[PATCH] mips/genmongoosev: Remove
Aun-Ali Zaidi admin at kodeit.net
Mon Dec 14 05:41:15 UTC 2015
updates #2448.
 c/src/lib/libbsp/mips/acinclude.m4                 |   2 -
 c/src/lib/libbsp/mips/genmongoosev/Makefile.am     |  85 --
 c/src/lib/libbsp/mips/genmongoosev/README          | 225 -----
 c/src/lib/libbsp/mips/genmongoosev/bsp_specs       |  15 -
 .../lib/libbsp/mips/genmongoosev/clock/clockdrv.c  |  59 --
 c/src/lib/libbsp/mips/genmongoosev/configure.ac    |  21 -
 .../libbsp/mips/genmongoosev/console/README.mguart | 101 ---
 .../lib/libbsp/mips/genmongoosev/console/conscfg.c |  93 ---
 .../lib/libbsp/mips/genmongoosev/console/mg5uart.c | 881 --------------------
 .../lib/libbsp/mips/genmongoosev/console/mg5uart.h |  97 ---
 .../libbsp/mips/genmongoosev/console/mg5uart_reg.c |  58 --
 c/src/lib/libbsp/mips/genmongoosev/include/bsp.h   |  73 --
 c/src/lib/libbsp/mips/genmongoosev/include/irq.h   |  95 ---
 .../lib/libbsp/mips/genmongoosev/include/lr33000.h |  99 ---
 .../lib/libbsp/mips/genmongoosev/include/lr333x0.h | 180 ----
 .../libbsp/mips/genmongoosev/include/mongoose-v.h  | 306 -------
 c/src/lib/libbsp/mips/genmongoosev/include/r3000.h | 229 ------
 c/src/lib/libbsp/mips/genmongoosev/include/tm27.h  |  36 -
 .../lib/libbsp/mips/genmongoosev/irq/vectorisrs.c  | 257 ------
 .../mips/genmongoosev/make/custom/genmongoosev.cfg |  16 -
 c/src/lib/libbsp/mips/genmongoosev/preinstall.am   | 103 ---
 c/src/lib/libbsp/mips/genmongoosev/start/mg5.h     | 379 ---------
 c/src/lib/libbsp/mips/genmongoosev/start/regs.h    | 148 ----
 c/src/lib/libbsp/mips/genmongoosev/start/start.S   | 909 ---------------------
 .../libbsp/mips/genmongoosev/startup/bspstart.c    |  97 ---
 .../libbsp/mips/genmongoosev/startup/gdb-support.c | 145 ----
 .../lib/libbsp/mips/genmongoosev/startup/linkcmds  | 228 ------
 c/src/lib/libbsp/mips/genmongoosev/timer/timer.c   |  93 ---
 28 files changed, 5030 deletions(-)
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/Makefile.am
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/README
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/bsp_specs
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/clock/clockdrv.c
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/configure.ac
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/console/README.mguart
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/console/conscfg.c
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.h
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart_reg.c
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/include/bsp.h
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/include/irq.h
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/include/lr33000.h
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/include/lr333x0.h
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/include/mongoose-v.h
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/include/r3000.h
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/include/tm27.h
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/irq/vectorisrs.c
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/make/custom/genmongoosev.cfg
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/preinstall.am
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/start/mg5.h
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/start/regs.h
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/start/start.S
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/startup/linkcmds
 delete mode 100644 c/src/lib/libbsp/mips/genmongoosev/timer/timer.c
diff --git a/c/src/lib/libbsp/mips/acinclude.m4 b/c/src/lib/libbsp/mips/acinclude.m4
index 6a7814f..cde1ebe 100644
--- a/c/src/lib/libbsp/mips/acinclude.m4
+++ b/c/src/lib/libbsp/mips/acinclude.m4
@@ -4,8 +4,6 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
   case "$1" in
   csb350 )
     AC_CONFIG_SUBDIRS([csb350]);;
-  genmongoosev )
-    AC_CONFIG_SUBDIRS([genmongoosev]);;
   hurricane )
     AC_CONFIG_SUBDIRS([hurricane]);;
   jmr3904 )
diff --git a/c/src/lib/libbsp/mips/genmongoosev/Makefile.am b/c/src/lib/libbsp/mips/genmongoosev/Makefile.am
deleted file mode 100644
index 44fb24b..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/Makefile.am
+++ /dev/null
@@ -1,85 +0,0 @@
-ACLOCAL_AMFLAGS = -I ../../../../aclocal
-include $(top_srcdir)/../../../../automake/compile.am
-include_bspdir = $(includedir)/bsp
-dist_project_lib_DATA = bsp_specs
-include_HEADERS = include/bsp.h
-include_HEADERS += include/tm27.h
-include_bsp_HEADERS = start/regs.h
-#isr
-include_bsp_HEADERS += ../../shared/include/irq-generic.h
-include_bsp_HEADERS += ../../shared/include/irq-info.h
-include_bsp_HEADERS += include/irq.h
-nodist_include_HEADERS = include/bspopts.h
-nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
-nodist_include_bsp_HEADERS += include/lr33000.h
-nodist_include_bsp_HEADERS += include/lr333x0.h
-nodist_include_bsp_HEADERS += include/mongoose-v.h
-nodist_include_bsp_HEADERS += include/r3000.h
-nodist_include_bsp_HEADERS += console/mg5uart.h
-DISTCLEANFILES = include/bspopts.h
-noinst_PROGRAMS =
-nodist_include_HEADERS += ../../shared/include/coverhd.h
-noinst_LIBRARIES = libbspstart.a
-libbspstart_a_SOURCES  = start/start.S
-libbspstart_a_SOURCES += start/regs.h
-libbspstart_a_SOURCES += start/mg5.h
-project_lib_DATA = start.$(OBJEXT)
-dist_project_lib_DATA += startup/linkcmds
-noinst_LIBRARIES += libbsp.a
-libbsp_a_SOURCES =
-# startup
-libbsp_a_SOURCES += ../../shared/bspclean.c
-libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
-libbsp_a_SOURCES += ../../shared/bsplibc.c
-libbsp_a_SOURCES += ../../shared/bsppost.c
-libbsp_a_SOURCES += startup/bspstart.c
-libbsp_a_SOURCES += ../../shared/bootcard.c
-libbsp_a_SOURCES += ../../shared/sbrk.c
-libbsp_a_SOURCES += ../../shared/bspgetworkarea.c
-# clock
-libbsp_a_SOURCES += clock/clockdrv.c
-libbsp_a_SOURCES += ../../shared/clockdrv_shell.h
-# console
-libbsp_a_SOURCES += console/conscfg.c
-libbsp_a_SOURCES += console/mg5uart.c
-libbsp_a_SOURCES += ../../shared/console.c
-libbsp_a_SOURCES += ../../shared/console_select.c
-libbsp_a_SOURCES += ../../shared/console_control.c
-libbsp_a_SOURCES += ../../shared/console_read.c
-libbsp_a_SOURCES += ../../shared/console_write.c
-# timer
-libbsp_a_SOURCES += timer/timer.c
-#isr
-libbsp_a_SOURCES += ../../shared/src/irq-generic.c
-libbsp_a_SOURCES += ../../shared/src/irq-legacy.c
-libbsp_a_SOURCES += ../../shared/src/irq-info.c
-libbsp_a_SOURCES += ../../shared/src/irq-shell.c
-libbsp_a_SOURCES += ../../shared/src/irq-server.c
-libbsp_a_SOURCES += ../shared/irq/vectorexceptions.c
-libbsp_a_SOURCES += ../shared/irq/irq.c
-libbsp_a_SOURCES += irq/vectorisrs.c
-libbsp_a_SOURCES += ../shared/irq/interruptmask.c
-gdbstub_CPPFLAGS = -I$(srcdir)/../../mips/shared/gdbstub
-noinst_PROGRAMS += gdbstub.rel
-gdbstub_rel_SOURCES  = ../../mips/shared/gdbstub/mips-stub.c
-gdbstub_rel_SOURCES += startup/gdb-support.c
-gdbstub_rel_SOURCES += ../../shared/gdbstub/rtems-stub-glue.c
-gdbstub_rel_CPPFLAGS = $(AM_CPPFLAGS) $(gdbstub_CPPFLAGS)
-gdbstub_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-libbsp_a_LIBADD  = ../../../libcpu/@RTEMS_CPU@/shared/cache.rel
-libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/shared/interrupts.rel
-include $(srcdir)/preinstall.am
-include $(top_srcdir)/../../../../automake/local.am
diff --git a/c/src/lib/libbsp/mips/genmongoosev/README b/c/src/lib/libbsp/mips/genmongoosev/README
index d8b9bd5..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/README
+++ /dev/null
@@ -1,225 +0,0 @@
-BSP supporting the on-CPU capabilities of the Synova Mongoose-V.
-The Synova Mongoose-V is a radiation hardened derivative of the
-LSI 33K with on-CPU peripherals.
-This BSP assumes that basic HW initialization is performed by PMON.
-Status
-Per-task floating point enable/disable is supported for both immediate
-and deferred FPU context swaps.
-Interrupt Levels are adapted reasonably well to the MIPS interrupt
-model. Bit 0 of the int level is a global enable/disable, corresponding
-to bit 0 of the processor's SR register.  Bits 1 thru 6 are configured
-as masks for the Int0 thru Int5 interrupts.  The 2 software interrupt
-bits are always enabled by default.  Each task maintains its own
-Interrupt Level setting, reconfiguring the SR register's interrupt bits
-whenever scheduled in.  The software ints, though not addressable via
-the various Interrupt Level functions, are maintained on a per-task
-basis, so if software manipulates them directly, things should behave as
-expected.  At the time of these udpates, the Interrupt Level was only 8
-bits, and completely supporting the global enable, software ints and the
-hardware ints would require 9 bits.  When more than 8 bits are
-available, there is no reason the software interrupts could not be added
-to the Interrupt Level.
-While supporting the Int0 thru Int5 bits in this way doesn't seem
-wonderfully useful, it does increase the level of compliance with the
-RTEMS spec.
-Interrupt Level 0 corresponds to interrupts globally enabled, software
-ints enabled and Int0 thru Int5 enabled.  If values other than 0 are
-supplied, they should be formulated to impose the desired bitmask.
-Interrupt priority is not a strong concept on this bsp, it is provided
-only by the order in which interrupts are checked.
-If during the vectoring of an interrupt, others arrive, they will all be
-processed in accordance with their ordering in SR & the peripheral
-register.  For example, if while we're vectoring Int4, Int3 and Int5 are
-asserted, Int3 will be serviced before Int5.  The peripheral interrupts
-are individually vectored as a consequence of Int5 being asserted,
-however Int5 is not itself vectored.  Within the set of peripheral
-interrupts, bit 0 is vectored first, 31 is last.
-Interrupts are not nested for MIPS1 or MIPS3 processors, but are
-processed serially as possible.  On an unloaded 50 task RTEMS program,
-runnning on a 12mhz MIPS1 processor, worst-case latencies of 100us were
-observed, the average being down at 60us or below.
-These features are principally a consequence of fixes and tweaks to the
-MIPS1 and MIPS3 processor support, and should be equally effective on
-both levels of MIPS processors for any of their bsp's.
-Address Map
-This is the generic address map of the Mongoose-V prototyping board
-this BSP was tested on.
-0x8000_0000 - 0x8FFF_FFFF   - RAM (KSEG0 cached)
-0xA000_0000 - 0xAFFF_FFFF   - RAM (KSEG1, same memory uncached)
-0xBFC0_0000 - 0xBFFF_FFFF   - EEPROM
-0xFFFE_xxxx                 - on-CPU peripherals
-This is the hardware address map of the board used as it was
-actually populated.
-0x8000_0000 - 0x83FF_FFFF   - 32 MB RAM (KSEG0 cached)
-0xA000_0000 - 0xA3FF_FFFF   - 32 MB RAM (KSEG1, same memory uncached)
-0xBFC0_0000 - 0xBFDF_FFFF   - 2 MB EEPROM
-This is the organization of the EEPROM when fully populated.  Since
-the board used to develop this BSP only had the first bank of EEPROM
-populated, only the first program image area was used.
-0xBFC0_0000 - 0xBFC3_FFFF   - PMON
-0xBFC4_0000 - 0xBFC4_FFFF   - reserved for boot loader
-0xBFC5_0000 - 0xBFDF_FFFF   - reserved for program 1 image
-0xBFE0_0000 - 0xBFFF_FFFF   - reserved for program 2 image
-The Mongoose-V on this board is at 12 Mhz.
-Downloading
-On the breadboard, a locally hacked PMON waits for a space to be pressed
-while the board is reset/powered up.  If found, the PMON console is
-entered, else PMON jumps to the EEPROM address above, presuming a user
-program is located there.
-The default output of an RTEMS link is an image linked to run from
-0x80020000.  It is suitable for copying to S3 records or can be burned
-to ROMs in whatever manner the user desires.  If you want to locate the
-image into ROM at some other address, use mips-rtems-objcopy to shift
-the LMA.
-Operation
-A small relocator is supplied in the bsp startup code which copies the
-image down to RAM for execution before doing any other initialization.
-This locator code is location independent, and will do nothing if the
-image is already located at its run location.  The LMA and VMA are both
-controlled via the bsp's link script.  The above behavior is produced by
-using the default script.  If this is not desirable, something like the
-following may be added to the user's RTEMS link statement to override
-the default linkcmds with a user-supplied version;
--qnolinkcmds -Wl,-T -Wl,mips-rtems-linkcmds-eprom
-this causes the file ./mips-rtems-linkcmds-eprom to override the default
-linkcmds.
-Before relocating the RTEMS image, the bsp startup routine attempts to
-configure the processor into a rational state.  During this process,
-status characters are emitted at 19200N81 on UART port 0.
-The default link script simply places the image at 0x8002000 with
-LMA=VMA, which is conviently located in RAM on our board.  You should
-probably consider creating your own linkcmds, putting things where you
-want and supply it as above.
-The Mongoose V has a somewhat restricted cache configuration model; you
-can only flush it if the code which does so executes within noncached
-memory, in our case, code in kseg1.  If you do so from elsewhere the
-code will appear to lock up, this is caused by the cache clearing
-routine making the instruction fetch always return 0, or nop- leaving
-the processor in an endless loop.  The default start.S code detects if
-its booting from outside kseg1, it which case it disables the cache
-flush code.  This means you cannot flush the cache with the bsp's
-functions if you boot your program from outside kseg1.  A more subtle
-issue is the bsp keeps a pointer to the location in kseg1 where the
-bsp's cache flush code resides.  This is advantageous because you can
-relocate the system anywhere and still control the cache, but might
-cause trouble if the boot image becomes inaccessible.  If this is
-possible, you should probably consider rolling your own cache control &
-disabling the bsp's.
-As stated above, if you boot from outside kseg1, the bsp disables the
-cache flush routines.  This is not desirable in the long run because the
-Mongoose V remote debugger stub assumes it can flush caches when exiting
-an exception so it might not be able to update code/data properly,
-though it should still nominally function.  However, if you're not using
-the remote debugger & don't care about flushing caches, then everything
-should run just fine.
-Our approach has to been locate ROM in kseg1, link the code for VMA in
-RAM and relocate the LMA up into kseg1 ROM.  Since the start.S code is
-position-independent, it will relocate the entire app down to the VMA
-region before starting things up with everything in its proper place.
-The cache clear code runs before relocation, so executes from ROM &
-things work.
-You can prevent including the default start.S by adding;
--qnostartfile
-to the link command line in addition to the "nolinkcmds" options above.
-Be sure to supply your replacement start.o.
-Questions
-Why can I send characters slowly to a Mongoose V, but get framing errors
-when sending them fast?
-- The MongooseV chip seems to <require> that all incoming data have 2
-  stop bits.  When typing on a serial terminal, this is not an issue
-  because the idle state of an RS232 line looks just like a stop bit-
-  but when streaming in data, such pacing is required.  The manual does
-  not indicate anything along these lines, instead, we suspect a
-  somewhat faulty UART design.
-Debugging
-After getting Joel's initial port of the gdb stub to the Mongoose bsp, I
-worked up & tested this stub on our R3000 board.  It seems to work OK.
-Our MIPS has 2 serial ports, the first being dedicated to the console, I
-chose to arrange the 2nd one for the remote gdb protocol.  While this
-solution is somewhat specific to our board & bsp, I think the technique
-is quite generalizable.
-The following is a code snippet to be included in the user program;
-extern int mg5rdbgOpenGDBuart(int);
-extern void mg5rdbgCloseGDBuart(void);
-void setupgdb(void)
-   printf("Configuring remote GDB stub...\n");
-   /* initialize remote gdb support */
-   if( mg5rdbgOpenGDBuart(-1) != RTEMS_SUCCESSFUL )
-      printf("Remote GDB stub is disabled.\n\n");
-It allows the program to decide if it wants gdb to be ready to pick up
-exceptions or not.  The 2 extern functions are located in the MongooseV
-bsp inside gdb-support.c.  They configure & initialize the 2nd serial
-port & invoke the vector initialization routine located in cpu_asm.
-Note, we call directly down into the MongooseV UART driver- its quite
-unfriendly to TERMIO.  I chose this approach because I wanted to
-minimize dependence on the I/O subsystems because they might be in a
-state just short of collapsing if the program had done something bad to
-cause the exception.
-If user code leaves the 2nd port alone, then things will work out OK.
-Greg Menke
-2/27/2002
diff --git a/c/src/lib/libbsp/mips/genmongoosev/bsp_specs b/c/src/lib/libbsp/mips/genmongoosev/bsp_specs
index ea4891e..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/bsp_specs
+++ /dev/null
@@ -1,15 +0,0 @@
-%rename endfile old_endfile
-%rename startfile old_startfile
-%rename link old_link
-*startfile:
-%{!qrtems: %(old_startfile)} \
-%{!nostdlib: \
-   %{qrtems: %{!qnostartfile: start.o%s -e _start} crti.o%s crtbegin.o%s}}
-*link:
-%(old_link) %{qrtems: -dc -dp -N}
-*endfile:
-%{!qrtems: %(old_endfile)} %{qrtems: crtend.o%s crtn.o%s}
diff --git a/c/src/lib/libbsp/mips/genmongoosev/clock/clockdrv.c b/c/src/lib/libbsp/mips/genmongoosev/clock/clockdrv.c
index 20f730a..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/clock/clockdrv.c
+++ /dev/null
@@ -1,59 +0,0 @@
- *  @file
- *  Instantiate the clock driver shell for the Mongoose-V's on-CPU timer.
- *  COPYRIGHT (c) 1989-2012.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#include <rtems.h>
-#include <bsp/irq.h>
-#include <bsp.h>
-#if defined(USE_TIMER2_FOR_CLOCK)
-#define CLOCK_BASE   MONGOOSEV_TIMER2_BASE
-#define CLOCK_VECTOR MONGOOSEV_IRQ_TIMER2
-#else
-#define CLOCK_BASE   MONGOOSEV_TIMER1_BASE
-#define CLOCK_VECTOR MONGOOSEV_IRQ_TIMER1
-#endif
-/* reset Timeout (TO) bit */
-#define Clock_driver_support_at_tick() \
-  do { \
-    MONGOOSEV_WRITE_REGISTER( CLOCK_BASE, MONGOOSEV_TIMER_CONTROL_REGISTER, \
-         (MONGOOSEV_TIMER_CONTROL_COUNTER_ENABLE | MONGOOSEV_TIMER_CONTROL_INTERRUPT_ENABLE)); \
-  } while(0)
-#define Clock_driver_support_install_isr( _new, _old ) \
-  do { \
-    rtems_interrupt_handler_install( \
-      CLOCK_VECTOR, \
-      "clock", \
-      0, \
-      _new, \
-      NULL \
-  } while(0)
-#define Clock_driver_support_initialize_hardware() \
-   do { \
-    uint32_t   _clicks = CPU_CLOCK_RATE_MHZ * rtems_configuration_get_microseconds_per_tick(); \
-    MONGOOSEV_WRITE_REGISTER( CLOCK_BASE, MONGOOSEV_TIMER_INITIAL_COUNTER_REGISTER, _clicks ); \
-    Clock_driver_support_at_tick(); \
-   } while(0)
-#define Clock_driver_support_shutdown_hardware() \
-  MONGOOSEV_WRITE_REGISTER( CLOCK_BASE, MONGOOSEV_TIMER_CONTROL_REGISTER, 0 )
-#define CLOCK_DRIVER_USE_DUMMY_TIMECOUNTER
-#include "../../../shared/clockdrv_shell.h"
diff --git a/c/src/lib/libbsp/mips/genmongoosev/configure.ac b/c/src/lib/libbsp/mips/genmongoosev/configure.ac
index d8aa776..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/configure.ac
+++ /dev/null
@@ -1,21 +0,0 @@
-## Process this file with autoconf to produce a configure script.
-AC_PREREQ([2.69])
-AC_INIT([rtems-c-src-lib-libbsp-mips-genmongoosev],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
-AC_CONFIG_SRCDIR([bsp_specs])
-RTEMS_TOP(../../../../../..)
-RTEMS_CANONICAL_TARGET_CPU
-AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
-RTEMS_BSP_CONFIGURE
-RTEMS_PROG_CC_FOR_TARGET
-RTEMS_CANONICALIZE_TOOLS
-RTEMS_PROG_CCAS
-RTEMS_BSP_CLEANUP_OPTIONS(0, 0)
-# Explicitly list all Makefiles here
-AC_CONFIG_FILES([Makefile])
-AC_OUTPUT
diff --git a/c/src/lib/libbsp/mips/genmongoosev/console/README.mguart b/c/src/lib/libbsp/mips/genmongoosev/console/README.mguart
index 8073ab7..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/console/README.mguart
+++ /dev/null
@@ -1,101 +0,0 @@
-Configuration Table Use
-sDeviceName
-   The name of this device.
-deviceType
-   This field must be SERIAL_MG5UART.
-pDeviceFns
-   The device interface control table.  This may be:
-      + mg5uart_fns for interrupt driven IO
-      + mg5uart_fns_polled for polled IO
-deviceProbe
-   This is the address of the routine which probes to see if the device
-   is present.
-pDeviceFlow
-   This field is ignored as hardware flow control is not currently supported.
-ulMargin
-    This is currently unused.
