Fwd: [PATCH 007/111] LIBPCI: added PCI layer to cpukit/libpci
Gedare Bloom
gedare at rtems.org
Thu Feb 26 19:35:39 UTC 2015
On Thu, Feb 26, 2015 at 11:38 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
> cpukit/Makefile.am | 3 +
> cpukit/configure.ac | 12 +
> cpukit/libpci/CHANGES | 46 ++
> cpukit/libpci/Makefile.am | 46 ++
> cpukit/libpci/README | 4 +
> cpukit/libpci/pci.h | 375 +++++++++++++
> cpukit/libpci/pci/access.h | 351 +++++++++++++
> cpukit/libpci/pci/cfg.h | 244 +++++++++
> cpukit/libpci/pci/cfg_auto.h | 59 +++
> cpukit/libpci/pci/cfg_peripheral.h | 20 +
> cpukit/libpci/pci/cfg_read.h | 22 +
> cpukit/libpci/pci/cfg_static.h | 22 +
> cpukit/libpci/pci/ids.h | 802 ++++++++++++++++++++++++++++
> cpukit/libpci/pci/ids_extra.h | 19 +
> cpukit/libpci/pci/irq.h | 105 ++++
> cpukit/libpci/pci_access.c | 74 +++
> cpukit/libpci/pci_access_func.c | 73 +++
> cpukit/libpci/pci_access_io.c | 48 ++
> cpukit/libpci/pci_access_mem.c | 22 +
> cpukit/libpci/pci_access_mem_be.c | 67 +++
> cpukit/libpci/pci_access_mem_le.c | 66 +++
> cpukit/libpci/pci_cfg.c | 55 ++
> cpukit/libpci/pci_cfg_auto.c | 1014 ++++++++++++++++++++++++++++++++++++
> cpukit/libpci/pci_cfg_peripheral.c | 32 ++
> cpukit/libpci/pci_cfg_print_code.c | 172 ++++++
> cpukit/libpci/pci_cfg_read.c | 357 +++++++++++++
> cpukit/libpci/pci_cfg_static.c | 157 ++++++
> cpukit/libpci/pci_find.c | 52 ++
> cpukit/libpci/pci_find_dev.c | 49 ++
> cpukit/libpci/pci_for_each.c | 62 +++
> cpukit/libpci/pci_for_each_child.c | 41 ++
> cpukit/libpci/pci_for_each_dev.c | 18 +
> cpukit/libpci/pci_get_dev.c | 36 ++
> cpukit/libpci/pci_irq.c | 20 +
> cpukit/libpci/pci_print.c | 190 +++++++
> cpukit/libpci/preinstall.am | 66 +++
> cpukit/preinstall.am | 3 +-
> cpukit/sapi/include/confdefs.h | 46 ++
> cpukit/wrapup/Makefile.am | 2 +
> doc/ada_user/Makefile.am | 1 +
> doc/ada_user/ada_user.texi | 2 +
> doc/develenv/direct.t | 3 +
> doc/user/Makefile.am | 9 +-
> doc/user/c_user.texi | 2 +
> doc/user/conf.t | 53 ++
> doc/user/libpci.t | 409 +++++++++++++++
> 46 files changed, 5328 insertions(+), 3 deletions(-)
> create mode 100644 cpukit/libpci/CHANGES
> create mode 100644 cpukit/libpci/Makefile.am
> create mode 100644 cpukit/libpci/README
> create mode 100644 cpukit/libpci/pci.h
> create mode 100644 cpukit/libpci/pci/access.h
> create mode 100644 cpukit/libpci/pci/cfg.h
> create mode 100644 cpukit/libpci/pci/cfg_auto.h
> create mode 100644 cpukit/libpci/pci/cfg_peripheral.h
> create mode 100644 cpukit/libpci/pci/cfg_read.h
> create mode 100644 cpukit/libpci/pci/cfg_static.h
> create mode 100644 cpukit/libpci/pci/ids.h
> create mode 100644 cpukit/libpci/pci/ids_extra.h
> create mode 100644 cpukit/libpci/pci/irq.h
> create mode 100644 cpukit/libpci/pci_access.c
> create mode 100644 cpukit/libpci/pci_access_func.c
> create mode 100644 cpukit/libpci/pci_access_io.c
> create mode 100644 cpukit/libpci/pci_access_mem.c
> create mode 100644 cpukit/libpci/pci_access_mem_be.c
> create mode 100644 cpukit/libpci/pci_access_mem_le.c
> create mode 100644 cpukit/libpci/pci_cfg.c
> create mode 100644 cpukit/libpci/pci_cfg_auto.c
> create mode 100644 cpukit/libpci/pci_cfg_peripheral.c
> create mode 100644 cpukit/libpci/pci_cfg_print_code.c
> create mode 100644 cpukit/libpci/pci_cfg_read.c
> create mode 100644 cpukit/libpci/pci_cfg_static.c
> create mode 100644 cpukit/libpci/pci_find.c
> create mode 100644 cpukit/libpci/pci_find_dev.c
> create mode 100644 cpukit/libpci/pci_for_each.c
> create mode 100644 cpukit/libpci/pci_for_each_child.c
> create mode 100644 cpukit/libpci/pci_for_each_dev.c
> create mode 100644 cpukit/libpci/pci_get_dev.c
> create mode 100644 cpukit/libpci/pci_irq.c
> create mode 100644 cpukit/libpci/pci_print.c
> create mode 100644 cpukit/libpci/preinstall.am
> create mode 100644 doc/user/libpci.t
> diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
> index 9a78587..0364bf1 100644
> --- a/cpukit/Makefile.am
> +++ b/cpukit/Makefile.am
> @@ -9,6 +9,7 @@ SUBDIRS += dev
> SUBDIRS += libcrypt
> SUBDIRS += libcsupport libblock libfs
> SUBDIRS += libnetworking librpc
> +SUBDIRS += libpci
> SUBDIRS += libi2c
> SUBDIRS += libmisc
> SUBDIRS += libmd
> @@ -95,7 +96,9 @@ endif
> include_rtems_HEADERS += include/rtems/bspIo.h
> include_rtems_HEADERS += include/rtems/userenv.h
> include_rtems_HEADERS += include/rtems/fs.h
> +if !LIBPCI
shouldn't this be if LIBPCI ?
> include_rtems_HEADERS += include/rtems/pci.h
> +endif
> include_rtems_HEADERS += include/rtems/concat.h
> include_rtems_HEADERS += include/rtems/status-checks.h
> diff --git a/cpukit/configure.ac b/cpukit/configure.ac
> index 27ffd81..8042c35 100644
> --- a/cpukit/configure.ac
> +++ b/cpukit/configure.ac
> @@ -385,6 +385,17 @@ esac
> AM_CONDITIONAL(LIBDL,[test x"$HAVE_LIBDL" = x"yes"])
> AC_MSG_RESULT([$HAVE_LIBDL])
> +# Filter libpci to only build for architectures that have support for it
> +AC_MSG_CHECKING([whether CPU supports libpci])
> +case $RTEMS_CPU in
> + sparc)
> + HAVE_LIBPCI=yes ;;
> + HAVE_LIBPCI=no ;;
> +esac
> +AM_CONDITIONAL(LIBPCI,[test x"$HAVE_LIBPCI" = x"yes"])
> +AC_MSG_RESULT([$HAVE_LIBPCI])
> RTEMS_AMPOLISH3
> # Explicitly list all Makefiles here
> @@ -423,6 +434,7 @@ libgnat/Makefile
> libcrypt/Makefile
> libcsupport/Makefile
> libnetworking/Makefile
> +libpci/Makefile
> librpc/Makefile
> libmisc/Makefile
> libi2c/Makefile
> diff --git a/cpukit/libpci/CHANGES b/cpukit/libpci/CHANGES
> new file mode 100644
> index 0000000..46064f0
> --- /dev/null
> +++ b/cpukit/libpci/CHANGES
> @@ -0,0 +1,46 @@
> + 2011-03-03, Daniel Hellstrom <daniel at gaisler.com>
> + Added support for ROM BARs at devices and PCI-PCI bridges.
> + 2011-02-11, Daniel Hellstrom <daniel at gaisler.com>
> + Split Library into different parts, this enables PCI initialization to be done
> + outside of the PCI Host driver and smaller systems that don't want
> + Configuration Space to be setup.
> + - Access Library (Configuration, Memory and I/O Space read/write routines)
> + - Configuration Libarary
> + A. Auto Config
> + B. Static Config (not implemented yet)
> + - Interrupt Library (shared interrupt support rely on BSP)
> + This file created.
> + Changed library to use 16-bit identifiers (pci_dev_t), instead to 3 integers
> + (BUS,SLOT,FUNC), this reduces the footprint.
> + 2010-09-29, Kristoffer Glembo <kristoffer at gaisler.com>
> + Fixed I/O BAR size calculation of bridges. Reading/Writing to 0x1C instead of
> + faulty 0x1E.
> + 2010-06-10, Daniel Hellstrom <daniel at gaisler.com>
> + Fix in pci_res_insert(), where the above mentioned optimization failed due to
> + bad compare statement. Optimization only affects systems with multiple PCI
> + buses.
> + 2010-04-19, Daniel Hellstrom <daniel at gaisler.com>
> + Optimized resource allocation when bridges are present: the resources lists
> + are sorted by boundary instead of size and a reorder aligorithm introduced
> + that move resources into unused areas if possible.
> + Fixed autoconf issue when bridges are present
> + 2010-02-03, Daniel Hellstrom <daniel at gaisler.com>
> + Fixed initialization problem when first device is a bridge.
> + PCI Library rewritten from scratch. Support multiple buses/bridges, print
> + current PCI configuration space setup, BAR assigment sort implementation
> + speeded up drastically (bootup time noticable shorter), interrupt assignment
> + implemented, PCI Host driver extracted from library, support for I/O areas.
> +.... not updated ... lots of more changes
Is this file worth keeping?
> diff --git a/cpukit/libpci/Makefile.am b/cpukit/libpci/Makefile.am
> index 0000000..fd42a6f
> --- /dev/null
> +++ b/cpukit/libpci/Makefile.am
> @@ -0,0 +1,46 @@
> +## $Id: Makefile.am
We don't use $Id anymore.
> +include $(top_srcdir)/automake/compile.am
> +include $(top_srcdir)/automake/multilib.am
> +if LIBPCI
> +EXTRA_DIST=
> +## PCI Library
> +include_HEADERS = pci.h
> +include_pcidir = $(includedir)/pci
> +include_pci_HEADERS = pci/access.h pci/cfg.h \
> + pci/cfg_auto.h pci/cfg_static.h \
> + pci/cfg_peripheral.h pci/cfg_read.h \
> + pci/ids.h pci/ids_extra.h pci/irq.h
> +noinst_LIBRARIES = libpci.a
> +libpci_a_SOURCES = pci_access.c
> +libpci_a_SOURCES += pci_access_func.c
> +libpci_a_SOURCES += pci_access_io.c
> +libpci_a_SOURCES += pci_access_mem.c
> +libpci_a_SOURCES += pci_access_mem_be.c
> +libpci_a_SOURCES += pci_access_mem_le.c
> +libpci_a_SOURCES += pci_cfg.c
> +libpci_a_SOURCES += pci_cfg_auto.c
> +libpci_a_SOURCES += pci_cfg_print_code.c
> +libpci_a_SOURCES += pci_cfg_read.c
> +libpci_a_SOURCES += pci_cfg_static.c
> +libpci_a_SOURCES += pci_cfg_peripheral.c
> +libpci_a_SOURCES += pci_find.c
> +libpci_a_SOURCES += pci_find_dev.c
> +libpci_a_SOURCES += pci_for_each.c
> +libpci_a_SOURCES += pci_for_each_dev.c
> +libpci_a_SOURCES += pci_for_each_child.c
> +libpci_a_SOURCES += pci_get_dev.c
> +libpci_a_SOURCES += pci_irq.c
> +libpci_a_SOURCES += pci_print.c
> +endif
> +include $(srcdir)/preinstall.am
> +include $(top_srcdir)/automake/local.am
> diff --git a/cpukit/libpci/README b/cpukit/libpci/README
> index 0000000..334f3a9
> --- /dev/null
> +++ b/cpukit/libpci/README
> @@ -0,0 +1,4 @@
> +PCI Library
> +LIBPCI is documented in the ../../doc directory, see ../../doc/README how
> +to build documentation.
I'd like to see doxygen for these headers (eventually).
> diff --git a/cpukit/libpci/pci.h b/cpukit/libpci/pci.h
> index 0000000..e9955bc
> --- /dev/null
> +++ b/cpukit/libpci/pci.h
> @@ -0,0 +1,375 @@
> + * PCI defines and function prototypes
> + * Copyright 1994, Drew Eckhardt
> + * Copyright 1997, 1998 Martin Mares <mj at atrey.karlin.mff.cuni.cz>
> + * New PCI library written from scratch. Defines in this file was reused.
> + * auto-generated pci_ids.h also reused.
