Waf branch - Tools [3/6]
Fri Feb 6 23:31:25 UTC 2015
On 6/02/2015 6:03 pm, Amar Takhar wrote:
> rtems-run
> Allows for easily running your newly built image in the simulator or hardware of
> your choice.  RTEMS will be consuming this for running tests
> rtems-test
> Run the test suite for a specific BSP and print a nice report.  It will also
> support testing subsets of RTEMS.  For example, networking or disk.
How do these command relate to the work I have already done in the
rtems-tools.git for the rtems-test command ?
The rtems-tools.git repo contains the details for running a executables
on a number of targets as well as running all the tests RTEMS builds ?