-ulHysteresis
-pDeviceParams
-    This is set to the default settings.
-ulCtrlPort1
-   This field is the address of the command register shared by both ports.
-ulCtrlPort2
-   This field is the address of the port being used.
-ulDataPort
-   This field is set to MG5UART_PORTA or MG5UART_PORTB.
-getRegister
-setRegister
-   These do NOT follow standard conventions and are ignored.
-   The register address routines are hard-coded as this is
-   an on-CPU part and assumed to provide a 32-bit wide interface.
-getData
-   This is address of the RX buffer register.
-setData
-   This is address of the TX buffer register.
-ulClock
-   baudRate Clock
-ulIntVector
-   This is the interrupt vector number associated with this chip.
-Example:
-#if (CONSOLE_USE_INTERRUPTS)
-#define MG5UART_FUNCTIONS &mg5uart_fns
-#else
-#define MG5UART_FUNCTIONS &mg5uart_fns_polled
-#endif
-  "/dev/com0",                            /* sDeviceName */
-  SERIAL_MG5UART,                         /* deviceType */
-  MG5UART_FUNCTIONS,                      /* pDeviceFns */
-  NULL,                                   /* deviceProbe, assume it is there */
-  NULL,                                   /* pDeviceFlow */
-  16,                                     /* ulMargin */
-  8,                                      /* ulHysteresis */
-  (void *) NULL,               /* NULL */ /* pDeviceParams */
-  MONGOOSEV_PERIPHERAL_COMMAND_REGISTER,  /* ulCtrlPort1 */
-  MONGOOSEV_UART0_BASE,                   /* ulCtrlPort2 */
-  MG5UART_UART0,                          /* ulDataPort */
-  mg5uart_get_register,                   /* getRegister */
-  mg5uart_set_register,                   /* setRegister */
-  NULL, /* unused */                      /* getData */
-  NULL, /* unused */                      /* setData */
-  12000000,                               /* ulClock */
-  MONGOOSEV_IRQ_UART0_RX_FRAME_ERROR      /* ulIntVector -- base for port */
diff --git a/c/src/lib/libbsp/mips/genmongoosev/console/conscfg.c b/c/src/lib/libbsp/mips/genmongoosev/console/conscfg.c
index 8a4cf99..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/console/conscfg.c
+++ /dev/null
@@ -1,93 +0,0 @@
- *  @file
- *  This file contains the libchip configuration information
- *  to instantiate the libchip driver for the on-CPU DUART
- *  and any other serial ports in the system.
-#include <unistd.h> /* write */
-#include <bsp.h>
-#include <libchip/serial.h>
-#include <bsp/mg5uart.h>
-/* #define CONSOLE_USE_INTERRUPTS */
-#ifdef CONSOLE_USE_INTERRUPTS
-#else
-#endif
-console_tbl     Console_Configuration_Ports[] = {
-   NULL,                                   /* getRegister */
-   NULL,                                   /* setRegister */
-   CLOCK_RATE,                             /* ulClock */
-  "/dev/com1",                             /* sDeviceName */
-   MONGOOSEV_UART1_BASE,                   /* ulCtrlPort2 */
-   MG5UART_UART1,                          /* ulDataPort */
-   MONGOOSEV_IRQ_UART1_RX_FRAME_ERROR      /* ulIntVector -- base for port */
- *  Declare some information used by the console driver
-#define NUM_CONSOLE_PORTS \
-  (sizeof(Console_Configuration_Ports)/sizeof(console_tbl))
-unsigned long  Console_Configuration_Count = NUM_CONSOLE_PORTS;
- *  printk() support that simply routes printk to stderr
-#include <rtems/bspIo.h>
-static void GENMG5_output_char(char c) { write( 2, &c, 1 ); }
-BSP_output_char_function_type           BSP_output_char = GENMG5_output_char;
-BSP_polling_getchar_function_type       BSP_poll_char = NULL;
diff --git a/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c b/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c
index af463d9..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c
+++ /dev/null
@@ -1,881 +0,0 @@
- *  @file
- *  This file contains the termios TTY driver for the UART found
- *  on the Synova Mongoose-V.
-#include <rtems.h>
-#include <rtems/libio.h>
-#include <rtems/score/sysstate.h>
-#include <stdlib.h>
-#include <libchip/sersupp.h>
-#include <bsp/mongoose-v.h>
-#include <bsp.h>
- *  Indices of registers
- *  Per chip context control
-typedef struct _mg5uart_context
-  int            mate;
-} mg5uart_context;
- *  Define MG5UART_STATIC to nothing while debugging so the entry points
- *  will show up in the symbol table.
-/* #define MG5UART_STATIC */
-#define MG5UART_STATIC static
-#define MG5UART_SETREG( _base, _register, _value ) \
-        MONGOOSEV_WRITE_REGISTER( _base, _register, _value )
-#define MG5UART_GETREG( _base, _register ) \
-        MONGOOSEV_READ_REGISTER( _base, _register )
- *  Console Device Driver Support Functions
-MG5UART_STATIC int mg5uart_baud_rate(
-  int        minor,
-  uint32_t   baud,
-  uint32_t  *code
-MG5UART_STATIC void mg5uart_enable_interrupts(
-  int minor,
-  int mask
- *  mg5uart_isr_XXX
- *  This is the single interrupt entry point which parcels interrupts
- *  out to the handlers for specific sources and makes sure that the
- *  shared handler gets the right arguments.
- *  NOTE: Yes .. this is ugly but it provides 5 interrupt source
- *  wrappers which are nearly functionally identical.
-extern void mips_default_isr(int vector);
-#define __ISR(_TYPE, _OFFSET) \
-  MG5UART_STATIC void mg5uart_process_isr_ ## _TYPE ( \
-    int  minor \
-  MG5UART_STATIC rtems_isr mg5uart_isr_ ## _TYPE ( \
-    void *arg \
-    rtems_vector_number vector = (rtems_vector_number) arg; \
-    int   minor; \
-    for(minor=0 ; minor<Console_Port_Count ; minor++) { \
-      if( Console_Port_Tbl[minor]->deviceType == SERIAL_MG5UART && \
-          vector == Console_Port_Tbl[minor]->ulIntVector + _OFFSET ) { \
-        mg5uart_process_isr_ ## _TYPE (minor); \
-	return; \
-    mips_default_isr( vector ); \
-__ISR(rx_frame_error, MG5UART_IRQ_RX_FRAME_ERROR)
-__ISR(rx_overrun_error, MG5UART_IRQ_RX_OVERRUN_ERROR)
-__ISR(tx_empty, MG5UART_IRQ_TX_EMPTY)
-__ISR(tx_ready, MG5UART_IRQ_TX_READY)
-__ISR(rx_ready, MG5UART_IRQ_RX_READY)
- *  mg5uart_set_attributes
- *  This function sets the UART channel to reflect the requested termios
- *  port settings.
-MG5UART_STATIC int mg5uart_set_attributes(
-  int minor,
-  const struct termios *t
-  uint32_t               pMG5UART_port;
-  uint32_t               pMG5UART;
-  uint32_t               cmd, cmdSave;
-  uint32_t               baudcmd;
-  uint32_t               shift;
-  rtems_interrupt_level  Irql;
-  pMG5UART      = Console_Port_Tbl[minor]->ulCtrlPort1;
-  pMG5UART_port = Console_Port_Tbl[minor]->ulCtrlPort2;
-   *  Set the baud rate
-  if (mg5uart_baud_rate( minor, t->c_cflag, &baudcmd ) == -1)
-    return -1;
-   *  Base settings
-   *  Base settings
-  cmd = MONGOOSEV_UART_CMD_RX_ENABLE | MONGOOSEV_UART_CMD_TX_ENABLE;
-   *  Parity
-  if (t->c_cflag & PARENB) {
-    cmd |= MONGOOSEV_UART_CMD_PARITY_ENABLE;
-    if (t->c_cflag & PARODD)
-      cmd |= MONGOOSEV_UART_CMD_PARITY_ODD;
-    else
-      cmd |= MONGOOSEV_UART_CMD_PARITY_EVEN;
-  } else {
-    cmd |= MONGOOSEV_UART_CMD_PARITY_DISABLE;
-   *  Character Size
-  if (t->c_cflag & CSIZE) {
-    switch (t->c_cflag & CSIZE) {
-      case CS5:
-      case CS6:
-      case CS7:
-        return -1;
-        break;
-      case CS8:
-        /* Mongoose-V only supports CS8 */
-        break;
-  } /* else default to CS8 */
-   *  Stop Bits
-#if 0
-  if (t->c_cflag & CSTOPB) {
-    /* 2 stop bits not supported by Mongoose-V uart */
-    return -1;
-#endif
-   *  XXX what about CTS/RTS
-  /* XXX */
-   *  Now write the registers
-  if ( Console_Port_Tbl[minor]->ulDataPort == MG5UART_UART0 )
-    shift = MONGOOSEV_UART0_CMD_SHIFT;
-  else
-    shift = MONGOOSEV_UART1_CMD_SHIFT;
-  rtems_interrupt_disable(Irql);
-  cmdSave = MG5UART_GETREG( pMG5UART, MG5UART_COMMAND_REGISTER );
-  MG5UART_SETREG( pMG5UART,
-		  MG5UART_COMMAND_REGISTER,
-		  (cmdSave & ~(MONGOOSEV_UART_ALL_STATUS_BITS << shift)) | (cmd << shift) );
-  MG5UART_SETREG( pMG5UART_port, MG5UART_BAUD_RATE, baudcmd );
-  rtems_interrupt_enable(Irql);
-  return 0;
- *  mg5uart_initialize_context
- *  This function sets the default values of the per port context structure.
-MG5UART_STATIC void mg5uart_initialize_context(
-  int               minor,
-  mg5uart_context  *pmg5uartContext
-  int          port;
-  unsigned int pMG5UART;
-  unsigned int pMG5UART_port;
-  pmg5uartContext->mate = -1;
-  for (port=0 ; port<Console_Port_Count ; port++ ) {
-    if ( Console_Port_Tbl[port]->ulCtrlPort1 == pMG5UART &&
-         Console_Port_Tbl[port]->ulCtrlPort2 != pMG5UART_port ) {
-      pmg5uartContext->mate = port;
-      break;
- *  mg5uart_init
- *  This function initializes the DUART to a quiecsent state.
-MG5UART_STATIC void mg5uart_init(int minor)
-  uint32_t  		cmdSave;
-  uint32_t  		shift;
-  mg5uart_context        *pmg5uartContext;
-  pmg5uartContext = (mg5uart_context *) malloc(sizeof(mg5uart_context));
-  Console_Port_Data[minor].pDeviceContext = (void *)pmg5uartContext;
-  mg5uart_initialize_context( minor, pmg5uartContext );
-  else
-   *  Disable the uart and leave this port disabled.
-  cmdSave = MG5UART_GETREG(pMG5UART, MG5UART_COMMAND_REGISTER) & ~(MONGOOSEV_UART_ALL_STATUS_BITS << shift);
-  MG5UART_SETREG( pMG5UART, MG5UART_COMMAND_REGISTER, cmdSave );
-   *  Disable interrupts on RX and TX for this port
-  mg5uart_enable_interrupts( minor, MG5UART_DISABLE_ALL );
- *  mg5uart_open
- *  This function opens a port for communication.
- *  Default state is 9600 baud, 8 bits, No parity, and 1 stop bit.
-MG5UART_STATIC int mg5uart_open(
-  int      major,
-  int      minor,
-  void    *arg
-  uint32_t      baudcmd;
-  uint32_t      shift;
-  else
-  /* XXX default baud rate could be from configuration table */
-  (void) mg5uart_baud_rate( minor, B19200, &baudcmd );
-   *  Set the DUART channel to a default useable state
-   *  B19200, 8Nx since there is no stop bit control.
-  cmd = MONGOOSEV_UART_CMD_TX_ENABLE | MONGOOSEV_UART_CMD_RX_ENABLE;
-		  cmd = (cmdSave & ~(MONGOOSEV_UART_ALL_STATUS_BITS << shift)) | (cmd << shift) );
-  return RTEMS_SUCCESSFUL;
- *  mg5uart_close
- *  This function shuts down the requested port.
-MG5UART_STATIC int mg5uart_close(
-  int      major,
-  int      minor,
-  void    *arg
-  uint32_t      shift;
-   *  Disable interrupts from this channel and then disable it totally.
-  /* XXX interrupts */
-  cmd = MONGOOSEV_UART_CMD_TX_DISABLE | MONGOOSEV_UART_CMD_RX_DISABLE;
-  else
-  return(RTEMS_SUCCESSFUL);
- *  mg5uart_write_polled
- *  This routine polls out the requested character.
-MG5UART_STATIC void mg5uart_write_polled(
-  int   minor,
-  char  c
-  uint32_t                status;
-  int                     shift;
-  int                     timeout;
-    shift = MONGOOSEV_UART0_IRQ_SHIFT;
-  else
-    shift = MONGOOSEV_UART1_IRQ_SHIFT;
-   * wait for transmitter holding register to be empty
-  timeout = 2000;
-  while( --timeout )
-    status = MG5UART_GETREG(pMG5UART, MG5UART_STATUS_REGISTER) >> shift;
-    if ( (status & (MONGOOSEV_UART_TX_READY | MONGOOSEV_UART_TX_EMPTY)) ==
-            (MONGOOSEV_UART_TX_READY | MONGOOSEV_UART_TX_EMPTY) )
-      break;
-    if( (status & (MONGOOSEV_UART_TX_READY | MONGOOSEV_UART_TX_EMPTY)) )
-       break;
-     * Yield while we wait
-#if 0
-     if(_System_state_Is_up(_System_state_Get()))
-       rtems_task_wake_after(RTEMS_YIELD_PROCESSOR);
-#endif
-   * transmit character
-  MG5UART_SETREG(pMG5UART_port, MG5UART_TX_BUFFER, c);
-MG5UART_STATIC void mg5uart_process_isr_rx_error(
-   int  minor,
-   uint32_t   mask
-  int                     shift;
-  else
-  /* now clear the error */
-  MG5UART_SETREG(
-     pMG5UART,
-     MG5UART_STATUS_REGISTER,
-     mask << shift );
-MG5UART_STATIC void mg5uart_process_isr_rx_frame_error(
-  int  minor
-   mg5uart_process_isr_rx_error( minor, MONGOOSEV_UART_RX_FRAME_ERROR );
-MG5UART_STATIC void mg5uart_process_isr_rx_overrun_error(
-  int  minor
-   mg5uart_process_isr_rx_error( minor, MONGOOSEV_UART_RX_OVERRUN_ERROR );
-MG5UART_STATIC void mg5uart_process_tx_isr(
-   int        minor,
-   uint32_t   source
-   int             shift;
-   mg5uart_enable_interrupts(minor, MG5UART_ENABLE_ALL_EXCEPT_TX);
-   else
-   MG5UART_SETREG(
-      pMG5UART,
-      source << shift );
-   if( rtems_termios_dequeue_characters( Console_Port_Data[minor].termios_data, 1) )
-      mg5uart_enable_interrupts(minor, MG5UART_ENABLE_ALL);
-      return;
-    *  There are no more characters to transmit.  The tx interrupts are be cleared
-    *  by writing data to the uart, so just disable the tx interrupt sources.
-   Console_Port_Data[minor].bActive = FALSE;
-   /* mg5uart_enable_interrupts(minor, MG5UART_ENABLE_ALL_EXCEPT_TX); */
-MG5UART_STATIC void mg5uart_process_isr_tx_empty(
-  int  minor
-   /* mg5uart_process_tx_isr( minor, MONGOOSEV_UART_TX_EMPTY ); */
-MG5UART_STATIC void mg5uart_process_isr_tx_ready(
-  int  minor
-   mg5uart_process_tx_isr( minor, MONGOOSEV_UART_TX_READY );
-MG5UART_STATIC void mg5uart_process_isr_rx_ready(
-  int  minor
-  char       c;
-  /* reading the RX buffer automatically resets the interrupt flag */
-  c = (char) MG5UART_GETREG(pMG5UART_port, MG5UART_RX_BUFFER);
-  rtems_termios_enqueue_raw_characters(
-     Console_Port_Data[minor].termios_data,
-     &c,
-    1
-static rtems_irq_connect_data mg5uart_rx_frame_error_cd  = {  \
-  0,                             /* filled in at initialization */
-  mg5uart_isr_rx_frame_error,   /* filled in at initialization */
-  NULL,   /* (void *) minor */
-  NULL,
-  NULL,
-  NULL
-static rtems_irq_connect_data mg5uart_rx_overrun_error_cd  = {  \
-  mg5uart_isr_rx_overrun_error,   /* filled in at initialization */
-  NULL,
-  NULL,
-  NULL
-static rtems_irq_connect_data mg5uart_tx_empty_cd  = {  \
-  mg5uart_isr_tx_empty,   /* filled in at initialization */
-  NULL,
-  NULL,
-  NULL
-static rtems_irq_connect_data mg5uart_tx_ready_cd  = {  \
-  mg5uart_isr_tx_ready,   /* filled in at initialization */
-  NULL,
-  NULL,
-  NULL
-static rtems_irq_connect_data mg5uart_rx_ready_cd  = {  \
-  mg5uart_isr_rx_ready,   /* filled in at initialization */
-  NULL,
-  NULL,
-  NULL
- *  mg5uart_initialize_interrupts
- *  This routine initializes the console's receive and transmit
- *  ring buffers and loads the appropriate vectors to handle the interrupts.
-MG5UART_STATIC void mg5uart_initialize_interrupts(int minor)
-  unsigned long v;
-  mg5uart_init(minor);
-  v = Console_Port_Tbl[minor]->ulIntVector;
-  mg5uart_rx_frame_error_cd.name    =  v + MG5UART_IRQ_RX_FRAME_ERROR;
-  mg5uart_rx_overrun_error_cd.name  =  v + MG5UART_IRQ_RX_OVERRUN_ERROR;
-  mg5uart_tx_empty_cd.name          =  v + MG5UART_IRQ_TX_EMPTY;
-  mg5uart_tx_ready_cd.name          =  v + MG5UART_IRQ_TX_READY;
-  mg5uart_rx_ready_cd.name          =  v + MG5UART_IRQ_RX_READY;
-  mg5uart_rx_frame_error_cd.handle    =  (void *)mg5uart_rx_frame_error_cd.name;
-  mg5uart_rx_overrun_error_cd.handle  =  (void *)mg5uart_rx_overrun_error_cd.name;
-  mg5uart_tx_empty_cd.handle          =  (void *)mg5uart_tx_empty_cd.name;
-  mg5uart_tx_ready_cd.handle          =  (void *)mg5uart_tx_ready_cd.name;
-  mg5uart_rx_ready_cd.handle          =  (void *)mg5uart_rx_ready_cd.name;
-  BSP_install_rtems_irq_handler( &mg5uart_rx_frame_error_cd );
-  BSP_install_rtems_irq_handler( &mg5uart_rx_overrun_error_cd );
-  BSP_install_rtems_irq_handler( &mg5uart_tx_empty_cd );
-  BSP_install_rtems_irq_handler( &mg5uart_tx_ready_cd );
-  BSP_install_rtems_irq_handler( &mg5uart_rx_ready_cd );
- *  mg5uart_write_support_int
- *  Console Termios output entry point when using interrupt driven output.
-MG5UART_STATIC int mg5uart_write_support_int(
-  int         minor,
-  const char *buf,
-  size_t      len
-   *  We are using interrupt driven output and termios only sends us
-   *  one character at a time.
-  if ( !len )
-     return 0;
-   *  Put the character out and enable interrupts if necessary.
-  MG5UART_SETREG(pMG5UART_port, MG5UART_TX_BUFFER, *buf);
-  if( Console_Port_Data[minor].bActive == FALSE )
-     Console_Port_Data[minor].bActive = TRUE;
-  return 1;
- *  mg5uart_write_support_polled
- *  Console Termios output entry point when using polled output.
-MG5UART_STATIC ssize_t mg5uart_write_support_polled(
-  int         minor,
-  const char *buf,
-  size_t      len
-  int nwrite = 0;
-   * poll each byte in the string out of the port.
-  while (nwrite < len)
-    mg5uart_write_polled(minor, *buf++);
-    nwrite++;
-   * return the number of bytes written.
-  return nwrite;
- *  mg5uart_inbyte_nonblocking_polled
- *  Console Termios polling input entry point.
-MG5UART_STATIC int mg5uart_inbyte_nonblocking_polled(
-  int minor
-  uint32_t                status;
-  uint32_t                tmp,shift;
-  else
-  /* reset overrrun or framing errors */
-  if( (tmp = (status & 0x3)) )
-     MG5UART_SETREG(pMG5UART, MG5UART_STATUS_REGISTER, (tmp << shift) );
-  if ( status & MONGOOSEV_UART_RX_READY )
-     return (int) MG5UART_GETREG(pMG5UART_port, MG5UART_RX_BUFFER);
-  else
-     return -1;
- *  mg5uart_baud_rate
-  int           minor,
-  uint32_t      baud,
-  uint32_t     *code
-  uint32_t   clock;
-  uint32_t   tmp_code;
-  uint32_t   baud_requested;
-  baud_requested = baud & CBAUD;
-  if (!baud_requested)
-    baud_requested = B9600;              /* default to 9600 baud */
-  baud_requested = rtems_termios_baud_to_number( baud_requested );
-  clock = (uint32_t) Console_Port_Tbl[minor]->ulClock;
-  if (!clock)
-    rtems_fatal_error_occurred(RTEMS_INVALID_NUMBER);
-   *  Formula is Code = round(ClockFrequency / Baud - 1).
-   *  Since this is integer math, we will divide by twice the baud and
-   *  check the remaining odd bit.
-  tmp_code = (clock / baud_requested) - 1;
-   *  From section 12.7, "Keep C>100 for best receiver operation."
-   *  That is 100 cycles which is not a lot of instructions.  It is
-   *  reasonable to think that the Mongoose-V could not keep
-   *  up with C < 100.
-  if ( tmp_code < 100 )
-    return RTEMS_INVALID_NUMBER;
-   *  upper word is receiver baud and lower word is transmitter baud
-  *code = (tmp_code << 16) | tmp_code;
-  return 0;
- *  mg5uart_enable_interrupts
- *  This function enables specific interrupt sources on the DUART.
