[PATCH 2/2] doc: Document network task affinity option
Daniel Cederman
cederman at gaisler.com
Wed Feb 4 09:52:17 UTC 2015
doc/networking/networkapp.t | 14 ++++++++++++++
1 file changed, 14 insertions(+)
diff --git a/doc/networking/networkapp.t b/doc/networking/networkapp.t
index 62b1a53..dd356a8 100644
--- a/doc/networking/networkapp.t
+++ b/doc/networking/networkapp.t
@@ -101,6 +101,11 @@ struct rtems_bsdnet_config @{
unsigned long tcp_tx_buf_size;
/* TCP TX: 16 * 1024 bytes */
unsigned long tcp_rx_buf_size;
+ /* Default Network Tasks CPU Affinity */
+#ifdef RTEMS_SMP
+ const cpu_set_t *network_task_cpuset;
+ size_t network_task_cpuset_size;
+#endif
@end group
@end example
@@ -229,6 +234,15 @@ This configuration parameter specifies the maximum amount of
buffer memory which may be used for TCP sockets to receive
into. The default size is sixteen kilobytes.
+ at item const cpu_set_t *network_task_cpuset
+This configuration parameter specifies the CPU affinity of the
+network task. If set to @code{0} the network task can be scheduled on
+any CPU. Only available in SMP configurations.
+ at item size_t network_task_cpuset_size
+This configuration parameter specifies the size of the
+ at code{network_task_cpuset} used. Only available in SMP configurations.
@end table
In addition, the following fields in the @code{rtems_bsdnet_ifconfig}
2.2.1
