[PATCH 6/7] IMFS: Allow static initialization of FS info
Mon Feb 9 20:35:56 UTC 2015
 cpukit/libfs/src/imfs/fifoimfs_init.c | 32 ++++++++++------
 cpukit/libfs/src/imfs/imfs.h          | 34 ++++++++---------
 cpukit/libfs/src/imfs/imfs_init.c     | 32 ++++++++++------
 cpukit/libfs/src/imfs/imfs_initsupp.c | 71 ++++++++++++++---------------------
 cpukit/libfs/src/imfs/imfs_mknod.c    | 17 +++++----
 cpukit/libfs/src/imfs/miniimfs_init.c | 32 ++++++++++------
 6 files changed, 118 insertions(+), 100 deletions(-)
diff --git a/cpukit/libfs/src/imfs/fifoimfs_init.c b/cpukit/libfs/src/imfs/fifoimfs_init.c
index 3b87f19..4063557 100644
--- a/cpukit/libfs/src/imfs/fifoimfs_init.c
+++ b/cpukit/libfs/src/imfs/fifoimfs_init.c
@@ -25,6 +25,10 @@
 #include "imfs.h"
+#include <stdlib.h>
+#include <rtems/seterr.h>
 const rtems_filesystem_operations_table fifoIMFS_ops = {
   .lock_h = rtems_filesystem_default_lock,
   .unlock_h = rtems_filesystem_default_unlock,
@@ -47,12 +51,11 @@ const rtems_filesystem_operations_table fifoIMFS_ops = {
   .statvfs_h = rtems_filesystem_default_statvfs
-static const IMFS_mknod_control *const
-  IMFS_fifo_mknod_controls[IMFS_TYPE_COUNT] = {
-  [IMFS_DIRECTORY] = &IMFS_mknod_control_directory,
-  [IMFS_DEVICE] = &IMFS_mknod_control_device,
-  [IMFS_MEMORY_FILE] = &IMFS_mknod_control_memfile,
-  [IMFS_FIFO] = &IMFS_mknod_control_fifo
+static const IMFS_mknod_controls IMFS_fifo_mknod_controls = {
+  .directory = &IMFS_mknod_control_directory,
+  .device = &IMFS_mknod_control_device,
+  .file = &IMFS_mknod_control_memfile,
+  .fifo = &IMFS_mknod_control_fifo
 int fifoIMFS_initialize(
@@ -60,9 +63,16 @@ int fifoIMFS_initialize(
   const void *data
-  return IMFS_initialize_support(
-    mt_entry,
-    &fifoIMFS_ops,
+  IMFS_fs_info_t *fs_info = calloc( 1, sizeof( *fs_info ) );
+  IMFS_mount_data mount_data = {
+    .fs_info = fs_info,
+    .ops = &fifoIMFS_ops,
+    .mknod_controls = &IMFS_fifo_mknod_controls
+  if ( fs_info == NULL ) {
+    rtems_set_errno_and_return_minus_one( ENOMEM );
+  return IMFS_initialize_support( mt_entry, &mount_data );
diff --git a/cpukit/libfs/src/imfs/imfs.h b/cpukit/libfs/src/imfs/imfs.h
index 5479791..00fc179 100644
--- a/cpukit/libfs/src/imfs/imfs.h
+++ b/cpukit/libfs/src/imfs/imfs.h
@@ -94,18 +94,6 @@ typedef block_p *block_ptr;
 #define IMFS_MEMFILE_MAXIMUM_SIZE \
   (LAST_TRIPLY_INDIRECT * IMFS_MEMFILE_BYTES_PER_BLOCK)
- *  What types of IMFS file systems entities there can be.