-  int minor,
-  int mask
-  uint32_t  		maskSave;
-  uint32_t              shift;
-   *  Enable interrupts on RX and TX -- not break
-  else
-  maskSave = MG5UART_GETREG( pMG5UART, MG5UART_INTERRUPT_MASK_REGISTER );
-  MG5UART_SETREG(
-     pMG5UART,
-     MG5UART_INTERRUPT_MASK_REGISTER,
-     (maskSave & ~(MONGOOSEV_UART_ALL_STATUS_BITS << shift)) | (mask << shift) );
- * Flow control is only supported when using interrupts
-const console_fns mg5uart_fns =
-  libchip_serial_default_probe,   /* deviceProbe */
-  mg5uart_open,                   /* deviceFirstOpen */
-  NULL,                           /* deviceLastClose */
-  NULL,                           /* deviceRead */
-  mg5uart_write_support_int,      /* deviceWrite */
-  mg5uart_initialize_interrupts,  /* deviceInitialize */
-  mg5uart_write_polled,           /* deviceWritePolled */
-  mg5uart_set_attributes,         /* deviceSetAttributes */
-  TRUE                            /* deviceOutputUsesInterrupts */
-const console_fns mg5uart_fns_polled =
-  mg5uart_close,                       /* deviceLastClose */
-  mg5uart_inbyte_nonblocking_polled,   /* deviceRead */
-  mg5uart_write_support_polled,        /* deviceWrite */
-  mg5uart_init,                        /* deviceInitialize */
-  FALSE,                               /* deviceOutputUsesInterrupts */
diff --git a/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.h b/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.h
index b9e69f2..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.h
+++ /dev/null
@@ -1,97 +0,0 @@
- *  COPYRIGHT (c) 1989-1999.
-#ifndef _MG5UART_H_
-#define _MG5UART_H_
-#ifdef __cplusplus
-extern "C" {
-#endif
- *  This is the ASCII for "MG5U" which should be unique enough to
- *  distinguish this type of serial device from others.
-#define SERIAL_MG5UART 0x474D5535
-#define MG5UART_UART0  0
-#define MG5UART_UART1  1
- *  These are just used in the interface between this driver and
- *  the read/write register routines when accessing the first
- *  control port.  They are indices of registers from the bases.
-/* shared registers from peripheral base (i.e. from ulCtrlPort1) */
-#define MG5UART_COMMAND_REGISTER          0
-#define MG5UART_STATUS_REGISTER           1
-#define MG5UART_INTERRUPT_CAUSE_REGISTER  2
-#define MG5UART_INTERRUPT_MASK_REGISTER   3
-#define MG5UART_STATUS_REGISTER           0x04
-#define MG5UART_INTERRUPT_CAUSE_REGISTER  0x08
-#define MG5UART_INTERRUPT_MASK_REGISTER   0x0C
-/* port specific registers from uart base (i.e. from ulCtrlPort2) */
-#define MG5UART_RX_BUFFER  0
-#define MG5UART_TX_BUFFER  4
-#define MG5UART_BAUD_RATE  8
- *  Interrupt mask values
-#define MG5UART_ENABLE_ALL_EXCEPT_TX MONGOOSEV_UART_ALL_RX_STATUS_BITS
-/* all rx ints on, but only tx ready.  no need to also int on tx empty */
-#define MG5UART_ENABLE_ALL           (MONGOOSEV_UART_ALL_STATUS_BITS & ~MONGOOSEV_UART_TX_EMPTY)
-#define MG5UART_DISABLE_ALL          0x0000
- *  Assume vectors are sequential.
-#define MG5UART_IRQ_RX_FRAME_ERROR   0
-#define MG5UART_IRQ_RX_OVERRUN_ERROR 1
-#define MG5UART_IRQ_TX_EMPTY         2
-#define MG5UART_IRQ_TX_READY         3
-#define MG5UART_IRQ_RX_READY         4
- * Driver function table
-extern const console_fns mg5uart_fns;
-extern const console_fns mg5uart_fns_polled;
- * Default register access routines
-uint32_t   mg5uart_get_register(    /* registers are on 32-bit boundaries */
-  uintptr_t   ulCtrlPort,           /*   and accessed as word             */
-  uint32_t    ucRegNum
-void  mg5uart_set_register(
-  uint32_t    ucRegNum,
-  uint32_t    ucData
-#ifdef __cplusplus
-#endif
-#endif /* _MG5UART_H_ */
diff --git a/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart_reg.c b/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart_reg.c
index 134695f..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart_reg.c
+++ /dev/null
@@ -1,58 +0,0 @@
- *  This file contains a typical set of register access routines which may be
- *  used with the mg5uart chip if accesses to the chip are as follows:
- *    + registers are accessed as uint32_t  's
- *    + registers are only u32-aligned (no address gaps)
- *  COPYRIGHT (c) 1989-2001.
-#include <rtems.h>
-#ifndef _MG5UART_MULTIPLIER
-#define _MG5UART_MULTIPLIER 1
-#define _MG5UART_NAME(_X) _X
-#define _MG5UART_TYPE uint32_t
-#endif
-#define CALCULATE_REGISTER_ADDRESS( _base, _reg ) \
-  (_MG5UART_TYPE *)((_base) + ((_reg) * _MG5UART_MULTIPLIER ))
- *  MG5UART Get Register Routine
-uint8_t   _MG5UART_NAME(mg5uart_get_register)(
-  uint32_t    ulCtrlPort,
-  uint8_t     ucRegNum
-  _MG5UART_TYPE *port;
-  port = CALCULATE_REGISTER_ADDRESS( ulCtrlPort, ucRegNum );
-  return *port;
- *  MG5UART Set Register Routine
-void  _MG5UART_NAME(mg5uart_set_register)(
-  uint8_t     ucRegNum,
-  uint8_t     ucData
-  *port = ucData;
diff --git a/c/src/lib/libbsp/mips/genmongoosev/include/bsp.h b/c/src/lib/libbsp/mips/genmongoosev/include/bsp.h
index ba0738c..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/include/bsp.h
+++ /dev/null
@@ -1,73 +0,0 @@
- *  @file
- *  This include file contains some definitions specific to a board
- *  based upon the generic capabilities of a Mongoose-V.
-#ifndef LIBBSP_MIPS_GENMONGOOSEV_BSP_H
-#define LIBBSP_MIPS_GENMONGOOSEV_BSP_H
-#include <bspopts.h>
-#include <bsp/default-initial-extension.h>
-#include <rtems.h>
-#include <rtems/iosupp.h>
-#include <rtems/console.h>
-#include <rtems/clockdrv.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
-#define BSP_FEATURE_IRQ_EXTENSION
-#define BSP_SHARED_HANDLER_SUPPORT      1
-#ifndef CPU_CLOCK_RATE
-#define CLOCK_RATE	12000000
-#endif
-#define CPU_CLOCK_RATE_HZ	CLOCK_RATE
-#define CPU_CLOCK_RATE_MHZ	(CLOCK_RATE/1000000)
- * Useful defines set here so we can avoid duplicating them all over
- * creation.
- * assertSoftwareInt defined in vectorisrs.c the prototype is here so
- * userspace code can get to it directly.
-extern void assertSoftwareInterrupt(uint32_t);
-/* from start.S */
-extern void promCopyIcacheFlush(void);
-extern void promCopyDcacheFlush(void);
- * Called from user programs wanting to use the GDB stub.
-void mg5rdbgCloseGDBuart(void);
-int mg5rdbgOpenGDBuart(int);
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/c/src/lib/libbsp/mips/genmongoosev/include/irq.h b/c/src/lib/libbsp/mips/genmongoosev/include/irq.h
index 7cfca65..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/include/irq.h
+++ /dev/null
@@ -1,95 +0,0 @@
- * @file
- * @ingroup bsp_interrupt
- * @brief interrupt definitions.
-#ifndef LIBBSP_MIPS_MONGOOSEV_IRQ_H
-#define LIBBSP_MIPS_MONGOOSEV_IRQ_H
-#ifndef ASM
-  #include <rtems.h>
-  #include <rtems/irq.h>
-  #include <rtems/irq-extension.h>
-  #include <rtems/score/mips.h>
-#endif
- * @addtogroup bsp_interrupt
- *  Interrupt Vector Numbers
- *  NOTE: IRQ INT5 is logical or of peripheral cause register
- *        per p. 5-22 of Mongoose-V manual.
-#define BSP_INTERRUPT_VECTOR_MIN              0
-#define MONGOOSEV_IRQ_INT0                    MIPS_INTERRUPT_BASE+0
-#define MONGOOSEV_IRQ_TIMER1                  MONGOOSEV_IRQ_INT0
-#define MONGOOSEV_IRQ_INT1                    MIPS_INTERRUPT_BASE+1
-#define MONGOOSEV_IRQ_TIMER2                  MONGOOSEV_IRQ_INT1
-#define MONGOOSEV_IRQ_INT2                    MIPS_INTERRUPT_BASE+2
-#define MONGOOSEV_IRQ_INT3                    MIPS_INTERRUPT_BASE+3
-#define MONGOOSEV_IRQ_FPU		      MONGOOSEV_IRQ_INT3
-#define MONGOOSEV_IRQ_INT4                    MIPS_INTERRUPT_BASE+4
-/* MONGOOSEV_IRQ_INT5 indicates that a peripheral caused the IRQ. */
-#define MONGOOSEV_IRQ_PERIPHERAL_BASE         MIPS_INTERRUPT_BASE+5
-#define MONGOOSEV_IRQ_XINT0                  MONGOOSEV_IRQ_PERIPHERAL_BASE + 0
-#define MONGOOSEV_IRQ_XINT1                  MONGOOSEV_IRQ_PERIPHERAL_BASE + 1
-#define MONGOOSEV_IRQ_XINT2                  MONGOOSEV_IRQ_PERIPHERAL_BASE + 2
-#define MONGOOSEV_IRQ_XINT3                  MONGOOSEV_IRQ_PERIPHERAL_BASE + 3
-#define MONGOOSEV_IRQ_XINT4                  MONGOOSEV_IRQ_PERIPHERAL_BASE + 4
-#define MONGOOSEV_IRQ_XINT5                  MONGOOSEV_IRQ_PERIPHERAL_BASE + 5
-#define MONGOOSEV_IRQ_XINT6                  MONGOOSEV_IRQ_PERIPHERAL_BASE + 6
-#define MONGOOSEV_IRQ_XINT7                  MONGOOSEV_IRQ_PERIPHERAL_BASE + 7
-#define MONGOOSEV_IRQ_XINT8                  MONGOOSEV_IRQ_PERIPHERAL_BASE + 8
-#define MONGOOSEV_IRQ_XINT9                  MONGOOSEV_IRQ_PERIPHERAL_BASE + 9
-#define MONGOOSEV_IRQ_RESERVED_BIT_10	     MONGOOSEV_IRQ_PERIPHERAL_BASE + 10
-#define MONGOOSEV_IRQ_UART0_RX_FRAME_ERROR   MONGOOSEV_IRQ_PERIPHERAL_BASE + 11
-#define MONGOOSEV_IRQ_UART0_RX_OVERRUN_ERROR MONGOOSEV_IRQ_PERIPHERAL_BASE + 12
-#define MONGOOSEV_IRQ_UART0_TX_EMPTY         MONGOOSEV_IRQ_PERIPHERAL_BASE + 13
-#define MONGOOSEV_IRQ_UART0_TX_READY         MONGOOSEV_IRQ_PERIPHERAL_BASE + 14
-#define MONGOOSEV_IRQ_UART0_RX_READY         MONGOOSEV_IRQ_PERIPHERAL_BASE + 15
-#define MONGOOSEV_IRQ_RESERVED_BIT_16        MONGOOSEV_IRQ_PERIPHERAL_BASE + 16
-#define MONGOOSEV_IRQ_UART1_RX_FRAME_ERROR   MONGOOSEV_IRQ_PERIPHERAL_BASE + 17
-#define MONGOOSEV_IRQ_UART1_RX_OVERRUN_ERROR MONGOOSEV_IRQ_PERIPHERAL_BASE + 18
-#define MONGOOSEV_IRQ_UART1_TX_EMPTY         MONGOOSEV_IRQ_PERIPHERAL_BASE + 19
-#define MONGOOSEV_IRQ_UART1_TX_READY         MONGOOSEV_IRQ_PERIPHERAL_BASE + 20
-#define MONGOOSEV_IRQ_UART1_RX_READY         MONGOOSEV_IRQ_PERIPHERAL_BASE + 21
-#define MONGOOSEV_IRQ_READ_ACCESS_VIOLATION  MONGOOSEV_IRQ_PERIPHERAL_BASE + 22
-#define MONGOOSEV_IRQ_WRITE_ACCESS_VIOLATION MONGOOSEV_IRQ_PERIPHERAL_BASE + 23
-#define MONGOOSEV_IRQ_RESERVED_24            MONGOOSEV_IRQ_PERIPHERAL_BASE + 24
-#define MONGOOSEV_IRQ_RESERVED_25            MONGOOSEV_IRQ_PERIPHERAL_BASE + 25
-#define MONGOOSEV_IRQ_RESERVED_26            MONGOOSEV_IRQ_PERIPHERAL_BASE + 26
-#define MONGOOSEV_IRQ_RESERVED_27            MONGOOSEV_IRQ_PERIPHERAL_BASE + 27
-#define MONGOOSEV_IRQ_RESERVED_28            MONGOOSEV_IRQ_PERIPHERAL_BASE + 28
-#define MONGOOSEV_IRQ_RESERVED_29            MONGOOSEV_IRQ_PERIPHERAL_BASE + 29
-#define MONGOOSEV_IRQ_UNCORRECTABLE_ERROR    MONGOOSEV_IRQ_PERIPHERAL_BASE + 30
-#define MONGOOSEV_IRQ_CORRECTABLE_ERROR      MONGOOSEV_IRQ_PERIPHERAL_BASE + 31
-#define MONGOOSEV_IRQ_SOFTWARE_1             MIPS_INTERRUPT_BASE+37
-#define MONGOOSEV_IRQ_SOFTWARE_2             MIPS_INTERRUPT_BASE+38
-#define MONGOOSEV_MAXIMUM_VECTORS            MIPS_INTERRUPT_BASE+39
-#define BSP_INTERRUPT_VECTOR_MAX             MONGOOSEV_MAXIMUM_VECTORS
-#endif /* LIBBSP_MIPS_MONGOOSEV_IRQ_H */
diff --git a/c/src/lib/libbsp/mips/genmongoosev/include/lr33000.h b/c/src/lib/libbsp/mips/genmongoosev/include/lr33000.h
index 348cfe8..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/include/lr33000.h
+++ /dev/null
@@ -1,99 +0,0 @@
-/* lr33000.h - LSI LR33000 CPU header */
-modification history
-01c,22sep92,rrr  added support for c++
-01b,20apr92,ajm	 added CR_DCAS for ethernet support
-01a,10feb92,ajm	 written for FCS
-#ifndef __INClr33000h
-#define __INClr33000h
-#ifdef __cplusplus
-extern "C" {
-#endif
-#ifdef _ASMLANGUAGE
-#define C0_DCIC	$7		/* cache control */
-#define C0_BPC	$3		/* breakpoint on instr */
-#define C0_BDA	$5		/* breakpoint on data */
-#endif /* _ASMLANGUAGE */
-#define DEBUG_VECT	0x00000040
-#define K0_DEBUG_VECT	(K0BASE+DEBUG_VECT)
-#define K1_DEBUG_VECT	(K1BASE+DEBUG_VECT)
-/* definitions for Debug and Cache Invalidate control (DCIC) register bits */
-#define DCIC_TR		0x80000000	/* Trap enable */
-#define DCIC_UD		0x40000000	/* User debug enable */
-#define DCIC_KD		0x20000000	/* Kernel debug enable */
-#define DCIC_TE		0x10000000	/* Trace enable */
-#define DCIC_DW		0x08000000	/* Enable data breakpoints on write */
-#define DCIC_DR		0x04000000	/* Enable data breakpoints on read */
-#define DCIC_DAE	0x02000000	/* Enable data addresss breakpoints */
-#define DCIC_PCE	0x01000000	/* Enable instruction breakpoints */
-#define DCIC_DE		0x00800000	/* Debug enable */
-#define DCIC_DL		0x00008000	/* Data cache line invalidate */
-#define DCIC_IL		0x00004000	/* Instruction cache line invalidate */
-#define DCIC_D		0x00002000	/* Data cache invalidate enable */
-#define DCIC_I		0x00001000	/* Instr. cache invalidate enable */
-#define DCIC_T		0x00000020	/* Trace, set by CPU */
-#define DCIC_W		0x00000010	/* Write reference, set by CPU */
-#define DCIC_R		0x00000008	/* Read reference, set by CPU */
-#define DCIC_DA		0x00000004	/* Data address, set by CPU */
-#define DCIC_PC		0x00000002	/* Program counter, set by CPU */
-#define DCIC_DB		0x00000001	/* Debug, set by CPU */
-/* Define counter/timer register addresses */
-#define M_TIC1		0xfffe0000	/* timer 1 initial count */
-#define M_TC1		0xfffe0004	/* timer 1 control	 */
-#define M_TIC2		0xfffe0008	/* timer 2 initial count */
-#define M_TC2		0xfffe000c	/* timer 2 control	 */
-#define M_RTIC		0xfffe0010	/* refresh timer	 */
-#define M_CFGREG	0xfffe0020	/* configuration reg	 */
-/* Definitions for counter/timer control register bits */
-#define TC_CE	 	0x00000004	/* count enable */
-#define TC_IE	 	0x00000002	/* interrupt enable (1 == enable) */
-#define TC_INT 	 	0x00000001	/* interrupt acknowlege (0 == ack) */
-#define TCNT_MASK	0x00ffffff	/* 24 bit timer mask */
-/* Definitions for Configuration register bits */
-#define CR_ICDISABLE	0x00800000	/* Instruction cache disable */
-#define CR_DCDISABLE	0x00400000	/* Data cache disable */
-#define CR_IBLK_2	0x00000000	/* Instruction cache block size */
-#define CR_IBLK_4	0x00100000	/* Instruction cache block size */
-#define CR_IBLK_8	0x00200000	/* Instruction cache block size */
-#define CR_IBLK_16	0x00300000	/* Instruction cache block size */
-#define CR_IBLKMSK	0x00300000	/* Instruction cache block size */
-#define CR_DBLK_2	0x00000000	/* Data cache block size */
-#define CR_DBLK_4	0x00040000	/* Data cache block size */
-#define CR_DBLK_8	0x00080000	/* Data cache block size */
-#define CR_DBLK_16	0x000c0000	/* Data cache block size */
-#define CR_DBLKMSK	0x000c0000	/* Data cache block size */
-#define CR_IODIS	0x00020000	/* Disable DRDY for I/O addresses */
-#define CR_IOWAITSHFT	13		/* I/O wait states */
-#define CR_PDIS		0x00001000	/* Disable DRDY for PROM addresses */
-#define CR_PWAITSHFT	8		/* PROM wait states */
-#define CR_DCAS		0x00000080	/* Define # cycles of DCAS */
-#define CR_DPEN		0x00000040	/* Enable parity check for DRAM */
-#define CR_RDYGEN	0x00000020	/* Disable DRDY for DRAM addresses */
-#define CR_BLKFDIS	0x00000010	/* Disable DRAM block refill */
-#define CR_RFSHEN	0x00000008	/* Enable refresh generator */
-#define CR_RASPCHG	0x00000004	/* Define RAS precharge */
-#define CR_CASLNTH	0x00000002	/* Define CAS active time */
-#define CR_DRAMEN	0x00000001	/* Enable DRAM controller */
-#define CR_PWT(x)	((x) << 8)	/* memory wait states */
-#define CR_IOWT(x)	((x) << 13)	/* io wait states */
-#define LR33000_DSIZE	0x400		/* Data cache = 1Kbytes */
-#define LR33000_ISIZE	0x2000		/* Instructrion cache = 8Kbytes */
-#ifdef __cplusplus
-#endif
-#endif /* __INClr33000h */
diff --git a/c/src/lib/libbsp/mips/genmongoosev/include/lr333x0.h b/c/src/lib/libbsp/mips/genmongoosev/include/lr333x0.h
index 17ada5d..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/include/lr333x0.h
+++ /dev/null
@@ -1,180 +0,0 @@
-/* lr333x0.h - LSI LR333x0 CPU header */
-#ifndef __INClr333x0h
-#define __INClr333x0h
-#ifdef __cplusplus
-extern "C" {
-#endif
-#define C0_TAR  $6              /* target address register */
-#define C0_BDAM $9              /* breakpoint data addr mask */
-#define C0_BPCM $11             /* breakpoint instr addr mask */
-#else
-IMPORT	int sysICsize;		/* inst cache size defined in BSP */
-IMPORT	int sysDCsize;		/* data cache size defined in BSP */
-IMPORT	BOOL sysICset0;		/* inst cache set 0 present ? */
-/* Define register addresses */
-#define M_SRAM          0xfffe0100      /* SRAM config reg */
-#define M_SPEC0         0xfffe0104
-#define M_SPEC1         0xfffe0108
-#define M_SPEC2         0xfffe010c
-#define M_SPEC3         0xfffe0110
-#define M_DRAM		0xfffe0120	/* DRAM configuration      */
-#define M_BIU		0xfffe0130	/* BIU/cache configuration */
-/* Definitions for Debug and Cache Invalidate control (DCIC) register bits */
-/* Definitions for Wait-state configuration register bits */
-#define	SPC_INHIBITSHFT 24		/* Inhibit shift count */
-#define	SPC_EXTGNT	0x00800000	/* External data ready */
-#define	SPC_16WIDE	0x00400000	/* 16-bit wide memory */
-#define	SPC_8WIDE	0x00200000	/* 8-bit wide memory */
-#define	SPC_PENA	0x00100000	/* Parity enable */
-#define	SPC_CACHED	0x00080000	/* Cache data */
-#define	SPC_CSDLY_3	0x00060000	/* Select delay, 3 cycles */
-#define	SPC_CSDLY_2	0x00040000	/* Select delay, 2 cycles */
-#define	SPC_CSDLY_1	0x00020000	/* Select delay, 1 cycles */
-#define	SPC_CSDLY_0	0x00000000	/* Select delay, 0 cycles */
-#define	SPC_BLKENA	0x00010000	/* Block enable */
-#define	SPC_BLKWAIT_7	0x0000e000	/* Block delay, 7 cycles */
-#define	SPC_BLKWAIT_6	0x0000c000	/* Block delay, 6 cycles */
