Some PowerPC fail to link some bootloader image
Wed Dec 9 14:55:59 UTC 2015
On Wed, Dec 9, 2015 at 8:47 AM, Sebastian Huber <
> Hello,
> I have a problem with some older PowerPC BSPs:
> powerpc-rtems4.12/c/mvme2307/testsuites/samples/hello (master) > make
> clean all
> test -z "*.num *.nxe *.elf *.srec* *.bin *.bt *.ralf" || rm -f *.num *.nxe
> test -z "hello.exe" || rm -f hello.exe
> rm -f *.o
> powerpc-rtems4.12-gcc -B../../../../../mvme2307/lib/ -specs bsp_specs
> -qrtems -DHAVE_CONFIG_H -I.
> -I/home/EB/sebastian_h/rtems-4.12/c/src/../../testsuites/samples/hello
> -I..     -mcpu=604 -mmultiple -mstring -mstrict-align -meabi -O2 -g -Wall
> -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
> -Wnested-externs -MT init.o -MD -MP -MF .deps/init.Tpo -c -o init.o
> /home/EB/sebastian_h/rtems-4.12/c/src/../../testsuites/samples/hello/init.c
> mv -f .deps/init.Tpo .deps/init.Po
> -qrtems -mcpu=604 -mmultiple -mstring -mstrict-align -meabi -O2 -g -Wall
> -Wnested-externs    -mcpu=604 -mmultiple -mstring -mstrict-align -meabi
> -o hello.exe init.o
> powerpc-rtems4.12-nm -g -n hello.exe > hello.num
> powerpc-rtems4.12-size hello.exe
>    text    data     bss     dec     hex filename
>  196229   10708   49013  255950   3e7ce hello.exe
> powerpc-rtems4.12-objcopy -O binary -R .comment -S hello.exe rtems
> gzip -vf9 rtems
> rtems:   54.2% -- replaced with rtems.gz
> powerpc-rtems4.12-ld -o hello.ralf
> ../../../../../mvme2307/lib/bootloader.o --just-symbols=hello.exe -b binary
> rtems.gz -T ../../../../../mvme2307/lib/ppcboot.lds -Map hello.map && chmod
> 755 hello.exe
> ../../../../../mvme2307/lib/bootloader.o:/home/EB/sebastian_h/rtems-4.12/c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/em86real.S:3486:
> undefined reference to `.LCL2'
> ../../../../../mvme2307/lib/bootloader.o:/home/EB/sebastian_h/rtems-4.12/c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/em86real.S:3529:
> make: *** [hello.exe] Error 1
> Is this a known issue?
I think it looks familiar but as an old issue which was previously resolved.
It is definitely a binutils problem with local symbols so should be posted
over there.
My recollection was that this was an issue with locally generated symbols.
It may be possible to just turn it into a real named symbol but that doesn't
mean it won't turn up somewhere else.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151209/ae3f17b4/attachment-0002.html>
