index 657b2f4..e69de29 100644
Zaphod Beeblebrox liamgreenlee at gmail.com
Wed Dec 23 00:17:33 UTC 2015
-#ifndef _BSPABORT_H
-#define _BSPABORT_H
-#include <rtems/system.h>
-#include <rtems.h>
-#include <rtems/bspIo.h>
-#define INSN_MASK         0xc5
-#define INSN_STM1         0x80
-#define INSN_STM2         0x84
-#define INSN_STR          0x40
-#define INSN_STRB         0x44
-#define INSN_LDM1         0x81
-#define INSN_LDM23        0x85
-#define INSN_LDR          0x41
-#define INSN_LDRB         0x45
-#define GET_RD(x)         ((x & 0x0000f000) >> 12)
-#define GET_RN(x)         ((x & 0x000f0000) >> 16)
-#define GET_U(x)          ((x & 0x00800000) >> 23)
-#define GET_I(x)          ((x & 0x02000000) >> 25)
-#define GET_REG(r, ctx)      (((uint32_t   *)ctx)[r])
-#define SET_REG(r, ctx, v)   (((uint32_t   *)ctx)[r] = v)
-#define GET_OFFSET(insn)     (insn & 0xfff)
- * Prototypes
-void _print_full_context(uint32_t);
-void do_data_abort(uint32_t, uint32_t, Context_Control *);
-#endif /* _BSPABORT_H */
+- *  ARM CPU Dependent Source
+- *  If you want a small footprint RTEMS, pls use simple_abort.c
+- *  COPYRIGHT (c) 2007 Ray Xu.
+- *  mailto: Rayx at gmail dot com
+- *  COPYRIGHT (c) 2000 Canon Research Centre France SA.
+- *  Emmanuel Raguet, mailto:raguet at crf.canon.fr
+- *  Copyright (c) 2002 Advent Networks, Inc
+- *      Jay Monkman <jmonkman at adventnetworks.com>
+- *  The license and distribution terms for this file may be
+- *  found in the file LICENSE in this distribution or at
+- *  http://www.rtems.org/license/LICENSE.
+-#include <rtems/system.h>
+-#include <rtems.h>
+-#include <rtems/bspIo.h>
+-#include "abort.h"
+-uint32_t g_data_abort_cnt = 0;
+-/*this is a big overhead for MCU only got 16K RAM*/
+-uint32_t g_data_abort_insn_list[1024];
+-char *_print_full_context_mode2txt[0x20]={
+-  [0x0]="user",  /* User */
+-  [0x1]="fiq",   /* FIQ - Fast Interrupt Request */
+-  [0x2]="irq",   /* IRQ - Interrupt Request */
+-  [0x3]="super", /* Supervisor */
+-  [0x7]="abort", /* Abort */
+-  [0xb]="undef", /* Undefined */
+-  [0xf]="system" /* System */
+-void _print_full_context(uint32_t spsr)
+-    char *mode;
+-    uint32_t prev_sp,prev_lr,cpsr,arm_switch_reg;
+-    int i;
+-    printk("active thread thread 0x%08x\n", rtems_task_self());
+-    mode=_print_full_context_mode2txt[spsr&0x1f];
+-    if(!mode) mode="unknown";
+-    __asm__ volatile (ARM_SWITCH_TO_ARM
+-              "	MRS  %[cpsr], cpsr \n"
+-              "	ORR  %[arm_switch_reg], %[spsr], #0xc0 \n"
+-              "	MSR  cpsr_c, %[arm_switch_reg] \n"
+-              "	MOV  %[prev_sp], sp \n"
+-              "	MOV  %[prev_lr], lr \n"
+-              "	MSR  cpsr_c, %[cpsr] \n"
+-	      ARM_SWITCH_BACK
+-              : [arm_switch_reg] "=&r" (arm_switch_reg), [prev_sp] "=&r" (prev_sp), [prev_lr] "=&r" (prev_lr),
+-		[cpsr] "=&r" (cpsr)
+-              : [spsr] "r" (spsr)
+-              : "cc");
+-    printk("Previous sp=0x%08x lr=0x%08x and actual cpsr=%08x\n",
+-           prev_sp, prev_lr, cpsr);
+-    for(i=0;i<48;){
+-        printk(" 0x%08x",((uint32_t*)prev_sp)[i++]);
+-        if((i%6) == 0)
+-            printk("\n");
+-/* This function is supposed to figure out what caused the
+- * data abort, do that, then return.
