[PATCH v3] ARM: Add BSP_START_NEEDS_REGISTER_INITIALIZATION
Martin Galvan
martin.galvan at tallertechnologies.com
Thu Feb 26 20:31:27 UTC 2015
This patch adds the macro BSP_START_NEEDS_REGISTER_INITIALIZATION and three hooks for BSP-specific register init code to arm/shared/start.S. Said hooks are bsp_start_init_registers_core (intended for initializing the ARM core registers), bsp_start_init_registers_banked_fiq (for the FIQ mode banked registers) and bsp_start_init_registers_vfp (for the FPU registers). BSP_START_NEEDS_REGISTER_INITIALIZATION would be defined in a BSP's configure.ac (so that it appears in its bspopts.h).
This patch also adds the register init code required by the TMS570. We've tested it with the tms570ls3137_hdk.cfg config and it works fine.
Changes in v3:
* Move bsp-start-init-registers.S to arm/shared/startup.
* Don't push/pop r0 in bsp_start_init_registers_vfp.
* Add VFP register init code for VFP-32 as well.
Changes in v2:
* Add bsp_start_* prefixes.
* Add *_banked_fiq suffixes to make it clear it's referring to the FIQ mode banked regs.
c/src/lib/libbsp/arm/shared/start/start.S | 28 ++++++
.../arm/shared/startup/bsp-start-init-registers.S | 105 +++++++++++++++++++++
c/src/lib/libbsp/arm/tms570/Makefile.am | 1 +
c/src/lib/libbsp/arm/tms570/configure.ac | 5 +
4 files changed, 139 insertions(+)
create mode 100644 c/src/lib/libbsp/arm/shared/startup/bsp-start-init-registers.S
diff --git a/c/src/lib/libbsp/arm/shared/start/start.S b/c/src/lib/libbsp/arm/shared/start/start.S
index f5f0fa4..65aa23d 100644
--- a/c/src/lib/libbsp/arm/shared/start/start.S
+++ b/c/src/lib/libbsp/arm/shared/start/start.S
@@ -48,6 +48,12 @@
.extern _ARMV4_Exception_fiq_default
.extern _ARMV7M_Exception_default
+#ifdef BSP_START_NEEDS_REGISTER_INITIALIZATION
+ .extern bsp_start_init_registers_core
+ .extern bsp_start_init_registers_banked_fiq
+ .extern bsp_start_init_registers_vfp
+#endif
/* Global symbols */
.globl _start
.globl bsp_start_vector_table_begin
@@ -127,6 +133,10 @@ _start:
* loader.
+ bl bsp_start_init_registers_core
+#endif
#ifdef RTEMS_SMP
/* Read MPIDR */
mrc p15, 0, r0, c0, c0, 5
@@ -161,6 +171,10 @@ _start:
add sp, r1
#endif
+ bl bsp_start_init_registers_banked_fiq
+#endif
/* Enter ABT mode and set up the ABT stack pointer */
mov r0, #(ARM_PSR_M_ABT | ARM_PSR_I | ARM_PSR_F)
msr cpsr, r0
@@ -207,6 +221,11 @@ _start:
/* Enable FPU */
mov r0, #(1 << 30)
vmsr FPEXC, r0
+ bl bsp_start_init_registers_vfp
+#endif
#endif /* ARM_MULTILIB_VFP */
@@ -304,6 +323,10 @@ bsp_start_vector_table_end:
_start:
+#endif
#ifdef ARM_MULTILIB_VFP
* Enable CP10 and CP11 coprocessors for privileged and user mode in
@@ -315,8 +338,13 @@ _start:
str r1, [r0]
dsb
isb
#endif
+#endif /* ARM_MULTILIB_VFP */
ldr sp, =bsp_stack_main_end
ldr lr, =bsp_start_hook_0_done + 1
b bsp_start_hook_0
diff --git a/c/src/lib/libbsp/arm/shared/startup/bsp-start-init-registers.S b/c/src/lib/libbsp/arm/shared/startup/bsp-start-init-registers.S
new file mode 100644
index 0000000..2e308ce
--- /dev/null
+++ b/c/src/lib/libbsp/arm/shared/startup/bsp-start-init-registers.S
@@ -0,0 +1,105 @@
+ * @file bsp-start-init-registers.S
+ * @brief ARM register initialization routines.
+ * Copyright (c) 2015 Taller Technologies. All rights reserved.
+ * @author Martin Galvan <martin.galvan at tallertechnologies.com>
+ * These routines initialize the core and VFP registers of ARM CPUs.
+ * This is necessary for boards that operate in a 1oo1D fashion,
+ * such as the TMS570.
