[PATCH 1/2] cpukit/task{set,get}note.c: Remove obsolete Notepads
Aun-Ali Zaidi admin at kodeit.net
Mon Dec 21 01:13:19 UTC 2015
updates #2493.
 cpukit/rtems/include/rtems/rtems/tasks.h | 2 +-
 cpukit/rtems/src/taskgetnote.c           | 2 --
 cpukit/rtems/src/tasksetnote.c           | 2 --
 3 files changed, 1 insertion(+), 5 deletions(-)
diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h b/cpukit/rtems/include/rtems/rtems/tasks.h
index 1ad537d..114624d 100644
--- a/cpukit/rtems/include/rtems/rtems/tasks.h
+++ b/cpukit/rtems/include/rtems/rtems/tasks.h
@@ -678,7 +678,7 @@ typedef struct {
    *  @note MUST BE LAST ENTRY.
-  uint32_t Notepads[ RTEMS_ZERO_LENGTH_ARRAY ] RTEMS_DEPRECATED;
+  //uint32_t Notepads[ RTEMS_ZERO_LENGTH_ARRAY ] RTEMS_DEPRECATED;
 }  RTEMS_API_Control;
diff --git a/cpukit/rtems/src/taskgetnote.c b/cpukit/rtems/src/taskgetnote.c
index c097d9c..ba40d2e 100644
--- a/cpukit/rtems/src/taskgetnote.c
+++ b/cpukit/rtems/src/taskgetnote.c
@@ -60,7 +60,6 @@ rtems_status_code rtems_task_get_note(
   if ( _Objects_Are_ids_equal( id, OBJECTS_ID_OF_SELF ) ||
        _Objects_Are_ids_equal( id, executing->Object.id ) ) {
       api = executing->API_Extensions[ THREAD_API_RTEMS ];
-      *note = api->Notepads[ notepad ];
       return RTEMS_SUCCESSFUL;
@@ -69,7 +68,6 @@ rtems_status_code rtems_task_get_note(
     case OBJECTS_LOCAL:
       api = the_thread->API_Extensions[ THREAD_API_RTEMS ];
       _Objects_Put( &the_thread->Object );
diff --git a/cpukit/rtems/src/tasksetnote.c b/cpukit/rtems/src/tasksetnote.c
index 42cd4e7..3e6e9aa 100644
--- a/cpukit/rtems/src/tasksetnote.c
+++ b/cpukit/rtems/src/tasksetnote.c
@@ -57,7 +57,6 @@ rtems_status_code rtems_task_set_note(
-      api->Notepads[ notepad ] = note;
@@ -66,7 +65,6 @@ rtems_status_code rtems_task_set_note(
     case OBJECTS_LOCAL:
2.1.4