> + * Copyright 2009, Cobham Gaisler AB
> + * For more information, please consult the following manuals (look at
> + * http://www.pcisig.com/ for how to get them):
> + * PCI BIOS Specification
> + * PCI Local Bus Specification
> + * PCI to PCI Bridge Specification
> + * PCI System Design Guide
License needed
> +#ifndef __PCI_H__
> +#define __PCI_H__
> +#include <pci/ids.h>
> + * Under PCI, each device has 256 bytes of configuration address space,
> + * of which the first 64 bytes are standardized as follows:
> +#define PCI_VENDOR_ID 0x00 /* 16 bits */
> +#define PCI_DEVICE_ID 0x02 /* 16 bits */
> +#define PCI_COMMAND 0x04 /* 16 bits */
> +#define PCI_COMMAND_IO 0x1 /* Enable response in I/O space */
> +#define PCI_COMMAND_MEMORY 0x2 /* Enable response in Memory space */
> +#define PCI_COMMAND_MASTER 0x4 /* Enable bus mastering */
> +#define PCI_COMMAND_SPECIAL 0x8 /* Enable response to special cycles */
> +#define PCI_COMMAND_INVALIDATE 0x10 /* Use memory write and invalidate */
> +#define PCI_COMMAND_VGA_PALETTE 0x20 /* Enable palette snooping */
> +#define PCI_COMMAND_PARITY 0x40 /* Enable parity checking */
> +#define PCI_COMMAND_WAIT 0x80 /* Enable address/data stepping */
> +#define PCI_COMMAND_SERR 0x100 /* Enable SERR */
> +#define PCI_COMMAND_FAST_BACK 0x200 /* Enable back-to-back writes */
> +#define PCI_STATUS 0x06 /* 16 bits */
> +#define PCI_STATUS_66MHZ 0x20 /* Support 66 Mhz PCI 2.1 bus */
> +#define PCI_STATUS_UDF 0x40 /* Support User Definable Features */
> +#define PCI_STATUS_FAST_BACK 0x80 /* Accept fast-back to back */
> +#define PCI_STATUS_PARITY 0x100 /* Detected parity error */
> +#define PCI_STATUS_DEVSEL_MASK 0x600 /* DEVSEL timing */
> +#define PCI_STATUS_DEVSEL_FAST 0x000
> +#define PCI_STATUS_DEVSEL_MEDIUM 0x200
> +#define PCI_STATUS_DEVSEL_SLOW 0x400
> +#define PCI_STATUS_SIG_TARGET_ABORT 0x800 /* Set on target abort */
> +#define PCI_STATUS_REC_TARGET_ABORT 0x1000 /* Master ack of " */
> +#define PCI_STATUS_REC_MASTER_ABORT 0x2000 /* Set on master abort */
> +#define PCI_STATUS_SIG_SYSTEM_ERROR 0x4000 /* Set when we drive SERR */
> +#define PCI_STATUS_DETECTED_PARITY 0x8000 /* Set on parity error */
> +#define PCI_CLASS_REVISION 0x08 /* High 24 bits are class, low 8
> + revision */
> +#define PCI_REVISION_ID 0x08 /* Revision ID */
> +#define PCI_CLASS_PROG 0x09 /* Reg. Level Programming Interface */
> +#define PCI_CLASS_DEVICE 0x0a /* Device class */
> +#define PCI_CACHE_LINE_SIZE 0x0c /* 8 bits */
> +#define PCI_LATENCY_TIMER 0x0d /* 8 bits */
> +#define PCI_HEADER_TYPE 0x0e /* 8 bits */
> +#define PCI_HEADER_TYPE_NORMAL 0
> +#define PCI_HEADER_TYPE_BRIDGE 1
> +#define PCI_HEADER_TYPE_CARDBUS 2
> +#define PCI_BIST 0x0f /* 8 bits */
> +#define PCI_BIST_CODE_MASK 0x0f /* Return result */
> +#define PCI_BIST_START 0x40 /* 1 to start BIST, 2 secs or less */
> +#define PCI_BIST_CAPABLE 0x80 /* 1 if BIST capable */
> + * Base addresses specify locations in memory or I/O space.
> + * Decoded size can be determined by writing a value of
> + * 0xffffffff to the register, and reading it back. Only
> + * 1 bits are decoded.
> +#define PCI_BASE_ADDRESS_0 0x10 /* 32 bits */
> +#define PCI_BASE_ADDRESS_1 0x14 /* 32 bits [htype 0,1 only] */
> +#define PCI_BASE_ADDRESS_2 0x18 /* 32 bits [htype 0 only] */
> +#define PCI_BASE_ADDRESS_3 0x1c /* 32 bits */
> +#define PCI_BASE_ADDRESS_4 0x20 /* 32 bits */
> +#define PCI_BASE_ADDRESS_5 0x24 /* 32 bits */
> +#define PCI_BASE_ADDRESS_SPACE 0x01 /* 0 = memory, 1 = I/O */
> +#define PCI_BASE_ADDRESS_SPACE_IO 0x01
> +#define PCI_BASE_ADDRESS_SPACE_MEMORY 0x00
> +#define PCI_BASE_ADDRESS_MEM_TYPE_MASK 0x06
> +#define PCI_BASE_ADDRESS_MEM_TYPE_32 0x00 /* 32 bit address */
> +#define PCI_BASE_ADDRESS_MEM_TYPE_1M 0x02 /* Below 1M */
> +#define PCI_BASE_ADDRESS_MEM_TYPE_64 0x04 /* 64 bit address */
> +#define PCI_BASE_ADDRESS_MEM_PREFETCH 0x08 /* prefetchable? */
> +#define PCI_BASE_ADDRESS_MEM_MASK (~0x0fUL)
> +#define PCI_BASE_ADDRESS_IO_MASK (~0x03UL)
> +/* bit 1 is reserved if address_space = 1 */
> +/* Header type 0 (normal devices) */
> +#define PCI_CARDBUS_CIS 0x28
> +#define PCI_SUBSYSTEM_VENDOR_ID 0x2c
> +#define PCI_SUBSYSTEM_ID 0x2e
> +#define PCI_ROM_ADDRESS 0x30 /* Bits 31..11 are address, 10..1 reserved */
> +#define PCI_ROM_ADDRESS_ENABLE 0x01
> +#define PCI_ROM_ADDRESS_MASK (~0x7ffUL)
> +/* 0x34 Capabilities Pointer (PCI 2.3) */
> +#define PCI_CAP_PTR 0x34 /* 8 bits */
> +/* 0x35-0x3b are reserved */
> +#define PCI_INTERRUPT_LINE 0x3c /* 8 bits */
> +#define PCI_INTERRUPT_PIN 0x3d /* 8 bits */
> +#define PCI_MIN_GNT 0x3e /* 8 bits */
> +#define PCI_MAX_LAT 0x3f /* 8 bits */
> +/* Header type 1 (PCI-to-PCI bridges) */
> +#define PCI_PRIMARY_BUS 0x18 /* Primary bus number */
> +#define PCI_SECONDARY_BUS 0x19 /* Secondary bus number */
> +#define PCI_SUBORDINATE_BUS 0x1a /* Highest bus number behind the bridge */
> +#define PCI_SEC_LATENCY_TIMER 0x1b /* Latency timer for secondary interface */
> +#define PCI_IO_BASE 0x1c /* I/O range behind the bridge */
> +#define PCI_IO_LIMIT 0x1d
> +#define PCI_IO_RANGE_TYPE_MASK 0x0f /* I/O bridging type */
> +#define PCI_IO_RANGE_TYPE_16 0x00
> +#define PCI_IO_RANGE_TYPE_32 0x01
> +#define PCI_IO_RANGE_MASK (~0x0f)
> +#define PCI_SEC_STATUS 0x1e /* Secondary status register, only bit 14 used */
> +#define PCI_MEMORY_BASE 0x20 /* Memory range behind */
> +#define PCI_MEMORY_LIMIT 0x22
> +#define PCI_MEMORY_RANGE_TYPE_MASK 0x0f
> +#define PCI_MEMORY_RANGE_MASK (~0x0f)
> +#define PCI_PREF_MEMORY_BASE 0x24 /* Prefetchable memory range behind */
> +#define PCI_PREF_MEMORY_LIMIT 0x26
> +#define PCI_PREF_RANGE_TYPE_MASK 0x0f
> +#define PCI_PREF_RANGE_TYPE_32 0x00
> +#define PCI_PREF_RANGE_TYPE_64 0x01
> +#define PCI_PREF_RANGE_MASK (~0x0f)
> +#define PCI_PREF_BASE_UPPER32 0x28 /* Upper half of prefetchable memory range */
> +#define PCI_PREF_LIMIT_UPPER32 0x2c
> +#define PCI_IO_BASE_UPPER16 0x30 /* Upper half of I/O addresses */
> +#define PCI_IO_LIMIT_UPPER16 0x32
> +/* 0x34-0x3b is reserved */
> +#define PCI_ROM_ADDRESS1 0x38 /* Same as PCI_ROM_ADDRESS, but for htype 1 */
> +/* 0x3c-0x3d are same as for htype 0 */
> +#define PCI_BRIDGE_CONTROL 0x3e
> +#define PCI_BRIDGE_CTL_PARITY 0x01 /* Enable parity detection on secondary interface */
> +#define PCI_BRIDGE_CTL_SERR 0x02 /* The same for SERR forwarding */
> +#define PCI_BRIDGE_CTL_NO_ISA 0x04 /* Disable bridging of ISA ports */
> +#define PCI_BRIDGE_CTL_VGA 0x08 /* Forward VGA addresses */
> +#define PCI_BRIDGE_CTL_MASTER_ABORT 0x20 /* Report master aborts */
> +#define PCI_BRIDGE_CTL_BUS_RESET 0x40 /* Secondary bus reset */
> +#define PCI_BRIDGE_CTL_FAST_BACK 0x80 /* Fast Back2Back enabled on secondary interface */
> +/* Header type 2 (CardBus bridges) */
> +/* 0x14-0x15 reserved */
> +#define PCI_CB_SEC_STATUS 0x16 /* Secondary status */
> +#define PCI_CB_PRIMARY_BUS 0x18 /* PCI bus number */
> +#define PCI_CB_CARD_BUS 0x19 /* CardBus bus number */
> +#define PCI_CB_SUBORDINATE_BUS 0x1a /* Subordinate bus number */
> +#define PCI_CB_LATENCY_TIMER 0x1b /* CardBus latency timer */
> +#define PCI_CB_MEMORY_BASE_0 0x1c
> +#define PCI_CB_MEMORY_LIMIT_0 0x20
> +#define PCI_CB_MEMORY_BASE_1 0x24
> +#define PCI_CB_MEMORY_LIMIT_1 0x28
> +#define PCI_CB_IO_BASE_0 0x2c
> +#define PCI_CB_IO_BASE_0_HI 0x2e
> +#define PCI_CB_IO_LIMIT_0 0x30
> +#define PCI_CB_IO_LIMIT_0_HI 0x32
> +#define PCI_CB_IO_BASE_1 0x34
> +#define PCI_CB_IO_BASE_1_HI 0x36
> +#define PCI_CB_IO_LIMIT_1 0x38
> +#define PCI_CB_IO_LIMIT_1_HI 0x3a
> +#define PCI_CB_IO_RANGE_MASK (~0x03)
> +#define PCI_CB_BRIDGE_CONTROL 0x3e
> +#define PCI_CB_BRIDGE_CTL_PARITY 0x01 /* Similar to standard bridge control register */
> +#define PCI_CB_BRIDGE_CTL_SERR 0x02
> +#define PCI_CB_BRIDGE_CTL_ISA 0x04
> +#define PCI_CB_BRIDGE_CTL_VGA 0x08
> +#define PCI_CB_BRIDGE_CTL_MASTER_ABORT 0x20
> +#define PCI_CB_BRIDGE_CTL_CB_RESET 0x40 /* CardBus reset */
> +#define PCI_CB_BRIDGE_CTL_16BIT_INT 0x80 /* Enable interrupt for 16-bit cards */
> +#define PCI_CB_BRIDGE_CTL_PREFETCH_MEM0 0x100 /* Prefetch enable for both memory regions */
> +#define PCI_CB_BRIDGE_CTL_PREFETCH_MEM1 0x200
> +#define PCI_CB_BRIDGE_CTL_POST_WRITES 0x400
> +#define PCI_CB_SUBSYSTEM_VENDOR_ID 0x40
> +#define PCI_CB_SUBSYSTEM_ID 0x42
> +#define PCI_CB_LEGACY_MODE_BASE 0x44 /* 16-bit PC Card legacy mode base address (ExCa) */
> +/* 0x48-0x7f reserved */
> +/* Device classes and subclasses */
> +#define PCI_CLASS_NOT_DEFINED 0x0000
> +#define PCI_CLASS_NOT_DEFINED_VGA 0x0001
> +#define PCI_BASE_CLASS_STORAGE 0x01
> +#define PCI_CLASS_STORAGE_SCSI 0x0100
> +#define PCI_CLASS_STORAGE_IDE 0x0101
> +#define PCI_CLASS_STORAGE_FLOPPY 0x0102
> +#define PCI_CLASS_STORAGE_IPI 0x0103
> +#define PCI_CLASS_STORAGE_RAID 0x0104
> +#define PCI_CLASS_STORAGE_OTHER 0x0180
> +#define PCI_BASE_CLASS_NETWORK 0x02
> +#define PCI_CLASS_NETWORK_ETHERNET 0x0200
> +#define PCI_CLASS_NETWORK_TOKEN_RING 0x0201
> +#define PCI_CLASS_NETWORK_FDDI 0x0202
> +#define PCI_CLASS_NETWORK_ATM 0x0203
> +#define PCI_CLASS_NETWORK_OTHER 0x0280
> +#define PCI_BASE_CLASS_DISPLAY 0x03
> +#define PCI_CLASS_DISPLAY_VGA 0x0300
> +#define PCI_CLASS_DISPLAY_XGA 0x0301
> +#define PCI_CLASS_DISPLAY_OTHER 0x0380
> +#define PCI_BASE_CLASS_MULTIMEDIA 0x04
> +#define PCI_CLASS_MULTIMEDIA_VIDEO 0x0400
> +#define PCI_CLASS_MULTIMEDIA_AUDIO 0x0401
> +#define PCI_CLASS_MULTIMEDIA_OTHER 0x0480
> +#define PCI_BASE_CLASS_MEMORY 0x05
> +#define PCI_CLASS_MEMORY_RAM 0x0500
> +#define PCI_CLASS_MEMORY_FLASH 0x0501
> +#define PCI_CLASS_MEMORY_OTHER 0x0580
> +#define PCI_BASE_CLASS_BRIDGE 0x06
> +#define PCI_CLASS_BRIDGE_HOST 0x0600
> +#define PCI_CLASS_BRIDGE_ISA 0x0601
> +#define PCI_CLASS_BRIDGE_EISA 0x0602
> +#define PCI_CLASS_BRIDGE_MC 0x0603
> +#define PCI_CLASS_BRIDGE_PCI 0x0604
> +#define PCI_CLASS_BRIDGE_PCMCIA 0x0605
> +#define PCI_CLASS_BRIDGE_NUBUS 0x0606
> +#define PCI_CLASS_BRIDGE_CARDBUS 0x0607
> +#define PCI_CLASS_BRIDGE_OTHER 0x0680
> +#define PCI_BASE_CLASS_COMMUNICATION 0x07
> +#define PCI_CLASS_COMMUNICATION_SERIAL 0x0700
> +#define PCI_CLASS_COMMUNICATION_PARALLEL 0x0701
> +#define PCI_CLASS_COMMUNICATION_OTHER 0x0780
> +#define PCI_BASE_CLASS_SYSTEM 0x08
> +#define PCI_CLASS_SYSTEM_PIC 0x0800
> +#define PCI_CLASS_SYSTEM_DMA 0x0801
> +#define PCI_CLASS_SYSTEM_TIMER 0x0802
> +#define PCI_CLASS_SYSTEM_RTC 0x0803
> +#define PCI_CLASS_SYSTEM_OTHER 0x0880
> +#define PCI_BASE_CLASS_INPUT 0x09
> +#define PCI_CLASS_INPUT_KEYBOARD 0x0900
> +#define PCI_CLASS_INPUT_PEN 0x0901
> +#define PCI_CLASS_INPUT_MOUSE 0x0902
> +#define PCI_CLASS_INPUT_OTHER 0x0980
> +#define PCI_BASE_CLASS_DOCKING 0x0a
> +#define PCI_CLASS_DOCKING_GENERIC 0x0a00
> +#define PCI_CLASS_DOCKING_OTHER 0x0a01
> +#define PCI_BASE_CLASS_PROCESSOR 0x0b
> +#define PCI_CLASS_PROCESSOR_386 0x0b00
> +#define PCI_CLASS_PROCESSOR_486 0x0b01
> +#define PCI_CLASS_PROCESSOR_PENTIUM 0x0b02
> +#define PCI_CLASS_PROCESSOR_ALPHA 0x0b10
> +#define PCI_CLASS_PROCESSOR_POWERPC 0x0b20
> +#define PCI_CLASS_PROCESSOR_CO 0x0b40
> +#define PCI_BASE_CLASS_SERIAL 0x0c
> +#define PCI_CLASS_SERIAL_FIREWIRE 0x0c00
> +#define PCI_CLASS_SERIAL_ACCESS 0x0c01
> +#define PCI_CLASS_SERIAL_SSA 0x0c02
> +#define PCI_CLASS_SERIAL_USB 0x0c03
> +#define PCI_CLASS_SERIAL_FIBER 0x0c04
> +#define PCI_CLASS_OTHERS 0xff
> +#define PCI_INVALID_VENDORDEVICEID 0xffffffff
> +#define PCI_MULTI_FUNCTION 0x80
> +#define PCI_MAX_DEVICES 32
> +#define PCI_MAX_FUNCTIONS 8
> +#include <pci/access.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +/* The PCI Library have the following build time configuration options. It is
> + * up to the BSP header file (bsp.h) to set options properly.