-#define	SPC_BLKWAIT_5	0x0000a000	/* Block delay, 5 cycles */
-#define	SPC_BLKWAIT_4	0x00008000	/* Block delay, 4 cycles */
-#define	SPC_BLKWAIT_3	0x00006000	/* Block delay, 3 cycles */
-#define	SPC_BLKWAIT_2	0x00004000	/* Block delay, 2 cycles */
-#define	SPC_BLKWAIT_1	0x00002000	/* Block delay, 1 cycles */
-#define	SPC_BLKWAIT_0	0x00000000	/* Block delay, 0 cycles */
-#define	SPC_RECSHFT     7		/* Recovery time shift count */
-#define	SPC_WAITENA     0x00000040	/* Wait-state generator enable */
-#define	SPC_WAITSHFT	0		/* Wait shift count */
-/* Definitions for DRAM configuration register bits */
-#define DRAM_DLP1	0x10000000	/* Data latch in phase 1 */
-#define DRAM_SYNC	0x08000000	/* Sunchronous DRAM mode */
-#define DRAM_SCFG	0x04000000	/* Synchronous Configuration mode */
-#define DRAM_DMARDY	0x02000000	/* DMA ready */
-#define DRAM_DMABLK_64	0x01400000	/* DMA block refill size, 64 words */
-#define DRAM_DMABLK_32	0x01000000	/* DMA block refill size, 32 words */
-#define DRAM_DMABLK_16	0x00c00000	/* DMA block refill size, 16 words */
-#define DRAM_DMABLK_8	0x00800000	/* DMA block refill size, 8 words */
-#define DRAM_DMABLK_4	0x00400000	/* DMA block refill size, 4 words */
-#define DRAM_DMABLK_2	0x00000000	/* DMA block refill size, 2 words */
-#define DRAM_DPTH_8	0x00300000	/* CAS ready depth, 8 per cycle */
-#define DRAM_DPTH_4	0x00200000	/* CAS ready depth, 4 per cycle */
-#define DRAM_DPTH_2	0x00100000	/* CAS ready depth, 2 per cycle */
-#define DRAM_DPTH_1	0x00000000	/* CAS ready depth, 1 per cycle */
-#define DRAM_RDYW	0x00080000	/* Ready Wait */
-#define DRAM_PGSZ_2K	0x00070000	/* Page size, 2K words */
-#define DRAM_PGSZ_1K	0x00060000	/* Page size, 1K words */
-#define DRAM_PGSZ_512	0x00050000	/* Page size, 512 words */
-#define DRAM_PGSZ_256	0x00040000	/* Page size, 256 words */
-#define DRAM_PGSZ_128	0x00030000	/* Page size, 128 words */
-#define DRAM_PGSZ_64	0x00020000	/* Page size, 64 words */
-#define DRAM_PGSZ_32	0x00010000	/* Page size, 32 words */
-#define DRAM_PGSZ_16	0x00000000	/* Page size, 16 words */
-#define DRAM_PGMW	0x00008000	/* Page mode write enable */
-#define DRAM_RFWE_0	0x00004000	/* Refresh write enable mode, bit 1 */
-#define DRAM_RFWE_1	0x00002000	/* Refresh write enable mode, bit 0 */
-#define DRAM_RFEN	0x00001000	/* Internal refresh enable */
-#define DRAM_RDYEN	0x00000800	/* Internal ready generation */
-#define DRAM_BFD	0x00000400	/* Block fetch disable */
-#define DRAM_PE		0x00000200	/* Parity checking enable */
-#define DRAM_RPC_3	0x00000180	/* RAS precharge, 3 */
-#define DRAM_RPC_2	0x00000100	/* RAS precharge, 2 */
-#define DRAM_RPC_1	0x00000080	/* RAS precharge, 1 */
-#define DRAM_RPC_0	0x00000000	/* RAS precharge, 0 */
-#define DRAM_RCD_3	0x00000060	/* RAS to CAS delay, 3 */
-#define DRAM_RCD_2	0x00000040	/* RAS to CAS delay, 2 */
-#define DRAM_RCD_1	0x00000020	/* RAS to CAS delay, 1 */
-#define DRAM_RCD_0	0x00000000	/* RAS to CAS delay, 0 */
-#define DRAM_CS		0x00000010	/* CAS short */
-#define DRAM_CL_8_5	0x0000000f	/* CAS length, 8.5 cycles */
-#define DRAM_CL_7_5	0x0000000c	/* CAS length, 7.5 cycles*/
-#define DRAM_CL_6_5	0x0000000a	/* CAS length, 6.5 cycles */
-#define DRAM_CL_5_5	0x00000008	/* CAS length, 5.5 cycles */
-#define DRAM_CL_4_5	0x00000006	/* CAS length, 4.5 cycles */
-#define DRAM_CL_3_5	0x00000004	/* CAS length, 3.5 cycles*/
-#define DRAM_CL_2_5	0x00000002	/* CAS length, 2.5 cycles */
-#define DRAM_CL_1_5	0x00000000	/* CAS length, 1.5 cycles */
-#define DRAM_DCE	0x00000001	/* DRAM controller enable */
-/* Definitions for BIU/cache configuration register bits */
-#define BIU_NOSTR	0x00020000	/* no instruction streaming */
-#define BIU_LDSCH	0x00010000	/* enable load scheduling */
-#define BIU_BGNT	0x00008000	/* enable bus grant */
-#define BIU_NOPAD	0x00004000	/* no wait state */
-#define BIU_RDPRI	0x00002000	/* enable read priority */
-#define BIU_INTP	0x00001000	/* interrupt polarity */
-#define BIU_IS1		0x00000800	/* enable Inst cache, set 1 */
-#define BIU_IS0		0x00000400	/* enable Inst cache, set 0 */
-#define BIU_IBLKSZ_16	0x00000300	/* Inst cache fill sz = 16 words */
-#define BIU_IBLKSZ_8	0x00000200	/* Inst cache fill sz = 8 words */
-#define BIU_IBLKSZ_4	0x00000100	/* Inst cache fill sz = 4 words */
-#define BIU_IBLKSZ_2	0x00000000	/* Inst cache fill sz = 2 words */
-#define BIU_DS		0x00000080	/* enable Data cache */
-#define BIU_DBLKSZ_16	0x00000030	/* Data cache fill sz = 16 words */
-#define BIU_DBLKSZ_8	0x00000020	/* Data cache fill sz = 8 words */
-#define BIU_DBLKSZ_4	0x00000010	/* Data cache fill sz = 4 words */
-#define BIU_DBLKSZ_2	0x00000000	/* Data cache fill sz = 2 words */
-#define BIU_RAM		0x00000008	/* scratchpad RAM */
-#define BIU_TAG		0x00000004	/* tag test mode */
-#define BIU_INV		0x00000002	/* invalidate mode */
-#define BIU_LOCK	0x00000001	/* lock mode */
-/* Definitions for cache sizes */
-#define LR33300_IC_SIZE	0x1000		/* 33300 Inst cache = 4Kbytes */
-#define LR33310_IC_SIZE	0x1000		/* 33310 Inst cache = 4Kbytes */
-					/*     Note: each set is 4Kbytes! */
-#define LR33300_DC_SIZE	0x800		/* 33300 Data cache = 2Kbytes */
-#define LR33310_DC_SIZE	0x1000		/* 33310 Data cache = 4Kbytes */
-#ifdef __cplusplus
-#endif
-#endif /* __INClr333x0h */
diff --git a/c/src/lib/libbsp/mips/genmongoosev/include/mongoose-v.h b/c/src/lib/libbsp/mips/genmongoosev/include/mongoose-v.h
index b8ded3d..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/include/mongoose-v.h
+++ /dev/null
@@ -1,306 +0,0 @@
- *  @file
- *  MIPS Mongoose-V specific information
-#ifndef __MONGOOSEV_h
-#define __MONGOOSEV_h
- *  Macros to assist in accessing memory mapped Mongoose registers
-#define MONGOOSEV_READ( _base ) \
-  ( *((volatile uint32_t*)(_base)) )
-#define MONGOOSEV_WRITE( _base, _value ) \
-  ( *((volatile uint32_t*)(_base)) = (_value) )
-#define MONGOOSEV_READ_REGISTER( _base, _register ) \
-  ( *((volatile uint32_t*)((_base) + (_register))) )
-#define MONGOOSEV_WRITE_REGISTER( _base, _register, _value ) \
-  ( *((volatile uint32_t*)((_base) + (_register))) = (_value) )
- * Macros to read/write the Mongoose FPU control register.
- *  BIU and DRAM Registers
-#define MONGOOSEV_BIU_CACHE_CONFIGURATION_REGISTER       0xFFFE0130
-#define MONGOOSEV_DRAM_CONFIGURATION_REGISTER            0xFFFE0120
-#define MONGOOSEV_REFRESH_TIMER_INITIAL_COUNTER_REGISTER 0xFFFE0010
-#define MONGOOSEV_WAIT_STATE_CONFIGURATION_REGISTER_BASE 0xFFFE0100
- *  Peripheral Function Addresses
- *  NOTE: Status and Interrupt Cause use the same bits
-#define MONGOOSEV_PERIPHERAL_COMMAND_REGISTER                   0xFFFE0180
-#define MONGOOSEV_PERIPHERAL_STATUS_REGISTER                    0xFFFE0184
-#define MONGOOSEV_PERIPHERAL_FUNCTION_INTERRUPT_CAUSE_REGISTER  0xFFFE0188
-#define MONGOOSEV_PERIPHERAL_FUNCTION_INTERRUPT_MASK_REGISTER   0xFFFE018C
-#define MONGOOSEV_WATCHDOG			0xBE000000
-/* UART Bits in Peripheral Command Register Bits (TX/RX tied together here) */
-#define MONGOOSEV_UART_CMD_RESET_BOTH_PORTS	0x0001
-#define MONGOOSEV_UART_CMD_LOOPBACK_CTSN	0x0002
-#define MONGOOSEV_UART_CMD_LOOPBACK_RXTX	0x0004
-#define MONGOOSEV_UART_CMD_RX_ENABLE		0x001
-#define MONGOOSEV_UART_CMD_RX_DISABLE		0x000
-#define MONGOOSEV_UART_CMD_TX_ENABLE		0x002
-#define MONGOOSEV_UART_CMD_TX_DISABLE		0x000
-#define MONGOOSEV_UART_CMD_TX_READY		0x004
-#define MONGOOSEV_UART_CMD_PARITY_ENABLE	0x008
-#define MONGOOSEV_UART_CMD_PARITY_DISABLE	0x000
-#define MONGOOSEV_UART_CMD_PARITY_EVEN		0x010
-#define MONGOOSEV_UART_CMD_PARITY_ODD		0x000
-#define MONGOOSEV_UART0_CMD_SHIFT 5
-#define MONGOOSEV_UART1_CMD_SHIFT 11
-#define MONGOOSEV_UART_CMD_TX_ENABLE_0 \
-        (MONGOOSEV_UART_CMD_TX_ENABLE << MONGOOSEV_UART0_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_RX_ENABLE_0 \
-        (MONGOOSEV_UART_CMD_RX_ENABLE << MONGOOSEV_UART0_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_TX_READY_0 \
-        (MONGOOSEV_UART_CMD_TX_READY << MONGOOSEV_UART0_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_PARITY_ENABLE_0 \
-        (MONGOOSEV_UART_CMD_PARITY_ENABLE << MONGOOSEV_UART0_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_PARITY_DISABLE_0 \
-        (MONGOOSEV_UART_CMD_PARITY_DISABLE << MONGOOSEV_UART0_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_PARITY_EVEN_0 \
-        (MONGOOSEV_UART_CMD_PARITY_EVEN << MONGOOSEV_UART0_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_PARITY_ODD_0 \
-        (MONGOOSEV_UART_CMD_PARITY_ODD << MONGOOSEV_UART0_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_TX_ENABLE_1 \
-        (MONGOOSEV_UART_CMD_TX_ENABLE << MONGOOSEV_UART1_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_RX_ENABLE_1 \
-        (MONGOOSEV_UART_CMD_RX_ENABLE << MONGOOSEV_UART1_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_TX_READY_1 \
-        (MONGOOSEV_UART_CMD_TX_READY << MONGOOSEV_UART1_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_PARITY_ENABLE_1 \
-        (MONGOOSEV_UART_CMD_PARITY_ENABLE << MONGOOSEV_UART1_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_PARITY_DISABLE_1 \
-        (MONGOOSEV_UART_CMD_PARITY_DISABLE << MONGOOSEV_UART1_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_PARITY_EVEN_1 \
-        (MONGOOSEV_UART_CMD_PARITY_EVEN << MONGOOSEV_UART1_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_PARITY_ODD_1 \
-        (MONGOOSEV_UART_CMD_PARITY_ODD << MONGOOSEV_UART1_CMD_SHIFT)
-/* UART Bits in Peripheral Status and Interrupt Cause Register */
-#define MONGOOSEV_UART_RX_FRAME_ERROR              0x0001
-#define MONGOOSEV_UART_RX_OVERRUN_ERROR            0x0002
-#define MONGOOSEV_UART_TX_EMPTY                    0x0004
-#define MONGOOSEV_UART_TX_READY                    0x0008
-#define MONGOOSEV_UART_RX_READY                    0x0010
-#define MONGOOSEV_UART_ALL_RX_STATUS_BITS          0x0013
-#define MONGOOSEV_UART_ALL_STATUS_BITS             0x001F
- *  The Peripheral Interrupt Status, Cause, and Mask registers have the
- *  same bit assignments although some revisions of the document have
- *  the Cause and Status registers incorrect.
-#define MONGOOSEV_UART0_IRQ_SHIFT 11
-#define MONGOOSEV_UART1_IRQ_SHIFT 17
-#define MONGOOSEV_UART_FRAME_ERROR_0 \
-        (MONGOOSEV_UART_FRAME_ERROR << MONGOOSEV_UART0_IRQ_SHIFT)
-#define MONGOOSEV_UART_RX_OVERRUN_ERROR_0 \
-        (MONGOOSEV_UART_RX_OVERRUN_ERROR << MONGOOSEV_UART0_IRQ_SHIFT)
-#define MONGOOSEV_UART_TX_EMPTY_0 \
-        (MONGOOSEV_UART_TX_EMPTY << MONGOOSEV_UART0_IRQ_SHIFT)
-#define MONGOOSEV_UART_TX_READY_0 \
-        (MONGOOSEV_UART_TX_READY << MONGOOSEV_UART0_IRQ_SHIFT)
-#define MONGOOSEV_UART_RX_READY_0 \
-        (MONGOOSEV_UART_RX_READY << MONGOOSEV_UART0_IRQ_SHIFT)
-#define MONGOOSEV_UART_FRAME_ERROR_1 \
-        (MONGOOSEV_UART_FRAME_ERROR << MONGOOSEV_UART1_IRQ_SHIFT)
-#define MONGOOSEV_UART_RX_OVERRUN_ERROR_1 \
-        (MONGOOSEV_UART_RX_OVERRUN_ERROR << MONGOOSEV_UART1_IRQ_SHIFT)
-#define MONGOOSEV_UART_TX_EMPTY_1 \
-        (MONGOOSEV_UART_TX_EMPTY << MONGOOSEV_UART1_IRQ_SHIFT)
-#define MONGOOSEV_UART_TX_READY_1 \
-        (MONGOOSEV_UART_TX_READY << MONGOOSEV_UART1_IRQ_SHIFT)
-#define MONGOOSEV_UART_RX_READY_1 \
-        (MONGOOSEV_UART_RX_READY << MONGOOSEV_UART1_IRQ_SHIFT)
- *  Bits in the Peripheral Interrupt Mask Register
-** Interrupt Status/Cause/Mask register bits - from 31 to 0
-#define MONGOOSEV_EDAC_SERR_BIT          0x80000000
-#define MONGOOSEV_EDAC_MERR_BIT          0x40000000
-/* 29 - 24 reserved */
-#define MONGOOSEV_MAVN_WRITE_ACCESS      0x00800000
-#define MONGOOSEV_MAVN_READ_ACCESS       0x00400000
-#define MONGOOSEV_UART_1_RX_READY        0x00200000
-#define MONGOOSEV_UART_1_TX_READY        0x00100000
-#define MONGOOSEV_UART_1_TX_EMPTY        0x00080000
-#define MONGOOSEV_UART_1_RX_OVERRUN      0x00040000
-#define MONGOOSEV_UART_1_FRAME_ERROR     0x00020000
-#define MONGOOSEV_RESERVED_16            0x00010000
-#define MONGOOSEV_UART_0_RX_READY        0x00008000
-#define MONGOOSEV_UART_0_TX_READY        0x00004000
-#define MONGOOSEV_UART_0_TX_EMPTY        0x00002000
-#define MONGOOSEV_UART_0_RX_OVERRUN      0x00001000
-#define MONGOOSEV_UART_0_FRAME_ERROR     0x00000800
-#define MONGOOSEV_RESERVED_10            0x00000400
-#define MONGOOSEV_EXTERN_INT_9           0x00000200
-#define MONGOOSEV_EXTERN_INT_8           0x00000100
-#define MONGOOSEV_EXTERN_INT_7           0x00000080
-#define MONGOOSEV_EXTERN_INT_6           0x00000040
-#define MONGOOSEV_EXTERN_INT_5           0x00000020
-#define MONGOOSEV_EXTERN_INT_4           0x00000010
-#define MONGOOSEV_EXTERN_INT_3           0x00000008
-#define MONGOOSEV_EXTERN_INT_2           0x00000004
-#define MONGOOSEV_EXTERN_INT_1           0x00000002
-#define MONGOOSEV_EXTERN_INT_0           0x00000001
-** Peripheral Command bits (non-uart, those are defined above)
-#define MONGOOSEV_COMMAND_ENABLE_EDAC	MONGOOSEV_EDAC_SERR_BIT
-#define MONGOOSEV_COMMAND_OVERRIDE_EDAC MONGOOSEV_EDAC_MERR_BIT
- *  EDAC Registers
-#define MONGOOSEV_EDAC_ERROR_ADDRESS_REGISTER       0xFFFE0190
-#define MONGOOSEV_EDAC_PARITY_TEST_MODE_REGISTER    0xFFFE0194
- *  MAVN Registers
-#define MONGOOSEV_MAVN_TEST_REGISTER               0xFFFE01B4
-#define MONGOOSEV_MAVN_ACCESS_PRIVILEGE_REGISTER   0xFFFE01B8
-#define MONGOOSEV_MAVN_ACCESS_VIOLATION_REGISTER   0xFFFE01BC
-#define MONGOOSEV_MAVN_RANGE_0_REGISTER            0xFFFE01C0
-#define MONGOOSEV_MAVN_RANGE_1_REGISTER            0xFFFE01C4
-#define MONGOOSEV_MAVN_RANGE_2_REGISTER            0xFFFE01C8
-#define MONGOOSEV_MAVN_RANGE_3_REGISTER            0xFFFE01CC
-#define MONGOOSEV_MAVN_RANGE_4_REGISTER            0xFFFE01D0
-#define MONGOOSEV_MAVN_RANGE_5_REGISTER            0xFFFE01D4
-#define MONGOOSEV_MAVN_RANGE_6_REGISTER            0xFFFE01D8
-#define MONGOOSEV_MAVN_RANGE_7_REGISTER            0xFFFE01DC
- *  Timer Base Addresses, Offsets, and Values
-#define MONGOOSEV_TIMER1_BASE    0xFFFE0000
-#define MONGOOSEV_TIMER2_BASE    0xFFFE0008
-#define MONGOOSEV_TIMER_INITIAL_COUNTER_REGISTER 0
-#define MONGOOSEV_TIMER_CONTROL_REGISTER         4
-/* Timer Control Register Constants */
-#define MONGOOSEV_TIMER_CONTROL_COUNTER_ENABLE    0x04
-#define MONGOOSEV_TIMER_CONTROL_INTERRUPT_ENABLE  0x02
-#define MONGOOSEV_TIMER_CONTROL_TIMEOUT           0x01
- *  UART Base Addresses and Offsets
- *  Many bits in the peripheral command register are UART related
- *  and the bits are defined there.
-#define MONGOOSEV_UART0_BASE   0xFFFE01E8
-#define MONGOOSEV_UART1_BASE   0xFFFE01F4
-#define MONGOOSEV_RX_BUFFER    0
-#define MONGOOSEV_TX_BUFFER    4
-#define MONGOOSEV_BAUD_RATE    8
- *  Status Register Bits
-#define SR_CUMASK	0xf0000000	/* coproc usable bits */
-#define SR_CU3		0x80000000	/* Coprocessor 3 usable */
-#define SR_CU2		0x40000000	/* Coprocessor 2 usable */
-#define SR_CU1		0x20000000	/* Coprocessor 1 usable */
-#define SR_CU0		0x10000000	/* Coprocessor 0 usable */
-#define SR_BEV		0x00400000	/* use boot exception vectors */
-#define SR_TS		0x00200000	/* TLB shutdown */
-#define SR_PE		0x00100000	/* cache parity error */
-#define SR_CM		0x00080000	/* cache miss */
-#define SR_PZ		0x00040000	/* cache parity zero */
-#define SR_SWC		0x00020000	/* swap cache */
-#define SR_ISC		0x00010000	/* Isolate data cache */
-#define SR_IMASK	0x0000ff00	/* Interrupt mask */
-#define SR_IMASK8	0x00000000	/* mask level 8 */
-#define SR_IMASK7	0x00008000	/* mask level 7 */
-#define SR_IMASK6	0x0000c000	/* mask level 6 */
-#define SR_IMASK5	0x0000e000	/* mask level 5 */
-#define SR_IMASK4	0x0000f000	/* mask level 4 */
-#define SR_IMASK3	0x0000f800	/* mask level 3 */
-#define SR_IMASK2	0x0000fc00	/* mask level 2 */
-#define SR_IMASK1	0x0000fe00	/* mask level 1 */
-#define SR_IMASK0	0x0000ff00	/* mask level 0 */
-#define SR_IBIT8	0x00008000	/* bit level 8 */
-#define SR_IBIT7	0x00004000	/* bit level 7 */
-#define SR_IBIT6	0x00002000	/* bit level 6 */
-#define SR_IBIT5	0x00001000	/* bit level 5 */
-#define SR_IBIT4	0x00000800	/* bit level 4 */
-#define SR_IBIT3	0x00000400	/* bit level 3 */
-#define SR_IBIT2	0x00000200	/* bit level 2 */
-#define SR_IBIT1	0x00000100	/* bit level 1 */
-#define SR_KUO		0x00000020	/* old kernel/user, 0 => k, 1 => u */
-#define SR_IEO		0x00000010	/* old interrupt enable, 1 => enable */
-#define SR_KUP		0x00000008	/* prev kernel/user, 0 => k, 1 => u */
-#define SR_IEP		0x00000004	/* prev interrupt enable, 1 => enable */
-#define SR_KUC		0x00000002	/* cur kernel/user, 0 => k, 1 => u */
-#define SR_IEC		0x00000001	/* cur interrupt enable, 1 => enable */
-#define SR_KUMSK	(SR_KUO|SR_IEO|SR_KUP|SR_IEP|SR_KUC|SR_IEC)
-#define SR_IMASKSHIFT	8
-#define MONGOOSEV_IC_SIZE	0x1000		/* instruction cache = 4Kbytes */
-#define MONGOOSEV_DC_SIZE	0x800		/* data cache 2Kbytes */
-#endif
diff --git a/c/src/lib/libbsp/mips/genmongoosev/include/r3000.h b/c/src/lib/libbsp/mips/genmongoosev/include/r3000.h
deleted file mode 100644
index 0d0670a..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/include/r3000.h
+++ /dev/null
@@ -1,229 +0,0 @@
-/* r3000.h - mips R3k architecture header file */
-* Copyright 1985-1997 by MIPS Computer Systems, Inc.
