[PATCH] ARM: Add BSP_NEEDS_REGISTER_INITIALIZATION
Martin Galvan martin.galvan at tallertechnologies.com
Wed Feb 25 14:52:20 UTC 2015
Follow-up from here:
https://lists.rtems.org/pipermail/devel/2015-February/009974.html
This patch adds the macro BSP_NEEDS_REGISTER_INITIALIZATION and three hooks for BSP-specific register init code to arm/shared/start.S. Said hooks are bsp_init_registers_core (intended for initializing the ARM core registers), bsp_init_registers_banked (for the FIQ mode banked registers) and bsp_init_registers_vfp (for the FPU registers). BSP_NEEDS_REGISTER_INITIALIZATION would be defined in a BSP's configure.ac (so that it appears in its bspopts.h).
This patch also adds the register init code required by the TMS570. We've tested it with the tms570ls3137_hdk.cfg config and it works fine.
 c/src/lib/libbsp/arm/shared/start/start.S                | 28 +++++++++++++++++++++++++
 c/src/lib/libbsp/arm/tms570/Makefile.am                  |  1 +
 c/src/lib/libbsp/arm/tms570/configure.ac                 |  5 +++++
 c/src/lib/libbsp/arm/tms570/startup/bsp-init-registers.S | 89 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
 4 files changed, 123 insertions(+)
 diff --git a/c/src/lib/libbsp/arm/shared/start/start.S b/c/src/lib/libbsp/arm/shared/start/start.S
index f5f0fa4..fa884ee 100644
--- a/c/src/lib/libbsp/arm/shared/start/start.S
+++ b/c/src/lib/libbsp/arm/shared/start/start.S
@@ -48,6 +48,12 @@
    .extern _ARMV4_Exception_fiq_default
    .extern _ARMV7M_Exception_default
+#ifdef BSP_NEEDS_REGISTER_INITIALIZATION
+   .extern bsp_init_registers_core
+   .extern bsp_init_registers_banked
+   .extern bsp_init_registers_vfp
+#endif
    /* Global symbols */
    .globl  _start
    .globl  bsp_start_vector_table_begin
@@ -127,6 +133,10 @@ _start:
     * loader.
+   bl bsp_init_registers_core
+#endif
 #ifdef RTEMS_SMP
    /* Read MPIDR */
    mrc p15, 0, r0, c0, c0, 5
@@ -161,6 +171,10 @@ _start:
    add sp, r1
 #endif
+   bl bsp_init_registers_banked
+#endif
    /* Enter ABT mode and set up the ABT stack pointer */
    mov r0, #(ARM_PSR_M_ABT | ARM_PSR_I | ARM_PSR_F)
    msr cpsr, r0
@@ -207,6 +221,11 @@ _start:
    /* Enable FPU */
    mov r0, #(1 << 30)
    vmsr FPEXC, r0
+   bl bsp_init_registers_vfp
+#endif
 #endif /* ARM_MULTILIB_VFP */
@@ -304,6 +323,10 @@ bsp_start_vector_table_end:
 _start:
+#endif
 #ifdef ARM_MULTILIB_VFP
     * Enable CP10 and CP11 coprocessors for privileged and user mode in
@@ -315,8 +338,13 @@ _start:
    str r1, [r0]
    dsb
    isb
 #endif
+#endif /* ARM_MULTILIB_VFP */
    ldr sp, =bsp_stack_main_end
    ldr lr, =bsp_start_hook_0_done + 1
    b   bsp_start_hook_0
diff --git a/c/src/lib/libbsp/arm/tms570/Makefile.am b/c/src/lib/libbsp/arm/tms570/Makefile.am
index bf3465d..c10a145 100644
--- a/c/src/lib/libbsp/arm/tms570/Makefile.am
+++ b/c/src/lib/libbsp/arm/tms570/Makefile.am
@@ -85,6 +85,7 @@ libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