> + * BSP_PCI_BIG_ENDIAN - Access inline routines will be for a big-endian PCI
> + * bus, if not defined the routines will assume that
> + * PCI is as the standard defines: little-endian.
> + * Note that drivers may be run-time configurable,
> + * meaning that they may adopt to either big-endian or
> + * little-endian PCI bus, the host driver or BSP may
> + * detect endianness during run-time.
> +/* Error return values */
> +enum {
> + PCISTS_ERR = -1, /* Undefined Error */
> + PCISTS_OK = 0,
> + PCISTS_EINVAL = 1, /* Bad input arguments */
> + PCISTS_MSTABRT = 2, /* CFG space access error (can be ignored) */
> +/* PCI System type can be used to determine system for drivers. Normally
> + * the system is Host, but the peripheral configuration library also supports
> + * being PCI peripheral not allowed to access configuration space.
> + * The active configuration Library set this variable.
> +enum {
> + PCI_SYSTEM_NONE = 0,
> + PCI_SYSTEM_HOST = 1,
> + PCI_SYSTEM_PERIPHERAL = 2,
> +extern int pci_system_type;
> +/* PCI Bus Endianness. The PCI specification is little endian, however on some
> + * embedded systems (AT697-LEON2 for example) the PCI bus is defined as big
> + * endian (non-standard) in order to avoid byte-twisting.
> +enum {
> + PCI_LITTLE_ENDIAN = 0,
> + PCI_BIG_ENDIAN = 1,
> +extern int pci_endian;
> +/* Return the number of PCI busses in the system */
> +extern int pci_bus_count(void);
> +/* Scan the PCI bus and print the PCI device/functions/bridges and their
> + * current resources and size to the system console.
> +extern void pci_print(void);
> +/* Print current configuration of a single PCI device by reading PCI
> + * configuration space
> +extern void pci_print_dev(pci_dev_t dev);
> +extern void pci_print_device(int bus, int slot, int function);
> +/*** PCI Configuration Space direct access routines ***/
> +/* Function iterates over all PCI buses/devices/functions and calls
> + * func(PCIDEV,arg) for each present device. The iteration is stopped if
> + * func() returns non-zero result the same result is returned. As long
> + * as func() returns zero the function will keep on iterating, when all
> + * devices has been processed the function return zero.
> + * The function iterates over all devices/functions on all buses by accessing
> + * configuration space directly (PCI RAM data structures not used). This
> + * function is valid to call after PCI buses have been enumrated.
> +extern int pci_for_each(int (*func)(pci_dev_t, void*), void *arg);
> +/* Get PCI Configuration space BUS|SLOT|FUNC for a device matching PCI
> + * Vendor, Device and instance number 'index'.
> + * Return Values
> + * -1 pci_find_dev did not find a device matching the criterion.
> + * 0 device was found, *pdev was updated with the device's BUS|SLOT|FUNC
> +extern int pci_find(uint16_t ven, uint16_t dev, int index, pci_dev_t *pdev);
> +#ifdef __cplusplus
> +#endif
> +#endif /* __PCI_H__ */
> diff --git a/cpukit/libpci/pci/access.h b/cpukit/libpci/pci/access.h
> index 0000000..f8365db
> --- /dev/null
> +++ b/cpukit/libpci/pci/access.h
> @@ -0,0 +1,351 @@
> +/* Routines to access PCI memory/configuration space and other PCI related
> + * functions the PCI Library provides.
> + * COPYRIGHT (c) 2010.
> + * Cobham Gaisler AB.
Can you put your copyright on one line? It makes it easier to 'grep'.
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#ifndef __PCI_ACCESS_H__
> +#define __PCI_ACCESS_H__
> +#include <stdint.h>
> +#include <libcpu/byteorder.h>
I'm not sure we should include libcpu in cpukit. Although I guess the
cache manager is done like that.
> +#include <pci.h>
> +/* Let BSP configure load/store from PCI */
> +#include <bsp.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +/* Identification of a PCI configuration space device (16-bit) */
> +typedef uint16_t pci_dev_t;
> +/* Create a PCI Configuration Space ID */
> +#define PCI_DEV(bus, slot, func) (((bus)<<8) | ((slot)<<3) | (func))
> +/* Get Bus of a PCI Configuration Space ID */
> +#define PCI_DEV_BUS(dev) (((dev) >> 8) & 0xff)
> +/* Get Slot/Device of a PCI Configuration Space ID */
> +#define PCI_DEV_SLOT(dev) (((dev) >> 3) & 0x1f)
> +/* Get Function of a PCI Configuration Space ID */
> +#define PCI_DEV_FUNC(dev) ((dev) & 0x7)
> +/* Get Device and Function of a PCI Configuration Space ID */
> +#define PCI_DEV_DEVFUNC(dev) ((dev) & 0xff)
> +/* Expand Device into argument lists */
> +#define PCI_DEV_EXPAND(dev) PCI_DEV_BUS((dev)), PCI_DEV_SLOT((dev)), PCI_DEV_FUNC((dev))
> +/* Configuration Space Read/Write Operations */
> +struct pci_cfg_ops {
> + /* Configuration Space Access and Setup Routines */
> + int (*read8)(pci_dev_t dev, int ofs, uint8_t *data);
> + int (*read16)(pci_dev_t dev, int ofs, uint16_t *data);
> + int (*read32)(pci_dev_t dev, int ofs, uint32_t *data);
> + int (*write8)(pci_dev_t dev, int ofs, uint8_t data);
> + int (*write16)(pci_dev_t dev, int ofs, uint16_t data);
> + int (*write32)(pci_dev_t dev, int ofs, uint32_t data);
> +/* Read a register over PCI I/O Space, and swap it if necessary (due to
> + * PCI endianness)
> +struct pci_io_ops {
> + uint8_t (*read8)(uint8_t *adr);
> + uint16_t(*read16)(uint16_t *adr);
> + uint32_t (*read32)(uint32_t *adr);
> + void (*write8)(uint8_t *adr, uint8_t data);
> + void (*write16)(uint16_t *adr, uint16_t data);
> + void (*write32)(uint32_t *adr, uint32_t data);
> +/* Read a register over PCI Memory Space (non-prefetchable memory), and
> + * swap it if necessary (due to PCI endianness)
> +struct pci_memreg_ops {
> + uint8_t (*ld8)(uint8_t *adr);
> + void (*st8)(uint8_t *adr, uint8_t data);
> + uint16_t(*ld_le16)(uint16_t *adr);
> + void (*st_le16)(uint16_t *adr, uint16_t data);
> + uint16_t(*ld_be16)(uint16_t *adr);
> + void (*st_be16)(uint16_t *adr, uint16_t data);
> + uint32_t (*ld_le32)(uint32_t *adr);
> + void (*st_le32)(uint32_t *adr, uint32_t data);
> + uint32_t (*ld_be32)(uint32_t *adr);
> + void (*st_be32)(uint32_t *adr, uint32_t data);
> +typedef uint8_t (*pci_ld8_t)(uint8_t *adr);
> +typedef void (*pci_st8_t)(uint8_t *adr, uint8_t data);
> +typedef uint16_t(pci_ld16_t)(uint16_t *adr);
> +typedef void (*pci_st16_t)(uint16_t *adr, uint16_t data);
> +typedef uint32_t (*pci_ld32_t)(uint32_t *adr);
> +typedef void (*pci_st32_t)(uint32_t *adr, uint32_t data);
> +struct pci_access_drv {
> + /* Configuration */
> + struct pci_cfg_ops cfg;
> + /* I/O Access operations */
> + struct pci_io_ops io;
> + /* Registers over Memory Access operations. Note that these funcs
> + * are only for code that need to be compatible with both Big-Endian
> + * and Little-Endian PCI bus or for some other reason need function
> + * pointers to access functions. Normally drivers use the inline
> + * functions for Registers-over-Memory access to avoid extra function
> + * call.
> + struct pci_memreg_ops *memreg;
> + /* Translate from PCI address to CPU address (dir=0). Translate
> + * CPU address to PCI address (dir!=0). The address will can be
> + * used to perform I/O access or memory access by CPU or PCI DMA
> + * peripheral.
> + * address In/Out. CPU address or PCI address.
> + * type Access type. 1=I/O, 2=MEMIO, 3=MEM
> + * dir Translate direction. 0=PCI-to-CPU, 0!=CPU-to-PCI,
> + * Return Value
> + * 0 = Success
> + * -1 = Requested Address not mapped into other address space
> + * i.e. not accessible
> + int (*translate)(uint32_t *address, int type, int dir);
> +/* Access Routines valid after a PCI-Access-Driver has registered */
> +extern struct pci_access_drv pci_access_ops;
> +/* Register PCI Access Driver */
> +extern int pci_access_drv_register(struct pci_access_drv *drv);
> +/* Set/unset bits in command and status register of a PCI device */
> +extern void pci_modify_cmdsts(pci_dev_t dev, uint32_t mask, uint32_t val);
> +/* Enable Memory in command register */
> +static inline void pci_mem_enable(pci_dev_t dev)
> + pci_modify_cmdsts(dev, PCI_COMMAND_MEMORY, PCI_COMMAND_MEMORY);
> +static inline void pci_mem_disable(pci_dev_t dev)
> + pci_modify_cmdsts(dev, PCI_COMMAND_MEMORY, 0);
> +static inline void pci_io_enable(pci_dev_t dev)
> + pci_modify_cmdsts(dev, PCI_COMMAND_IO, PCI_COMMAND_IO);
> +static inline void pci_io_disable(pci_dev_t dev)
> + pci_modify_cmdsts(dev, PCI_COMMAND_IO, 0);
> +static inline void pci_master_enable(pci_dev_t dev)
> + pci_modify_cmdsts(dev, PCI_COMMAND_MASTER, PCI_COMMAND_MASTER);
> +static inline void pci_master_disable(pci_dev_t dev)
> + pci_modify_cmdsts(dev, PCI_COMMAND_MASTER, 0);
> +/* Configuration Space Access Read Routines */
> +extern int pci_cfg_r8(pci_dev_t dev, int ofs, uint8_t *data);
> +extern int pci_cfg_r16(pci_dev_t dev, int ofs, uint16_t *data);
> +extern int pci_cfg_r32(pci_dev_t dev, int ofs, uint32_t *data);
> +/* Configuration Space Access Write Routines */
> +extern int pci_cfg_w8(pci_dev_t dev, int ofs, uint8_t data);
> +extern int pci_cfg_w16(pci_dev_t dev, int ofs, uint16_t data);
> +extern int pci_cfg_w32(pci_dev_t dev, int ofs, uint32_t data);
> +/* Read a register over PCI I/O Space */
> +extern uint8_t pci_io_r8(uint32_t adr);
> +extern uint16_t pci_io_r16(uint32_t adr);
> +extern uint32_t pci_io_r32(uint32_t adr);
> +/* Write a register over PCI I/O Space */
> +extern void pci_io_w8(uint32_t adr, uint8_t data);
> +extern void pci_io_w16(uint32_t adr, uint16_t data);
> +extern void pci_io_w32(uint32_t adr, uint32_t data);
> +/* Translate PCI address into CPU accessible address */
> +static inline int pci_pci2cpu(uint32_t *address, int type)
> + return pci_access_ops.translate(address, type, 0);
> +/* Translate CPU accessible address into PCI address (for DMA) */
> +static inline int pci_cpu2pci(uint32_t *address, int type)
> + return pci_access_ops.translate(address, type, 1);
> +/*** Read/Write a register over PCI Memory Space ***/
> +static inline uint8_t pci_ld8(volatile uint8_t *addr)
> + return *addr;
> +static inline void pci_st8(volatile uint8_t *addr, uint8_t val)
> + *addr = val;
> +#ifdef BSP_PCI_BIG_ENDIAN
> +/* BSP has decided Big Endian PCI Bus (non-standard) */
> +static inline uint16_t pci_ld_le16(volatile uint16_t *addr)
> + return ld_be16(addr);
> +static inline void pci_st_le16(volatile uint16_t *addr, uint16_t val)
> + st_be16(addr, val);
> +static inline uint32_t pci_ld_le32(volatile uint32_t *addr)
> + return ld_be32(addr);
> +static inline void pci_st_le32(volatile uint32_t *addr, uint32_t val)
> + st_be32(addr, val);
> +static inline uint16_t pci_ld_be16(volatile uint16_t *addr)
> + return ld_le16(addr);
> +static inline void pci_st_be16(volatile uint16_t *addr, uint16_t val)
> + st_le16(addr, val);
> +static inline uint32_t pci_ld_be32(volatile uint32_t *addr)
> + return ld_le32(addr);
> +static inline void pci_st_be32(volatile uint32_t *addr, uint32_t val)
> + st_le32(addr, val);
> +#else
> +/* Little Endian PCI Bus */
> +#endif
> +/* Registers-over-Memory Space access routines. The routines are not inlined
> + * so it is possible during run-time to select which function implemention
> + * to use. The use of these functions are not recommended since it will have a
> + * performance penalty.
