Gaisler Qemu Patches Disappeared
Mon Feb 2 14:47:18 UTC 2015
Hi Daniel
Qemu doesn't build with the RSB because the Gaisler patches that
were referenced seem to have disappeared.  As best I can tell, the entire
directory is no longer there. Where are the patches now? Do you have
a patch for the RSB?
downloading:
patches/Provide-the-missing-LIBUSB_LOG_LEVEL_-for-older-libusb-or-FreeBSD.-Providing-just-the-needed-value-as-a-defined..patch
- 666.0 bytes
download:
https://gaisler.org/qemu/0001-LEON3-Add-emulation-of-AMBA-plug-play.patch ->
patches/0001-LEON3-Add-emulation-of-AMBA-plug-play.patch
download:
https://gaisler.org/qemu/0001-LEON3-Add-emulation-of-AMBA-plug-play.patch:
error: HTTP Error 404: Not Found
error: downloading
all paths have failed, giving up
Build FAILED
  See error report:
rsb-report-qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed-x86_64-linux-gnu-1.txt
error: downloading
Build Set: Time 0:09:25.091254
