Gaisler Qemu Patches Disappeared
Jiri Gaisler jiri at gaisler.se
Mon Feb 2 15:19:54 UTC 2015
This is my fault, a server switch failed to move the qemu directory
to the new server. I will restore the files as soon as possible.
Jiri.
On 02/02/2015 03:47 PM, Joel Sherrill wrote:
> Hi Daniel
> Qemu doesn't build with the RSB because the Gaisler patches that
> were referenced seem to have disappeared.  As best I can tell, the entire
> directory is no longer there. Where are the patches now? Do you have
> a patch for the RSB?
> downloading:
> patches/Provide-the-missing-LIBUSB_LOG_LEVEL_-for-older-libusb-or-FreeBSD.-Providing-just-the-needed-value-as-a-defined..patch
> - 666.0 bytes
> download:
> https://gaisler.org/qemu/0001-LEON3-Add-emulation-of-AMBA-plug-play.patch ->
> patches/0001-LEON3-Add-emulation-of-AMBA-plug-play.patch
> download:
> https://gaisler.org/qemu/0001-LEON3-Add-emulation-of-AMBA-plug-play.patch:
> error: HTTP Error 404: Not Found
> error: downloading
> all paths have failed, giving up
> Build FAILED
>   See error report:
> rsb-report-qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed-x86_64-linux-gnu-1.txt
> error: downloading
> Build Set: Time 0:09:25.091254