> + * 8-bit accesses are the same for Little and Big endian PCI buses.
> +uint8_t pci_mem_ld8(uint8_t *adr);
> +void pci_mem_st8(uint8_t *adr, uint8_t data);
> +/* Registers-over-Memory Space - Generic Big endian PCI bus definitions */
> +uint16_t pci_mem_be_ld_le16(uint16_t *adr);
> +uint16_t pci_mem_be_ld_be16(uint16_t *adr);
> +uint32_t pci_mem_be_ld_le32(uint32_t *adr);
> +uint32_t pci_mem_be_ld_be32(uint32_t *adr);
> +void pci_mem_be_st_le16(uint16_t *adr, uint16_t data);
> +void pci_mem_be_st_be16(uint16_t *adr, uint16_t data);
> +void pci_mem_be_st_le32(uint32_t *adr, uint32_t data);
> +void pci_mem_be_st_be32(uint32_t *adr, uint32_t data);
> +/* Registers-over-Memory Space - Generic Little endian PCI bus definitions */
> +uint16_t pci_mem_le_ld_le16(uint16_t *adr);
> +uint16_t pci_mem_le_ld_be16(uint16_t *adr);
> +uint32_t pci_mem_le_ld_le32(uint32_t *adr);
> +uint32_t pci_mem_le_ld_be32(uint32_t *adr);
> +void pci_mem_le_st_le16(uint16_t *adr, uint16_t data);
> +void pci_mem_le_st_be16(uint16_t *adr, uint16_t data);
> +void pci_mem_le_st_le32(uint32_t *adr, uint32_t data);
> +void pci_mem_le_st_be32(uint32_t *adr, uint32_t data);
> +/* Get Read/Write function for accessing a register over PCI Memory Space
> + * (non-inline functions).
> + * Arguments
> + * wr 0(Read), 1(Write)
> + * size 1(Byte), 2(Word), 4(Double Word)
> + * func Where function pointer will be stored
> + * endian PCI_LITTLE_ENDIAN or PCI_BIG_ENDIAN
> + * type 1(I/O), 3(REG over MEM), 4(CFG)
> + * Return
> + * 0 Found function
> + * others No such function defined by host driver or BSP
> +extern int pci_access_func(int wr, int size, void **func, int endian, int type);
> +/* Predefined functions for Host drivers or BSPs that define the
> + * register-over-memory space functions operations.
> +extern struct pci_memreg_ops pci_mem_le_ops; /* For Little-Endian PCI bus */
> +extern struct pci_memreg_ops pci_mem_be_ops; /* For Big-Endian PCI bus */
> +#ifdef __cplusplus
> +#endif
> +#endif /* !__PCI_ACCESS_H__ */
> diff --git a/cpukit/libpci/pci/cfg.h b/cpukit/libpci/pci/cfg.h
> index 0000000..18c48db
> --- /dev/null
> +++ b/cpukit/libpci/pci/cfg.h
> @@ -0,0 +1,244 @@
> +/* PCI Configuration Library, two versions of the library exists:
> + * - auto configuration (default)
> + * - static configuration (user defined config)
> + * both versions are defined here.
> +#ifndef __PCI_CFG_H__
> +#define __PCI_CFG_H__
> +#include <pci.h>
> +/* PCI Configuration library */
> +/* Return the number of PCI buses in system */
> +/* PCI Address assigned to BARs which failed to fit into the PCI Window or
> + * is disabled by any other cause.
> +extern uint32_t pci_invalid_address;
> +/* PCI Configuration Library of the system */
> +enum {
> + PCI_CONFIG_LIB_NONE = 0,
> + PCI_CONFIG_LIB_AUTO = 1,
> + PCI_CONFIG_LIB_STATIC = 2,
> + PCI_CONFIG_LIB_READ = 3,
> + PCI_CONFIG_LIB_PERIPHERAL = 4,
> +extern const int pci_config_lib_type;
> +/* Configuration library function pointers, these are set in <rtems/confdefs.h>
> + * by project configuration or by the BSP. The configuration will pull in the
> + * PCI Library needed and the PCI initialization functions will call these
> + * functions on initialization from the host driver.
> +extern int (*pci_config_lib_init)(void);
> +extern void (*pci_config_lib_register)(void *config);
> +/* Configure PCI devices and bridges, and setup the RAM data structures
> + * describing the PCI devices currently present in the system.
> + * Returns 0 on success, -1 on failure.
> +extern int pci_config_init(void);
> +/* Register a config-library specific configuration used by the libarary in
> + * pci_config_init().
> +extern void pci_config_register(void *config);
> +/* Print current PCI configuration (C-code) to terminal, can be used in
> + * static and peripheral PCI configuration library. The configuration is
> + * taken from the current configuration library setup.
> +extern void pci_cfg_print(void);
> +struct pci_bus; /* Bridge Device and secondary bus information */
> +struct pci_dev; /* Device/function */
> +struct pci_res; /* Resource: BAR, ROM or Bridge Window */
> +/* The Host Bridge and all subdevices (the PCI RAM data structure) */
> +extern struct pci_bus pci_hb;
> +/* Iterate over all PCI devices on a bus (see search options) and call func(),
> + * iteration is stopped if a non-zero value is returned by func().
> + * The function iterates over the PCI RAM data structure, it is not
> + * available until after all devices have been found and pci_hb is populated,
> + * typically after pci_config_init() is called.
> + * search options: 0 (no child buses), 1 (depth first, recursive)
> + * Return Values
> + * 0 All PCI devices were processed, func() returned 0 on every call
> + * X func() returned non-zero X value, the search was stopped
> +#define SEARCH_DEPTH 1
does this define need to be here?
> +extern int pci_for_each_child(
> + struct pci_bus *bus,
> + int (*func)(struct pci_dev *, void *arg),
> + void *arg,
> + int search);
> +/* Depth first search of all PCI devices in PCI RAM data structure and call
> + * func(dev, arg), iteration is stopped if a non-zero value is returned by
> + * func().
> + * Return Values
> +extern int pci_for_each_dev(
> + void *arg);
> +/* Get PCI device from RAM device tree for a device matching PCI Vendor, Device
> + * and instance number 'index'.
> + * Return Values
> + * 0 device was found, *ppdev was updated with the PCI device address
> +extern int pci_find_dev(uint16_t ven, uint16_t dev, int index,
> + struct pci_dev **ppdev);
> +/* Get PCI device from RAM device tree by BUS|SLOT|FUNC.
> + * Return Values
> + * -1 pci_get_dev did not find a device matching the criterion
> +extern int pci_get_dev(pci_dev_t pcidev, struct pci_dev **ppdev);
> +/* Resource flags */
> +#define PCI_RES_IO 1
> +#define PCI_RES_MEMIO 2
> +#define PCI_RES_MEM_PREFETCH 1
> +#define PCI_RES_MEM (PCI_RES_MEMIO | PCI_RES_MEM_PREFETCH)
> +#define PCI_RES_TYPE_MASK 0x3
> +#define PCI_RES_IO32 0x08
> +#define PCI_RES_FAIL 0x10 /* Alloc Failed */
> +/* BAR Resouces entry */
> +struct pci_res {
> + struct pci_res *next;
> + uint32_t size;
> + uint32_t boundary;
> + unsigned char flags; /* I/O, MEM or MEMIO */
> + unsigned char bar;
You define an enum below for this field, maybe it makes sense to use a
named enum for it?
> + /* Assigned Resource (PCI address), zero if not assigned */
> + uint32_t start;
> + uint32_t end;
> +/* Get Device from resource pointer */
> +#define RES2DEV(res) ((struct pci_dev *) \
> + ((void *)res - (res->bar * (sizeof(struct pci_res)))))
This is tricky and could probably do with a bit more explanation i.e.
that bar is a "counter" for the resource within the array of
resources[] located at the start of the pci_dev. Also, we should avoid
pointer arithmetic on void* type. I'd prefer to see a cast to
uintptr_t and explicit arithmetic done in terms of bytes. This mixing
of types in a non-standard way is asking for trouble some day.
> +/* Device flags */
> +#define PCI_DEV_BRIDGE 0x01 /* Device is a Bridge (struct pci_bus) */
> +#define PCI_DEV_RES_FAIL 0x02 /* Resource alloction for device BARs failed */
> +/* Bus Flags */
> +#define PCI_BUS_IO 0x01 /* 16-bit I/O address decoding */
> +#define PCI_BUS_MEMIO 0x02 /* Bus support non-prefetchable mem (always) */
> +#define PCI_BUS_MEM 0x04 /* Bus support prefetchable memory space */
> +#define PCI_BUS_IO32 0x08 /* 32-bit I/O address decoding */
> +#define BRIDGE_RES_COUNT 2 /* Number of BAR resources a bridge can have */
> +#define BUS_RES_START BRIDGE_RES_COUNT
> +/* Bus Resources Array */
> +enum {
> + BUS_RES_IO = 0,
> + BUS_RES_MEMIO = 1,
> + BUS_RES_MEM = 2,
> +/* Device Resource array index meaning */
> +enum {
> + /* A Device has up to 6 BARs and an optional ROM BAR */
> + DEV_RES_BAR1 = 0,
> + DEV_RES_BAR2 = 1,
> + DEV_RES_BAR3 = 2,
> + DEV_RES_BAR4 = 3,
> + DEV_RES_BAR5 = 4,
> + DEV_RES_BAR6 = 5,
> + DEV_RES_ROM = 6,
> + /* Bridges have 2 BARs (BAR1 and BAR2) and 3 Windows to secondary bus
> + * and an optional ROM BAR
> + BRIDGE_RES_BAR1 = 0,
> + BRIDGE_RES_BAR2 = 1,
> + BRIDGE_RES_IO = 2,
> + BRIDGE_RES_MEMIO = 3,
> + BRIDGE_RES_MEM = 4,
> + BRIDGE_RES_UNUSED1 = 5,
> + BRIDGE_RES_ROM = 6,
> +/* Maximum Number of Resources of a device */
> +#define DEV_RES_CNT (DEV_RES_ROM + 1)
> +/* PCI Device (Bus|Slot|Function) description */
> +struct pci_dev {
> + struct pci_res resources[DEV_RES_CNT]; /* must be topmost field */
> + struct pci_dev *next;
> + struct pci_bus *bus;
> + pci_dev_t busdevfun;
> + uint8_t flags;
> + uint8_t sysirq;
> + uint16_t vendor;
> + uint16_t device;
> + uint16_t subvendor;
> + uint16_t subdevice;
> + uint32_t classrev;
> + /* static configuration settings */
> + uint16_t command;
> +/* PCI Bus description */
> +struct pci_bus {
> + struct pci_dev dev; /* PCI Bridge */
> + struct pci_dev *devs; /* Devices on child (secondary) Bus */
> + unsigned int flags;
> + /* Bridge Information */
> + int num; /* Bus number (0=Root-PCI-bus) */
> + int pri; /* Primary Bus Number */
> + int sord; /* Subordinate Buses (Child bus count) */
> +#if defined(PCI_CFG_AUTO_LIB)
> + /* Resources of devices on bus. USED INTERNALLY IN AUTO-CFG LIBRARY.
> + * BUS_RES_IO = 0: I/O resources
> + * BUS_RES_MEMIO = 1: Prefetchable memory resources
> + * BUS_RES_MEM = 2: Non-Prefetchable memory resources
> + struct pci_res *busres[3];
> +#endif
> +#include <pci/cfg_auto.h>
> +#include <pci/cfg_static.h>
> +#include <pci/cfg_read.h>
> +#include <pci/cfg_peripheral.h>
> +#endif
> diff --git a/cpukit/libpci/pci/cfg_auto.h b/cpukit/libpci/pci/cfg_auto.h
> index 0000000..25e7336
> --- /dev/null
> +++ b/cpukit/libpci/pci/cfg_auto.h
> @@ -0,0 +1,59 @@
> +/* PCI Auto Configuration Library
> +#ifndef __PCI_CFG_AUTO_H__
> +#define __PCI_CFG_AUTO_H__
> +#define CFGOPT_NOSETUP_IRQ 0x1 /* Skip IRQ setup */
> +/* PCI Memory Layout setup, used by the auto-config library in order to
> + * determine the addresses of PCI BARs and Buses.
> + * All addresses are in PCI address space, the actual address the CPU access
> + * may be different, and taken care of elsewhere.
