp_spurious_initialize();
1.8.4.5
