[PATCH] rtems/bit_all_bsps: Remove genmongoosev reference
Aun-Ali Zaidi admin at kodeit.net
Mon Dec 14 05:41:34 UTC 2015
closes #2448.
 rtems/bit_all_bsps | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/rtems/bit_all_bsps b/rtems/bit_all_bsps
index 4ffdafd..a4f9d7c 100755
--- a/rtems/bit_all_bsps
+++ b/rtems/bit_all_bsps
@@ -142,7 +142,7 @@ get_bsps()
                all_bsps="${all_bsps} gen68302 csb360 simcpu32 mrm332 av5282"
                all_bsps="${all_bsps} gen68340 mcf5235 idp pgh360"
                all_bsps="${all_bsps} m5484FireEngine" ;;
-      mips)    all_bsps="jmr3904 genmongoosev csb350 hurricane"
+      mips)    all_bsps="jmr3904 csb350 hurricane"
                all_bsps="${all_bsps} rbtx4925 rbtx4938" ;;
       nios2)   all_bsps="nios2_iss" ;;
       powerpc) all_bsps="psim mcp750 mvme2100 mvme2307 mvme3100"
2.1.4
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