> +struct pci_auto_setup {
> + int options;
> + /* PCI prefetchable Memory space (OPTIONAL) */
> + uint32_t mem_start;
> + uint32_t mem_size; /* 0 = Use MEMIO space for prefetchable mem BARs */
> + /* PCI non-prefetchable Memory */
> + uint32_t memio_start;
> + uint32_t memio_size;
> + /* PCI I/O space (OPTIONAL) */
> + uint32_t io_start;
> + uint32_t io_size; /* 0 = No I/O space */
> + /* Get System IRQ connected to a PCI line of a PCI device on bus0.
> + * The return IRQ value zero equals no IRQ (IRQ disabled).
> + uint8_t (*irq_map)(pci_dev_t dev, int irq_pin);
> + /* IRQ Bridge routing. Returns the interrupt pin (0..3 = A..D) that
> + * a device is connected to on parent bus.
> + int (*irq_route)(pci_dev_t dev, int irq_pin);
> +/* Do PCI initialization: Enumrate buses, scan buses for devices, assign
> + * I/O MEM and MEMIO resources, assign IRQ and so on.
> +extern int pci_config_auto(void);
> +/* Register a configuration for the auto library (struct pci_auto_setup *) */
> +extern void pci_config_auto_register(void *config);
> +/* PCI memory map */
> +extern struct pci_auto_setup pci_auto_cfg;
> +#endif
> diff --git a/cpukit/libpci/pci/cfg_peripheral.h b/cpukit/libpci/pci/cfg_peripheral.h
> index 0000000..68f2e24
> --- /dev/null
> +++ b/cpukit/libpci/pci/cfg_peripheral.h
> @@ -0,0 +1,20 @@
> +/* PCI Peripheral Configuration Library
> +#ifndef __PCI_CFG_PERIPHERAL_H__
> +#define __PCI_CFG_PERIPHERAL_H__
> +/* The user must provide a PCI configuration using the "struct pci_bus pci_hb"
> + * structure. Nothing else than setting pci_system_type and pci_bus_cnt is done
> + * by the peripheral library.
> +extern int pci_config_peripheral(void);
> +#endif
> diff --git a/cpukit/libpci/pci/cfg_read.h b/cpukit/libpci/pci/cfg_read.h
> index 0000000..af60a4e
> --- /dev/null
> +++ b/cpukit/libpci/pci/cfg_read.h
> @@ -0,0 +1,22 @@
> +/* PCI Read Configuration Library. Read current config that bootloader/BIOS
> + * has setup.
> +#ifndef __PCI_CFG_READ_H__
> +#define __PCI_CFG_READ_H__
> +/* Build PCI device tree in "struct pci_bus pci_hb" according to current setup
> + * in hardware. Devices/buses are created by reading the resource assignments
> + * that the BIOS/bootloader has already setup for us.
> +extern int pci_config_read(void);
> +#endif
> diff --git a/cpukit/libpci/pci/cfg_static.h b/cpukit/libpci/pci/cfg_static.h
> index 0000000..5633dfc
> --- /dev/null
> +++ b/cpukit/libpci/pci/cfg_static.h
> @@ -0,0 +1,22 @@
> +/* Static PCI Auto Configuration Library
> +#ifndef __PCI_CFG_STATIC_H__
> +#define __PCI_CFG_STATIC_H__
> +/* This function initializes all buses and device accorind to a user defined
> + * "static" configuration. The configuration can manually created with C
> + * data structures. Or it can be automatically created on a running target
> + * using the pci_cfg_print() routine after the AUTO or READ Configuration
> + * Library has setup the PCI bus
> +extern int pci_config_static(void);
> +#endif
> diff --git a/cpukit/libpci/pci/ids.h b/cpukit/libpci/pci/ids.h
> index 0000000..2d2592b
> --- /dev/null
> +++ b/cpukit/libpci/pci/ids.h
> @@ -0,0 +1,802 @@
> +/* PCI Identifiers - auto generated */
What is it gerenated from and how/when to regenerate it?
> +#ifndef __PCI_IDS_H__
> +#define __PCI_IDS_H__
> +/* Include non-public PCI ids (not auto generated) */
> +#include <pci/ids_extra.h>
> +/* Not a valid ID, used to match any device ID */
> +#define PCI_ID_ANY 0xffff
> + * Vendor and card ID's: sort these numerically according to vendor
> + * (and according to card ID within vendor). Send all updates to
> + * <linux-pcisupport at cck.uni-kl.de>.
> +#define PCI_VENDOR_ID_COMPAQ 0x0e11
> +#define PCI_DEVICE_ID_COMPAQ_1280 0x3033
> +#define PCI_DEVICE_ID_COMPAQ_TRIFLEX 0x4000
> +#define PCI_DEVICE_ID_COMPAQ_SMART2P 0xae10
> +#define PCI_DEVICE_ID_COMPAQ_NETEL100 0xae32
> +#define PCI_DEVICE_ID_COMPAQ_NETEL10 0xae34
> +#define PCI_DEVICE_ID_COMPAQ_NETFLEX3I 0xae35
> +#define PCI_DEVICE_ID_COMPAQ_NETEL100D 0xae40
> +#define PCI_DEVICE_ID_COMPAQ_NETEL100PI 0xae43
> +#define PCI_DEVICE_ID_COMPAQ_NETEL100I 0xb011
> +#define PCI_DEVICE_ID_COMPAQ_THUNDER 0xf130
> +#define PCI_DEVICE_ID_COMPAQ_NETFLEX3B 0xf150
> +#define PCI_VENDOR_ID_NCR 0x1000
> +#define PCI_DEVICE_ID_NCR_53C810 0x0001
> +#define PCI_DEVICE_ID_NCR_53C820 0x0002
> +#define PCI_DEVICE_ID_NCR_53C825 0x0003
> +#define PCI_DEVICE_ID_NCR_53C815 0x0004
> +#define PCI_DEVICE_ID_NCR_53C860 0x0006
> +#define PCI_DEVICE_ID_NCR_53C896 0x000b
> +#define PCI_DEVICE_ID_NCR_53C895 0x000c
> +#define PCI_DEVICE_ID_NCR_53C885 0x000d
> +#define PCI_DEVICE_ID_NCR_53C875 0x000f
> +#define PCI_DEVICE_ID_NCR_53C875J 0x008f
> +#define PCI_VENDOR_ID_ATI 0x1002
> +#define PCI_DEVICE_ID_ATI_68800 0x4158
> +#define PCI_DEVICE_ID_ATI_215CT222 0x4354
> +#define PCI_DEVICE_ID_ATI_210888CX 0x4358
> +#define PCI_DEVICE_ID_ATI_215GB 0x4742
> +#define PCI_DEVICE_ID_ATI_215GD 0x4744
> +#define PCI_DEVICE_ID_ATI_215GI 0x4749
> +#define PCI_DEVICE_ID_ATI_215GP 0x4750
> +#define PCI_DEVICE_ID_ATI_215GQ 0x4751
> +#define PCI_DEVICE_ID_ATI_215GT 0x4754
> +#define PCI_DEVICE_ID_ATI_215GTB 0x4755
> +#define PCI_DEVICE_ID_ATI_210888GX 0x4758
> +#define PCI_DEVICE_ID_ATI_215LG 0x4c47
> +#define PCI_DEVICE_ID_ATI_264LT 0x4c54
> +#define PCI_DEVICE_ID_ATI_264VT 0x5654
> +#define PCI_VENDOR_ID_VLSI 0x1004
> +#define PCI_DEVICE_ID_VLSI_82C592 0x0005
> +#define PCI_DEVICE_ID_VLSI_82C593 0x0006
> +#define PCI_DEVICE_ID_VLSI_82C594 0x0007
> +#define PCI_DEVICE_ID_VLSI_82C597 0x0009
> +#define PCI_DEVICE_ID_VLSI_82C541 0x000c
> +#define PCI_DEVICE_ID_VLSI_82C543 0x000d
> +#define PCI_DEVICE_ID_VLSI_82C532 0x0101
> +#define PCI_DEVICE_ID_VLSI_82C534 0x0102
> +#define PCI_DEVICE_ID_VLSI_82C535 0x0104
> +#define PCI_DEVICE_ID_VLSI_82C147 0x0105
> +#define PCI_DEVICE_ID_VLSI_VAS96011 0x0702
> +#define PCI_VENDOR_ID_ADL 0x1005
> +#define PCI_DEVICE_ID_ADL_2301 0x2301
> +#define PCI_VENDOR_ID_NS 0x100b
> +#define PCI_DEVICE_ID_NS_87415 0x0002
> +#define PCI_DEVICE_ID_NS_87410 0xd001
> +#define PCI_VENDOR_ID_TSENG 0x100c
> +#define PCI_DEVICE_ID_TSENG_W32P_2 0x3202
> +#define PCI_DEVICE_ID_TSENG_W32P_b 0x3205
> +#define PCI_DEVICE_ID_TSENG_W32P_c 0x3206
> +#define PCI_DEVICE_ID_TSENG_W32P_d 0x3207
> +#define PCI_DEVICE_ID_TSENG_ET6000 0x3208
> +#define PCI_VENDOR_ID_WEITEK 0x100e
> +#define PCI_DEVICE_ID_WEITEK_P9000 0x9001
> +#define PCI_DEVICE_ID_WEITEK_P9100 0x9100
> +#define PCI_VENDOR_ID_DEC 0x1011
> +#define PCI_DEVICE_ID_DEC_BRD 0x0001
> +#define PCI_DEVICE_ID_DEC_TULIP 0x0002
> +#define PCI_DEVICE_ID_DEC_TGA 0x0004
> +#define PCI_DEVICE_ID_DEC_TULIP_FAST 0x0009
> +#define PCI_DEVICE_ID_DEC_TGA2 0x000D
> +#define PCI_DEVICE_ID_DEC_FDDI 0x000F
> +#define PCI_DEVICE_ID_DEC_TULIP_PLUS 0x0014
> +#define PCI_DEVICE_ID_DEC_21142 0x0019
> +#define PCI_DEVICE_ID_DEC_21052 0x0021
> +#define PCI_DEVICE_ID_DEC_21150 0x0022
> +#define PCI_DEVICE_ID_DEC_21152 0x0024
> +#define PCI_VENDOR_ID_CIRRUS 0x1013
> +#define PCI_DEVICE_ID_CIRRUS_7548 0x0038
> +#define PCI_DEVICE_ID_CIRRUS_5430 0x00a0
> +#define PCI_DEVICE_ID_CIRRUS_5434_4 0x00a4
> +#define PCI_DEVICE_ID_CIRRUS_5434_8 0x00a8
> +#define PCI_DEVICE_ID_CIRRUS_5436 0x00ac
> +#define PCI_DEVICE_ID_CIRRUS_5446 0x00b8
> +#define PCI_DEVICE_ID_CIRRUS_5480 0x00bc
> +#define PCI_DEVICE_ID_CIRRUS_5464 0x00d4
> +#define PCI_DEVICE_ID_CIRRUS_5465 0x00d6
> +#define PCI_DEVICE_ID_CIRRUS_6729 0x1100
> +#define PCI_DEVICE_ID_CIRRUS_6832 0x1110
> +#define PCI_DEVICE_ID_CIRRUS_7542 0x1200
> +#define PCI_DEVICE_ID_CIRRUS_7543 0x1202
> +#define PCI_DEVICE_ID_CIRRUS_7541 0x1204
> +#define PCI_VENDOR_ID_IBM 0x1014
> +#define PCI_DEVICE_ID_IBM_FIRE_CORAL 0x000a
> +#define PCI_DEVICE_ID_IBM_TR 0x0018
> +#define PCI_DEVICE_ID_IBM_82G2675 0x001d
> +#define PCI_DEVICE_ID_IBM_MCA 0x0020
> +#define PCI_DEVICE_ID_IBM_82351 0x0022
> +#define PCI_DEVICE_ID_IBM_SERVERAID 0x002e
> +#define PCI_DEVICE_ID_IBM_TR_WAKE 0x003e
> +#define PCI_DEVICE_ID_IBM_MPIC 0x0046
> +#define PCI_DEVICE_ID_IBM_3780IDSP 0x007d
> +#define PCI_DEVICE_ID_IBM_MPIC_2 0xffff
> +#define PCI_VENDOR_ID_WD 0x101c
> +#define PCI_DEVICE_ID_WD_7197 0x3296
> +#define PCI_VENDOR_ID_AMD 0x1022
> +#define PCI_DEVICE_ID_AMD_LANCE 0x2000
> +#define PCI_DEVICE_ID_AMD_SCSI 0x2020
> +#define PCI_VENDOR_ID_TRIDENT 0x1023
> +#define PCI_DEVICE_ID_TRIDENT_9397 0x9397