-typedef enum {
-  IMFS_DIRECTORY,
-  IMFS_DEVICE,
-  IMFS_MEMORY_FILE,
-  IMFS_FIFO
-} IMFS_jnode_types_t;
-#define IMFS_TYPE_COUNT (IMFS_FIFO + 1)
@@ -375,10 +363,23 @@ static inline void IMFS_mtime_ctime_update( IMFS_jnode_t *jnode )
 typedef struct {
+  const IMFS_mknod_control *directory;
+  const IMFS_mknod_control *device;
+  const IMFS_mknod_control *file;
+  const IMFS_mknod_control *fifo;
+} IMFS_mknod_controls;
+typedef struct {
   IMFS_directory_t Root_directory;
-  const IMFS_mknod_control *mknod_controls[ IMFS_TYPE_COUNT ];
+  const IMFS_mknod_controls *mknod_controls;
 } IMFS_fs_info_t;
+typedef struct {
+  IMFS_fs_info_t *fs_info;
+  const rtems_filesystem_operations_table *ops;
+} IMFS_mount_data;
  *  Shared Data
@@ -415,14 +416,11 @@ extern int miniIMFS_initialize(
    const void                           *data
- * @brief IMFS initialization support.
 extern int IMFS_initialize_support(
   rtems_filesystem_mount_table_entry_t *mt_entry,
-  const rtems_filesystem_operations_table *op_table,
-  const IMFS_mknod_control *const mknod_controls[ IMFS_TYPE_COUNT ]
+  const void                           *data
  * @brief Unmount this instance of IMFS.
diff --git a/cpukit/libfs/src/imfs/imfs_init.c b/cpukit/libfs/src/imfs/imfs_init.c
index 854363c..e82490f 100644
--- a/cpukit/libfs/src/imfs/imfs_init.c
+++ b/cpukit/libfs/src/imfs/imfs_init.c
@@ -21,6 +21,10 @@
 #include "imfs.h"
 const rtems_filesystem_operations_table IMFS_ops = {
@@ -43,12 +47,11 @@ const rtems_filesystem_operations_table IMFS_ops = {
-  IMFS_mknod_controls[ IMFS_TYPE_COUNT ] = {
-  [IMFS_FIFO] = &IMFS_mknod_control_enosys
+static const IMFS_mknod_controls IMFS_default_mknod_controls = {
+  .fifo = &IMFS_mknod_control_enosys
 int IMFS_initialize(
@@ -56,9 +59,16 @@ int IMFS_initialize(
   const void                           *data
-    mt_entry,
-    &IMFS_ops,
+    .ops = &IMFS_ops,
+    .mknod_controls = &IMFS_default_mknod_controls
diff --git a/cpukit/libfs/src/imfs/imfs_initsupp.c b/cpukit/libfs/src/imfs/imfs_initsupp.c
index fee4990..5f0df25 100644
--- a/cpukit/libfs/src/imfs/imfs_initsupp.c
+++ b/cpukit/libfs/src/imfs/imfs_initsupp.c
@@ -104,51 +104,38 @@ IMFS_jnode_t *IMFS_initialize_node(
+  const void                           *data
-  int rv = 0;
-  IMFS_fs_info_t *fs_info = calloc( 1, sizeof( *fs_info ) );
-  if ( fs_info != NULL ) {
-    IMFS_jnode_t *root_node;
-    memcpy(
-      fs_info->mknod_controls,
-      mknod_controls,
-      sizeof( fs_info->mknod_controls )
-    root_node = IMFS_initialize_node(
-      &fs_info->Root_directory.Node,
-      &fs_info->mknod_controls[ IMFS_DIRECTORY ]->node_control,
-      0,
-      (S_IFDIR | 0755),
-      NULL
-    IMFS_assert( root_node != NULL );
-    mt_entry->fs_info = fs_info;
-    mt_entry->ops = op_table;
-    mt_entry->pathconf_limits_and_options = &IMFS_LIMITS_AND_OPTIONS;
-    mt_entry->mt_fs_root->location.node_access = root_node;
-    IMFS_Set_handlers( &mt_entry->mt_fs_root->location );