+#include <rtems/asm.h>
+.section .text
+.syntax unified
+.cpu cortex-r4
+.arm
+/* Initialization of the ARM core registers. */
+FUNCTION_ENTRY(bsp_start_init_registers_core)
+ mov r0, #0
+ mov r1, #0
+ mov r2, #0
+ mov r3, #0
+ mov r4, #0
+ mov r5, #0
+ mov r6, #0
+ mov r7, #0
+ mov r8, #0
+ mov r9, #0
+ mov r10, #0
+ mov r11, #0
+ mov r12, #0
+ mov r13, #0
+ bx lr
+FUNCTION_END(bsp_start_init_registers_core)
+/* Initialization of the FIQ mode banked registers. */
+FUNCTION_ENTRY(bsp_start_init_registers_banked_fiq)
+ mov r8, #0
+ mov r9, #0
+ mov r10, #0
+ mov r11, #0
+ mov r12, #0
+ bx lr
+FUNCTION_END(bsp_start_init_registers_banked_fiq)
+#ifdef ARM_MULTILIB_VFP
+/* Initialization of the FPU registers. */
+FUNCTION_ENTRY(bsp_start_init_registers_vfp)
+ mov r0, #0
+ vmov d0, r0, r0
+ vmov d1, r0, r0
+ vmov d2, r0, r0
+ vmov d3, r0, r0
+ vmov d4, r0, r0
+ vmov d5, r0, r0
+ vmov d6, r0, r0
+ vmov d7, r0, r0
+ vmov d8, r0, r0
+ vmov d9, r0, r0
+ vmov d10, r0, r0
+ vmov d11, r0, r0
+ vmov d12, r0, r0
+ vmov d13, r0, r0
+ vmov d14, r0, r0
+ vmov d15, r0, r0
+#ifdef ARM_MULTILIB_VFP_D32
+ vmov d16, r0, r0
+ vmov d17, r0, r0
+ vmov d18, r0, r0
+ vmov d19, r0, r0
+ vmov d20, r0, r0
+ vmov d21, r0, r0
+ vmov d22, r0, r0
+ vmov d23, r0, r0
+ vmov d24, r0, r0
+ vmov d25, r0, r0
+ vmov d26, r0, r0
+ vmov d27, r0, r0
+ vmov d28, r0, r0
+ vmov d29, r0, r0
+ vmov d30, r0, r0
+ vmov d31, r0, r0
+#endif /* ARM_MULTILIB_VFP_D32 */
+ bx lr
+FUNCTION_END(bsp_start_init_registers_vfp)
diff --git a/c/src/lib/libbsp/arm/tms570/Makefile.am b/c/src/lib/libbsp/arm/tms570/Makefile.am
index bf3465d..6cad609 100644
--- a/c/src/lib/libbsp/arm/tms570/Makefile.am
+++ b/c/src/lib/libbsp/arm/tms570/Makefile.am
@@ -82,6 +82,7 @@ libbsp_a_SOURCES += ../../shared/cpucounterdiff.c
# Startup
libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
+libbsp_a_SOURCES += ../shared/startup/bsp-start-init-registers.S
libbsp_a_SOURCES += ../../shared/bsppretaskinghook.c
libbsp_a_SOURCES += startup/bspreset.c
libbsp_a_SOURCES += startup/bspstart.c
diff --git a/c/src/lib/libbsp/arm/tms570/configure.ac b/c/src/lib/libbsp/arm/tms570/configure.ac
index cefe50a..e06d4e4 100644
--- a/c/src/lib/libbsp/arm/tms570/configure.ac
+++ b/c/src/lib/libbsp/arm/tms570/configure.ac
@@ -36,6 +36,11 @@ RTEMS_BSPOPTS_SET([BSP_MINIMUM_TASK_STACK_SIZE],[*],[1024])
RTEMS_BSPOPTS_HELP([BSP_MINIMUM_TASK_STACK_SIZE],[Suggested minimum task stack
size in bytes])
+RTEMS_BSPOPTS_SET([BSP_START_NEEDS_REGISTER_INITIALIZATION],[*],[1])
+RTEMS_BSPOPTS_HELP([BSP_START_NEEDS_REGISTER_INITIALIZATION],
+ [The TMS570 needs to have the registers of its CPU initialized
+ to avoid CCMR4F errors])
RTEMS_BSPOPTS_SET([TMS570_OSCILLATOR_MAIN],[*],[12000000U])
RTEMS_BSPOPTS_HELP([TMS570_OSCILLATOR_MAIN],[main oscillator frequency in Hz])
2.3.0