> +#define PCI_DEVICE_ID_TRIDENT_9420 0x9420
> +#define PCI_DEVICE_ID_TRIDENT_9440 0x9440
> +#define PCI_DEVICE_ID_TRIDENT_9660 0x9660
> +#define PCI_DEVICE_ID_TRIDENT_9750 0x9750
> +#define PCI_VENDOR_ID_AI 0x1025
> +#define PCI_DEVICE_ID_AI_M1435 0x1435
> +#define PCI_VENDOR_ID_MATROX 0x102B
> +#define PCI_DEVICE_ID_MATROX_MGA_2 0x0518
> +#define PCI_DEVICE_ID_MATROX_MIL 0x0519
> +#define PCI_DEVICE_ID_MATROX_MYS 0x051A
> +#define PCI_DEVICE_ID_MATROX_MIL_2 0x051b
> +#define PCI_DEVICE_ID_MATROX_MIL_2_AGP 0x051f
> +#define PCI_DEVICE_ID_MATROX_MGA_IMP 0x0d10
> +#define PCI_VENDOR_ID_CT 0x102c
> +#define PCI_DEVICE_ID_CT_65545 0x00d8
> +#define PCI_DEVICE_ID_CT_65548 0x00dc
> +#define PCI_DEVICE_ID_CT_65550 0x00e0
> +#define PCI_DEVICE_ID_CT_65554 0x00e4
> +#define PCI_DEVICE_ID_CT_65555 0x00e5
> +#define PCI_VENDOR_ID_MIRO 0x1031
> +#define PCI_DEVICE_ID_MIRO_36050 0x5601
> +#define PCI_VENDOR_ID_NEC 0x1033
> +#define PCI_DEVICE_ID_NEC_PCX2 0x0046
> +#define PCI_VENDOR_ID_FD 0x1036
> +#define PCI_DEVICE_ID_FD_36C70 0x0000
> +#define PCI_VENDOR_ID_SI 0x1039
> +#define PCI_DEVICE_ID_SI_5591_AGP 0x0001
> +#define PCI_DEVICE_ID_SI_6202 0x0002
> +#define PCI_DEVICE_ID_SI_503 0x0008
> +#define PCI_DEVICE_ID_SI_ACPI 0x0009
> +#define PCI_DEVICE_ID_SI_5597_VGA 0x0200
> +#define PCI_DEVICE_ID_SI_6205 0x0205
> +#define PCI_DEVICE_ID_SI_501 0x0406
> +#define PCI_DEVICE_ID_SI_496 0x0496
> +#define PCI_DEVICE_ID_SI_601 0x0601
> +#define PCI_DEVICE_ID_SI_5107 0x5107
> +#define PCI_DEVICE_ID_SI_5511 0x5511
> +#define PCI_DEVICE_ID_SI_5513 0x5513
> +#define PCI_DEVICE_ID_SI_5571 0x5571
> +#define PCI_DEVICE_ID_SI_5591 0x5591
> +#define PCI_DEVICE_ID_SI_5597 0x5597
> +#define PCI_DEVICE_ID_SI_7001 0x7001
> +#define PCI_VENDOR_ID_HP 0x103c
> +#define PCI_DEVICE_ID_HP_J2585A 0x1030
> +#define PCI_DEVICE_ID_HP_J2585B 0x1031
> +#define PCI_VENDOR_ID_PCTECH 0x1042
> +#define PCI_DEVICE_ID_PCTECH_RZ1000 0x1000
> +#define PCI_DEVICE_ID_PCTECH_RZ1001 0x1001
> +#define PCI_DEVICE_ID_PCTECH_SAMURAI_0 0x3000
> +#define PCI_DEVICE_ID_PCTECH_SAMURAI_1 0x3010
> +#define PCI_DEVICE_ID_PCTECH_SAMURAI_IDE 0x3020
> +#define PCI_VENDOR_ID_DPT 0x1044
> +#define PCI_DEVICE_ID_DPT 0xa400
> +#define PCI_VENDOR_ID_OPTI 0x1045
> +#define PCI_DEVICE_ID_OPTI_92C178 0xc178
> +#define PCI_DEVICE_ID_OPTI_82C557 0xc557
> +#define PCI_DEVICE_ID_OPTI_82C558 0xc558
> +#define PCI_DEVICE_ID_OPTI_82C621 0xc621
> +#define PCI_DEVICE_ID_OPTI_82C700 0xc700
> +#define PCI_DEVICE_ID_OPTI_82C701 0xc701
> +#define PCI_DEVICE_ID_OPTI_82C814 0xc814
> +#define PCI_DEVICE_ID_OPTI_82C822 0xc822
> +#define PCI_DEVICE_ID_OPTI_82C825 0xd568
> +#define PCI_VENDOR_ID_SGS 0x104a
> +#define PCI_DEVICE_ID_SGS_2000 0x0008
> +#define PCI_DEVICE_ID_SGS_1764 0x0009
> +#define PCI_VENDOR_ID_BUSLOGIC 0x104B
> +#define PCI_DEVICE_ID_BUSLOGIC_MULTIMASTER_NC 0x0140
> +#define PCI_DEVICE_ID_BUSLOGIC_MULTIMASTER 0x1040
> +#define PCI_DEVICE_ID_BUSLOGIC_FLASHPOINT 0x8130
> +#define PCI_VENDOR_ID_TI 0x104c
> +#define PCI_DEVICE_ID_TI_TVP4010 0x3d04
> +#define PCI_DEVICE_ID_TI_TVP4020 0x3d07
> +#define PCI_DEVICE_ID_TI_PCI1130 0xac12
> +#define PCI_DEVICE_ID_TI_PCI1031 0xac13
> +#define PCI_DEVICE_ID_TI_PCI1131 0xac15
> +#define PCI_DEVICE_ID_TI_PCI1250 0xac16
> +#define PCI_DEVICE_ID_TI_PCI1220 0xac17
> +#define PCI_VENDOR_ID_OAK 0x104e
> +#define PCI_DEVICE_ID_OAK_OTI107 0x0107
> +/* Winbond have two vendor IDs! See 0x10ad as well */
> +#define PCI_VENDOR_ID_WINBOND2 0x1050
> +#define PCI_DEVICE_ID_WINBOND2_89C940 0x0940
> +#define PCI_VENDOR_ID_MOTOROLA 0x1057
> +#define PCI_DEVICE_ID_MOTOROLA_MPC105 0x0001
> +#define PCI_DEVICE_ID_MOTOROLA_MPC106 0x0002
> +#define PCI_DEVICE_ID_MOTOROLA_RAVEN 0x4801
> +#define PCI_VENDOR_ID_PROMISE 0x105a
> +#define PCI_DEVICE_ID_PROMISE_20246 0x4d33
> +#define PCI_DEVICE_ID_PROMISE_5300 0x5300
> +#define PCI_VENDOR_ID_N9 0x105d
> +#define PCI_DEVICE_ID_N9_I128 0x2309
> +#define PCI_DEVICE_ID_N9_I128_2 0x2339
> +#define PCI_DEVICE_ID_N9_I128_T2R 0x493d
> +#define PCI_VENDOR_ID_UMC 0x1060
> +#define PCI_DEVICE_ID_UMC_UM8673F 0x0101
> +#define PCI_DEVICE_ID_UMC_UM8891A 0x0891
> +#define PCI_DEVICE_ID_UMC_UM8886BF 0x673a
> +#define PCI_DEVICE_ID_UMC_UM8886A 0x886a
> +#define PCI_DEVICE_ID_UMC_UM8881F 0x8881
> +#define PCI_DEVICE_ID_UMC_UM8886F 0x8886
> +#define PCI_DEVICE_ID_UMC_UM9017F 0x9017
> +#define PCI_DEVICE_ID_UMC_UM8886N 0xe886
> +#define PCI_DEVICE_ID_UMC_UM8891N 0xe891
> +#define PCI_VENDOR_ID_X 0x1061
> +#define PCI_DEVICE_ID_X_AGX016 0x0001
> +#define PCI_VENDOR_ID_PICOP 0x1066
> +#define PCI_DEVICE_ID_PICOP_PT86C52X 0x0001
> +#define PCI_DEVICE_ID_PICOP_PT80C524 0x8002
> +#define PCI_VENDOR_ID_APPLE 0x106b
> +#define PCI_DEVICE_ID_APPLE_BANDIT 0x0001
> +#define PCI_DEVICE_ID_APPLE_GC 0x0002
> +#define PCI_DEVICE_ID_APPLE_HYDRA 0x000e
> +#define PCI_VENDOR_ID_NEXGEN 0x1074
> +#define PCI_DEVICE_ID_NEXGEN_82C501 0x4e78
> +#define PCI_VENDOR_ID_QLOGIC 0x1077
> +#define PCI_DEVICE_ID_QLOGIC_ISP1020 0x1020
> +#define PCI_DEVICE_ID_QLOGIC_ISP1022 0x1022
> +#define PCI_VENDOR_ID_CYRIX 0x1078
> +#define PCI_DEVICE_ID_CYRIX_5510 0x0000
> +#define PCI_DEVICE_ID_CYRIX_PCI_MASTER 0x0001
> +#define PCI_DEVICE_ID_CYRIX_5520 0x0002
> +#define PCI_DEVICE_ID_CYRIX_5530_LEGACY 0x0100
> +#define PCI_DEVICE_ID_CYRIX_5530_SMI 0x0101
> +#define PCI_DEVICE_ID_CYRIX_5530_IDE 0x0102
> +#define PCI_DEVICE_ID_CYRIX_5530_AUDIO 0x0103
> +#define PCI_DEVICE_ID_CYRIX_5530_VIDEO 0x0104
> +#define PCI_VENDOR_ID_LEADTEK 0x107d
> +#define PCI_DEVICE_ID_LEADTEK_805 0x0000
> +#define PCI_VENDOR_ID_CONTAQ 0x1080
> +#define PCI_DEVICE_ID_CONTAQ_82C599 0x0600
> +#define PCI_DEVICE_ID_CONTAQ_82C693 0xc693
> +#define PCI_VENDOR_ID_FOREX 0x1083
> +#define PCI_VENDOR_ID_OLICOM 0x108d
> +#define PCI_DEVICE_ID_OLICOM_OC3136 0x0001
> +#define PCI_DEVICE_ID_OLICOM_OC2315 0x0011
> +#define PCI_DEVICE_ID_OLICOM_OC2325 0x0012
> +#define PCI_DEVICE_ID_OLICOM_OC2183 0x0013
> +#define PCI_DEVICE_ID_OLICOM_OC2326 0x0014
> +#define PCI_DEVICE_ID_OLICOM_OC6151 0x0021
> +#define PCI_VENDOR_ID_SUN 0x108e
> +#define PCI_DEVICE_ID_SUN_EBUS 0x1000
> +#define PCI_DEVICE_ID_SUN_HAPPYMEAL 0x1001
> +#define PCI_DEVICE_ID_SUN_SIMBA 0x5000
> +#define PCI_DEVICE_ID_SUN_PBM 0x8000
> +#define PCI_DEVICE_ID_SUN_SABRE 0xa000
> +#define PCI_VENDOR_ID_CMD 0x1095
> +#define PCI_DEVICE_ID_CMD_640 0x0640
> +#define PCI_DEVICE_ID_CMD_643 0x0643
> +#define PCI_DEVICE_ID_CMD_646 0x0646
> +#define PCI_DEVICE_ID_CMD_647 0x0647
> +#define PCI_DEVICE_ID_CMD_670 0x0670
> +#define PCI_VENDOR_ID_VISION 0x1098
> +#define PCI_DEVICE_ID_VISION_QD8500 0x0001
> +#define PCI_DEVICE_ID_VISION_QD8580 0x0002
> +#define PCI_VENDOR_ID_BROOKTREE 0x109e
> +#define PCI_DEVICE_ID_BROOKTREE_848 0x0350
> +#define PCI_DEVICE_ID_BROOKTREE_849A 0x0351
> +#define PCI_DEVICE_ID_BROOKTREE_8474 0x8474
> +#define PCI_VENDOR_ID_SIERRA 0x10a8
> +#define PCI_DEVICE_ID_SIERRA_STB 0x0000
> +#define PCI_VENDOR_ID_ACC 0x10aa
> +#define PCI_DEVICE_ID_ACC_2056 0x0000
> +#define PCI_VENDOR_ID_WINBOND 0x10ad
> +#define PCI_DEVICE_ID_WINBOND_83769 0x0001
> +#define PCI_DEVICE_ID_WINBOND_82C105 0x0105
> +#define PCI_DEVICE_ID_WINBOND_83C553 0x0565
> +#define PCI_VENDOR_ID_DATABOOK 0x10b3
> +#define PCI_DEVICE_ID_DATABOOK_87144 0xb106
> +#define PCI_VENDOR_ID_PLX 0x10b5
> +#define PCI_DEVICE_ID_PLX_9050 0x9050
> +#define PCI_DEVICE_ID_PLX_9060 0x9060
> +#define PCI_DEVICE_ID_PLX_9060ES 0x906E
> +#define PCI_DEVICE_ID_PLX_9060SD 0x906D
> +#define PCI_DEVICE_ID_PLX_9080 0x9080
> +#define PCI_VENDOR_ID_MADGE 0x10b6
> +#define PCI_DEVICE_ID_MADGE_MK2 0x0002
> +#define PCI_DEVICE_ID_MADGE_C155S 0x1001
> +#define PCI_VENDOR_ID_3COM 0x10b7
> +#define PCI_DEVICE_ID_3COM_3C339 0x3390
> +#define PCI_DEVICE_ID_3COM_3C590 0x5900
> +#define PCI_DEVICE_ID_3COM_3C595TX 0x5950
> +#define PCI_DEVICE_ID_3COM_3C595T4 0x5951
> +#define PCI_DEVICE_ID_3COM_3C595MII 0x5952
> +#define PCI_DEVICE_ID_3COM_3C900TPO 0x9000
> +#define PCI_DEVICE_ID_3COM_3C900COMBO 0x9001
> +#define PCI_DEVICE_ID_3COM_3C905TX 0x9050
> +#define PCI_DEVICE_ID_3COM_3C905T4 0x9051
> +#define PCI_DEVICE_ID_3COM_3C905B_TX 0x9055
> +#define PCI_VENDOR_ID_SMC 0x10b8
> +#define PCI_DEVICE_ID_SMC_EPIC100 0x0005
> +#define PCI_VENDOR_ID_AL 0x10b9
> +#define PCI_DEVICE_ID_AL_M1445 0x1445
> +#define PCI_DEVICE_ID_AL_M1449 0x1449