+- * All unhandled instructions cause the system to hang.
+-void do_data_abort(
+-  uint32_t insn,
+-  uint32_t spsr,
+-  Context_Control *ctx
+-    /* Clarify, which type is correct, CPU_Exception_frame or Context_Control */
+-    uint8_t               decode;
+-    uint8_t               insn_type;
+-    rtems_interrupt_level level;
+-    g_data_abort_insn_list[g_data_abort_cnt & 0x3ff] = ctx->register_lr - 8;
+-    g_data_abort_cnt++;
+-    decode = ((insn >> 20) & 0xff);
+-    insn_type = decode & INSN_MASK;
+-    switch(insn_type) {
+-    case INSN_STM1:
+-        printk("\n\nINSN_STM1\n");
+-        break;
+-    case INSN_STM2:
+-        printk("\n\nINSN_STM2\n");
+-        break;
+-    case INSN_STR:
+-        printk("\n\nINSN_STR\n");
+-        break;
+-    case INSN_STRB:
+-        printk("\n\nINSN_STRB\n");
+-        break;
+-    case INSN_LDM1:
+-        printk("\n\nINSN_LDM1\n");
+-        break;
+-    case INSN_LDM23:
+-        printk("\n\nINSN_LDM23\n");
+-        break;
+-    case INSN_LDR:
+-        printk("\n\nINSN_LDR\n");
+-        break;
+-    case INSN_LDRB:
+-        printk("\n\nINSN_LDRB\n");
+-        break;
+-    default:
+-        printk("\n\nUnrecognized instruction\n");
+-        break;
+-    printk("data_abort at address 0x%x, instruction: 0x%x,   spsr = 0x%x\n",
+-           ctx->register_lr - 8, insn, spsr);
+-    _print_full_context(spsr);
+-    /* disable interrupts, wait forever */
+-    rtems_interrupt_disable(level);
+-    (void) level; /* avoid set but unused warning */
+-    while(1) {
+-        continue;
+diff --git c/src/lib/libbsp/arm/shared/abort/abort.h c/src/lib/libbsp/arm/shared/abort/abort.h
+index 6d8704f..e69de29 100644
+--- c/src/lib/libbsp/arm/shared/abort/abort.h
++++ c/src/lib/libbsp/arm/shared/abort/abort.h
+@@ -1,52 +0,0 @@
+-#ifndef _BSPABORT_H
+-#define _BSPABORT_H
+-#define INSN_MASK         0xc5
+-#define INSN_STM1         0x80
+-#define INSN_STM2         0x84
+-#define INSN_STR          0x40
+-#define INSN_STRB         0x44
+-#define INSN_LDM1         0x81
+-#define INSN_LDM23        0x85
+-#define INSN_LDR          0x41
+-#define INSN_LDRB         0x45
+-#define GET_RD(x)         ((x & 0x0000f000) >> 12)
+-#define GET_RN(x)         ((x & 0x000f0000) >> 16)
+-#define GET_U(x)          ((x & 0x00800000) >> 23)
+-#define GET_I(x)          ((x & 0x02000000) >> 25)
+-#define GET_REG(r, ctx)      (((uint32_t   *)ctx)[r])
+-#define SET_REG(r, ctx, v)   (((uint32_t   *)ctx)[r] = v)
+-#define GET_OFFSET(insn)     (insn & 0xfff)
+- * Prototypes
+-void _print_full_context(uint32_t);
+-void do_data_abort(uint32_t, uint32_t, Context_Control *);
+-#endif /* _BSPABORT_H */
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/i2c/cadence-i2c.c b/c/src/lib/libbsp/arm/xilinx-zynq/i2c/cadence-i2c.c
index 76211da..035333a 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/i2c/cadence-i2c.c
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/i2c/cadence-i2c.c
@@ -1,4 +1,7 @@
+/*@file
+ *@ingroup xilinx-zynq_i2c
