Waf branch - Configuration [4/6]
Amar Takhar amar at rtems.org
Mon Feb 9 17:14:40 UTC 2015
On 2015-02-07 10:27 +1100, Chris Johns wrote:
> On 6/02/2015 6:04 pm, Amar Takhar wrote:
> > Onto the BSP configuration.
> For my Zynq board at the moment has 256M and I have L2 cache disabled
> and with the autotools configure I need use BSPOPTS as:
>   BSP_DATA_CACHE_ENABLED= BSP_INSTRUCTION_CACHE_ENABLED= \
>    BSP_ZYNQ_RAM_LENGTH=256M
I have added support for the xilinx_zynq_zc706.  This is the only zynq BSP
enabled at the moment.
Look in config.cfg when you do a 'waf' configure for all the available options
these are exposed there.
Amar.
