Gaisler Qemu Patches Disappeared
Jiri Gaisler
jiri at gaisler.se
Mon Feb 2 15:45:36 UTC 2015
Should be fixed now, sorry for the trouble.
Jiri.
On 02/02/2015 04:32 PM, Joel Sherrill wrote:
> On February 2, 2015 8:19:54 AM MST, Jiri Gaisler <jiri at gaisler.se> wrote:
>> This is my fault, a server switch failed to move the qemu directory
>> to the new server. I will restore the files as soon as possible.
> The is for the quick response Jiri. Upgrades always come with issues.
>> Jiri.
>> On 02/02/2015 03:47 PM, Joel Sherrill wrote:
>>> Hi Daniel
>>> Qemu doesn't build with the RSB because the Gaisler patches that
>>> were referenced seem to have disappeared. As best I can tell, the
>> entire
>>> directory is no longer there. Where are the patches now? Do you have
>>> a patch for the RSB?
>>> downloading:
>> patches/Provide-the-missing-LIBUSB_LOG_LEVEL_-for-older-libusb-or-FreeBSD.-Providing-just-the-needed-value-as-a-defined..patch
>>> - 666.0 bytes
>>> download:
>> https://gaisler.org/qemu/0001-LEON3-Add-emulation-of-AMBA-plug-play.patch
>>> patches/0001-LEON3-Add-emulation-of-AMBA-plug-play.patch
>>> download:
>> https://gaisler.org/qemu/0001-LEON3-Add-emulation-of-AMBA-plug-play.patch:
>>> error: HTTP Error 404: Not Found
>>> error: downloading
>>> all paths have failed, giving up
>>> Build FAILED
>>> See error report:
>> rsb-report-qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed-x86_64-linux-gnu-1.txt
>>> error: downloading
>>> Build Set: Time 0:09:25.091254
> --joel
