Waf branch - Configuration [4/6]
Amar Takhar amar at rtems.org
Fri Feb 6 07:04:06 UTC 2015
Onto the BSP configuration.  Each one is a class with a very simple method of
defining the features it supports.
See rtems_waf/defaults/bsp/sparc.py
The 'Base' class defines options for that architecture.  Multiple inheritance is
supported see erc32.
These classes are only meant to define the defaults for a BSP.  Every user can
change any option they want.  There are no 'hidden' options they're all put into
config.cfg with *full* documentation on what it does.
There are two 'sections' to each config.  build() defines only modify when RTEMS
is built eg enabling or disabling a feature or modifying how the build works.
header() is config.h or bsp header files.  You can do a find build -name "*.h"
to see the various autogenerated files.
GCC spec files are autogenerated and no longer exist in source.  This is
necessary in order to support more than one compiler as these options need to be
translated.
By defining requirements via RTEMS Config it lets us use any compiler or tool we
want trivially.  RTEMS Config removes lock-in.  It holds information and
disburses it as we see fit.  Whether that is a compiler, GUI, documentation or
the build system.  This also lets us have binary distributions that ships all
BSPS.  We can also ship bsp+tests as separate packages which allows users to
get started w/out building RTEMS immediately on all platforms.
Waf works on all operating systems the only requirement is stock Python.
Users can also use MSVC as their IDE if they chose -- it will work fine we
can even add integration by creating a plugin that pulls in the RTEMS Config
information.
Caveats:
 - This is a preview only.  It works but there are issues.
 - Joel/Chris have already stated that BSPs need to be 'encapsulated'.  This
   means the config and all source need to be in a separate dir to allow for
   private BSPs.  This will be supported after the source move.
 - This is usable once we decide to go forward.  It is something I have worked
   on over the last 4 years.  While there are issues there is nothing I cannot
   fix in the python code.  What needs help is the source definitions from
   auto*->waf.
I also had to make a lot of 'temp' hacks to the build due to the changes in the
last year.  My commit messages aren't detailed for the 'waf' branch.  The 'fix'
and 'include' branches have useful messages.
More emails to follow (5/6)
Amar.