-01k,17jan96,kkk  made MINCACHE 512 (spr# 7556)
-01j,13jan96,kkk  undid 01i.
-01i,18dec96,tam  enabled FP exceptions via FP_TASK_STATUS (spr #7665).
-01h,13sep93,caf  fixed K2SIZE (SPR #1880).
-01g,22sep92,rrr  added support for c++
-01f,02jun92,ajm  the 5.0.5 merge
-01e,26may92,rrr  the tree shuffle
-01d,04oct91,rrr  passed through the ansification filter
-		  -changed copyright notice
-01c,23jul91,ajm  changed default fp status register to all exceptions
-		  off forcing the user to enable exceptions for signals
-		  Enable FPA interrupt to tasks
-01b,08jul91,ajm  added SR_KUMSK for exception handling
-01a,21feb91,ajm  written.
-#ifndef __INCr3000h
-#define __INCr3000h
-#ifdef __cplusplus
-extern "C" {
-#endif
-* Segment base addresses and sizes
-#define	K0BASE		0x80000000
-#define	K0SIZE		0x20000000
-#define	K1BASE		0xA0000000
-#define	K1SIZE		0x20000000
-#define	K2BASE		0xC0000000
-#define	K2SIZE		0x40000000
-* Exception vectors
-#define	UT_VEC		K0BASE			/* utlbmiss vector */
-#define	E_VEC		(K0BASE+0x80)		/* exception vector */
-#define	R_VEC		(K1BASE+0x1fc00000)	/* reset vector */
- * Address conversion macros
-#define	K0_TO_K1(x)	((unsigned)(x)|0xA0000000)	/* kseg0 to kseg1 */
-#define	K1_TO_K0(x)	((unsigned)(x)&0x9FFFFFFF)	/* kseg1 to kseg0 */
-#define	K0_TO_PHYS(x)	((unsigned)(x)&0x1FFFFFFF)	/* kseg0 to physical */
-#define	K1_TO_PHYS(x)	((unsigned)(x)&0x1FFFFFFF)	/* kseg1 to physical */
-#define	PHYS_TO_K0(x)	((unsigned)(x)|0x80000000)	/* physical to kseg0 */
-#define	PHYS_TO_K1(x)	((unsigned)(x)|0xA0000000)	/* physical to kseg1 */
-* Address predicates
-#define	IS_KSEG0(x)	((unsigned)(x) >= K0BASE && (unsigned)(x) < K1BASE)
-#define	IS_KSEG1(x)	((unsigned)(x) >= K1BASE && (unsigned)(x) < K2BASE)
-#define	IS_KUSEG(x)	((unsigned)(x) < K0BASE)
-* Cache size constants
-#define	MINCACHE	+(1*512)	/* leading plus for mas's benefit */
-#define	MAXCACHE	+(256*1024)	/* leading plus for mas's benefit */
-* Cause bit definitions
-#define	CAUSE_BD	0x80000000	/* Branch delay slot */
-#define	CAUSE_CEMASK	0x30000000	/* coprocessor error */
-#define	CAUSE_CESHIFT	28
-#define	CAUSE_IP8	0x00008000	/* External level 8 pending */
-#define	CAUSE_IP7	0x00004000	/* External level 7 pending */
-#define	CAUSE_IP6	0x00002000	/* External level 6 pending */
-#define	CAUSE_IP5	0x00001000	/* External level 5 pending */
-#define	CAUSE_IP4	0x00000800	/* External level 4 pending */
-#define	CAUSE_IP3	0x00000400	/* External level 3 pending */
-#define	CAUSE_SW2	0x00000200	/* Software level 2 pending */
-#define	CAUSE_SW1	0x00000100	/* Software level 1 pending */
-#define	CAUSE_IPMASK	0x0000FF00	/* Pending interrupt mask */
-#define	CAUSE_IPSHIFT	8
-#define	CAUSE_EXCMASK	0x0000003C	/* Cause code bits */
-#define	CAUSE_EXCSHIFT	2
-* Status definition bits
-* fpa definitions
-#define FP_ROUND	0x3		/* r3010 round mode mask */
-#define FP_STICKY 	0x7c		/* r3010 sticky bits mask */
-#define FP_ENABLE 	0xf80		/* r3010 enable mode mask */
-#define FP_EXC		0x3f000		/* r3010 exception mask */
-#define FP_ROUND_N	0x0		/* round to nearest */
-#define FP_ROUND_Z 	0x1		/* round to zero */
-#define FP_ROUND_P 	0x2		/* round to + infinity */
-#define FP_ROUND_M 	0x3		/* round to - infinity */
-#define FP_STICKY_I	0x4		/* sticky inexact operation */
-#define FP_STICKY_U	0x8		/* sticky underflow */
-#define FP_STICKY_O	0x10		/* sticky overflow */
-#define FP_STICKY_Z	0x20		/* sticky divide by zero */
-#define FP_STICKY_V	0x40		/* sticky invalid operation */
-#define FP_ENABLE_I	0x80		/* enable inexact operation */
-#define FP_ENABLE_U	0x100		/* enable underflow exc  */
-#define FP_ENABLE_O	0x200		/* enable overflow exc  */
-#define FP_ENABLE_Z	0x400		/* enable divide by zero exc  */
-#define FP_ENABLE_V	0x800		/* enable invalid operation exc  */
-#define FP_EXC_I	0x1000		/* inexact operation */
-#define FP_EXC_U	0x2000		/* underflow */
-#define FP_EXC_O	0x4000		/* overflow */
-#define FP_EXC_Z	0x8000		/* divide by zero */
-#define FP_EXC_V	0x10000		/* invalid operation */
-#define FP_EXC_E	0x20000		/* unimplemented operation */
-#define FP_COND		0x800000	/* condition bit */
-#define FP_EXC_SHIFT	12
-#define FP_ENABLE_SHIFT	7
-#define FP_EXC_MASK	(FP_EXC_I|FP_EXC_U|FP_EXC_O|FP_EXC_Z|FP_EXC_V|FP_EXC_E)
-#define FP_ENABLE_MASK	(FP_ENABLE_I|FP_ENABLE_U|FP_ENABLE_O|FP_ENABLE_Z| \
-			 FP_ENABLE_V)
-#define FP_TASK_STATUS	0x0 		/* all FP exceptions  are disabled
-					   (see fppAlib.s and spr #7665) */
-* tlb definitions
-#define	TLB_ENTRIES		64
-#define	TLBLO_PFNMASK		0xfffff000
-#define	TLBLO_PFNSHIFT		12
-#define	TLBLO_N			0x800		/* non-cacheable */
-#define	TLBLO_D			0x400		/* writeable */
-#define	TLBLO_V			0x200		/* valid bit */
-#define	TLBHI_VPNMASK		0xfffff000
-#define	TLBHI_VPNSHIFT		12
-#define	TLBHI_PIDMASK		0xfc0
-#define	TLBHI_PIDSHIFT		6
-#define	TLBHI_NPID		64
-#define	TLBINX_PROBE		0x80000000
-#define	TLBINX_INXMASK		0x00003f00
-#define	TLBINX_INXSHIFT		8
-#define	TLBRAND_RANDMASK	0x00003f00
-#define	TLBRAND_RANDSHIFT	8
-#define	TLBCTXT_BASEMASK	0xffe00000
-#define	TLBCTXT_BASESHIFT	21
-#define	TLBCTXT_VPNMASK		0x001ffffc
-#define	TLBCTXT_VPNSHIFT	2
-* Coprocessor 0 operations
-#define	C0_READI  0x1		/* read ITLB entry addressed by C0_INDEX */
-#define	C0_WRITEI 0x2		/* write ITLB entry addressed by C0_INDEX */
-#define	C0_WRITER 0x6		/* write ITLB entry addressed by C0_RAND */
-#define	C0_PROBE  0x8		/* probe for ITLB entry addressed by TLBHI */
-#define	C0_RFE	  0x10		/* restore for exception */
-#ifdef __cplusplus
-#endif
-#endif /* __INCr3000h */
diff --git a/c/src/lib/libbsp/mips/genmongoosev/include/tm27.h b/c/src/lib/libbsp/mips/genmongoosev/include/tm27.h
index 8c2dd5e..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/include/tm27.h
+++ /dev/null
@@ -1,36 +0,0 @@
- *  @file
-#ifndef _RTEMS_TMTEST27
-#error "This is an RTEMS internal file you must not include directly."
-#endif
-#ifndef __tm27_h
-#define __tm27_h
- *  Define the interrupt mechanism for Time Test 27
-#define MUST_WAIT_FOR_INTERRUPT 1
-#define Install_tm27_vector( handler ) \
-      MONGOOSEV_IRQ_SOFTWARE_1, "benchmark", 0, \
-      (rtems_interrupt_handler)handler, NULL );
-#define Cause_tm27_intr()   assertSoftwareInterrupt(0);
-#define Clear_tm27_intr() /* empty */
-#define Lower_tm27_intr() /* empty */
-#endif
diff --git a/c/src/lib/libbsp/mips/genmongoosev/irq/vectorisrs.c b/c/src/lib/libbsp/mips/genmongoosev/irq/vectorisrs.c
index b7210f7..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/irq/vectorisrs.c
+++ /dev/null
@@ -1,257 +0,0 @@
- *  @file
- *  ISR Vectoring support for the Synova Mongoose-V.
-#include <rtems.h>
-#include <rtems/mips/iregdef.h>
-#include <rtems/mips/idtcpu.h>
-#include <rtems/irq.h>
-#include <bsp/irq-generic.h>
-#include <rtems/bspIo.h>  /* for printk */
-int mips_default_isr( int vector );
-int assertSoftwareInterrupt( uint32_t   n );
-void mips_vector_isr_handlers( CPU_Interrupt_frame *frame );
-  unsigned int sr, sr2;
-  unsigned int cause;
-  mips_get_sr( sr );
-  mips_get_cause( cause );
-  sr2 = sr & ~0xffff;
-  mips_set_sr(sr2);
-  printk( "Unhandled isr exception: vector 0x%02x, cause 0x%08X, sr 0x%08X\n", vector, cause, sr );
-  rtems_fatal_error_occurred(1);
-  return 0;
-/* userspace routine to assert either software interrupt */
-   if( n<2 )
-      uint32_t   c;
-      mips_get_cause(c);
-      c = ((n+1) << CAUSE_IPSHIFT);
-      mips_set_cause(c);
-      return n;
-   else return -1;
- * Instrumentation tweaks for isr timing measurement, turning them off
- * via this #if will remove the code entirely from the RTEMS kernel.
-#if 0
-#define SET_ISR_FLAG( offset )	*((uint32_t*)(0x8001e000+offset)) = 1;
-#define CLR_ISR_FLAG( offset )	*((uint32_t*)(0x8001e000+offset)) = 0;
-#else
-#endif
-static volatile uint32_t   _ivcause, _ivsr;
-static uint32_t   READ_CAUSE(void)
-   mips_get_cause( _ivcause );
-   _ivcause &= SR_IMASK;	/* mask off everything other than the interrupt bits */
-   return ((_ivcause & (_ivsr & SR_IMASK)) >> CAUSE_IPSHIFT);
- * This rather strangely coded routine enforces an interrupt priority
- * scheme.  As it runs thru finding whichever interrupt caused it to get
- * here, it test for other interrupts arriving in the meantime (maybe it
- * occured while the vector code is executing for instance).  Each new
- * interrupt will be served in order of its priority.  In an effort to
- * minimize overhead, the cause register is only fetched after an
- * interrupt is serviced.  Because of the intvect goto's, this routine
- * will only exit when all interrupts have been serviced and no more
- * have arrived, this improves interrupt latency at the cost of
- * increasing scheduling jitter; though scheduling jitter should only
- * become apparent in high interrupt load conditions.
-   uint32_t  	cshifted;
-   /* mips_get_sr( sr ); */
-   _ivsr = frame->c0_sr;
-   cshifted = READ_CAUSE();
-  intvect:
-   if( cshifted & 0x3 )
-      /* making the software interrupt the highest priority is kind of
-       * stupid, but it makes the bit testing lots easier.  On the other
-       * hand, these ints are infrequently used and the testing overhead
-       * is minimal.  Who knows, high-priority software ints might be
-       * handy in some situation.
-      /* unset both software int cause bits */
-      mips_set_cause( _ivcause & ~(3 << CAUSE_IPSHIFT) );
-      if ( cshifted & 0x01 )       /* SW[0] */
-	 bsp_interrupt_handler_dispatch( MONGOOSEV_IRQ_SOFTWARE_1 );
-      if ( cshifted & 0x02 )       /* SW[1] */
-	 bsp_interrupt_handler_dispatch( MONGOOSEV_IRQ_SOFTWARE_2 );
-   if ( cshifted & 0x04 )       /* IP[0] ==> INT0 == TIMER1 */
-      SET_ISR_FLAG( 0x4 );
-      bsp_interrupt_handler_dispatch( MONGOOSEV_IRQ_TIMER1 );
-      CLR_ISR_FLAG( 0x4 );
-      if( (cshifted = READ_CAUSE()) & 0x3 ) goto intvect;
-   if ( cshifted & 0x08 )       /* IP[1] ==> INT1 == TIMER2*/
-      SET_ISR_FLAG( 0x8 );
-      bsp_interrupt_handler_dispatch( MONGOOSEV_IRQ_TIMER2 );
-      CLR_ISR_FLAG( 0x8 );
-      if( (cshifted = READ_CAUSE()) & 0x7 ) goto intvect;
-   if ( cshifted & 0x10 )       /* IP[2] ==> INT2 */
-      SET_ISR_FLAG( 0x10 );
-      bsp_interrupt_handler_dispatch( MONGOOSEV_IRQ_INT2 );
-      CLR_ISR_FLAG( 0x10 );
-      if( (cshifted = READ_CAUSE()) & 0xf ) goto intvect;
-   if ( cshifted & 0x20 )       /* IP[3] ==> INT3 == FPU interrupt */
-      SET_ISR_FLAG( 0x20 );
-      bsp_interrupt_handler_dispatch( MONGOOSEV_IRQ_INT3 );
-      CLR_ISR_FLAG( 0x20 );
-      if( (cshifted = READ_CAUSE()) & 0x1f ) goto intvect;
-   if ( cshifted & 0x40 )       /* IP[4] ==> INT4, external interrupt */
-      SET_ISR_FLAG( 0x40 );
-      bsp_interrupt_handler_dispatch( MONGOOSEV_IRQ_INT4 );
-      CLR_ISR_FLAG( 0x40 );
-      if( (cshifted = READ_CAUSE()) & 0x3f ) goto intvect;
-   if ( cshifted & 0x80 )       /* IP[5] ==> INT5, peripheral interrupt */
-      uint32_t    bit;
-      uint32_t    pf_icr, pf_mask, pf_reset = 0;
-      uint32_t    i, m;
-      pf_icr = MONGOOSEV_READ( MONGOOSEV_PERIPHERAL_FUNCTION_INTERRUPT_CAUSE_REGISTER );
-      for (bit=0, pf_mask = 1;    bit < 32;     bit++, pf_mask <<= 1 )
-	 if ( pf_icr & pf_mask )
-	    SET_ISR_FLAG( 0x80 + (bit*4) );
-	    bsp_interrupt_handler_dispatch( MONGOOSEV_IRQ_PERIPHERAL_BASE + bit );
-	    CLR_ISR_FLAG( 0x80 + (bit*4) );
-	    pf_reset |= pf_mask;
-	    if( (cshifted = READ_CAUSE()) & 0xff ) break;
-       * iterate thru 32 bits in 4 chunks of 8 bits each.  This lets us
-       * quickly get past unasserted interrupts instead of flogging our
-       * way thru a full 32 bits.  pf_mask shifts left 8 bits at a time
-       * to serve as a interrupt cause test mask.
-      for( bit=0, pf_mask = 0xff;    (bit < 32 && pf_icr);     (bit+=8, pf_mask <<= 8) )
-	    /* one or more of the 8 bits we're testing is high */
-	    m = (1 << bit);
-	    /* iterate thru the 8 bits, servicing any of the interrupts */
-	    for(i=0; (i<8 && pf_icr); (i++, m <<= 1))
-	       if( pf_icr & m )
-		  SET_ISR_FLAG( 0x80 + ((bit + i) * 4) );
-		  bsp_interrupt_handler_dispatch( MONGOOSEV_IRQ_PERIPHERAL_BASE + bit + i );
-		  CLR_ISR_FLAG( 0x80 + ((bit + i) * 4) );
-		  /* or each serviced interrupt into our interrupt clear mask */
-		  pf_reset |= m;
-		  /* xor off each int we service so we can immediately
-		   * exit once we get the last one
-		  pf_icr   %= m;
-		  /* if another interrupt has arrived, jump out right
-		   * away but be sure to reset all the interrupts we've
-		   * already serviced
-		  if( READ_CAUSE() & 0xff ) goto pfexit;
-     pfexit:
-      MONGOOSEV_WRITE( MONGOOSEV_PERIPHERAL_STATUS_REGISTER, pf_reset );
-    * this is a last ditch interrupt check, if an interrupt arrives
-    * after this step, servicing it will incur the entire interrupt
-    * overhead cost.
-   if( (cshifted = READ_CAUSE()) & 0xff ) goto intvect;
diff --git a/c/src/lib/libbsp/mips/genmongoosev/make/custom/genmongoosev.cfg b/c/src/lib/libbsp/mips/genmongoosev/make/custom/genmongoosev.cfg
index e2e1bd4..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/make/custom/genmongoosev.cfg
+++ /dev/null
@@ -1,16 +0,0 @@
-#  Config file for "generic" Mongoose-V board
-include $(RTEMS_ROOT)/make/custom/default.cfg
-RTEMS_CPU=mips
-RTEMS_CPU_MODEL=mongoosev
-#  This contains the compiler options necessary to select the CPU model
-#  and (hopefully) optimize for it.
-CPU_CFLAGS = -mips1 -G0
-# optimize flag: typically -O2
-CFLAGS_OPTIMIZE_V = -O2 -g
diff --git a/c/src/lib/libbsp/mips/genmongoosev/preinstall.am b/c/src/lib/libbsp/mips/genmongoosev/preinstall.am
index e5988a4..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/preinstall.am
+++ /dev/null
@@ -1,103 +0,0 @@
-## Automatically generated by ampolish3 - Do not edit
-if AMPOLISH3
-$(srcdir)/preinstall.am: Makefile.am
-	$(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
-endif
-PREINSTALL_DIRS =
-DISTCLEANFILES += $(PREINSTALL_DIRS)
-all-am: $(PREINSTALL_FILES)
-PREINSTALL_FILES =
-CLEANFILES = $(PREINSTALL_FILES)
-all-local: $(TMPINSTALL_FILES)
-TMPINSTALL_FILES =
-CLEANFILES += $(TMPINSTALL_FILES)
-$(PROJECT_LIB)/$(dirstamp):
-	@$(MKDIR_P) $(PROJECT_LIB)
-	@: > $(PROJECT_LIB)/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
-$(PROJECT_INCLUDE)/$(dirstamp):
-	@$(MKDIR_P) $(PROJECT_INCLUDE)
-	@: > $(PROJECT_INCLUDE)/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
-$(PROJECT_INCLUDE)/bsp/$(dirstamp):
-	@$(MKDIR_P) $(PROJECT_INCLUDE)/bsp
-	@: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-$(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
-PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
-$(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
-$(PROJECT_INCLUDE)/tm27.h: include/tm27.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
-$(PROJECT_INCLUDE)/bsp/regs.h: start/regs.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/regs.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/regs.h
-$(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
-$(PROJECT_INCLUDE)/bsp/irq-info.h: ../../shared/include/irq-info.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-info.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-info.h
-$(PROJECT_INCLUDE)/bsp/irq.h: include/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
-$(PROJECT_INCLUDE)/bspopts.h: include/bspopts.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bspopts.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bspopts.h
-$(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
-$(PROJECT_INCLUDE)/bsp/lr33000.h: include/lr33000.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/lr33000.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/lr33000.h
-$(PROJECT_INCLUDE)/bsp/lr333x0.h: include/lr333x0.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/lr333x0.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/lr333x0.h
-$(PROJECT_INCLUDE)/bsp/mongoose-v.h: include/mongoose-v.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mongoose-v.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mongoose-v.h
-$(PROJECT_INCLUDE)/bsp/r3000.h: include/r3000.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/r3000.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/r3000.h
-$(PROJECT_INCLUDE)/bsp/mg5uart.h: console/mg5uart.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mg5uart.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mg5uart.h
-$(PROJECT_INCLUDE)/coverhd.h: ../../shared/include/coverhd.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
-$(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
-TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
-$(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
-PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds
diff --git a/c/src/lib/libbsp/mips/genmongoosev/start/mg5.h b/c/src/lib/libbsp/mips/genmongoosev/start/mg5.h
index 8d54133..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/start/mg5.h
+++ /dev/null
@@ -1,379 +0,0 @@
-** Section 1: Registers
-#define  PMON_ADDRESS  0xbfc00000
-** Mongoose V Peripheral Function Registers
-#define MG5_COMMAND_REG     0xfffe0180
-** Extended Interrupt Registers
-** These registers are used as follows:
-** 1. The mask register is used to allow peripheral function and external
-**    interrupts to function. To enable an interrupt, set the appropriate
-**    bit.
