Starting with RTEMS
Rohini Kulkarni
krohini1593 at gmail.com
Thu Feb 19 12:43:24 UTC 2015
Hi,
How can I figure out which targets can be tested with a simulator. I would
like to set up an environment which I can work with further.
Thank you.
On 17 Feb 2015 06:11, "Joel Sherrill" <joel.sherrill at oarcorp.com> wrote:
> On 2/16/2015 6:33 PM, Nick Withers wrote:
> > On Mon, 2015-02-16 at 22:57 +0530, Rohini Kulkarni wrote:
> >> Hi,
> >> I am trying to build RTEMS for arm. I want to know what --enable
> >> -rtemsbsp in config does, when building RTEMS.
> > Hi Rohini!
> > It selects which Board Support Package(s) (BSP(s)) you'd like to compile
> > RTEMS for - or, if you prefer, which BSPs' code should be compiled - it
> > takes a while for each and building the lot is almost always going to be
> > unnecessary.
> > There're a lot of different ARM variants and boards, what kind do you
> > have?
> > P.S., As a "could you help be to use this" kind o' question, this one'd
> > probably be best on the users@ list :-)
> Good answer and I will pitch in that for many cases, you want one that will
> run on a simulator. Especially if you are looking at potential GSoC
> projects. :)
> >> Thank you.
> >> Rohini Kulkarni
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150219/a2edaeed/attachment.html>