-  } else {
-    errno = ENOMEM;
-    rv = -1;
-  if ( rv == 0 ) {
-    IMFS_determine_bytes_per_block(
-      &imfs_memfile_bytes_per_block,
-      imfs_rq_memfile_bytes_per_block,
-      IMFS_MEMFILE_DEFAULT_BYTES_PER_BLOCK
+  const IMFS_mount_data *mount_data = data;
+  IMFS_fs_info_t *fs_info = mount_data->fs_info;
+  IMFS_jnode_t *root_node;
+  fs_info->mknod_controls = mount_data->mknod_controls;
+  root_node = IMFS_initialize_node(
+    &fs_info->Root_directory.Node,
+    &fs_info->mknod_controls->directory->node_control,
+    0,
+    (S_IFDIR | 0755),
+    NULL
+  IMFS_assert( root_node != NULL );
+  mt_entry->fs_info = fs_info;
+  mt_entry->ops = mount_data->ops;
+  mt_entry->pathconf_limits_and_options = &IMFS_LIMITS_AND_OPTIONS;
+  mt_entry->mt_fs_root->location.node_access = root_node;
+  IMFS_Set_handlers( &mt_entry->mt_fs_root->location );
+  IMFS_determine_bytes_per_block(
+    &imfs_memfile_bytes_per_block,
+    imfs_rq_memfile_bytes_per_block,
+    IMFS_MEMFILE_DEFAULT_BYTES_PER_BLOCK
-  return rv;
+  return 0;
 int IMFS_node_clone( rtems_filesystem_location_info_t *loc )
diff --git a/cpukit/libfs/src/imfs/imfs_mknod.c b/cpukit/libfs/src/imfs/imfs_mknod.c
index ed67192..1a8438b 100644
--- a/cpukit/libfs/src/imfs/imfs_mknod.c
+++ b/cpukit/libfs/src/imfs/imfs_mknod.c
@@ -23,17 +23,20 @@
 #include "imfs.h"
-static IMFS_jnode_types_t get_type( mode_t mode )
+static const IMFS_mknod_control *get_control(
+  const IMFS_mknod_controls *controls,
+  mode_t mode
   if ( S_ISDIR( mode ) ) {
-    return IMFS_DIRECTORY;
+    return controls->directory;
   } else if ( S_ISBLK( mode ) || S_ISCHR( mode ) ) {
-    return IMFS_DEVICE;
-  } else if (S_ISFIFO( mode )) {
-    return IMFS_FIFO;
+    return controls->device;
+  } else if ( S_ISFIFO( mode ) ) {
+    return controls->fifo;
   } else {
     IMFS_assert( S_ISREG( mode ) );
-    return IMFS_MEMORY_FILE;
+    return controls->file;
@@ -48,7 +51,7 @@ int IMFS_mknod(
   int rv = 0;
   const IMFS_fs_info_t *fs_info = parentloc->mt_entry->fs_info;
   const IMFS_mknod_control *mknod_control =
-    fs_info->mknod_controls[ get_type( mode ) ];
+    get_control( fs_info->mknod_controls, mode );
   IMFS_jnode_t *new_node;
   new_node = IMFS_create_node(
diff --git a/cpukit/libfs/src/imfs/miniimfs_init.c b/cpukit/libfs/src/imfs/miniimfs_init.c
index 87879fc..7451c5e 100644
--- a/cpukit/libfs/src/imfs/miniimfs_init.c
+++ b/cpukit/libfs/src/imfs/miniimfs_init.c
@@ -21,6 +21,10 @@
 #include "imfs.h"
 const rtems_filesystem_operations_table miniIMFS_ops = {
@@ -43,12 +47,11 @@ const rtems_filesystem_operations_table miniIMFS_ops = {
-  IMFS_mini_mknod_controls[ IMFS_TYPE_COUNT ] = {
+static const IMFS_mknod_controls IMFS_mini_mknod_controls = {
@@ -56,9 +59,16 @@ int miniIMFS_initialize(
   const void                           *data
-    mt_entry,
-    &miniIMFS_ops,
+    .ops = &miniIMFS_ops,
+    .mknod_controls = &IMFS_mini_mknod_controls
2.1.4