-** 2. The status register contains the state of the peripheral functions
-**    and external devices. This register should be read to poll devices
-**    such as the uart when the interrupts are not enabled. Writing to this
-**    register will clear the interrupt.
-** 3. The Cause register is similar to the status register, with the
-**    exception that it only shows the bits that are set in the mask
-**    register. This register should be read to determine which interrupt(s)
-**    need to be serviced. This register when written to will CAUSE the interrupt.
-#define MG5_INT_STATUS_REG      0xfffe0184   /* Read to determine state/Write to clear */
-#define MG5_INT_CAUSE_REG       0xfffe0188   /* Read to determine int/Write to cause int */
-#define MG5_INT_MASK_REG        0xfffe018c   /* Set bit here to enable int */
-** EDAC Registers
-#define MG5_EDAC_ADDR_REG       0xfffe0190   /* edac error address */
-#define MG5_EDAC_PARITY_REG     0xfffe0194   /* edac parity */
-** High speed serial port registers
-** This section is reserved for future Mongoose Processors
-** Floating Point Register
-#define MG5_FPU_CNTRL_REG     0xfffe0020     /* FPU control register */
-** MAVN Registers
-#define MG5_MAVN_TEST_REG   0xfffe01b4   /* test mavn */
-#define MG5_MAVN_PRIVLEGE_REG   0xfffe01b8   /* privlege bits */
-#define MG5_MAVN_VIOLATION_REG  0xfffe01bc   /* address of violation */
-#define MG5_MAVN_RANGE_0_REG    0xfffe01c0   /* Range 0 */
-#define MG5_MAVN_RANGE_1_REG    0xfffe01c4   /* Range 1 */
-#define MG5_MAVN_RANGE_2_REG    0xfffe01c8   /* Range 2 */
-#define MG5_MAVN_RANGE_3_REG    0xfffe01cc   /* Range 3 */
-#define MG5_MAVN_RANGE_4_REG    0xfffe01d0   /* Range 4 */
-#define MG5_MAVN_RANGE_5_REG    0xfffe01d4   /* Range 5 */
-** Uart Specific Peripheral Function Registers
-#define MG5_UART_0_RX_REG   0xfffe01e8
-#define MG5_UART_0_TX_REG       0xfffe01ec
-#define MG5_UART_0_BAUD_REG     0xfffe01f0
-#define MG5_UART_1_RX_REG       0xfffe01f4
-#define MG5_UART_1_TX_REG       0xfffe01f8
-#define MG5_UART_1_BAUD_REG     0xfffe01fc
-** Section 2: Bit definitions
-** Command Register Bits - defined from 31 to 0
-#define EDAC_ENABLE_BIT          0x80000000
-#define EDAC_OVERRIDE_BIT        0x40000000
-/* 29 - 16 reserved */
-#define UART_1_PARITY_EVEN_BIT  0x00008000
-#define UART_1_PARITY_ENABLE_BIT   0x00004000
-#define UART_1_RTS_BIT           0x00002000
-#define UART_1_TX_ENABLE_BIT         0x00001000
-#define UART_1_RX_ENABLE_BIT         0x00000800
-#define UART_1_TX_BREAK_BIT      0x00000400
-#define UART_0_PARITY_EVEN_BIT  0x00000200
-#define UART_0_PARITY_ENABLE_BIT   0x00000100
-#define UART_0_RTS_BIT           0x00000080
-#define UART_0_TX_ENABLE_BIT         0x00000040
-#define UART_0_RX_ENABLE_BIT         0x00000020
-#define UART_0_TX_BREAK_BIT      0x00000010
-#define UART_LOOPBACK_MODE_BIT  0x00000008
-#define UART_CTSN_TEST_BIT       0x00000004
-#define UART_RESET_BIT           0x00000002
-#define EDAC_SERR_BIT            0x80000000
-#define EDAC_MERR_BIT            0x40000000
-#define UART_0_RX_READY_BIT      0x00008000
-#define UART_0_TX_READY_BIT        0x00004000
-#define UART_0_TX_EMPTY_BIT      0x00002000
-#define UART_0_RX_OVERRUN_BIT      0x00001000
-#define UART_0_FRAME_ERR_BIT       0x00000800
-#define UART_0_RESERVED_BIT        0x00000400
-#define UART_1_RX_READY_BIT        0x00200000
-#define UART_1_TX_READY_BIT        0x00100000
-#define UART_1_TX_EMPTY_BIT        0x00080000
-#define UART_1_RX_OVERRUN_BIT      0x00040000
-#define UART_1_FRAME_ERR_BIT       0x00020000
-#define UART_1_RESERVED_BIT        0x00010000
-#define MAVN_WRITE_ACC_BIT       0x00400000
-#define MAVN_READ_ACC_BIT        0x00800000
-#define EXTERN_INT_9_BIT           0x00000200
-#define EXTERN_INT_8_BIT           0x00000100
-#define EXTERN_INT_7_BIT           0x00000080
-#define EXTERN_INT_6_BIT           0x00000040
-#define EXTERN_INT_5_BIT           0x00000020
-#define EXTERN_INT_4_BIT           0x00000010
-#define EXTERN_INT_3_BIT           0x00000008
-#define EXTERN_INT_2_BIT           0x00000004
-#define EXTERN_INT_1_BIT           0x00000002
-#define EXTERN_INT_0_BIT           0x00000001
-** MAVN Range Bits
-#define MAVN_RANGE_0_WRITE_BIT  0x00000001
-#define MAVN_RANGE_1_WRITE_BIT  0x00000002
-#define MAVN_RANGE_2_WRITE_BIT  0x00000004
-#define MAVN_RANGE_3_WRITE_BIT  0x00000008
-#define MAVN_RANGE_4_WRITE_BIT  0x00000010
-#define MAVN_RANGE_5_WRITE_BIT  0x00000020
-#define MAVN_GLOBAL_WRITE_BIT     0x00000200
-#define MAVN_RANGE_0_READ_BIT     0x00000400
-#define MAVN_RANGE_1_READ_BIT   0x00000800
-#define MAVN_RANGE_2_READ_BIT   0x00001000
-#define MAVN_RANGE_3_READ_BIT   0x00002000
-#define MAVN_RANGE_4_READ_BIT   0x00004000
-#define MAVN_RANGE_5_READ_BIT   0x00008000
-#define MAVN_GLOBAL_READ_BIT      0x00080000
-#define MAVN_ENABLE_BIT         0x80000000
-#define MAVN_TEST_BIT           0x40000000
-#define MAVN_RANGE_NO_ACESS  0x00000000
-#define MAVN_PS_CODE_512     0x00000009
-#define MAVN_PS_CODE_1K      0x0000000a
-#define MAVN_PS_CODE_2K      0x0000000b
-#define MAVN_PS_CODE_4K      0x0000000c
-#define MAVN_PS_CODE_8K      0x0000000d
-#define MAVN_PS_CODE_16K     0x0000000e
-#define MAVN_PS_CODE_32K     0x0000000f
-#define MAVN_PS_CODE_64K     0x00000010
-#define MAVN_PS_CODE_128K    0x00000011
-#define MAVN_PS_CODE_256K    0x00000012
-#define MAVN_PS_CODE_512K    0x00000013
-#define MAVN_PS_CODE_1M      0x00000014
-#define MAVN_PS_CODE_2M      0x00000015
-** FPU Control Bits
-#define FPU_CNTRL_CONDITION   0x00800000
-#define FPU_CNTRL_EXCEPT_E    0x00020000
-#define FPU_CNTRL_EXCEPT_V    0x00010000
-#define FPU_CNTRL_EXCEPT_Z    0x00008000
-#define FPU_CNTRL_EXCEPT_O    0x00004000
-#define FPU_CNTRL_EXCEPT_U    0x00002000
-#define FPU_CNTRL_EXCEPT_I    0x00001000
-#define FPU_CNTRL_TRAP_V      0x00000800
-#define FPU_CNTRL_TRAP_Z      0x00000400
-#define FPU_CNTRL_TRAP_O      0x00000200
-#define FPU_CNTRL_TRAP_U      0x00000100
-#define FPU_CNTRL_TRAP_I      0x00000080
-#define FPU_CNTRL_STICKY_V    0x00000040
-#define FPU_CNTRL_STICKY_Z    0x00000020
-#define FPU_CNTRL_STICKY_O    0x00000010
-#define FPU_CNTRL_STICKY_U    0x00000008
-#define FPU_CNTRL_STICKY_I    0x00000004
-#define FPU_CNTRL_ROUND_RN    0x00000000
-#define FPU_CNTRL_ROUND_RZ    0x00000001
-#define FPU_CNTRL_ROUND_RP    0x00000002
-#define FPU_CNTRL_ROUND_RM    0x00000003
-#define FPU_EXCEPTIONS        FPU_CNTRL_TRAP_V|FPU_CNTRL_TRAP_Z|FPU_CNTRL_TRAP_O|FPU_CNTRL_TRAP_U|FPU_CNTRL_TRAP_I
-#define FPU_CONFIGURATION     FPU_EXCEPTIONS|FPU_CNTRL_ROUND_RN
-** Section 3 -- Masks
-#define UART_TX_BAUD_MASK       0x00007FFF
-#define UART_RX_BAUD_MASK       0x7FFF0000
-#define UART_DATA_MASK          0x000000FF
-#define UART_TX_BAUD_4800(x)    ((((x*1000000)/4800) - 1) & UART_TX_BAUD_MASK)
-#define UART_TX_BAUD_9600(x)    ((((x*1000000)/9600) - 1) & UART_TX_BAUD_MASK)
-#define UART_TX_BAUD_19200(x)   ((((x*1000000)/19200) - 1)& UART_TX_BAUD_MASK)
-#define UART_TX_BAUD_38400(x)   ((((x*1000000)/38400) - 1)& UART_TX_BAUD_MASK)
-#define UART_RX_BAUD_4800(x)    (((((x*1000000)/4800) - 1)  << 16) & UART_RX_BAUD_MASK)
-#define UART_RX_BAUD_9600(x)    (((((x*1000000)/9600) - 1)  << 16) & UART_RX_BAUD_MASK)
-#define UART_RX_BAUD_19200(x)   (((((x*1000000)/19200) - 1) << 16)& UART_RX_BAUD_MASK)
-#define UART_RX_BAUD_38400(x)   (((((x*1000000)/38400) - 1) << 16)& UART_RX_BAUD_MASK)
-#define UART_BAUD_4800(x)    ((((x*1000000)/4800) - 1) & UART_TX_BAUD_MASK) | (((((x*1000000)/4800) - 1)  << 16) & UART_RX_BAUD_MASK)
-#define UART_BAUD_9600(x)    ((((x*1000000)/9600) - 1) & UART_TX_BAUD_MASK) | (((((x*1000000)/9600) - 1)  << 16) & UART_RX_BAUD_MASK)
-#define UART_BAUD_19200(x)   ((((x*1000000)/19200) - 1)& UART_TX_BAUD_MASK) | (((((x*1000000)/19200) - 1) << 16)& UART_RX_BAUD_MASK)
-#define UART_BAUD_38400(x)   ((((x*1000000)/38400) - 1)& UART_TX_BAUD_MASK) | (((((x*1000000)/38400) - 1) << 16)& UART_RX_BAUD_MASK)
-#define EDAC_PARITY_MASK        0x000000FF
-#define MAVN_START_ADDR_MASK    0xFFFFFE00
-#define MAVN_PS_CODE_MASK       0x0000001F
-/* lr33000.h - defines for LSI Logic LR33000 */
-#ifdef LANGUAGE_C
-#define TIC1   (*((volatile unsigned long *)M_TIC1)) /* timer1 count */
-#define TC1    (*((volatile unsigned long *)M_TC1))  /* timer1 cntrl */
-#define TIC2   (*((volatile unsigned long *)M_TIC2)) /* timer2 count */
-#define TC2    (*((volatile unsigned long *)M_TC2))  /* timer2 cntrl */
-#define RTIC   (*((volatile unsigned long *)M_RTIC)) /* refrsh timer */
-#endif
-#define TC_IE    0x00000002 /* interrupt enable */
-#define TC_INT   0x00000001 /* interrupt request */
-/* lr33000.h */
-#define _LR33300_
-#define M_DRAM      0xfffe0120  /* DRAM config reg */
-#ifdef LANGUAGE_C
-#define SRAM        (*((volatile unsigned long *)M_SRAM))
-#define SPEC0       (*((volatile unsigned long *)M_SPEC0))
-#define SPEC1       (*((volatile unsigned long *)M_SPEC1))
-#define SPEC2       (*((volatile unsigned long *)M_SPEC2))
-#define SPEC3       (*((volatile unsigned long *)M_SPEC3))
-#define DRAM        (*((volatile unsigned long *)M_DRAM))
-#endif
-    /* wait-state config registers */
-#define SPC_INHIBITMASK (0xf<<24)
-#define SPC_EXTGNT  (1<<23)
-#define SPC_16WIDE  (1<<22)
-#define SPC_8WIDE   (1<<21)
-#define SPC_PENA    (1<<20)
-#define SPC_CACHED  (1<<19)
-#define SPC_CSDLYMASK   (3<<17)
-#define SPC_CSDLYSHFT   17
-#define SPC_BLKENA  (1<<16)
-#define SPC_BLKWAITMASK (7<<13)
-#define SPC_BLKWAITSHFT 13
-#define SPC_RECMASK (63<<7)
-#define SPC_WAITENA (1<<6)
-#define SPC_WAITMASK    (63<<0)
-    /* DCR */
-#define DRAM_DLP1   (1<<28)
-#define DRAM_SYNC   (1<<27)
-#define DRAM_SCFG   (1<<26)
-#define DRAM_DMARDY (1<<25)
-#define DRAM_DMABLKMASK (7<<22)
-#define DRAM_DMABLKSHFT 22
-#define DRAM_DPTHMASK   (3<<20)
-#define DRAM_DPTHSHFT   20
-#define DRAM_RDYW   (1<<19)
-#define DRAM_PGSZMASK   (7<<16)
-#define DRAM_PGSZSHFT   16
-#define DRAM_PGMW   (1<<15)
-#define DRAM_RFWEMASK   (3<<13)
-#define DRAM_RFWESHFT   13
-#define DRAM_RFEN   (1<<12)
-#define DRAM_RDYEN  (1<<11)
-#define DRAM_BFD    (1<<10)
-#define DRAM_PE     (1<<9)
-#define DRAM_RPCMASK    (3<<7)
-#define DRAM_RPCSHFT    7
-#define DRAM_RCDMASK    (3<<5)
-#define DRAM_RCDSHFT    5
-#define DRAM_CS     (1<<4)
-#define DRAM_CLMASK (7<<1)
-#define DRAM_CLSHFT 1
-#define DRAM_DCE    (1<<0)
-/* _LR33300_ */
-#define _ERNIE_CORE_
-#ifdef LANGUAGE_C
-#define BIU     (*((volatile unsigned long *)M_BIU))
-#define C0_TAR      6       /* target address register */
-#define C0_BDAM     9       /* breakpoint data addr mask */
-#define C0_BPCM     11      /* breakpoint instr addr mask */
-#else
-#endif
-    /* cause register */
-#define CAUSE_BT    (1<<30)     /* branch taken */
-    /* BIU */
-#define BIU_NOSTR   (1<<17)
-#define BIU_LDSCH   (1<<16)
-#define BIU_BGNT    (1<<15)
-#define BIU_NOPAD   (1<<14)
-#define BIU_RDPRI   (1<<13)
-#define BIU_INTP    (1<<12)
-#define BIU_IS1     (1<<11)
-#define BIU_IS0     (1<<10)
-#define BIU_IBLKSZMASK  (3<<8)
-#define BIU_IBLKSZSHFT  8
-#define BIU_IBLKSZ2 (0<<BIU_IBLKSZSHFT)
-#define BIU_IBLKSZ4 (1<<BIU_IBLKSZSHFT)
-#define BIU_IBLKSZ8 (2<<BIU_IBLKSZSHFT)
-#define BIU_IBLKSZ16    (3<<BIU_IBLKSZSHFT)
-#define BIU_DS      (1<<7)
-#define BIU_DS1     (1<<7)
-#define BIU_DS0     (1<<6)
-#define BIU_DBLKSZMASK  (3<<4)
-#define BIU_DBLKSZSHFT  4
-#define BIU_DBLKSZ2 (0<<BIU_DBLKSZSHFT)
-#define BIU_DBLKSZ4 (1<<BIU_DBLKSZSHFT)
-#define BIU_DBLKSZ8 (2<<BIU_DBLKSZSHFT)
-#define BIU_DBLKSZ16    (3<<BIU_DBLKSZSHFT)
-#define BIU_RAM     (1<<3)
-#define BIU_TAG     (1<<2)
-#define BIU_INV     (1<<1)
-#define BIU_LOCK    (1<<0)
-/* _ERNIE_CORE_ */
diff --git a/c/src/lib/libbsp/mips/genmongoosev/start/regs.h b/c/src/lib/libbsp/mips/genmongoosev/start/regs.h
index e63544f..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/start/regs.h
+++ /dev/null
@@ -1,148 +0,0 @@
- * regs.S -- standard MIPS register names from
- * newlib-1.8.2/libgloss/mips and adapted.
- * Copyright (c) 1995 Cygnus Support
- * The authors hereby grant permission to use, copy, modify, distribute,
- * and license this software and its documentation for any purpose, provided
- * that existing copyright notices are retained in all copies and that this
- * notice is included verbatim in any distributions. No written agreement,
- * license, or royalty fee is required for any of the authorized uses.
- * Modifications to this software may be copyrighted by their authors
- * and need not follow the licensing terms described here, provided that
- * the new terms are clearly indicated on the first page of each file where
- * they apply.
-/* Standard MIPS register names: */
-#define zero    $0
-#define z0  $0
-#define v0  $2
-#define v1  $3
-#define a0  $4
-#define a1  $5
-#define a2  $6
-#define a3  $7
-#define t0  $8
-#define t1  $9
-#define t2  $10
-#define t3  $11
-#define t4  $12
-#define t5  $13
-#define t6  $14
-#define t7  $15
-#define s0  $16
-#define s1  $17
-#define s2  $18
-#define s3  $19
-#define s4  $20
-#define s5  $21
-#define s6  $22
-#define s7  $23
-#define t8  $24
-#define t9  $25
-#define k0  $26 /* kernel private register 0 */
-#define k1  $27 /* kernel private register 1 */
-#define gp  $28 /* global data pointer */
-#define sp  $29 /* stack-pointer */
-#define fp  $30 /* frame-pointer */
-#define ra  $31 /* return address */
-#define pc  $pc /* pc, used on mips16 */
-#define fp0 $f0
-#define fp1 $f1
-#define WATCHDOG    0xBE000000
-/* Useful memory constants: */
-#ifndef __mips64
-   #define K1BASE       0xA0000000
-#else
-#define K1BASE      0xFFFFFFFFA0000000LL
-#endif
-#define PHYS_TO_K1(a)   ((unsigned)(a) | K1BASE)
-/* Standard Co-Processor 0 register numbers: */
-#define C0_DCIC     $7      /* debug & cache invalidate control */
-#define C0_COUNT    $9      /* Count Register */
-#define C0_SR           $12         /* Status Register */
-#define C0_CAUSE    $13     /* last exception description */
-#define C0_EPC      $14         /* Exception error address */
-#define C0_CONFIG   $16     /* CPU configuration */
-/* Standard Status Register bitmasks: */
-#define SR_CU1      0x20000000  /* Mark CP1 as usable */
-#define SR_FR       0x04000000  /* Enable MIPS III FP registers */
-#define SR_BEV      0x00400000  /* Controls location of exception vectors */
-#define SR_PE       0x00100000  /* Mark soft reset (clear parity error) */
-/* defined differently for Mongoose5- we don't use these anymore */
-#if UNUSED
-#define SR_KX     0x00000080  /* Kernel extended addressing enabled */
-#define SR_SX     0x00000040  /* Supervisor extended addressing enabled */
-#define SR_UX     0x00000020  /* User extended addressing enabled */
-#endif
-/* R3000 */
-/* Standard (R4000) cache operations. Taken from "MIPS R4000
-   Microprocessor User's Manual" 2nd edition: */
-#define CACHE_I     (0) /* primary instruction */
-#define CACHE_D     (1) /* primary data */
-#define CACHE_SI    (2) /* secondary instruction */
-#define CACHE_SD    (3) /* secondary data (or combined instruction/data) */
-#define INDEX_INVALIDATE        (0) /* also encodes WRITEBACK if CACHE_D or CACHE_SD */
-#define INDEX_LOAD_TAG          (1)
-#define INDEX_STORE_TAG         (2)
-#define CREATE_DIRTY_EXCLUSIVE      (3) /* CACHE_D and CACHE_SD only */
-#define HIT_INVALIDATE          (4)
-#define CACHE_FILL          (5) /* CACHE_I only */
-#define HIT_WRITEBACK_INVALIDATE    (5) /* CACHE_D and CACHE_SD only */
-#define HIT_WRITEBACK           (6) /* CACHE_I, CACHE_D and CACHE_SD only */
-#define HIT_SET_VIRTUAL         (7) /* CACHE_SI and CACHE_SD only */
-#define BUILD_CACHE_OP(o,c)     (((o) << 2) | (c))
-/* Individual cache operations: */
-#define INDEX_INVALIDATE_I      BUILD_CACHE_OP(INDEX_INVALIDATE,CACHE_I)
-#define INDEX_WRITEBACK_INVALIDATE_D    BUILD_CACHE_OP(INDEX_INVALIDATE,CACHE_D)
-#define INDEX_INVALIDATE_SI             BUILD_CACHE_OP(INDEX_INVALIDATE,CACHE_SI)
-#define INDEX_WRITEBACK_INVALIDATE_SD   BUILD_CACHE_OP(INDEX_INVALIDATE,CACHE_SD)
-#define INDEX_LOAD_TAG_I        BUILD_CACHE_OP(INDEX_LOAD_TAG,CACHE_I)
-#define INDEX_LOAD_TAG_D                BUILD_CACHE_OP(INDEX_LOAD_TAG,CACHE_D)
-#define INDEX_LOAD_TAG_SI               BUILD_CACHE_OP(INDEX_LOAD_TAG,CACHE_SI)
-#define INDEX_LOAD_TAG_SD               BUILD_CACHE_OP(INDEX_LOAD_TAG,CACHE_SD)
-#define INDEX_STORE_TAG_I               BUILD_CACHE_OP(INDEX_STORE_TAG,CACHE_I)
-#define INDEX_STORE_TAG_D               BUILD_CACHE_OP(INDEX_STORE_TAG,CACHE_D)
-#define INDEX_STORE_TAG_SI              BUILD_CACHE_OP(INDEX_STORE_TAG,CACHE_SI)
-#define INDEX_STORE_TAG_SD              BUILD_CACHE_OP(INDEX_STORE_TAG,CACHE_SD)
-#define CREATE_DIRTY_EXCLUSIVE_D        BUILD_CACHE_OP(CREATE_DIRTY_EXCLUSIVE,CACHE_D)
-#define CREATE_DIRTY_EXCLUSIVE_SD       BUILD_CACHE_OP(CREATE_DIRTY_EXCLUSIVE,CACHE_SD)
-#define HIT_INVALIDATE_I                BUILD_CACHE_OP(HIT_INVALIDATE,CACHE_I)
-#define HIT_INVALIDATE_D                BUILD_CACHE_OP(HIT_INVALIDATE,CACHE_D)
-#define HIT_INVALIDATE_SI               BUILD_CACHE_OP(HIT_INVALIDATE,CACHE_SI)
-#define HIT_INVALIDATE_SD               BUILD_CACHE_OP(HIT_INVALIDATE,CACHE_SD)
-#define CACHE_FILL_I                    BUILD_CACHE_OP(CACHE_FILL,CACHE_I)
-#define HIT_WRITEBACK_INVALIDATE_D      BUILD_CACHE_OP(HIT_WRITEBACK_INVALIDATE,CACHE_D)
-#define HIT_WRITEBACK_INVALIDATE_SD     BUILD_CACHE_OP(HIT_WRITEBACK_INVALIDATE,CACHE_SD)
-#define HIT_WRITEBACK_I                 BUILD_CACHE_OP(HIT_WRITEBACK,CACHE_I)
-#define HIT_WRITEBACK_D                 BUILD_CACHE_OP(HIT_WRITEBACK,CACHE_D)
-#define HIT_WRITEBACK_SD                BUILD_CACHE_OP(HIT_WRITEBACK,CACHE_SD)
-#define HIT_SET_VIRTUAL_SI      BUILD_CACHE_OP(HIT_SET_VIRTUAL,CACHE_SI)
-#define HIT_SET_VIRTUAL_SD              BUILD_CACHE_OP(HIT_SET_VIRTUAL,CACHE_SD)
-/*> EOF regs.S <*/
diff --git a/c/src/lib/libbsp/mips/genmongoosev/start/start.S b/c/src/lib/libbsp/mips/genmongoosev/start/start.S
index 190c2d1..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/start/start.S
+++ /dev/null
@@ -1,909 +0,0 @@
-** start.S -- startup file for Mongoose V BSP based upon crt0.S from
-** newlib-1.8.2/libgloss/mips and adapted for RTEMS.
