[PATCH] Chase Newlib sys/select.h changes
Tue Dec 15 08:13:45 UTC 2015
Hello Nick,
I checked in the shell changes separately. With them I can build the
latest Newlib with --disable-networking. It should be sufficient to
remove the <sys/select.h> from libnetworking.
On 14/12/15 10:09, Sebastian Huber wrote:
> Hello Nick,
> this patch needs an update once this is committed to Newlib:
> https://sourceware.org/ml/newlib/2015/msg00905.html
> On 10/12/15 10:04, Nick Withers wrote:
>> Hi all,
>> Attached is a patch for master similar to that I posted to the Newlib
>> mailing list in https://sourceware.org/ml/newlib/2015/msg00888.html *.
>> It chases Newlib changes to sys/types.h / sys/select.h and allows us to
>> use Newlib's sys/select.h directly rather than rolling our own.
>> A few notes:
>>   - I removed the BSD advertising clause from what's now sys/selinfo.h,
>> but am not sure that I should have
>>   - I made a few not-really-related but minor changes to
>> cpukit/libmisc/shell/*.c printf()s to ensure format specifiers matched
>> parameter types
>>   - the sys/selinfo.h file doesn't directly correspond to any FreeBSD
>> revision, though it's basically the same as https://svnweb.freebsd.org/
>> base/head/sys/sys/selinfo.h?revision=70650&view=markup , not sure how
>> fussed we are with e.g., $FreeBSD$ tags and such...?
>> * It doesn't mess with disabling dl tests on PSim; I ran into troubles
>> with dl02 which I'll look into separately
>> devel mailing list
>> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
