[PATCH] Chase Newlib sys/select.h changes
Mon Dec 14 09:09:00 UTC 2015
Hello Nick,
this patch needs an update once this is committed to Newlib:
https://sourceware.org/ml/newlib/2015/msg00905.html
On 10/12/15 10:04, Nick Withers wrote:
> Hi all,
> Attached is a patch for master similar to that I posted to the Newlib
> mailing list in https://sourceware.org/ml/newlib/2015/msg00888.html *.
> It chases Newlib changes to sys/types.h / sys/select.h and allows us to
> use Newlib's sys/select.h directly rather than rolling our own.
> A few notes:
>   - I removed the BSD advertising clause from what's now sys/selinfo.h,
> but am not sure that I should have
>   - I made a few not-really-related but minor changes to
> cpukit/libmisc/shell/*.c printf()s to ensure format specifiers matched
> parameter types
>   - the sys/selinfo.h file doesn't directly correspond to any FreeBSD
> revision, though it's basically the same as https://svnweb.freebsd.org/
> base/head/sys/sys/selinfo.h?revision=70650&view=markup , not sure how
> fussed we are with e.g., $FreeBSD$ tags and such...?
> * It doesn't mess with disabling dl tests on PSim; I ran into troubles
> with dl02 which I'll look into separately
> devel mailing list
> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
