[PATCH] powerpc/mvme5500: Add support for Altivec and fix various warnings.
Aun-Ali Zaidi
admin at kodeit.net
Sat Dec 19 22:39:28 UTC 2015
* Makefile.am: Add support for Altivec.
* startup/bspstart.c, Makefile.am: Use shared/startup/zerobss.c instead.
* irq/BSP_irq.c, pci/detect_host_bridge.c,pci.c,pcifinddevice.c:Remove warnings.
closes #1778.
c/src/lib/libbsp/powerpc/mvme5500/ChangeLog | 6 ++++
c/src/lib/libbsp/powerpc/mvme5500/Makefile.am | 4 ++-
c/src/lib/libbsp/powerpc/mvme5500/bsp_specs | 3 +-
c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c | 3 +-
.../powerpc/mvme5500/network/if_1GHz/if_wm.c | 2 +-
.../powerpc/mvme5500/pci/detect_host_bridge.c | 2 +-
c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c | 22 ++++++------
.../libbsp/powerpc/mvme5500/pci/pcifinddevice.c | 2 +-
c/src/lib/libbsp/powerpc/mvme5500/start/start.S | 41 +++++++++++++++++-----
9 files changed, 58 insertions(+), 27 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/ChangeLog b/c/src/lib/libbsp/powerpc/mvme5500/ChangeLog
index 5405f52..dd043d4 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/ChangeLog
+++ b/c/src/lib/libbsp/powerpc/mvme5500/ChangeLog
@@ -1,3 +1,9 @@
+2011-04-10 Kate Feng <feng at bnl.gov>
+ * Makefile.am: Add support for Altivec.
+ * startup/bspstart.c, Makefile.am: Use shared/startup/zerobss.c instead.
+ * irq/BSP_irq.c, pci/detect_host_bridge.c,pci.c,pcifinddevice.c:Remove warnings.
2011-03-31 Kate Feng <feng at bnl.gov>
PR 1778/bsps
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/Makefile.am b/c/src/lib/libbsp/powerpc/mvme5500/Makefile.am
index 7af78a0..78af61e 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/mvme5500/Makefile.am
@@ -29,6 +29,7 @@ EXTRA_DIST = startup/bootpstuff.c
startup_SOURCES = startup/bspstart.c \
../../powerpc/shared/startup/pgtbl_setup.c startup/pgtbl_activate.c \
../../powerpc/shared/startup/pretaskinghook.c \
+ ../../powerpc/shared/startup/zerobss.c \
../../powerpc/shared/startup/sbrk.c ../../shared/bootcard.c \
../../shared/bsppredriverhook.c startup/bspclean.c \
../../shared/bsplibc.c ../../shared/bsppost.c \
@@ -115,7 +116,8 @@ libbsp_a_LIBADD = \
../../../libcpu/@RTEMS_CPU@/@exceptions@/exc_bspsupport.rel \
../../../libcpu/@RTEMS_CPU@/@exceptions@/irq_bspsupport.rel \
../../../libcpu/@RTEMS_CPU@/mpc6xx/mmu.rel \
- ../../../libcpu/@RTEMS_CPU@/mpc6xx/timer.rel
+ ../../../libcpu/@RTEMS_CPU@/mpc6xx/timer.rel \
+ ../../../libcpu/@RTEMS_CPU@/mpc6xx/altivec.rel
if HAS_NETWORKING
libbsp_a_LIBADD += network.rel
endif
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/bsp_specs b/c/src/lib/libbsp/powerpc/mvme5500/bsp_specs
index cd53745..8dbdcf2 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/bsp_specs
+++ b/c/src/lib/libbsp/powerpc/mvme5500/bsp_specs
@@ -4,8 +4,7 @@
*startfile:
%{!qrtems: %(old_startfile)} \
-%{!nostdlib: %{qrtems: ecrti%O%s rtems_crti%O%s crtbegin.o%s \
- mvme5500start.o%s -e __rtems_entry_point -u __vectors}}
+%{!nostdlib: %{qrtems: ecrti%O%s rtems_crti%O%s crtbegin.o%s -e __rtems_entry_point -u __vectors mvme5500start.o%s}}
*link:
%{!qrtems: %(old_link)} %{qrtems: -dp -Bstatic}
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c b/c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c
index 25d2a92..c767e86 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c
+++ b/c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c
@@ -382,7 +382,8 @@ int BSP_setup_the_pic(rtems_irq_global_settings* config)
* bit 10:GPP interrupts as level sensitive(1) or edge sensitive(0).
