Waf branch - Configuration [4/6]
Mon Feb 9 21:15:00 UTC 2015
On 10/02/2015 4:14 am, Amar Takhar wrote:
> On 2015-02-07 10:27 +1100, Chris Johns wrote:
>> On 6/02/2015 6:04 pm, Amar Takhar wrote:
>>> Onto the BSP configuration.
>> For my Zynq board at the moment has 256M and I have L2 cache disabled
>> and with the autotools configure I need use BSPOPTS as:
>>    BSP_DATA_CACHE_ENABLED= BSP_INSTRUCTION_CACHE_ENABLED= \
>>     BSP_ZYNQ_RAM_LENGTH=256M
> I have added support for the xilinx_zynq_zc706.  This is the only zynq BSP
> enabled at the moment.
Awesome. I will try this out soon.
> Look in config.cfg when you do a 'waf' configure for all the available options
> these are exposed there.
Do I just edit these options ?
If so, is this temporary or the way we do this ? I am considering the
use case of a project with a release process that includes building
RTEMS. I am not sure patching this file is a good idea as it could be a
little fragile.
