[PATCH] ARM: Add BSP_NEEDS_REGISTER_INITIALIZATION
Thu Feb 26 08:23:41 UTC 2015
Hello Martin,
can you please use BSP_START_* and bsp_start_* prefixes. Since this
bsp_init_registers_banked seems to be FIQ specific it should reflect
this in its name. The term banked it used in so many different places,
e.g. hypervisor mode etc.
On 25/02/15 15:52, Martin Galvan wrote:
> Follow-up from here:
> https://lists.rtems.org/pipermail/devel/2015-February/009974.html
> This patch adds the macro BSP_NEEDS_REGISTER_INITIALIZATION and three hooks for BSP-specific register init code to arm/shared/start.S. Said hooks are bsp_init_registers_core (intended for initializing the ARM core registers), bsp_init_registers_banked (for the FIQ mode banked registers) and bsp_init_registers_vfp (for the FPU registers). BSP_NEEDS_REGISTER_INITIALIZATION would be defined in a BSP's configure.ac (so that it appears in its bspopts.h).
> This patch also adds the register init code required by the TMS570. We've tested it with the tms570ls3137_hdk.cfg config and it works fine.
>   c/src/lib/libbsp/arm/shared/start/start.S                | 28 +++++++++++++++++++++++++
>   c/src/lib/libbsp/arm/tms570/Makefile.am                  |  1 +
>   c/src/lib/libbsp/arm/tms570/configure.ac                 |  5 +++++
>   c/src/lib/libbsp/arm/tms570/startup/bsp-init-registers.S | 89 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
>   4 files changed, 123 insertions(+)
>   diff --git a/c/src/lib/libbsp/arm/shared/start/start.S b/c/src/lib/libbsp/arm/shared/start/start.S
> index f5f0fa4..fa884ee 100644
> --- a/c/src/lib/libbsp/arm/shared/start/start.S
> +++ b/c/src/lib/libbsp/arm/shared/start/start.S
> @@ -48,6 +48,12 @@
>      .extern _ARMV4_Exception_fiq_default
>      .extern _ARMV7M_Exception_default
> +#ifdef BSP_NEEDS_REGISTER_INITIALIZATION
> +   .extern bsp_init_registers_core
> +   .extern bsp_init_registers_banked
> +   .extern bsp_init_registers_vfp
> +#endif
>      /* Global symbols */
>      .globl  _start
>      .globl  bsp_start_vector_table_begin
> @@ -127,6 +133,10 @@ _start:
>       * loader.
> +   bl bsp_init_registers_core
> +#endif
>   #ifdef RTEMS_SMP
>      /* Read MPIDR */
>      mrc p15, 0, r0, c0, c0, 5
> @@ -161,6 +171,10 @@ _start:
>      add sp, r1
>   #endif
> +   bl bsp_init_registers_banked
> +#endif
>      /* Enter ABT mode and set up the ABT stack pointer */
>      mov r0, #(ARM_PSR_M_ABT | ARM_PSR_I | ARM_PSR_F)
>      msr cpsr, r0
> @@ -207,6 +221,11 @@ _start:
>      /* Enable FPU */
>      mov r0, #(1 << 30)
>      vmsr FPEXC, r0
> +   bl bsp_init_registers_vfp
> +#endif
>   #endif /* ARM_MULTILIB_VFP */
> @@ -304,6 +323,10 @@ bsp_start_vector_table_end:
>   _start:
> +#endif
>   #ifdef ARM_MULTILIB_VFP
>       * Enable CP10 and CP11 coprocessors for privileged and user mode in
> @@ -315,8 +338,13 @@ _start:
>      str r1, [r0]
>      dsb
>      isb
>   #endif
> +#endif /* ARM_MULTILIB_VFP */
>      ldr sp, =bsp_stack_main_end
>      ldr lr, =bsp_start_hook_0_done + 1
>      b   bsp_start_hook_0
> diff --git a/c/src/lib/libbsp/arm/tms570/Makefile.am b/c/src/lib/libbsp/arm/tms570/Makefile.am
> index bf3465d..c10a145 100644
> --- a/c/src/lib/libbsp/arm/tms570/Makefile.am
> +++ b/c/src/lib/libbsp/arm/tms570/Makefile.am
