Some PowerPC fail to link some bootloader image
Sebastian Huber
Wed Dec 9 14:47:03 UTC 2015
Hello,
I have a problem with some older PowerPC BSPs:
powerpc-rtems4.12/c/mvme2307/testsuites/samples/hello (master) > make
clean all
test -z "*.num *.nxe *.elf *.srec* *.bin *.bt *.ralf" || rm -f *.num
test -z "hello.exe" || rm -f hello.exe
rm -f *.o
powerpc-rtems4.12-gcc -B../../../../../mvme2307/lib/ -specs bsp_specs
-qrtems -DHAVE_CONFIG_H -I.
-I/home/EB/sebastian_h/rtems-4.12/c/src/../../testsuites/samples/hello
-I.. -mcpu=604 -mmultiple -mstring -mstrict-align -meabi -O2 -g
-Wall -Wmissing-prototypes -Wimplicit-function-declaration
-Wstrict-prototypes -Wnested-externs -MT init.o -MD -MP -MF
.deps/init.Tpo -c -o init.o
/home/EB/sebastian_h/rtems-4.12/c/src/../../testsuites/samples/hello/init.c
mv -f .deps/init.Tpo .deps/init.Po
-qrtems -mcpu=604 -mmultiple -mstring -mstrict-align -meabi -O2 -g -Wall
-Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
-Wnested-externs -mcpu=604 -mmultiple -mstring -mstrict-align
-meabi -o hello.exe init.o
powerpc-rtems4.12-nm -g -n hello.exe > hello.num
powerpc-rtems4.12-size hello.exe
text data bss dec hex filename
196229 10708 49013 255950 3e7ce hello.exe
powerpc-rtems4.12-objcopy -O binary -R .comment -S hello.exe rtems
gzip -vf9 rtems
rtems: 54.2% -- replaced with rtems.gz
powerpc-rtems4.12-ld -o hello.ralf
../../../../../mvme2307/lib/bootloader.o --just-symbols=hello.exe -b
binary rtems.gz -T ../../../../../mvme2307/lib/ppcboot.lds -Map
hello.map && chmod 755 hello.exe
../../../../../mvme2307/lib/bootloader.o:/home/EB/sebastian_h/rtems-4.12/c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/em86real.S:3486:
undefined reference to `.LCL2'
../../../../../mvme2307/lib/bootloader.o:/home/EB/sebastian_h/rtems-4.12/c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/em86real.S:3529:
make: *** [hello.exe] Error 1
Is this a known issue?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
