Gaisler Qemu Patches Disappeared
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Feb 2 16:25:39 UTC 2015
On 2/2/2015 9:45 AM, Jiri Gaisler wrote:
> Should be fixed now, sorry for the trouble.
No problem. My build is past that now. I thought I built
qemu with the RSB last week while teaching an RTEMS class.
When did the server switch occur?
--joel
> Jiri.
> On 02/02/2015 04:32 PM, Joel Sherrill wrote:
>> On February 2, 2015 8:19:54 AM MST, Jiri Gaisler <jiri at gaisler.se> wrote:
>>> This is my fault, a server switch failed to move the qemu directory
>>> to the new server. I will restore the files as soon as possible.
>> The is for the quick response Jiri. Upgrades always come with issues.
>>> Jiri.
>>> On 02/02/2015 03:47 PM, Joel Sherrill wrote:
>>>> Hi Daniel
>>>> Qemu doesn't build with the RSB because the Gaisler patches that
>>>> were referenced seem to have disappeared. As best I can tell, the
>>> entire
>>>> directory is no longer there. Where are the patches now? Do you have
>>>> a patch for the RSB?
>>>> downloading:
>>> patches/Provide-the-missing-LIBUSB_LOG_LEVEL_-for-older-libusb-or-FreeBSD.-Providing-just-the-needed-value-as-a-defined..patch
>>>> - 666.0 bytes
>>>> download:
>>> https://gaisler.org/qemu/0001-LEON3-Add-emulation-of-AMBA-plug-play.patch
>>>> patches/0001-LEON3-Add-emulation-of-AMBA-plug-play.patch
>>>> download:
>>> https://gaisler.org/qemu/0001-LEON3-Add-emulation-of-AMBA-plug-play.patch:
>>>> error: HTTP Error 404: Not Found
>>>> error: downloading
>>>> all paths have failed, giving up
>>>> Build FAILED
>>>> See error report:
>>> rsb-report-qemu-d5b4dc3b50175f0c34f3cf4b053e123fb37f5aed-x86_64-linux-gnu-1.txt
>>>> error: downloading
>>>> Build Set: Time 0:09:25.091254
>> --joel