> +#define PCI_DEVICE_ID_AL_M1451 0x1451
> +#define PCI_DEVICE_ID_AL_M1461 0x1461
> +#define PCI_DEVICE_ID_AL_M1489 0x1489
> +#define PCI_DEVICE_ID_AL_M1511 0x1511
> +#define PCI_DEVICE_ID_AL_M1513 0x1513
> +#define PCI_DEVICE_ID_AL_M1521 0x1521
> +#define PCI_DEVICE_ID_AL_M1523 0x1523
> +#define PCI_DEVICE_ID_AL_M1531 0x1531
> +#define PCI_DEVICE_ID_AL_M1533 0x1533
> +#define PCI_DEVICE_ID_AL_M3307 0x3307
> +#define PCI_DEVICE_ID_AL_M4803 0x5215
> +#define PCI_DEVICE_ID_AL_M5219 0x5219
> +#define PCI_DEVICE_ID_AL_M5229 0x5229
> +#define PCI_DEVICE_ID_AL_M5237 0x5237
> +#define PCI_DEVICE_ID_AL_M7101 0x7101
> +#define PCI_VENDOR_ID_MITSUBISHI 0x10ba
> +#define PCI_VENDOR_ID_SURECOM 0x10bd
> +#define PCI_DEVICE_ID_SURECOM_NE34 0x0e34
> +#define PCI_VENDOR_ID_NEOMAGIC 0x10c8
> +#define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_NM2070 0x0001
> +#define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_128V 0x0002
> +#define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_128ZV 0x0003
> +#define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_NM2160 0x0004
> +#define PCI_VENDOR_ID_ASP 0x10cd
> +#define PCI_DEVICE_ID_ASP_ABP940 0x1200
> +#define PCI_DEVICE_ID_ASP_ABP940U 0x1300
> +#define PCI_DEVICE_ID_ASP_ABP940UW 0x2300
> +#define PCI_VENDOR_ID_MACRONIX 0x10d9
> +#define PCI_DEVICE_ID_MACRONIX_MX98713 0x0512
> +#define PCI_DEVICE_ID_MACRONIX_MX987x5 0x0531
> +#define PCI_VENDOR_ID_CERN 0x10dc
> +#define PCI_DEVICE_ID_CERN_SPSB_PMC 0x0001
> +#define PCI_DEVICE_ID_CERN_SPSB_PCI 0x0002
> +#define PCI_DEVICE_ID_CERN_HIPPI_DST 0x0021
> +#define PCI_DEVICE_ID_CERN_HIPPI_SRC 0x0022
> +#define PCI_VENDOR_ID_NVIDIA 0x10de
> +#define PCI_VENDOR_ID_IMS 0x10e0
> +#define PCI_DEVICE_ID_IMS_8849 0x8849
> +#define PCI_VENDOR_ID_TEKRAM2 0x10e1
> +#define PCI_DEVICE_ID_TEKRAM2_690c 0x690c
> +#define PCI_VENDOR_ID_TUNDRA 0x10e3
> +#define PCI_DEVICE_ID_TUNDRA_CA91C042 0x0000
> +#define PCI_VENDOR_ID_AMCC 0x10e8
> +#define PCI_DEVICE_ID_AMCC_MYRINET 0x8043
> +#define PCI_DEVICE_ID_AMCC_PARASTATION 0x8062
> +#define PCI_DEVICE_ID_AMCC_S5933 0x807d
> +#define PCI_DEVICE_ID_AMCC_S5933_HEPC3 0x809c
> +#define PCI_VENDOR_ID_INTERG 0x10ea
> +#define PCI_DEVICE_ID_INTERG_1680 0x1680
> +#define PCI_DEVICE_ID_INTERG_1682 0x1682
> +#define PCI_VENDOR_ID_REALTEK 0x10ec
> +#define PCI_DEVICE_ID_REALTEK_8029 0x8029
> +#define PCI_DEVICE_ID_REALTEK_8129 0x8129
> +#define PCI_DEVICE_ID_REALTEK_8139 0x8139
> +#define PCI_VENDOR_ID_TRUEVISION 0x10fa
> +#define PCI_DEVICE_ID_TRUEVISION_T1000 0x000c
> +#define PCI_VENDOR_ID_INIT 0x1101
> +#define PCI_DEVICE_ID_INIT_320P 0x9100
> +#define PCI_DEVICE_ID_INIT_360P 0x9500
> +#define PCI_VENDOR_ID_TTI 0x1103
> +#define PCI_DEVICE_ID_TTI_HPT343 0x0003
> +#define PCI_VENDOR_ID_VIA 0x1106
> +#define PCI_DEVICE_ID_VIA_82C505 0x0505
> +#define PCI_DEVICE_ID_VIA_82C561 0x0561
> +#define PCI_DEVICE_ID_VIA_82C586_1 0x0571
> +#define PCI_DEVICE_ID_VIA_82C576 0x0576
> +#define PCI_DEVICE_ID_VIA_82C585 0x0585
> +#define PCI_DEVICE_ID_VIA_82C586_0 0x0586
> +#define PCI_DEVICE_ID_VIA_82C595 0x0595
> +#define PCI_DEVICE_ID_VIA_82C597_0 0x0597
> +#define PCI_DEVICE_ID_VIA_82C926 0x0926
> +#define PCI_DEVICE_ID_VIA_82C416 0x1571
> +#define PCI_DEVICE_ID_VIA_82C595_97 0x1595
> +#define PCI_DEVICE_ID_VIA_82C586_2 0x3038
> +#define PCI_DEVICE_ID_VIA_82C586_3 0x3040
> +#define PCI_DEVICE_ID_VIA_86C100A 0x6100
> +#define PCI_DEVICE_ID_VIA_82C597_1 0x8597
> +#define PCI_VENDOR_ID_VORTEX 0x1119
> +#define PCI_DEVICE_ID_VORTEX_GDT60x0 0x0000
> +#define PCI_DEVICE_ID_VORTEX_GDT6000B 0x0001
> +#define PCI_DEVICE_ID_VORTEX_GDT6x10 0x0002
> +#define PCI_DEVICE_ID_VORTEX_GDT6x20 0x0003
> +#define PCI_DEVICE_ID_VORTEX_GDT6530 0x0004
> +#define PCI_DEVICE_ID_VORTEX_GDT6550 0x0005
> +#define PCI_DEVICE_ID_VORTEX_GDT6x17 0x0006
> +#define PCI_DEVICE_ID_VORTEX_GDT6x27 0x0007
> +#define PCI_DEVICE_ID_VORTEX_GDT6537 0x0008
> +#define PCI_DEVICE_ID_VORTEX_GDT6557 0x0009
> +#define PCI_DEVICE_ID_VORTEX_GDT6x15 0x000a
> +#define PCI_DEVICE_ID_VORTEX_GDT6x25 0x000b
> +#define PCI_DEVICE_ID_VORTEX_GDT6535 0x000c
> +#define PCI_DEVICE_ID_VORTEX_GDT6555 0x000d
> +#define PCI_DEVICE_ID_VORTEX_GDT6x17RP 0x0100
> +#define PCI_DEVICE_ID_VORTEX_GDT6x27RP 0x0101
> +#define PCI_DEVICE_ID_VORTEX_GDT6537RP 0x0102
> +#define PCI_DEVICE_ID_VORTEX_GDT6557RP 0x0103
> +#define PCI_DEVICE_ID_VORTEX_GDT6x11RP 0x0104
> +#define PCI_DEVICE_ID_VORTEX_GDT6x21RP 0x0105
> +#define PCI_DEVICE_ID_VORTEX_GDT6x17RP1 0x0110
> +#define PCI_DEVICE_ID_VORTEX_GDT6x27RP1 0x0111
> +#define PCI_DEVICE_ID_VORTEX_GDT6537RP1 0x0112
> +#define PCI_DEVICE_ID_VORTEX_GDT6557RP1 0x0113
> +#define PCI_DEVICE_ID_VORTEX_GDT6x11RP1 0x0114
> +#define PCI_DEVICE_ID_VORTEX_GDT6x21RP1 0x0115
> +#define PCI_DEVICE_ID_VORTEX_GDT6x17RP2 0x0120
> +#define PCI_DEVICE_ID_VORTEX_GDT6x27RP2 0x0121
> +#define PCI_DEVICE_ID_VORTEX_GDT6537RP2 0x0122
> +#define PCI_DEVICE_ID_VORTEX_GDT6557RP2 0x0123
> +#define PCI_DEVICE_ID_VORTEX_GDT6x11RP2 0x0124
> +#define PCI_DEVICE_ID_VORTEX_GDT6x21RP2 0x0125
> +#define PCI_VENDOR_ID_EF 0x111a
> +#define PCI_DEVICE_ID_EF_ATM_FPGA 0x0000
> +#define PCI_DEVICE_ID_EF_ATM_ASIC 0x0002
> +#define PCI_VENDOR_ID_FORE 0x1127
> +#define PCI_DEVICE_ID_FORE_PCA200PC 0x0210
> +#define PCI_DEVICE_ID_FORE_PCA200E 0x0300
> +#define PCI_VENDOR_ID_IMAGINGTECH 0x112f
> +#define PCI_DEVICE_ID_IMAGINGTECH_ICPCI 0x0000
> +#define PCI_VENDOR_ID_PHILIPS 0x1131
> +#define PCI_DEVICE_ID_PHILIPS_SAA7145 0x7145
> +#define PCI_DEVICE_ID_PHILIPS_SAA7146 0x7146
> +#define PCI_VENDOR_ID_CYCLONE 0x113c
> +#define PCI_DEVICE_ID_CYCLONE_SDK 0x0001
> +#define PCI_VENDOR_ID_ALLIANCE 0x1142
> +#define PCI_DEVICE_ID_ALLIANCE_PROMOTIO 0x3210
> +#define PCI_DEVICE_ID_ALLIANCE_PROVIDEO 0x6422
> +#define PCI_DEVICE_ID_ALLIANCE_AT24 0x6424
> +#define PCI_DEVICE_ID_ALLIANCE_AT3D 0x643d
> +#define PCI_VENDOR_ID_SK 0x1148
> +#define PCI_DEVICE_ID_SK_FP 0x4000
> +#define PCI_DEVICE_ID_SK_TR 0x4200
> +#define PCI_DEVICE_ID_SK_GE 0x4300
> +#define PCI_VENDOR_ID_VMIC 0x114a
> +#define PCI_DEVICE_ID_VMIC_VME 0x7587
> +#define PCI_VENDOR_ID_DIGI 0x114f
> +#define PCI_DEVICE_ID_DIGI_EPC 0x0002
> +#define PCI_DEVICE_ID_DIGI_RIGHTSWITCH 0x0003
> +#define PCI_DEVICE_ID_DIGI_XEM 0x0004
> +#define PCI_DEVICE_ID_DIGI_XR 0x0005
> +#define PCI_DEVICE_ID_DIGI_CX 0x0006
> +#define PCI_DEVICE_ID_DIGI_XRJ 0x0009
> +#define PCI_DEVICE_ID_DIGI_EPCJ 0x000a
> +#define PCI_DEVICE_ID_DIGI_XR_920 0x0027
> +#define PCI_VENDOR_ID_MUTECH 0x1159
> +#define PCI_DEVICE_ID_MUTECH_MV1000 0x0001
> +#define PCI_VENDOR_ID_RENDITION 0x1163
> +#define PCI_DEVICE_ID_RENDITION_VERITE 0x0001
> +#define PCI_DEVICE_ID_RENDITION_VERITE2100 0x2000
> +#define PCI_VENDOR_ID_TOSHIBA 0x1179
> +#define PCI_DEVICE_ID_TOSHIBA_601 0x0601
> +#define PCI_DEVICE_ID_TOSHIBA_TOPIC95 0x060a
> +#define PCI_DEVICE_ID_TOSHIBA_TOPIC97 0x060f
> +#define PCI_VENDOR_ID_RICOH 0x1180
> +#define PCI_DEVICE_ID_RICOH_RL5C465 0x0465
> +#define PCI_DEVICE_ID_RICOH_RL5C466 0x0466
> +#define PCI_DEVICE_ID_RICOH_RL5C475 0x0475
> +#define PCI_DEVICE_ID_RICOH_RL5C478 0x0478
> +#define PCI_VENDOR_ID_ARTOP 0x1191
> +#define PCI_DEVICE_ID_ARTOP_ATP8400 0x0004
> +#define PCI_DEVICE_ID_ARTOP_ATP850UF 0x0005
> +#define PCI_VENDOR_ID_ZEITNET 0x1193
> +#define PCI_DEVICE_ID_ZEITNET_1221 0x0001
> +#define PCI_DEVICE_ID_ZEITNET_1225 0x0002
> +#define PCI_VENDOR_ID_OMEGA 0x119b
> +#define PCI_DEVICE_ID_OMEGA_82C092G 0x1221
> +#define PCI_VENDOR_ID_LITEON 0x11ad
> +#define PCI_DEVICE_ID_LITEON_LNE100TX 0x0002
> +#define PCI_VENDOR_ID_NP 0x11bc
> +#define PCI_DEVICE_ID_NP_PCI_FDDI 0x0001
> +#define PCI_VENDOR_ID_ATT 0x11c1
> +#define PCI_DEVICE_ID_ATT_L56XMF 0x0440
> +#define PCI_VENDOR_ID_SPECIALIX 0x11cb
> +#define PCI_DEVICE_ID_SPECIALIX_IO8 0x2000
> +#define PCI_DEVICE_ID_SPECIALIX_XIO 0x4000
> +#define PCI_DEVICE_ID_SPECIALIX_RIO 0x8000
> +#define PCI_VENDOR_ID_AURAVISION 0x11d1
> +#define PCI_DEVICE_ID_AURAVISION_VXP524 0x01f7
> +#define PCI_VENDOR_ID_IKON 0x11d5
> +#define PCI_DEVICE_ID_IKON_10115 0x0115
> +#define PCI_DEVICE_ID_IKON_10117 0x0117
> +#define PCI_VENDOR_ID_ZORAN 0x11de
> +#define PCI_DEVICE_ID_ZORAN_36057 0x6057
> +#define PCI_DEVICE_ID_ZORAN_36120 0x6120
> +#define PCI_VENDOR_ID_KINETIC 0x11f4
> +#define PCI_DEVICE_ID_KINETIC_2915 0x2915
> +#define PCI_VENDOR_ID_COMPEX 0x11f6