> @@ -85,6 +85,7 @@ libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
>   libbsp_a_SOURCES += ../../shared/bsppretaskinghook.c
>   libbsp_a_SOURCES += startup/bspreset.c
>   libbsp_a_SOURCES += startup/bspstart.c
> +libbsp_a_SOURCES += startup/bsp-init-registers.S
>   # POM
>   libbsp_a_SOURCES += pom/tms570-pom.c
> diff --git a/c/src/lib/libbsp/arm/tms570/configure.ac b/c/src/lib/libbsp/arm/tms570/configure.ac
> index cefe50a..6b52e74 100644
> --- a/c/src/lib/libbsp/arm/tms570/configure.ac
> +++ b/c/src/lib/libbsp/arm/tms570/configure.ac
> @@ -36,6 +36,11 @@ RTEMS_BSPOPTS_SET([BSP_MINIMUM_TASK_STACK_SIZE],[*],[1024])
>   RTEMS_BSPOPTS_HELP([BSP_MINIMUM_TASK_STACK_SIZE],[Suggested minimum task stack
>              size in bytes])
> +RTEMS_BSPOPTS_SET([BSP_NEEDS_REGISTER_INITIALIZATION],[*],[1])
> +RTEMS_BSPOPTS_HELP([BSP_NEEDS_REGISTER_INITIALIZATION],
> +                   [The TMS570 needs to have the registers of its CPU initialized
> +                    to avoid CCMR4F errors])
>   RTEMS_BSPOPTS_SET([TMS570_OSCILLATOR_MAIN],[*],[12000000U])
>   RTEMS_BSPOPTS_HELP([TMS570_OSCILLATOR_MAIN],[main oscillator frequency in Hz])
> diff --git a/c/src/lib/libbsp/arm/tms570/startup/bsp-init-registers.S b/c/src/lib/libbsp/arm/tms570/startup/bsp-init-registers.S
> new file mode 100644
> index 0000000..1c58918
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tms570/startup/bsp-init-registers.S
> @@ -0,0 +1,89 @@
> + * @file bsp-init-registers.S
> + * @brief CPU register initialization routines for the TMS570.
> + * Copyright (c) 2015 Taller Technologies.  All rights reserved.
> + * @author Martin Galvan <martin.galvan at tallertechnologies.com>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> + * These routines perform the initialization of the CPU registers of the TMS570.
> + * This is necessary because of the 1oo1D lockstep execution of the TMS570's CCMR4F.
> +#include <rtems/asm.h>
> +.section .text
> +.syntax unified
> +.cpu cortex-r4
> +.arm
> +/* Initialization of the ARM core registers. */
> +FUNCTION_ENTRY(bsp_init_registers_core)
> +    mov r0, #0
> +    mov r1, #0
> +    mov r2, #0
> +    mov r3, #0
> +    mov r4, #0
> +    mov r5, #0
> +    mov r6, #0
> +    mov r7, #0
> +    mov r8, #0
> +    mov r9, #0
> +    mov r10, #0
> +    mov r11, #0
> +    mov r12, #0
> +    mov r13, #0
> +    bx lr
> +FUNCTION_END(bsp_init_registers_core)
> +/* Initialization of the FIQ mode banked registers. */
> +FUNCTION_ENTRY(bsp_init_registers_banked)
> +    mov r8, #0
> +    mov r9, #0
> +    mov r10, #0
> +    mov r11, #0
> +    mov r12, #0
> +    bx lr
> +FUNCTION_END(bsp_init_registers_banked)
> +#ifdef ARM_MULTILIB_VFP
> +/* Initialization of the FPU registers. */
> +FUNCTION_ENTRY(bsp_init_registers_vfp)
> +    stmfd sp!, {r0}
> +    mov r0, #0
> +    vmov d0, r0, r0
> +    vmov d1, r0, r0
> +    vmov d2, r0, r0
> +    vmov d3, r0, r0
> +    vmov d4, r0, r0
> +    vmov d5, r0, r0
> +    vmov d6, r0, r0
> +    vmov d7, r0, r0
> +    vmov d8, r0, r0
> +    vmov d9, r0, r0
> +    vmov d10, r0, r0
> +    vmov d11, r0, r0
> +    vmov d12, r0, r0
> +    vmov d13, r0, r0
> +    vmov d14, r0, r0
> +    vmov d15, r0, r0
> +    ldmfd sp!, {r0}
> +    bx lr
> +FUNCTION_END(bsp_init_registers_vfp)
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
