Gaisler Qemu Patches Disappeared
Jiri Gaisler
jiri at gaisler.se
Mon Feb 2 20:11:56 UTC 2015
On 02/02/2015 05:25 PM, Joel Sherrill wrote:
> On 2/2/2015 9:45 AM, Jiri Gaisler wrote:
>> Should be fixed now, sorry for the trouble.
> No problem. My build is past that now. I thought I built
> qemu with the RSB last week while teaching an RTEMS class.
> When did the server switch occur?
I made a gradual switch-over Friday to Saturday. All my server apps run
in a LXC container, so I normally just move the container to the new host
and start it. This time, I decided to upgrade the O/S running in the
container so I had to re-install all apps (http, mail server, certificates,
piwigo, owncloud ...) manually. Somehow I forgot the qemu directory ...
Jiri.
(The server sits in my basement, I have been blessed with a 1G fiber despite
living out in the woods ...)
> --joel
>> Jiri.
>> On 02/02/2015 04:32 PM, Joel Sherrill wrote:
>>> On February 2, 2015 8:19:54 AM MST, Jiri Gaisler <jiri at gaisler.se> wrote:
>>>> This is my fault, a server switch failed to move the qemu directory
>>>> to the new server. I will restore the files as soon as possible.
>>> The is for the quick response Jiri. Upgrades always come with issues.
>>>> Jiri.
>>>> On 02/02/2015 03:47 PM, Joel Sherrill wrote:
>>>>> Hi Daniel
>>>>> Qemu doesn't build with the RSB because the Gaisler patches that
>>>>> were referenced seem to have disappeared. As best I can tell, the
>>>> entire
>>>>> directory is no longer there. Where are the patches now? Do you have
>>>>> a patch for the RSB?
>>>>> downloading:
>>>> patches/Provide-the-missing-LIBUSB_LOG_LEVEL_-for-older-libusb-or-FreeBSD.-Providing-just-the-needed-value-as-a-defined..patch
>>>>> - 666.0 bytes
>>>>> download:
>>>> https://gaisler.org/qemu/0001-LEON3-Add-emulation-of-AMBA-plug-play.patch
>>>>> patches/0001-LEON3-Add-emulation-of-AMBA-plug-play.patch
>>>>> download:
>>>> https://gaisler.org/qemu/0001-LEON3-Add-emulation-of-AMBA-plug-play.patch:
>>>>> error: HTTP Error 404: Not Found
>>>>> error: downloading
>>>>> all paths have failed, giving up
>>>>> Build FAILED
>>>>> See error report:
>>>> rsb-report-qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed-x86_64-linux-gnu-1.txt
>>>>> error: downloading
>>>>> Build Set: Time 0:09:25.091254
>>> --joel