 libbsp_a_SOURCES += ../../shared/bsppretaskinghook.c
 libbsp_a_SOURCES += startup/bspreset.c
 libbsp_a_SOURCES += startup/bspstart.c
+libbsp_a_SOURCES += startup/bsp-init-registers.S
 # POM
 libbsp_a_SOURCES += pom/tms570-pom.c
diff --git a/c/src/lib/libbsp/arm/tms570/configure.ac b/c/src/lib/libbsp/arm/tms570/configure.ac
index cefe50a..6b52e74 100644
--- a/c/src/lib/libbsp/arm/tms570/configure.ac
+++ b/c/src/lib/libbsp/arm/tms570/configure.ac
@@ -36,6 +36,11 @@ RTEMS_BSPOPTS_SET([BSP_MINIMUM_TASK_STACK_SIZE],[*],[1024])
 RTEMS_BSPOPTS_HELP([BSP_MINIMUM_TASK_STACK_SIZE],[Suggested minimum task stack
            size in bytes])
+RTEMS_BSPOPTS_SET([BSP_NEEDS_REGISTER_INITIALIZATION],[*],[1])
+RTEMS_BSPOPTS_HELP([BSP_NEEDS_REGISTER_INITIALIZATION],
+                   [The TMS570 needs to have the registers of its CPU initialized
+                    to avoid CCMR4F errors])
 RTEMS_BSPOPTS_SET([TMS570_OSCILLATOR_MAIN],[*],[12000000U])
 RTEMS_BSPOPTS_HELP([TMS570_OSCILLATOR_MAIN],[main oscillator frequency in Hz])
diff --git a/c/src/lib/libbsp/arm/tms570/startup/bsp-init-registers.S b/c/src/lib/libbsp/arm/tms570/startup/bsp-init-registers.S
new file mode 100644
index 0000000..1c58918
--- /dev/null
+++ b/c/src/lib/libbsp/arm/tms570/startup/bsp-init-registers.S
@@ -0,0 +1,89 @@
+ * @file bsp-init-registers.S
+ * @brief CPU register initialization routines for the TMS570.
+ * Copyright (c) 2015 Taller Technologies.  All rights reserved.
+ * @author Martin Galvan <martin.galvan at tallertechnologies.com>
+ * These routines perform the initialization of the CPU registers of the TMS570.
+ * This is necessary because of the 1oo1D lockstep execution of the TMS570's CCMR4F.
+#include <rtems/asm.h>
+.section .text
+.syntax unified
+.cpu cortex-r4
+.arm
+/* Initialization of the ARM core registers. */
+FUNCTION_ENTRY(bsp_init_registers_core)
+    mov r0, #0
+    mov r1, #0
+    mov r2, #0
+    mov r3, #0
+    mov r4, #0
+    mov r5, #0
+    mov r6, #0
+    mov r7, #0
+    mov r8, #0
+    mov r9, #0
+    mov r10, #0
+    mov r11, #0
+    mov r12, #0
+    mov r13, #0
+    bx lr
+FUNCTION_END(bsp_init_registers_core)
+/* Initialization of the FIQ mode banked registers. */
+FUNCTION_ENTRY(bsp_init_registers_banked)
+    mov r8, #0
+    mov r9, #0
+    mov r10, #0
+    mov r11, #0
+    mov r12, #0
+    bx lr
+FUNCTION_END(bsp_init_registers_banked)
+#ifdef ARM_MULTILIB_VFP
+/* Initialization of the FPU registers. */
+FUNCTION_ENTRY(bsp_init_registers_vfp)
+    stmfd sp!, {r0}
+    mov r0, #0
+    vmov d0, r0, r0
+    vmov d1, r0, r0
+    vmov d2, r0, r0
+    vmov d3, r0, r0
+    vmov d4, r0, r0
+    vmov d5, r0, r0
+    vmov d6, r0, r0
+    vmov d7, r0, r0
+    vmov d8, r0, r0
+    vmov d9, r0, r0
+    vmov d10, r0, r0
+    vmov d11, r0, r0
+    vmov d12, r0, r0
+    vmov d13, r0, r0
+    vmov d14, r0, r0
+    vmov d15, r0, r0
+    ldmfd sp!, {r0}
+    bx lr
+FUNCTION_END(bsp_init_registers_vfp)
