Problem with system time in lpc176x bsp
Marcos Díaz marcos.diaz at tallertechnologies.com
Wed Dec 23 21:22:43 UTC 2015
That patch didn't work,
one reason is that it has a mistake:
in kern_tc.c you defined this macro:
#define _Timecounter_Release(lock_context) \
+  *_ISR_lock_ISR_disable_and_acquire*(&_Timecounter_Lock, lock_context)
I think you meant:
     *_ISR_lock_Release_and_ISR_enable*(&_Timecounter_Lock, lock_context)
The other reason is that as I said, the driver checks for the flag PENDSTSET
of the ICSR register, and I think this approach is wrong, because that flag
goes down when the tick interrupt is attended. I used the solution I
proposed before, but I'm still seeing some errors. I'll let you know what I
find.
On Wed, Dec 23, 2015 at 3:53 AM, Sebastian Huber <
> Hello Marcos,
> yes, nested interrupts are a problem for the current implementation. Its a
> general problem of the RTEMS testsuite that we cannot test nested
> interrupts. I think we have to fix this at some time.
> Could you please test the attached patch?
______________________________
<http://www.tallertechnologies.com>
Marcos Díaz
Software Engineer
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
Skype: markdiaz22
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151223/6224eb73/attachment-0002.html>
