Question on all SPARC BSP get nanoseconds handler
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Feb 2 17:45:04 UTC 2015
Hi
Last week while teaching an RTEMS class, we looked at a SPARC BSP's
get nanoseconds since last tick handler. They all follow this pattern:
clicks = Read Counter
if ( clock interrupt pending ) {
clicks = Read Counter;
time =(2 * time per tick) - (clicks);
} else {
time = time per tick - clicks
return time;
The code is correct but I would like to add a comment to all three versions
of this code so it is clear what was intended.
I think it is something like. Read the counter. If there is not an
interrupt pending,
then we are in the same clock tick. If there is one pending, then see
how long
past that tick we are. The handler has to report from slightly > 0 to
slightly
less than 2 ticks depending on where we are relative to the next clock tick.
Just wanting to make the code more understandable for the next person. Help
writing the comment is appreciated.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150202/ddb2ef1a/attachment-0001.html>
