Waf branch - Tools [3/6]
Amar Takhar amar at rtems.org
Sat Feb 7 01:25:36 UTC 2015
On 2015-02-07 10:31 +1100, Chris Johns wrote:
> How do these command relate to the work I have already done in the
> rtems-tools.git for the rtems-test command ?
Yes I saw you used the name.  I have not had a chance to look at what your work
does it may be similar or completely different.
> The rtems-tools.git repo contains the details for running a executables
> on a number of targets as well as running all the tests RTEMS builds ?
I have not had a chance to look at this.  The work I did on both of those tools
preceeds what you did in rtems-tools.
Amar.