+ *@brief
  * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
@@ -57,19 +60,31 @@ typedef struct {
   bool hold;
   rtems_id task_id;
   uint32_t input_clock;
-  rtems_vector_number irq;
+  rtems_vector_number irq;xilinx-zynq_i2c
 } cadence_i2c_bus;
+ at ingroup xilinx-zynq_i2c
+ at brief Disable cadence interrupts
 static void cadence_i2c_disable_interrupts(volatile cadence_i2c *regs)
   regs->irqdisable = 0xffff;
+ at brief Clear irq status
 static void cadence_i2c_clear_irq_status(volatile cadence_i2c *regs)
   regs->irqstatus = regs->irqstatus;
+ at brief Reset cadence
 static void cadence_i2c_reset(cadence_i2c_bus *bus)
   volatile cadence_i2c *regs = bus->regs;
@@ -90,6 +105,10 @@ static void cadence_i2c_reset(cadence_i2c_bus *bus)
   cadence_i2c_clear_irq_status(regs);
+ at brief Set cadence i2c address size
 static uint32_t cadence_i2c_set_address_size(
   const i2c_msg *msg,
   uint32_t control
@@ -104,6 +123,10 @@ static uint32_t cadence_i2c_set_address_size(
   return control;
+ at brief Setup read transfer
 static void cadence_i2c_setup_read_transfer(
   cadence_i2c_bus *bus,
   volatile cadence_i2c *regs,
@@ -138,6 +161,10 @@ static void cadence_i2c_next_byte(cadence_i2c_bus *bus)
+ at brief Cadence i2c write to fifo
 static void cadence_i2c_write_to_fifo(
@@ -164,6 +191,10 @@ static void cadence_i2c_write_to_fifo(
+ at brief Setup cadence i2c write transfer
 static void cadence_i2c_setup_write_transfer(
@@ -176,6 +207,10 @@ static void cadence_i2c_setup_write_transfer(
   cadence_i2c_write_to_fifo(bus, regs);
+ at brief Setup cadence i2c transfer
 static void cadence_i2c_setup_transfer(
@@ -218,6 +253,10 @@ static void cadence_i2c_setup_transfer(
   regs->address = CADENCE_I2C_ADDRESS(msgs->addr);
+ at brief Continue cadence i2c read transfer
 static void cadence_i2c_continue_read_transfer(
@@ -253,6 +292,10 @@ static void cadence_i2c_continue_read_transfer(
+ at brief Interrup cadence i2c
 static void cadence_i2c_interrupt(void *arg)
   cadence_i2c_bus *bus = arg;
@@ -321,6 +364,10 @@ static void cadence_i2c_interrupt(void *arg)
+ at brief Cadence i2c transfer
 static int cadence_i2c_transfer(
   i2c_bus *base,
   i2c_msg *msgs,
@@ -362,6 +409,11 @@ static int cadence_i2c_transfer(
   return bus->irqstatus == 0 ? 0 : -EIO;
+ at brief Set cadence i2c clock
 static int cadence_i2c_set_clock(i2c_bus *base, unsigned long clock)
   cadence_i2c_bus *bus = (cadence_i2c_bus *) base;
@@ -407,6 +459,10 @@ static int cadence_i2c_set_clock(i2c_bus *base, unsigned long clock)
   return 0;
+ at brief Destroy cadence i2c
 static void cadence_i2c_destroy(i2c_bus *base)
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/include/cadence-i2c-regs.h b/c/src/lib/libbsp/arm/xilinx-zynq/include/cadence-i2c-regs.h
index c06a47c..a5a4e02 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/include/cadence-i2c-regs.h
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/include/cadence-i2c-regs.h
@@ -1,4 +1,8 @@
+ *@file
+ *@defgroup xilinx-zynq_i2c Cadenc I2C Setup
