[PATCH] bsp/sparc: Move BSP_ISR_handler to a separate file
Wed Feb 4 15:12:07 UTC 2015
I'd like to entertain a new name for this "BSP_ISR_handler" function
now that it becomes an exported symbol. We should put it into a proper
namespace.
Also, I'm not sure on the legality of putting a copyright for Cobham
Gaisler that predates Cobham's acquisition of Aeroflex. But I am not a
lawyer.
-Gedare
On Wed, Feb 4, 2015 at 4:52 AM, Daniel Cederman <cederman at gaisler.com> wrote:
> This allows it to be wrapped by another function at link-time
> and can be used to trace interrupts. If not placed in a separate
> file, the function pointer address used in BSP_shared_interrupt_init
> will be resolved at compile-time, and the function will not be wrappable.
>  c/src/lib/libbsp/sparc/Makefile.am                 |  1 +
>  c/src/lib/libbsp/sparc/erc32/Makefile.am           |  1 +
>  c/src/lib/libbsp/sparc/erc32/include/bsp.h         |  3 ++
>  c/src/lib/libbsp/sparc/leon2/Makefile.am           |  1 +
>  c/src/lib/libbsp/sparc/leon2/include/bsp.h         |  3 ++
>  c/src/lib/libbsp/sparc/leon3/Makefile.am           |  1 +
>  c/src/lib/libbsp/sparc/leon3/include/bsp.h         |  3 ++
>  .../lib/libbsp/sparc/shared/irq/bsp_isr_handler.c  | 35 ++++++++++++++++++++++
>  c/src/lib/libbsp/sparc/shared/irq/irq-shared.c     | 32 +++++++-------------
>  9 files changed, 58 insertions(+), 22 deletions(-)
>  create mode 100644 c/src/lib/libbsp/sparc/shared/irq/bsp_isr_handler.c
> diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
> index 3d433fb..615aea7 100644
> --- a/c/src/lib/libbsp/sparc/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/Makefile.am
> @@ -11,6 +11,7 @@ EXTRA_DIST += shared/start/start.S
>  # Interrupt
>  EXTRA_DIST += shared/irq/irq-shared.c
> +EXTRA_DIST += shared/irq/bsp_isr_handler.c
>  # AMBA Plug&Play bus
>  EXTRA_DIST += shared/include/ambapp.h
> diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am b/c/src/lib/libbsp/sparc/erc32/Makefile.am
> index c99d2fb..8dcdd32 100644
> --- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
> @@ -71,6 +71,7 @@ include_bsp_HEADERS += \
>      include/bsp/irq.h
>  libbsp_a_SOURCES += \
>      ../../sparc/shared/irq/irq-shared.c \
> +    ../../sparc/shared/irq/bsp_isr_handler.c \
>      ../../shared/src/irq-default-handler.c \
>      ../../shared/src/irq-generic.c \
>      ../../shared/src/irq-info.c \
> diff --git a/c/src/lib/libbsp/sparc/erc32/include/bsp.h b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
> index 3393910..2e531ec 100644
> --- a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
> +++ b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
> @@ -106,6 +106,9 @@ typedef void (*bsp_shared_isr)(void *arg);
>  /* Initializes the Shared System Interrupt service */
>  extern void BSP_shared_interrupt_init(void);
> +/* Called directly from IRQ trap handler TRAP[0x10..0x1F] = IRQ[0..15] */
> +void BSP_ISR_handler(rtems_vector_number vector);
>  /* Registers a shared IRQ handler, and enable it at IRQ controller. Multiple
>   * interrupt handlers may use the same IRQ number, all ISRs will be called
>   * when an interrupt on that line is fired.
> diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> index d1e3817..efcb286 100644
> --- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> @@ -80,6 +80,7 @@ include_bsp_HEADERS += \
>      include/bsp/irq.h
> diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp.h b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
> index 41a1e43..807f8d9 100644
> --- a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
> +++ b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
> @@ -130,6 +130,9 @@ typedef void (*bsp_shared_isr)(void *arg);
> diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> index c894095..cec0b34 100644
> --- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> @@ -82,6 +82,7 @@ include_bsp_HEADERS += \
>      startup/eirq.c \
> diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
> index 2514190..f4e1121 100644
> --- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
> +++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
> @@ -153,6 +153,9 @@ typedef void (*bsp_shared_isr)(void *arg);
> diff --git a/c/src/lib/libbsp/sparc/shared/irq/bsp_isr_handler.c b/c/src/lib/libbsp/sparc/shared/irq/bsp_isr_handler.c
> new file mode 100644
> index 0000000..cc55a15
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/shared/irq/bsp_isr_handler.c
> @@ -0,0 +1,35 @@
> +*  COPYRIGHT (c) 2015
> +*  Cobham Gaisler
> +*  The license and distribution terms for this file may be
> +*  found in the file LICENSE in this distribution or at
> +*  http://www.rtems.org/license/LICENSE.
> +#include <rtems.h>
> +#include <bsp.h>
> +#include <bsp/irq-generic.h>
> +static inline void bsp_dispatch_irq(int irq)
> +  bsp_interrupt_handler_entry *e =
> +    &bsp_interrupt_handler_table[bsp_interrupt_handler_index(irq)];
> +  while (e != NULL) {
> +    (*e->handler)(e->arg);
> +    e = e->next;
> +  int irq = vector - 0x10;
> +  /* Let BSP fixup and/or handle incomming IRQ */
> +  irq = bsp_irq_fixup(irq);
> +  bsp_dispatch_irq(irq);
> diff --git a/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c b/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
> index 79dbe55..d75dee0 100644
> --- a/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
> +++ b/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
> @@ -1,3 +1,13 @@
> +*  COPYRIGHT (c) 2012-2015
> +*  Cobham Gaisler
>  #include <rtems.h>
>  #include <bsp.h>
> @@ -27,28 +37,6 @@ static inline int bsp_irq_cpu(int irq)
>  #endif
> -static inline void bsp_dispatch_irq(int irq)
> -  bsp_interrupt_handler_entry *e =
> -    &bsp_interrupt_handler_table[bsp_interrupt_handler_index(irq)];
> -  while (e != NULL) {
> -    (*e->handler)(e->arg);
> -    e = e->next;
> -/* Called directly from IRQ trap handler TRAP[0x10..0x1F] = IRQ[0..15] */
> -static void BSP_ISR_handler(rtems_vector_number vector)
> -  int irq = vector - 0x10;
> -  /* Let BSP fixup and/or handle incomming IRQ */
> -  irq = bsp_irq_fixup(irq);
> -  bsp_dispatch_irq(irq);
>  /* Initialize interrupts */
> 2.2.1
> devel mailing list
> devel at rtems.org