-** crt0.S -- startup file for MIPS.
-** Copyright (c) 1995, 1996, 1997 Cygnus Support
-** The authors hereby grant permission to use, copy, modify, distribute,
-** and license this software and its documentation for any purpose, provided
-** that existing copyright notices are retained in all copies and that this
-** notice is included verbatim in any distributions. No written agreement,
-** license, or royalty fee is required for any of the authorized uses.
-** Modifications to this software may be copyrighted by their authors
-** and need not follow the licensing terms described here, provided that
-** the new terms are clearly indicated on the first page of each file where
-** they apply.
-** Modification History:
-**        01/XX/01  Joel Sherrill, OAR Corp,
-**           Modified for Mongoose V BSP for NASA/GSFC Code 582.
-**        06/XX/01  Greg Menke, Raytheon, Code 582
-**           Debug modifications. Removed R4000 dependencies.
-**           Added HACKED_PMON defines to facilitate startup.
-**           Added DEFAULT_EXIT_RETURN_TO_MONITOR option.
-**        11/14/01  A.Ferrer, NASA/GSFC, Code 582
-**           Cleanup for ST5 mission.
-**        11/27/01  A.Ferrer, NASA/GSFC, Code 582
-**           Added cache flush routines.
-#ifndef LANGUAGE_ASSEMBLY
-#define LANGUAGE_ASSEMBLY
-#endif
-#include <rtems/asm.h>
-#include <bsp/regs.h>
-#include "mg5.h"
-#ifdef __mips16
-   /* This file contains 32 bit assembly code.  */
-   .set nomips16
-#endif
-** defined by linkcmds, pointing to the start of the relocation target
-** memory, referenced in this way so we can avoid defining it
-** multiply
-   .bss
-   .word 0
-   .text
-   .align 2
-** Function: _start
-   /* Without the following nop, GDB thinks _start is a data variable.
-   ** This is probably a bug in GDB in handling a symbol that is at the
-   ** start of the .text section.
-    nop
-   .globl  _start
-   .ent    _start
-   .globl putch_rom
-_start:
-   .set    noreorder
-   $LF1 = . + 8
-   ** Get the address of start into $5 in a position independent fashion.
-   ** This lets us know whether we have been relocated or not.
-   bal     $LF1
-   nop
-_branch:
-   move    a1, ra      /* save return address from the jump above */
-   /* ensure we're sane before doing anything */
-   li      t0, SR_CU0|SR_PE
-   mtc0    t0, C0_SR
-   nop
-   li      t0, 0
-   mtc0    t0, C0_DCIC
-   nop
-   mtc0    t0, C0_CAUSE
-   nop
-   ** Call cpuinit. Masking used to call EEPROM address of _cpuinit.  Label is RAM label.
-   move   t2,a1
-   and    t2,0xffff0000
-   la     t0,_cpuinit
-   and    t0,0x0000ffff
-   or     t0,t2
-   jal    t0
-   nop
-   ** Configure UART
-   move   t2,a1
-   and    t2,0xffff0000
-   la     t0,config_uart
-   and    t0,0x0000ffff
-   or     t0,t2
-   jal    t0
-   nop
-   ** Print 'b'.  Show that we started.
-   move   t2,a1
-   and    t2,0xffff0000
-   li     a0,'b'
-   la     t0,putch_rom
-   and    t0,0x0000ffff
-   or     t0,t2
-   jal    t0
-   nop
-   li	k0,0
-   li   k1,0
-   move t1,a1
-   nop
-   li	t2,0xa0000000	/* lower limit of kseg1 */
-   li   t3,0xbfffffff	/* upper limit of kseg1 */
-   subu	t0,t1,t2
-   srl  t0,31		/* shift high bit down to bit 0 */
-   bnez t0,1f		/* booting from below kseg1 */
-   subu t0,t3,t1
-   bnez t0,1f		/* booting from above kseg1 */
-   ** Call IcacheFlush. Masking used to call EEPROM address of IcacheFlush.  Label is RAM label.
-   move   t2,a1
-   and    t2,0xffff0000
-   la     t0,IcacheFlush
-   and    t0,0x0000ffff
-   or     t0,t2
-   move	  k0,t0		/* save cache flush in-prom address */
-   jal    t0
-   nop
-   ** Print 'I'.  Show that we flushed I cache.
-   move   t2,a1
-   and    t2,0xffff0000
-   li     a0,'I'
-   la     t0,putch_rom
-   and    t0,0x0000ffff
-   or     t0,t2
-   jal    t0
-   nop
-   ** Call DcacheFlush. Masking used to call EEPROM address of DcacheFlush.  Label is RAM label.
-   move   t2,a1
-   and    t2,0xffff0000
-   la     t0,DcacheFlush
-   and    t0,0x0000ffff
-   or     t0,t2
-   jal    t0
-   nop
-   ** Print 'D'.  Show that we flushed D cache.
-   move   t2,a1
-   and    t2,0xffff0000
-   li     a0,'D'
-   la     t0,putch_rom
-   and    t0,0x0000ffff
-   or     t0,t2
-   move	  k1,t0		/* save cache flush in-prom address */
-   jal    t0
-   nop
-1:
-   ** Print ' RTEMS  b'.  Show that we are booting.
-   move   t2,a1
-   and    t2,0xffff0000
-   li     a0,' '
-   la     t0,putch_rom
-   and    t0,0x0000ffff
-   or     t0,t2
-   jal    t0
-   nop
-   move   t2,a1
-   and    t2,0xffff0000
-   li     a0,'R'
-   la     t0,putch_rom
-   and    t0,0x0000ffff
-   or     t0,t2
-   jal    t0
-   nop
-   move   t2,a1
-   and    t2,0xffff0000
-   li     a0,'T'
-   la     t0,putch_rom
-   and    t0,0x0000ffff
-   or     t0,t2
-   jal    t0
-   nop
-   move   t2,a1
-   and    t2,0xffff0000
-   li     a0,'E'
-   la     t0,putch_rom
-   and    t0,0x0000ffff
-   or     t0,t2
-   jal    t0
-   nop
-   move   t2,a1
-   and    t2,0xffff0000
-   li     a0,'M'
-   la     t0,putch_rom
-   and    t0,0x0000ffff
-   or     t0,t2
-   jal    t0
-   nop
-   move   t2,a1
-   and    t2,0xffff0000
-   li     a0,'S'
-   la     t0,putch_rom
-   and    t0,0x0000ffff
-   or     t0,t2
-   jal    t0
-   nop
-   move   t2,a1
-   and    t2,0xffff0000
-   li     a0,' '
-   la     t0,putch_rom
-   and    t0,0x0000ffff
-   or     t0,t2
-   jal    t0
-   nop
-   move   t2,a1
-   and    t2,0xffff0000
-   li     a0,'b'
-   la     t0,putch_rom
-   and    t0,0x0000ffff
-   or     t0,t2
-   jal    t0
-   nop
-   ** get the address of the _branch label above as it would appear in
-   ** the relocated code
-   la  a2, _branch                 /* relocation destination */
-   beq a1, a2, _start_in_ram       /* skip relocating if we're already there */
-   nop
-   /* relocate the code from EEPROM to RAM */
-   ** Print 'r'
-   move   t2,a1
-   and    t2,0xffff0000
-   li     a0,'r'
-   la     t0,putch_rom
-   and    t0,0x0000ffff
-   or     t0,t2
-   jal	  t0
-   nop
-   la		a3, _edata
-relocate:
-   lw		t0, (a1)            /* load from EEPROM */
-   addu		a1, 4
-   sw		t0, (a2)            /* store to RAM */
-   addu		a2, 4
-   bne		a2, a3, relocate    /* copied all the way to edata? */
-   nop
-   ** Print 'R'
-   li     a0,'R'
-   la     t0,putch_rom
-   and    t0,0x0000ffff
-   or     t0,t2
-   jal    t0
-   nop
-   la  a2, _start_in_ram
-   jr  a2
-   nop
-   .end _start
-** Function: _start_in_ram
-   .globl  _start_in_ram
-   .ent _start_in_ram
-_start_in_ram:
-   ** Print 'S'.  Already in RAM no need to reference EEPROM address.
-   li	a0,'S'
-   jal	putch_rom
-   nop
-   la	gp, _gp			/* set the global data pointer */
-   .end _start_in_ram
-** Function: zerobss
-   .globl  zerobss
-   .ent    zerobss
-zerobss:
-   ** Print 'z'.  Starting to zero out bss.
-   li a0,'z'
-   jal putch_rom
-   nop
-   la		v0, _fbss
-   la		v1, _end
-3:
-   sw		zero,0(v0)
-   bltu		v0,v1,3b
-   addiu	v0,v0,4               /* executed in delay slot */
-   la  t0, _stack_init         /* initialize stack so we */
-   ** We must subtract 24 bytes for the 3 8 byte arguments to main, in
-   ** case main wants to write them back to the stack.  The caller is
-   ** supposed to allocate stack space for parameters in registers in
-   ** the old MIPS ABIs.  We must do this even though we aren't passing
-   ** arguments, because main might be declared to have them.
-   ** Some ports need a larger alignment for the stack, so we subtract
-   ** 32, which satisifes the stack for the arguments and keeps the
-   ** stack pointer better aligned.
-   subu    t0,t0,32
-   move    sp,t0               /* set stack pointer */
-   nop
-   ** Print 'Z'.  Finished zeroing bss.
-   li	a0,'Z'
-   jal	putch_rom
-   nop
-   .end    zerobss
-** Function: _init
-   .globl  exit .text
-   .globl  _initialize_rtems
-   .ent    _initialize_rtems
-_initialize_rtems:
-   ** Print 'i'.  Starting to initialize RTEMS.
-   li		a0, 'i'
-   jal		putch_rom
-   nop
-   ** Save the boot-time addresses of the I & D cache flush routines.
-   ** Note, if we're running from RAM, we cannot manipulate the cache
-   ** so we just disable the cache flush functions.
-   la		a0,_promIcache
-   sw		k0,0(a0)
-   nop
-   la		a0,_promDcache
-   sw		k1,0(a0)
-   nop
-   move		a0,zero         /* set command line to 0 */
-   jal		boot_card           /* call the program start function */
-   nop
-   ** fall through to the "exit" routine
-   jal _sys_exit
-   nop
-   .end _initialize_rtems
-** Function: _sys_exit
-** Exit from the application by jumping to PMON address in EEPROM.
-   .globl  _sys_exit
-   .ent _sys_exit
-_sys_exit:
-   la  t0, PMON_ADDRESS
-   jal t0
-   .end _sys_exit
-** function: putch
-** input   : ASCII character in A0
-** registers used: ra, a0, t0, t1
-   .globl putch_rom
-   .ent   putch_rom
-putch_rom:
-   ** Delay for UART
-   li   t0, 1000
-   move t1, zero
-2:
-   beq  t0, t1, 3f
-   addu t1, 1
-   b    2b
-   nop
-3:
-   ** Print a character out from a0
-   li   t0, MG5_INT_STATUS_REG      /* load uart register base address */
-   lw   t1, 0(t0)                   /* Read status */
-   nop
-   and  t1, t1, UART_0_TX_READY_BIT /* see if the transmitter is ready */
-   beq  t1 , zero , 1f              /* skip uart output if not ready */
-   nop
-   la   t0, MG5_UART_0_TX_REG
-   sw   a0, 0(t0)
-   nop
-1: /*
-   ** if jumped to here, UART was not ready...forget it
-   j    ra
-  .end putch_rom
-** function: config_uart
-** registers used: ra, t0, t1
-   .globl config_uart
-   .ent   config_uart
-config_uart:
-   **  Configure UART 0
-   /* First, reset the uart */
-   la   t0, MG5_COMMAND_REG
-   li   t1, UART_RESET_BIT
-   sw   t1, 0(t0)
-   /* Next, set the baud rate register for 19200 with a clock speed of 12 Mhz*/
-   la   t0, MG5_UART_0_BAUD_REG
-   li   t1, 0x02700270
-   sw   t1, 0(t0)
-   /* Now, clear the reset bit & set the tx enable bit */
-   li   t1, UART_0_TX_ENABLE_BIT
-   sw   t1, 0(t0)
-   ** return
-   j    ra
-.end config_uart
-* CpuInit:
-*   Perform CPU-specific initialization
-*   This routine is only callable from assembly because it
-*   clobbers s7. It should be called from your ROM-based startup
-*   code. It returns:
-*       s0 = address of cache flush routine
-   .globl  _cpuinit
-   .ent _cpuinit
-_cpuinit:
-   ** BIU/Cache config register setup
-   ** RES    = 0: 31 -> 18 : Reserved
-   ** RES    = 1: 17       : Reserved must be set to 1 (Synova Manual)
-   ** RES    = 0: 16       : Reserved must be set to 0 (Synova Manual)
-   ** BGNT   = 0: 15       : Disable Bus Grant (set to 0)
-   ** NOPAD  = 1: 14       : No padding of waitstates between transactions
-   ** RDPRI  = 1: 13       : Loads have priority over stores
-   ** INTP   = 1: 12       : Interrupts are active high
-   ** IS1    = 1: 11       : Enable I-Cache
-   ** IS0    = 0: 10       : Hardwired to zero
-   ** IBLKSZ =10:  9 ->  8 : I-Cache refill size = 8 words
-   ** DS     = 1:  7       : Enable D-Cache
-   ** RES    = 0:  6       : Hardwared to zero
-   ** DBLKSZ =10:  5 ->  4 : D-Cache refill block size 8 words
-   ** RAM    = 0:  3       : No Scratchpad RAM
-   ** TAG    = 0:  2       : Disable tag test
-   ** INV    = 0:  1       : Disable invalidate mode
-   ** LOCK   = 0:  0       : Disable cache lock
-   ** 0x00027AA0 caches on
-   ** 0x00027220 caches off
-   li  t0,0x00027aa0
-   sw  t0,M_BIU
-   ** Refresh register setup
-   ** set 94 clock cycles at 12Mhz
-   li  t1,M_RTIC
-   li  t0,0x5E
-   sw  t0,(t1)
-   ** DRAM register setup
-   ** RESERVED=0: 31 -> 29 : Reserved
-   ** SYNC  = 0 : 27       : No Syncronous DRAM
-   ** SCFG  = 0 : 26       : No Syncronous DRAM
-   ** DMARDY =1 : 25       : Internal DRDY for DMA
-   ** DMABLK =0 : 24 -> 22 : 2 word blk size for DMA transfers
-   ** DPTH = 0  : 21 -> 20 : No interleaved or syncronous memory
-   ** RDYW = 0  : 19       : No interleaved or syncronous memory
-   ** PGSZ = 110: 18 -> 16 : Page size = 1K
-   ** PGMW = 0  : 15       : Disable page mode write
-   ** RFWE = 0  : 14 -> 13 : Allow BIU to do non-DRAM work during refresh
-   ** RFEN = 1  : 12       : Enable Refresh generator
-   ** RDYEN = 1 : 11       : Internal DRDY
-   ** BFD =   1 : 10       : Block fetch disable
-   ** PE =    0 : 9        : No parity checking
-   ** RPC =   0 : 8 -> 7   : RAS Precharge = 2 SYSCLK cycles
-   ** RCD =   1 : 6 -> 5   : RAS-to-CAS delay = 3 cycles
-   ** CS  =   0 : 4        : CAS shortened by 1/2 cycle
-   ** CL  =   1 : 3 -> 1   : 2.5 cycle CAS pulse width
-   ** DCE =   1 : 0        : Enable DRAM controller
-   li  s0,0x02061C23
-   sw  s0,M_DRAM
-   ** SRAM setup
-   ** Dont Care about this, we are not using SRAM
-   ** Power on default of 0x0 is ok
-   li  t0,0
-   sw  t0,M_SRAM
-   ** SPEC0 setup
-   ** SPEC0 contains the BCRT registers, BCRT Shared RAM and EEPROM
-   ** This area is configured to use an external waitstate generator
-   ** and Data Ready signal.
-   ** Also, I see no need to cache this data. It could confuse the
-   ** BCRT.
-   ** - 9/29/99 - APC - set NOSNOOP to 1 and EXTGNT to 1
-   **  Bit 23 = 1 : EXTGNT External data ready = 1
-   **  Bit 19 = 1 : NOSNOOP No Snoop = 1
-   li  t0,0x00880000         # use external waitstates
-   sw  t0,M_SPEC0
-   ** SPEC1 setup
-   ** This is where most of the SDB I/O is.
-   **  Important fields:
-   **  Bit 19 =1 : NOSNOOP = 1
-   **  Bit 6 = 1 : Enable DAWG
-   **  Bit 5 -> 0  = 1 : 1 Wait state
-   li  t0,0x00880000      /* Bit23 EXTGNT set to 1, Bit19 NOSNOOP set to 1 */
-   sw  t0,M_SPEC1
-   ** SPEC2 setup
-   ** SPEC2 is not currently used on the SDB.
-   ** Bit 19 = 1 : NOSNOOP = 1
-   **li t0, 0x00080000
-   **sw t0,M_SPEC2
-   li  t0, 0x0
-   sw  t0,M_SPEC2
-   ** SPEC3 Setup
-   ** SPEC3 will be used for the SONIC ethernet controller.
-   ** Use the same ** of waitstates that the turborocket board uses.
-   **li t0, (SPC_CACHED | SPC_WAITENA | (16<<SPC_WAITSHFT))
-   **sw t0,M_SPEC3
-   li  t0, 0x0
-   sw  t0,M_SPEC3
-   ** Finally, delay to allow RAM to stabilize
-   li  t0,2000
-1: subu    t0,1
-   bne t0,zero,1b
-   nop
-   ** Init Mongoose V registers.
-   ** Mongoose V Control Register Setup
-   ** For now just setup UART defaults, turn edac off.
-   ** May not even need to put anything in here...
-   li  t0,0
-   sw  t0,MG5_COMMAND_REG
-   ** Setup Mongoose V extended interrupt mask
-   li  t0,0
-   sw  t0,MG5_INT_MASK_REG
-   ** Clear Mongoose V extended interrupts
-   ** Clear all of the pulse interrupts that may be pending.
