[PATCH 1/2] cpukit/task{set,get}note.c: Remove obsolete Notepads
Joel Sherrill
joel at rtems.org
Mon Dec 21 18:32:11 UTC 2015
To remove notepads fully, the documentation and testsuites
should also be touched. There should be more in the patch.
--joel
On Mon, Dec 21, 2015 at 1:15 AM, Sebastian Huber <
> On 21/12/15 02:13, Aun-Ali Zaidi wrote:
>> updates #2493.
>> cpukit/rtems/include/rtems/rtems/tasks.h | 2 +-
>> cpukit/rtems/src/taskgetnote.c | 2 --
>> cpukit/rtems/src/tasksetnote.c | 2 --
>> 3 files changed, 1 insertion(+), 5 deletions(-)
>> diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h
>> b/cpukit/rtems/include/rtems/rtems/tasks.h
>> index 1ad537d..114624d 100644
>> --- a/cpukit/rtems/include/rtems/rtems/tasks.h
>> +++ b/cpukit/rtems/include/rtems/rtems/tasks.h
>> @@ -678,7 +678,7 @@ typedef struct {
>> * @note MUST BE LAST ENTRY.
>> - uint32_t Notepads[ RTEMS_ZERO_LENGTH_ARRAY ] RTEMS_DEPRECATED;
>> + //uint32_t Notepads[ RTEMS_ZERO_LENGTH_ARRAY ] RTEMS_DEPRECATED;
> Please don't use comments or #if 0 to remove things.
> } RTEMS_API_Control;
>> diff --git a/cpukit/rtems/src/taskgetnote.c
>> b/cpukit/rtems/src/taskgetnote.c
>> index c097d9c..ba40d2e 100644
>> --- a/cpukit/rtems/src/taskgetnote.c
>> +++ b/cpukit/rtems/src/taskgetnote.c
>> @@ -60,7 +60,6 @@ rtems_status_code rtems_task_get_note(
>> if ( _Objects_Are_ids_equal( id, OBJECTS_ID_OF_SELF ) ||
>> _Objects_Are_ids_equal( id, executing->Object.id ) ) {
>> api = executing->API_Extensions[ THREAD_API_RTEMS ];
>> - *note = api->Notepads[ notepad ];
>> return RTEMS_SUCCESSFUL;
>> @@ -69,7 +68,6 @@ rtems_status_code rtems_task_get_note(
>> case OBJECTS_LOCAL:
>> api = the_thread->API_Extensions[ THREAD_API_RTEMS ];
>> _Objects_Put( &the_thread->Object );
> What is the purpose of this function after your change?
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151221/962783f8/attachment.html>
