[PATCH] h8300: Regenerate h8300 architecture
Aun-Ali Zaidi
admin at kodeit.net
Mon Dec 14 03:48:00 UTC 2015
closes #2453.
c/src/lib/libbsp/h8300/acinclude.m4 | 2 --
c/src/lib/libbsp/h8300/configure.ac | 2 +-
2 files changed, 1 insertion(+), 3 deletions(-)
diff --git a/c/src/lib/libbsp/h8300/acinclude.m4 b/c/src/lib/libbsp/h8300/acinclude.m4
index 15e13d7..296a6f7 100644
--- a/c/src/lib/libbsp/h8300/acinclude.m4
+++ b/c/src/lib/libbsp/h8300/acinclude.m4
@@ -2,8 +2,6 @@
AC_DEFUN([RTEMS_CHECK_BSPDIR],
case "$1" in
- h8sim )
- AC_CONFIG_SUBDIRS([h8sim]);;
AC_MSG_ERROR([Invalid BSP]);;
esac
diff --git a/c/src/lib/libbsp/h8300/configure.ac b/c/src/lib/libbsp/h8300/configure.ac
index 9271783..e885460 100644
--- a/c/src/lib/libbsp/h8300/configure.ac
+++ b/c/src/lib/libbsp/h8300/configure.ac
@@ -2,7 +2,7 @@
AC_PREREQ([2.69])
AC_INIT([rtems-c-src-lib-libbsp-h8300],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
-AC_CONFIG_SRCDIR([h8sim])
+AC_CONFIG_SRCDIR([Makefile.am])
RTEMS_TOP(../../../../..)
RTEMS_CANONICAL_TARGET_CPU
2.1.4
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