-   li  t0,( EDAC_SERR_BIT | EDAC_MERR_BIT | UART_0_RX_OVERRUN_BIT | UART_0_FRAME_ERR_BIT | UART_1_RX_OVERRUN_BIT | UART_1_FRAME_ERR_BIT | MAVN_WRITE_ACC_BIT | MAVN_READ_ACC_BIT )
-   sw  t0,MG5_INT_STATUS_REG
-   ** Setup MAVN Access Priv Register
-   li  t0,0x7FFFFFFF  /* Default reset value */
-   sw  t0,MG5_MAVN_PRIVLEGE_REG
-   ** Mavn Range Register 0 -- 0 and 1 cover EEPROM
-   ** 0xbfc00000 -> 0xbfe00000
-   li  t0,( 0xBFC00000 | 0x15 )
-   sw  t0,MG5_MAVN_RANGE_0_REG
-   ** Mavn Range Register 1
-   ** 0xbfe00000 -> 0xc0000000
-   li  t0,( 0xBFE00000 | 0x15 )
-   sw  t0,MG5_MAVN_RANGE_1_REG
-   ** Mavn Range Register 2 -- 2 and 3 cover the first RAM
-   ** 0x80000000 -> 0x80200000
-   li  t0,( 0x80000000 | 0x15 )
-   sw  t0,MG5_MAVN_RANGE_2_REG
-   ** Mavn Range Register 3
-   ** 0x80200000 -> 0x80400000
-   li  t0, ( 0x80200000 | 0x15 )
-   sw  t0, MG5_MAVN_RANGE_3_REG
-   ** Mavn Range Register 4 -- IO Space 1
-   ** 0xBE00000 -> 0xBe0000200
-   li  t0, ( 0xBe000000 | 0x09 )
-   sw  t0, MG5_MAVN_RANGE_4_REG
-   ** Mavn Range Register 5 -- IO Space 2
-   ** 0xBe200000 -> 0xbe400000
-   li  t0, ( 0xBE200000 | 0x15 )
-   sw  t0, MG5_MAVN_RANGE_5_REG
-   ** MAVN Error Address Register ( Unstick )
-   la      t0, MG5_MAVN_VIOLATION_REG
-   lw      t1, 0(t0)
-   ** Read EDAC Error Register to unstick it
-   la      t0, MG5_EDAC_ADDR_REG
-   lw      t1, 0(t0)
-   ** Enable Mongoose V EDAC
-   li      t1, EDAC_ENABLE_BIT
-   sw      t1, 0(t0)
-   nop
-   ** Program Watchdog to 10 seconds - If PMON will
-   ** run, it will be set to MAX later.
-   la      t0, 0xBE000000
-   li      t1, 0xA0
-   sw      t1, 0(t0)
-3: nop
-   j ra
-   .end _cpuinit
-** Keep the boot-time address of the I & D cache reset code for
-** later on.  If we need to clear the I/D caches, we <must> run from
-** non-cached memory.  This means the relocated versions are useless,
-** thankfully they are quite small.
-_promIcache:	.word 0
-_promDcache:	.word 0
-	.globl promCopyIcacheFlush
-	.ent promCopyIcacheFlush
-	.set noreorder
-promCopyIcacheFlush:
-	move	a0,ra
-	la	t1,_promIcache
-	lw	t0,0(t1)
-	nop
-	beqz	t0,1f
-	jal	t0
-	nop
-1:	j	a0
-	nop
-	.set reorder
-	.end promCopyIcacheFlush
-	.globl promCopyDcacheFlush
-	.ent promCopyDcacheFlush
-	.set noreorder
-promCopyDcacheFlush:
-	move	a0,ra
-	la	t1,_promDcache
-	lw	t0,0(t1)
-	nop
-	beqz	t0,1f
-	jal	t0
-	nop
-1:	j	a0
-	nop
-	.set reorder
-	.end promCopyDcacheFlush
-** Function Name:   IcacheFlush
-** Description:     This functions flushes the on chip icache.
-     .ent IcacheFlush
-     .set noreorder
-IcacheFlush:
-1:
-     ** Assume I cache is already enabled in BIU/Cache setup
-     ** Get contents of M_BIU register and save in t1
-     li        t0, M_BIU
-     lw        t1, 0(t0)
-     ** Isolate I cache
-     mfc0      t3, C0_SR        /* Read Status Register */
-     nop
-     or        t0, t3, SR_ISC   /* Isolate Cache so we don't propagate operations */
-     mtc0      t0, C0_SR        /* Write it back to Status Register */
-     nop
-     ** Setup for cache flush
-     li        t8, 0            /* Store zero */
-     li        t9, LR33300_IC_SIZE
-icache_write:
-     sw        zero, 0(t8)          /* Store zero to memory addres in t8 */
-     addu      t8, 4                /* Increment t8 address by 4 */
-     bltu      t8, t9, icache_write /* check to see if we are done */
-     nop
-     ** De-isolate I cache
-     mtc0      t3, C0_SR        /* Load unchanged t3 to Status Register */
-     nop
-     jal       ra
-     nop
-     .set reorder
-     .end IcacheFlush
-** Function Name:   DcacheFlush
-** Description:     This functions flushes the on chip dcache.
-     .ent DcacheFlush
-     .set noreorder
-DcacheFlush:
-     ** isolate icache
-     mfc0      t3,C0_SR
-     nop
-     or        t0, t3, SR_ISC
-     mtc0      t0, C0_SR
-     nop
-     ** Setup up for cache flush
-     li        t8, 0
-     li        t9, LR33300_DC_SIZE
-dcache_write:
-     sw        zero, 0(t8)
-     addu      t8, 4
-     bltu      t8, t9, dcache_write /* check to see if we are done */
-     nop
-     ** De-isolate cache
-     mtc0      t3, C0_SR
-     nop
-     jal       ra
-     nop
-     .set reorder
-     .end DcacheFlush
-/* EOF start.S */
diff --git a/c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c b/c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c
index a8dd2cb..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c
+++ /dev/null
@@ -1,97 +0,0 @@
- *  @file
- *  This routine starts the application.  It includes application,
- *  board, and monitor specific initialization and configuration.
- *  The generic CPU dependent initialization has been performed
- *  before this routine is invoked.
- *  Modification History:
- *        12/10/01  A.Ferrer, NASA/GSFC, Code 582
- *           Set interrupt mask to 0xAF00 (Line 139).
- *  COPYRIGHT (c) 1989-2012.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#include <string.h>
-#include <bsp.h>
-#include <bsp/mongoose-v.h>
-#include <libcpu/isr_entries.h>
-void bsp_start( void );
-void clear_cache( void );
-extern void _sys_exit(int);
-extern void mips_gdb_stub_install(void);
- *  bsp_start
- *  This routine does the bulk of the system initialization.
- /* mask off any interrupts */
- MONGOOSEV_WRITE( MONGOOSEV_PERIPHERAL_FUNCTION_INTERRUPT_MASK_REGISTER, 0 );
- /* reset the config register & clear any pending peripheral interrupts */
- MONGOOSEV_WRITE( MONGOOSEV_PERIPHERAL_COMMAND_REGISTER, 0 );
- MONGOOSEV_WRITE(
-   MONGOOSEV_PERIPHERAL_COMMAND_REGISTER, MONGOOSEV_UART_CMD_RESET_BOTH_PORTS );
- /* reset both timers */
- MONGOOSEV_WRITE_REGISTER(
-   MONGOOSEV_TIMER1_BASE, MONGOOSEV_TIMER_INITIAL_COUNTER_REGISTER, 0xffffffff);
-   MONGOOSEV_TIMER1_BASE, MONGOOSEV_TIMER_CONTROL_REGISTER, 0);
-   MONGOOSEV_TIMER2_BASE, MONGOOSEV_TIMER_INITIAL_COUNTER_REGISTER, 0xffffffff);
-   MONGOOSEV_TIMER2_BASE, MONGOOSEV_TIMER_CONTROL_REGISTER, 0);
- /* clear any pending interrupts */
- MONGOOSEV_WRITE( MONGOOSEV_PERIPHERAL_STATUS_REGISTER, 0xffffffff );
- /* clear any writable bits in the cause register */
- mips_set_cause( 0 );
- /* set interrupt mask, but globally off. */
-  *  Bit 15 | Bit 14 | Bit 13 | Bit 12 | Bit 11 | Bit 10 | Bit  9 | Bit  8 |
-  *  periph | unused |  FPU   | unused | timer2 | timer1 | swint1 | swint2 |
-  *  extern |        |        |        |        |        |        |        |
-  *    1        0        1        0        0        1        0        0
-  *    0x8C00   Enable only internal Mongoose V timers.
-  *    0xA400   Enable Peripherial ints, FPU and timer1
-  *    0x0400   Timer1 only
-  /* mips_set_sr( (SR_CU0 | SR_CU1 | 0xA400) ); */
-  /* to start up, only enable coprocessor 0 & timer int. per-task
-   * processor settings will be applied as they are created, this
-   * is just to configure the processor for startup
-  mips_set_sr( (SR_CU0 | 0x400) );
-  bsp_interrupt_initialize();
-   promCopyIcacheFlush();
-   promCopyDcacheFlush();
diff --git a/c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c b/c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c
index 6d064de..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c
+++ /dev/null
@@ -1,145 +0,0 @@
- *  GDB Support Routines for the Mongoose-V
- *  COPYRIGHT (c) 1989-2014.
-#include <bsp.h>
-#include "gdb_if.h"
-#include <rtems/libio.h>
-#include <stdio.h>
-We're going to call right down into the uart driver because we're
-operating within an exception.  if things are broken because something
-bad happened, this may be our last chance to debug before RTEMS goes
-mad, so we won't rely on the I/O subsystem to be operating.  This is a
-little messy, but at least we're not talking right to the hardware.
-extern int mg5uart_set_attributes(int minor,const struct termios *t);
-extern int mg5uart_open(int major,int minor, void *arg);
-extern int mg5uart_close(int major,int minor, void *arg);
-extern void mg5uart_write_polled(int minor, char c );
-extern int mg5uart_inbyte_nonblocking_polled(int minor);
- *  Prototypes for methods assumed to exist by the gdb stub
-char getDebugChar (void);
-void putDebugChar (char c);
-static int debugUartEnabled = 0;
-int mg5rdbgOpenGDBuart(int breakoninit)
-   struct termios t;
-   memset(&t,0,sizeof(struct termios));
-   if( mg5uart_open(0,1,NULL) != RTEMS_SUCCESSFUL )
-      printf("gdbstub: Failed to open UART port 2\n");
-      return -1;
-   t.c_cflag |= B19200;
-   t.c_cflag |= CS8;
-   if( mg5uart_set_attributes(1,&t) != 0 )
-      printf("gdbstub: Failed to configure UART 2 for 19200N82\n");
-      return -1;
-   printf("gdbstub: UART 2 configured for 19200N82\n");
-   debugUartEnabled  = -1;
-   /* set up vectoring for gdb */
-   mips_gdb_stub_install(-1);
-      this is a rough approximation of our memory map.  Yours is
-      probably different.  It only needs to be sufficient for the stub
-      to know what it can and can't do and where.
-   gdbstub_add_memsegment(0         , 0x8001ffff, MEMOPT_READABLE );
-   gdbstub_add_memsegment(0x80020000, 0x80afffff, MEMOPT_READABLE | MEMOPT_WRITEABLE );
-   gdbstub_add_memsegment(0x80b00000, 0x814fffff, MEMOPT_READABLE );
-   gdbstub_add_memsegment(0x81500000, 0x81ffffff, MEMOPT_READABLE | MEMOPT_WRITEABLE );
-   if( breakoninit )
-      printf("gdbstub: GDB stub entered, connect host debugger now\n");
-         break to gdb.  We'll wait there for the operator to get their gdb
-         going, then they can 'continue' or do whatever.
-      mips_break(0);
-      printf("gdbstub: User code running\n");
-   else
-      printf("gdbstub: GDB stub ready for exceptions\n");
-   return RTEMS_SUCCESSFUL;
-void mg5rdbgCloseGDBuart(void)
-   mg5uart_close(0,1,NULL);
-   debugUartEnabled  = 0;
-   if( debugUartEnabled )
-      int rv;
-      while( (rv = mg5uart_inbyte_nonblocking_polled(1)) < 0 );
-      return (char)rv;
-   return 0;
-      return mg5uart_write_polled(1,c);
-      * initialize hardware pc and data breakpoints to quiet state*
-      uint32_t   dcic, reg, mask;
-      reg = 0xffffffff;
-      mask = 0xffffffff;
-      mips_set_bpcrm( reg, mask );
-      mips_set_bdarm( reg, mask );
-      mips_get_dcic( dcic );
-      * configure dcic for trapping, user & kernel mode, PC traps and enable it *
-      dcic = DCIC_TR | DCIC_UD | DCIC_KD | DCIC_PCE | DCIC_DE;
-      * dcic = DCIC_UD | DCIC_KD | DCIC_PCE | DCIC_DE; *
-      mips_set_dcic( dcic );
-      mips_get_bpcrm( reg, mask );
-      * printf("bpc is %08X, bpc_mask is %08X, dcic is now %08X\n", reg, mask, dcic ); *
diff --git a/c/src/lib/libbsp/mips/genmongoosev/startup/linkcmds b/c/src/lib/libbsp/mips/genmongoosev/startup/linkcmds
index e396379..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/startup/linkcmds
+++ /dev/null
@@ -1,228 +0,0 @@
- *  Linker script for Mongoose-V prototyping board.
- *  See README for address map details.
-/*    . = 0x80020000; */
- * Declare some sizes.
-RamBase = DEFINED(RamBase) ? RamBase : 0x80000000;
-RamSize = DEFINED(RamSize) ? RamSize : 32M;
-HeapSize = DEFINED(HeapSize) ? HeapSize : 0x0;
-_StackSize = DEFINED(_StackSize) ? _StackSize : 0x4000;
-ClockRate = DEFINED(ClockRate) ? ClockRate : 12000000;
-MEMORY
-   ram      : ORIGIN = 0x80020000, LENGTH = 4M
-SECTIONS
-    .text :
-       _ftext = . ;
-      */start.o(.text)
-      *(.text*)
-      *(.gnu.linkonce.t*)
-      *(.mips16.fn.*)
-      *(.mips16.call.*)
-      *(.reginfo)
-      PROVIDE (__runtime_reloc_start = .);
-      *(.rel.sdata)
-      *(.rel.dyn)
-      PROVIDE (__runtime_reloc_stop = .);
-       * Special FreeBSD sysctl sections.
-      . = ALIGN (16);
-      __start_set_sysctl_set = .;
-      *(set_sysctl_*);
-      __stop_set_sysctl_set = ABSOLUTE(.);
-      *(set_domain_*);
-      *(set_pseudo_*);
-      *(.gcc_except_table*)
-      *(.eh_frame_hdr)
-      *(.eh_frame)
-    } >ram
-  .init :
-     KEEP(*(.init))
-  } > ram
-  .fini :
-     KEEP(*(.fini))
-  }  > ram
-  .ctors    :
-    /* gcc uses crtbegin.o to find the start of
-       the constructors, so we make sure it is
-       first.  Because this is a wildcard, it
-       doesn't matter if the user does not
-       actually link against crtbegin.o; the
-       linker won't look for a file to match a
-       wildcard.  The wildcard also means that it
-       doesn't matter which directory crtbegin.o
-       is in.  */
-    KEEP (*crtbegin.o(.ctors))
-    /* We don't want to include the .ctor section from
-       from the crtend.o file until after the sorted ctors.
-       The .ctor section from the crtend file contains the
-       end of ctors marker and it must be last */
-    KEEP (*(EXCLUDE_FILE (*crtend.o) .ctors))
-    KEEP (*(SORT(.ctors.*)))
-    KEEP (*(.ctors))
-  } >ram
-  .dtors    :
-    KEEP (*crtbegin.o(.dtors))
-    KEEP (*(EXCLUDE_FILE (*crtend.o) .dtors))
-    KEEP (*(SORT(.dtors.*)))
-    KEEP (*(.dtors))
-    etext  =  .;
-    _etext  =  .;
-  } >ram
-  .rdata :
-    *(.rdata)
-    *(.rodata)
-    *(.rodata.*)
-    KEEP (*(SORT(.rtemsroset.*)))
-    *(.gnu.linkonce.r*)
-  } >ram
-  .tdata : {
-    _TLS_Data_begin = .;
-    *(.tdata .tdata.* .gnu.linkonce.td.*)
-    _TLS_Data_end = .;
-  } >ram
-  .tbss : {
-    _TLS_BSS_begin = .;
-    *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
-    _TLS_BSS_end = .;
-  } >ram
-  _TLS_Data_size = _TLS_Data_end - _TLS_Data_begin;
-  _TLS_Data_begin = _TLS_Data_size != 0 ? _TLS_Data_begin : _TLS_BSS_begin;
-  _TLS_Data_end = _TLS_Data_size != 0 ? _TLS_Data_end : _TLS_BSS_begin;
-  _TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
-  _TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
-  _TLS_Alignment = MAX (ALIGNOF (.tdata), ALIGNOF (.tbss));
-  .data :
-    _fdata = ALIGN(16);
-    *(.data)
-    *(.data.*)
-    KEEP (*(SORT(.rtemsrwset.*)))
-    *(.gnu.linkonce.d*)
-  } >ram
-  .jcr :
-    . = ALIGN(8);
-    KEEP (*(.jcr))
-    _gp = ALIGN(16) + 0x7440;
-    __global = _gp;
-  } >ram
-  .lit8 :
-    *(.lit8)
-  } >ram
-  .lit4 :
-    *(.lit4)
-  } >ram
-  .sdata :
-    *(.sdata*)
-    *(.gnu.linkonce.s*)
-  } >ram
-  .sbss :
-   edata  =  .;
-   _edata  =  .;
-   _fbss = .;
-    *(.sbss*)
-    *(.scommon)
-  } >ram
-  .bss :
-    _bss_start = . ;
-    *(.bss .bss.* .gnu.linkonce.b.*)
-    *(COMMON)
-    . = ALIGN (64);
-    _stack_limit = .;
-    . += _StackSize;
-    __stack = .;
-    _stack_init = .;
-    _clear_end = .;
-    WorkAreaBase = .;
-    end = .;
-    _end = .;
-  } >ram
-** DWARF debug sections.
-** Symbols in the DWARF debugging sections are relative to
-** the beginning of the section so we begin them at 0.
-  /* DWARF 1 */
-  .debug          0 : { *(.debug) }
-  .line           0 : { *(.line) }
-  /* GNU DWARF 1 extensions */
-  .debug_srcinfo  0 : { *(.debug_srcinfo) }
-  .debug_sfnames  0 : { *(.debug_sfnames) }
-  /* DWARF 1.1 and DWARF 2 */
-  .debug_aranges  0 : { *(.debug_aranges) }
-  .debug_pubnames 0 : { *(.debug_pubnames) }
-  /* DWARF 2 */
-  .debug_info     0 : { *(.debug_info) }
-  .debug_abbrev   0 : { *(.debug_abbrev) }
-  .debug_line     0 : { *(.debug_line) }
-  .debug_frame    0 : { *(.debug_frame)}
-  .debug_str      0 : { *(.debug_str) }
-  .debug_loc      0 : { *(.debug_loc) }
-  .debug_macinfo  0 : { *(.debug_macinfo) }
-  /* SGI/MIPS DWARF 2 extensions */
-  .debug_weaknames 0 : { *(.debug_weaknames) }
-  .debug_funcnames 0 : { *(.debug_funcnames) }
-  .debug_typenames 0 : { *(.debug_typenames) }
-  .debug_varnames  0 : { *(.debug_varnames) }
diff --git a/c/src/lib/libbsp/mips/genmongoosev/timer/timer.c b/c/src/lib/libbsp/mips/genmongoosev/timer/timer.c
deleted file mode 100644
index a956c4b..0000000
--- a/c/src/lib/libbsp/mips/genmongoosev/timer/timer.c
+++ /dev/null
@@ -1,93 +0,0 @@
- *  This file implements a benchmark timer using a MONGOOSE-V timer.
- *  COPYRIGHT (c) 1989-2001.
-#include <assert.h>
-#include <bsp.h>
-#include <rtems/btimer.h>
-bool benchmark_timer_find_average_overhead;
-#if defined(USE_TIMER2_FOR_CLOCK)
-#define TIMER_BASE   MONGOOSEV_TIMER1_BASE
-#define TIMER_VECTOR MONGOOSEV_IRQ_TIMER1
-#else
-#define TIMER_BASE   MONGOOSEV_TIMER2_BASE
-#define TIMER_VECTOR MONGOOSEV_IRQ_TIMER2
-#endif
-void benchmark_timer_initialize(void)
-   *  Programming the compare register as the maximum value should let
-   *  it run long enough and accurate enough not to require an interrupt.
-   *  but if it ever does generate an interrupt, we will simply fault.
-   *  NOTE:  This is similar to the clock driver initialization
-   *         with the exception that the divider is disabled and
-   *         the compare register is set to the maximum value.
-   MONGOOSEV_WRITE_REGISTER( TIMER_BASE, MONGOOSEV_TIMER_CONTROL_REGISTER, 0);
-			     MONGOOSEV_TIMER_INITIAL_COUNTER_REGISTER,
-			     0xffffffff );
-			     MONGOOSEV_TIMER_CONTROL_REGISTER,
-			     MONGOOSEV_TIMER_CONTROL_COUNTER_ENABLE );
-#define AVG_OVERHEAD      0  /* It typically takes N instructions */
-                             /*     to start/stop the timer. */
-#define LEAST_VALID       1  /* Don't trust a value lower than this */
-                             /* mongoose-v can count cycles. :) */
-benchmark_timer_t benchmark_timer_read(void)
-  uint32_t          clicks;
-  uint32_t          total;
-  uint32_t          tcr;
-  clicks = MONGOOSEV_READ_REGISTER( TIMER_BASE,
-				    MONGOOSEV_TIMER_INITIAL_COUNTER_REGISTER );
-  total = 0xffffffff - clicks;
-  tcr = MONGOOSEV_READ_REGISTER( TIMER_BASE, MONGOOSEV_TIMER_CONTROL_REGISTER );
-			    0 );
-  if ( tcr & MONGOOSEV_TIMER_CONTROL_TIMEOUT )
-    printk( "MG5 timer overran\n" );
-  if ( benchmark_timer_find_average_overhead == true )
-    return total;          /* in cycle units */
-  if ( total < LEAST_VALID )
-    return 0;            /* below timer resolution */
-  return (total - AVG_OVERHEAD) / CPU_CLOCK_RATE_MHZ;
-void benchmark_timer_disable_subtracting_average_overhead(
-  bool find_flag
-  benchmark_timer_find_average_overhead = find_flag;
-/* eof */
2.1.4
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