* MOTload default is set as level sensitive(1). Set it agin to make sure.
- out_le32(GT_CommUnitArb_Ctrl, (in_le32(GT_CommUnitArb_Ctrl)| (1<<10)));
+ out_le32((volatile unsigned int *)GT_CommUnitArb_Ctrl,
+ (in_le32((volatile unsigned int *)GT_CommUnitArb_Ctrl)| (1<<10)));
#if 0
printk("BSP_irqMask_reg[0] = 0x%x, BSP_irqCause_reg[0] 0x%x\n",
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/network/if_1GHz/if_wm.c b/c/src/lib/libbsp/powerpc/mvme5500/network/if_1GHz/if_wm.c
index 1224dda..7bf96ba 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/network/if_1GHz/if_wm.c
+++ b/c/src/lib/libbsp/powerpc/mvme5500/network/if_1GHz/if_wm.c
@@ -1728,7 +1728,7 @@ static void wm_gmii_mediainit(struct wm_softc *sc)
/* We have MII. */
sc->sc_flags |= WM_F_HAS_MII;
-#if 1
+#if 0
/* <skf> May 2009 : The value that should be programmed into IPGT is 10 */
sc->sc_tipg = TIPG_IPGT(10)+TIPG_IPGR1(8)+TIPG_IPGR2(6);
#else
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/pci/detect_host_bridge.c b/c/src/lib/libbsp/powerpc/mvme5500/pci/detect_host_bridge.c
index 4615464..05df501 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/pci/detect_host_bridge.c
+++ b/c/src/lib/libbsp/powerpc/mvme5500/pci/detect_host_bridge.c
@@ -27,7 +27,7 @@
unsigned long _BSP_clear_hostbridge_errors(int enableMCP, int quiet)
- unsigned int pcidata, pcidata1;
+ uint32_t pcidata, pcidata1;
int PciLocal, busNumber=0;
/* On the mvme5500 board, the GT64260B system controller had the MCP
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c b/c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c
index 0bc243c..24299a9 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c
+++ b/c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c
@@ -108,7 +108,7 @@ unsigned char offset,unsigned char *val)
BSP_pci[n].config_data,pciConfigPack(bus,dev,func,offset));
#endif
- out_be32(BSP_pci[n].pci_config_addr, pciConfigPack(bus,dev,func,offset));
+ out_be32((volatile unsigned int *) BSP_pci[n].pci_config_addr, pciConfigPack(bus,dev,func,offset));
*val = in_8(BSP_pci[n].pci_config_data + (offset&3));
return PCIBIOS_SUCCESSFUL;
@@ -129,8 +129,8 @@ unsigned char func, unsigned char offset, unsigned short *val)
printk("addr %x, data %x, pack %x \n", config_addr,
#endif
- *val = in_le16(BSP_pci[n].pci_config_data + (offset&2));
+ *val = in_le16((volatile unsigned short *) (BSP_pci[n].pci_config_data + (offset&2)));
@@ -147,8 +147,8 @@ unsigned char func, unsigned char offset, unsigned int *val)
*val = 0xffffffff;
if ((offset&3)|| (offset & ~0xff)) return PCIBIOS_BAD_REGISTER_NUMBER;
- *val = in_le32(BSP_pci[n].pci_config_data);
+ out_be32((volatile unsigned int *)BSP_pci[n].pci_config_addr, pciConfigPack(bus,dev,func,offset));
+ *val = in_le32((volatile unsigned int *)BSP_pci[n].pci_config_data);
@@ -163,8 +163,8 @@ static int indirect_pci_write_config_byte(unsigned char bus, unsigned char dev,u
if (offset & ~0xff) return PCIBIOS_BAD_REGISTER_NUMBER;
- out_8(BSP_pci[n].pci_config_data + (offset&3), val);
+ out_8((volatile unsigned char *) (BSP_pci[n].pci_config_data + (offset&3)), val);
@@ -179,8 +179,8 @@ static int indirect_pci_write_config_word(unsigned char bus, unsigned char dev,u
if ((offset&1)|| (offset & ~0xff)) return PCIBIOS_BAD_REGISTER_NUMBER;
- out_le16(BSP_pci[n].pci_config_data + (offset&3), val);
+ out_le16((volatile unsigned short *)(BSP_pci[n].pci_config_data + (offset&3)), val);
@@ -195,8 +195,8 @@ static int indirect_pci_write_config_dword(unsigned char bus,unsigned char dev,u
- out_le32(BSP_pci[n].pci_config_data, val);
+ out_le32((volatile unsigned int *)BSP_pci[n].pci_config_data, val);
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c b/c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c
index c3b677d..44723d0 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c
+++ b/c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c
@@ -35,7 +35,7 @@ int BSP_pciFindDevicePrint(unsigned short vendorid, unsigned short deviceid,
int pci_find_device( unsigned short vendorid, unsigned short deviceid,
int instance, int *pbus, int *pdev, int *pfun )
- unsigned int d;
+ uint32_t d;
unsigned short s;
unsigned char bus,dev,fun,hd;
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/start/start.S b/c/src/lib/libbsp/powerpc/mvme5500/start/start.S
index a54836e..436600a 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/start/start.S
+++ b/c/src/lib/libbsp/powerpc/mvme5500/start/start.S
@@ -4,7 +4,7 @@
* Copyright (C) 1999 Eric Valette. valette at crf.canon.fr
* S. Kate Feng <feng1 at bnl.gov>, April 2004
- * Mapped the 2nd 256MB of RAM to support the MVME5500 boards.
