Starting with RTEMS
Tue Feb 17 00:41:07 UTC 2015
On 2/16/2015 6:33 PM, Nick Withers wrote:
> On Mon, 2015-02-16 at 22:57 +0530, Rohini Kulkarni wrote:
>> Hi,
>> I am trying to build RTEMS for arm. I want to know what --enable
>> -rtemsbsp in config does, when building RTEMS.
> Hi Rohini!
> It selects which Board Support Package(s) (BSP(s)) you'd like to compile
> RTEMS for - or, if you prefer, which BSPs' code should be compiled - it
> takes a while for each and building the lot is almost always going to be
> unnecessary.
> There're a lot of different ARM variants and boards, what kind do you
> have?
> P.S., As a "could you help be to use this" kind o' question, this one'd
> probably be best on the users@ list :-)
Good answer and I will pitch in that for many cases, you want one that will
run on a simulator. Especially if you are looking at potential GSoC
projects. :)
>> Thank you.
>> Rohini Kulkarni
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