> +#define PCI_DEVICE_ID_COMPEX_ENET100VG4 0x0112
> +#define PCI_DEVICE_ID_COMPEX_RL2000 0x1401
> +#define PCI_VENDOR_ID_RP 0x11fe
> +#define PCI_DEVICE_ID_RP32INTF 0x0001
> +#define PCI_DEVICE_ID_RP8INTF 0x0002
> +#define PCI_DEVICE_ID_RP16INTF 0x0003
> +#define PCI_DEVICE_ID_RP4QUAD 0x0004
> +#define PCI_DEVICE_ID_RP8OCTA 0x0005
> +#define PCI_DEVICE_ID_RP8J 0x0006
> +#define PCI_DEVICE_ID_RPP4 0x000A
> +#define PCI_DEVICE_ID_RPP8 0x000B
> +#define PCI_DEVICE_ID_RP8M 0x000C
> +#define PCI_VENDOR_ID_CYCLADES 0x120e
> +#define PCI_DEVICE_ID_CYCLOM_Y_Lo 0x0100
> +#define PCI_DEVICE_ID_CYCLOM_Y_Hi 0x0101
> +#define PCI_DEVICE_ID_CYCLOM_Z_Lo 0x0200
> +#define PCI_DEVICE_ID_CYCLOM_Z_Hi 0x0201
> +#define PCI_VENDOR_ID_ESSENTIAL 0x120f
> +#define PCI_DEVICE_ID_ESSENTIAL_ROADRUNNER 0x0001
> +#define PCI_VENDOR_ID_O2 0x1217
> +#define PCI_DEVICE_ID_O2_6729 0x6729
> +#define PCI_DEVICE_ID_O2_6730 0x673a
> +#define PCI_DEVICE_ID_O2_6832 0x6832
> +#define PCI_DEVICE_ID_O2_6836 0x6836
> +#define PCI_VENDOR_ID_3DFX 0x121a
> +#define PCI_DEVICE_ID_3DFX_VOODOO 0x0001
> +#define PCI_DEVICE_ID_3DFX_VOODOO2 0x0002
> +#define PCI_VENDOR_ID_SIGMADES 0x1236
> +#define PCI_DEVICE_ID_SIGMADES_6425 0x6401
> +#define PCI_VENDOR_ID_CCUBE 0x123f
> +#define PCI_VENDOR_ID_DIPIX 0x1246
> +#define PCI_VENDOR_ID_STALLION 0x124d
> +#define PCI_DEVICE_ID_STALLION_ECHPCI832 0x0000
> +#define PCI_DEVICE_ID_STALLION_ECHPCI864 0x0002
> +#define PCI_DEVICE_ID_STALLION_EIOPCI 0x0003
> +#define PCI_VENDOR_ID_OPTIBASE 0x1255
> +#define PCI_DEVICE_ID_OPTIBASE_FORGE 0x1110
> +#define PCI_DEVICE_ID_OPTIBASE_FUSION 0x1210
> +#define PCI_DEVICE_ID_OPTIBASE_VPLEX 0x2110
> +#define PCI_DEVICE_ID_OPTIBASE_VPLEXCC 0x2120
> +#define PCI_DEVICE_ID_OPTIBASE_VQUEST 0x2130
> +#define PCI_VENDOR_ID_SATSAGEM 0x1267
> +#define PCI_DEVICE_ID_SATSAGEM_PCR2101 0x5352
> +#define PCI_DEVICE_ID_SATSAGEM_TELSATTURBO 0x5a4b
> +#define PCI_VENDOR_ID_HUGHES 0x1273
> +#define PCI_DEVICE_ID_HUGHES_DIRECPC 0x0002
> +#define PCI_VENDOR_ID_ENSONIQ 0x1274
> +#define PCI_DEVICE_ID_ENSONIQ_AUDIOPCI 0x5000
> +#define PCI_VENDOR_ID_ALTEON 0x12ae
> +#define PCI_DEVICE_ID_ALTEON_ACENIC 0x0001
> +#define PCI_VENDOR_ID_PICTUREL 0x12c5
> +#define PCI_DEVICE_ID_PICTUREL_PCIVST 0x0081
> +#define PCI_VENDOR_ID_NVIDIA_SGS 0x12d2
> +#define PCI_DEVICE_ID_NVIDIA_SGS_RIVA128 0x0018
> +#define PCI_VENDOR_ID_CBOARDS 0x1307
> +#define PCI_DEVICE_ID_CBOARDS_DAS1602_16 0x0001
> +#define PCI_VENDOR_ID_SYMPHONY 0x1c1c
> +#define PCI_DEVICE_ID_SYMPHONY_101 0x0001
> +#define PCI_VENDOR_ID_TEKRAM 0x1de1
> +#define PCI_DEVICE_ID_TEKRAM_DC290 0xdc29
> +#define PCI_VENDOR_ID_3DLABS 0x3d3d
> +#define PCI_DEVICE_ID_3DLABS_300SX 0x0001
> +#define PCI_DEVICE_ID_3DLABS_500TX 0x0002
> +#define PCI_DEVICE_ID_3DLABS_DELTA 0x0003
> +#define PCI_DEVICE_ID_3DLABS_PERMEDIA 0x0004
> +#define PCI_DEVICE_ID_3DLABS_MX 0x0006
> +#define PCI_VENDOR_ID_AVANCE 0x4005
> +#define PCI_DEVICE_ID_AVANCE_ALG2064 0x2064
> +#define PCI_DEVICE_ID_AVANCE_2302 0x2302
> +#define PCI_VENDOR_ID_NETVIN 0x4a14
> +#define PCI_DEVICE_ID_NETVIN_NV5000SC 0x5000
> +#define PCI_VENDOR_ID_S3 0x5333
> +#define PCI_DEVICE_ID_S3_PLATO_PXS 0x0551
> +#define PCI_DEVICE_ID_S3_ViRGE 0x5631
> +#define PCI_DEVICE_ID_S3_TRIO 0x8811
> +#define PCI_DEVICE_ID_S3_AURORA64VP 0x8812
> +#define PCI_DEVICE_ID_S3_TRIO64UVP 0x8814
> +#define PCI_DEVICE_ID_S3_ViRGE_VX 0x883d
> +#define PCI_DEVICE_ID_S3_868 0x8880
> +#define PCI_DEVICE_ID_S3_928 0x88b0
> +#define PCI_DEVICE_ID_S3_864_1 0x88c0
> +#define PCI_DEVICE_ID_S3_864_2 0x88c1
> +#define PCI_DEVICE_ID_S3_964_1 0x88d0
> +#define PCI_DEVICE_ID_S3_964_2 0x88d1
> +#define PCI_DEVICE_ID_S3_968 0x88f0
> +#define PCI_DEVICE_ID_S3_TRIO64V2 0x8901
> +#define PCI_DEVICE_ID_S3_PLATO_PXG 0x8902
> +#define PCI_DEVICE_ID_S3_ViRGE_DXGX 0x8a01
> +#define PCI_DEVICE_ID_S3_ViRGE_GX2 0x8a10
> +#define PCI_DEVICE_ID_S3_ViRGE_MX 0x8c01
> +#define PCI_DEVICE_ID_S3_ViRGE_MXP 0x8c02
> +#define PCI_DEVICE_ID_S3_ViRGE_MXPMV 0x8c03
> +#define PCI_DEVICE_ID_S3_SONICVIBES 0xca00
> +#define PCI_VENDOR_ID_INTEL 0x8086
> +#define PCI_DEVICE_ID_INTEL_82375 0x0482
> +#define PCI_DEVICE_ID_INTEL_82424 0x0483
> +#define PCI_DEVICE_ID_INTEL_82378 0x0484
> +#define PCI_DEVICE_ID_INTEL_82430 0x0486
> +#define PCI_DEVICE_ID_INTEL_82434 0x04a3
> +#define PCI_DEVICE_ID_INTEL_82092AA_0 0x1221
> +#define PCI_DEVICE_ID_INTEL_82092AA_1 0x1222
> +#define PCI_DEVICE_ID_INTEL_7116 0x1223
> +#define PCI_DEVICE_ID_INTEL_82596 0x1226
> +#define PCI_DEVICE_ID_INTEL_82865 0x1227
> +#define PCI_DEVICE_ID_INTEL_82557 0x1229
> +#define PCI_DEVICE_ID_INTEL_82437 0x122d
> +#define PCI_DEVICE_ID_INTEL_82371FB_0 0x122e
> +#define PCI_DEVICE_ID_INTEL_82371FB_1 0x1230
> +#define PCI_DEVICE_ID_INTEL_82371MX 0x1234
> +#define PCI_DEVICE_ID_INTEL_82437MX 0x1235
> +#define PCI_DEVICE_ID_INTEL_82441 0x1237
> +#define PCI_DEVICE_ID_INTEL_82380FB 0x124b
> +#define PCI_DEVICE_ID_INTEL_82439 0x1250
> +#define PCI_DEVICE_ID_INTEL_82371SB_0 0x7000
> +#define PCI_DEVICE_ID_INTEL_82371SB_1 0x7010
> +#define PCI_DEVICE_ID_INTEL_82371SB_2 0x7020
> +#define PCI_DEVICE_ID_INTEL_82437VX 0x7030
> +#define PCI_DEVICE_ID_INTEL_82439TX 0x7100
> +#define PCI_DEVICE_ID_INTEL_82371AB_0 0x7110
> +#define PCI_DEVICE_ID_INTEL_82371AB 0x7111
> +#define PCI_DEVICE_ID_INTEL_82371AB_2 0x7112
> +#define PCI_DEVICE_ID_INTEL_82371AB_3 0x7113
> +#define PCI_DEVICE_ID_INTEL_82443LX_0 0x7180
> +#define PCI_DEVICE_ID_INTEL_82443LX_1 0x7181
> +#define PCI_DEVICE_ID_INTEL_82443BX_0 0x7190
> +#define PCI_DEVICE_ID_INTEL_82443BX_1 0x7191
> +#define PCI_DEVICE_ID_INTEL_82443BX_2 0x7192
> +#define PCI_DEVICE_ID_INTEL_P6 0x84c4
> +#define PCI_DEVICE_ID_INTEL_82450GX 0x84c5
> +#define PCI_VENDOR_ID_KTI 0x8e2e
> +#define PCI_DEVICE_ID_KTI_ET32P2 0x3000
> +#define PCI_VENDOR_ID_ADAPTEC 0x9004
> +#define PCI_DEVICE_ID_ADAPTEC_7810 0x1078
> +#define PCI_DEVICE_ID_ADAPTEC_7850 0x5078
> +#define PCI_DEVICE_ID_ADAPTEC_7855 0x5578
> +#define PCI_DEVICE_ID_ADAPTEC_5800 0x5800
> +#define PCI_DEVICE_ID_ADAPTEC_1480A 0x6075
> +#define PCI_DEVICE_ID_ADAPTEC_7860 0x6078
> +#define PCI_DEVICE_ID_ADAPTEC_7861 0x6178
> +#define PCI_DEVICE_ID_ADAPTEC_7870 0x7078
> +#define PCI_DEVICE_ID_ADAPTEC_7871 0x7178
> +#define PCI_DEVICE_ID_ADAPTEC_7872 0x7278
> +#define PCI_DEVICE_ID_ADAPTEC_7873 0x7378
> +#define PCI_DEVICE_ID_ADAPTEC_7874 0x7478
> +#define PCI_DEVICE_ID_ADAPTEC_7895 0x7895
> +#define PCI_DEVICE_ID_ADAPTEC_7880 0x8078
> +#define PCI_DEVICE_ID_ADAPTEC_7881 0x8178
> +#define PCI_DEVICE_ID_ADAPTEC_7882 0x8278
> +#define PCI_DEVICE_ID_ADAPTEC_7883 0x8378
> +#define PCI_DEVICE_ID_ADAPTEC_7884 0x8478
> +#define PCI_DEVICE_ID_ADAPTEC_1030 0x8b78
> +#define PCI_VENDOR_ID_ADAPTEC2 0x9005
> +#define PCI_DEVICE_ID_ADAPTEC2_2940U2 0x0010
> +#define PCI_DEVICE_ID_ADAPTEC2_7890 0x001f
> +#define PCI_DEVICE_ID_ADAPTEC2_3940U2 0x0050
> +#define PCI_DEVICE_ID_ADAPTEC2_7896 0x005f
> +#define PCI_VENDOR_ID_ATRONICS 0x907f
> +#define PCI_DEVICE_ID_ATRONICS_2015 0x2015
> +#define PCI_VENDOR_ID_HOLTEK 0x9412
> +#define PCI_DEVICE_ID_HOLTEK_6565 0x6565
> +#define PCI_VENDOR_ID_TIGERJET 0xe159
> +#define PCI_DEVICE_ID_TIGERJET_300 0x0001
> +#define PCI_VENDOR_ID_ARK 0xedd8
> +#define PCI_DEVICE_ID_ARK_STING 0xa091
> +#define PCI_DEVICE_ID_ARK_STINGARK 0xa099
> +#define PCI_DEVICE_ID_ARK_2000MT 0xa0a1
> +#endif /* !__PCI_IDS_H__ */
> diff --git a/cpukit/libpci/pci/ids_extra.h b/cpukit/libpci/pci/ids_extra.h
> new file mode 100644
> index 0000000..ffa18cb
> --- /dev/null
> +++ b/cpukit/libpci/pci/ids_extra.h
> @@ -0,0 +1,19 @@
> +/* RTEMS local PCI data base */
> +/* Only included from pci_ids.h */
> +#error pci/ids_extra.h should only be included from pci/ids.h
> +#endif
> +/* Gaisler PCI IDs */
> +#define PCIID_VENDOR_GAISLER 0x1AC8
> +#define PCIID_VENDOR_GAISLER_OLD 0x16E3
> +/* Gaisler PCI Devices */
> +#define PCIID_DEVICE_GR_RASTA_IO 0x0010 /* GR-RASTA-IO */
> +#define PCIID_DEVICE_GR_RASTA_IO_OLD 0x0210 /* old GR-RASTA-IO ID*/
> +#define PCIID_DEVICE_GR_RASTA_TMTC 0x0011 /* GR-RASTA-TMTC */
> +#define PCIID_DEVICE_GR_RASTA_ADCDAC 0x0014 /* GR-RASTA-ADCDAC */
> +#define PCIID_DEVICE_GR_701 0x0701 /* GR-701 */
> +#define PCIID_DEVICE_GR_TMTC_1553 0x0198 /* GR-TMTC-1553 */
> +#define PCIID_DEVICE_GR_RASTA_SPW_RTR 0x0062 /* GR-RASTA-SPW-ROUTER */
This is all the farther I got for now.