+ * Mapped the 2nd 256MB of RAM to support the MVME5500/MVME6100 boards.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
@@ -16,8 +16,10 @@
#include <rtems/asm.h>
#include <rtems/score/cpu.h>
#include <rtems/powerpc/powerpc.h>
#include <libcpu/io.h>
#include <libcpu/bat.h>
+#include <bspopts.h>
#define SYNC \
sync; \
@@ -33,7 +35,6 @@
li r10,0x63 ; \
sc
.text
.globl __rtems_entry_point
.type __rtems_entry_point, at function
@@ -62,6 +63,21 @@ __rtems_entry_point:
mr r29,r5
mr r28,r6
mr r27,r7
+#ifdef __ALTIVEC__
+ /* enable altivec; gcc may use it! */
+ mfmsr r0
+ oris r0, r0, (1<<(32-16-6))
+ mtmsr r0
+ * set vscr and vrsave to known values
+ li r0, 0
+ mtvrsave r0
+ vxor 0,0,0
+ mtvscr 0
+#endif
* Make sure we have nothing in BATS and TLB
@@ -72,7 +88,8 @@ __rtems_entry_point:
* of RAM to KERNELBASE.
lis r11,KERNELBASE at h
- ori r11,r11,0x1ffe /* set up BAT0 registers for 604+ */
+/* set up BAT registers for 604 */
+ ori r11,r11,0x1ffe
li r8,2 /* R/W access */
isync
mtspr DBAT0L,r8 /* N.B. 6xx (not 601) have valid */
@@ -81,8 +98,8 @@ __rtems_entry_point:
mtspr IBAT0U,r11
isync
- * Use the 2nd pair of BAT registers to map the 2nd 256MB
- * of RAM to 0x10000000. <SKF>
+ * <skf> Use the 2nd pair of BAT registers to map the 2nd 256MB
+ * of RAM to 0x10000000.
lis r11,MEM256MB at h
ori r11,r11,0x1ffe /* set up BAT1 registers for 604+ */
@@ -106,7 +123,7 @@ __rtems_entry_point:
enter_C_code:
bl MMUon
- bl __eabi /* setup EABI and SYSV environment */
+ bl __eabi /* setup EABI and SYSV environment */
bl zero_bss
* restore prep boot params
@@ -122,9 +139,16 @@ enter_C_code:
addis r9,r0, __rtems_end+(4096-PPC_MINIMUM_STACK_FRAME_SIZE)@ha
addi r9,r9, __rtems_end+(4096-PPC_MINIMUM_STACK_FRAME_SIZE)@l
- mr r1, r9
- * We are know in a environment that is totally independent from bootloader setup.
+ * align initial stack
+ * (we hope that the bootloader stack was 16-byte aligned)
+ * or we haven't used altivec yet...)
+ li r0, (CPU_STACK_ALIGNMENT-1)
+ andc r1, r9, r0
+ * We are now in an environment that is totally independent from
+ * bootloader setup.
lis r5,environ at ha
la r5,environ at l(r5) /* environp */
@@ -165,7 +189,6 @@ MMUoff:
.globl _return_to_ppcbug
.type _return_to_ppcbug, at function
_return_to_ppcbug:
mflr r30
bl MMUoff
2.1.4
