[PATCH 7/7] IMFS: Add fine grained configuration
Sebastian Huber
Mon Feb 9 20:35:57 UTC 2015
Remove miniIMFS. Statically initialize the root IMFS.
Add configuration options to disable individual
features of the root IMFS, e.g.
o CONFIGURE_IMFS_DISABLE_CHOWN,
o CONFIGURE_IMFS_DISABLE_FCHMOD,
o CONFIGURE_IMFS_DISABLE_LINK,
o CONFIGURE_IMFS_DISABLE_MKNOD,
o CONFIGURE_IMFS_DISABLE_MOUNT,
o CONFIGURE_IMFS_DISABLE_READLINK,
o CONFIGURE_IMFS_DISABLE_RENAME,
o CONFIGURE_IMFS_DISABLE_RMNOD,
o CONFIGURE_IMFS_DISABLE_SYMLINK,
o CONFIGURE_IMFS_DISABLE_UNMOUNT, and
o CONFIGURE_IMFS_DISABLE_UTIME.
.../lib/libbsp/powerpc/beatnik/irq/irq_test_app.c | 1 -
cpukit/libfs/Makefile.am | 4 +-
cpukit/libfs/src/imfs/fifoimfs_init.c | 78 -----
cpukit/libfs/src/imfs/imfs.h | 21 +-
cpukit/libfs/src/imfs/imfs_init.c | 2 +-
cpukit/libfs/src/imfs/imfs_load_tar.c | 5 +-
cpukit/libfs/src/imfs/imfs_make_generic_node.c | 10 -
cpukit/libfs/src/imfs/miniimfs_init.c | 74 -----
cpukit/sapi/include/confdefs.h | 184 +++++++-----
doc/user/conf.t | 320 ++++++++++++++++++---
testsuites/fstests/fsimfsgeneric01/init.c | 16 +-
testsuites/fstests/mimfs_support/fs_support.c | 2 +
testsuites/libtests/tar03/init.c | 9 -
testsuites/psxtests/psxfile01/main.c | 2 +
testsuites/psxtests/psximfs02/init.c | 2 +
testsuites/psxtests/psxmount/main.c | 2 +
testsuites/psxtests/psxreaddir/main.c | 2 +
testsuites/psxtests/psxstat/main.c | 2 +
testsuites/samples/iostream/system.h | 3 -
testsuites/sptests/sp47/init.c | 2 -
testsuites/sptests/sp48/init.c | 2 -
21 files changed, 437 insertions(+), 306 deletions(-)
delete mode 100644 cpukit/libfs/src/imfs/fifoimfs_init.c
delete mode 100644 cpukit/libfs/src/imfs/miniimfs_init.c
diff --git a/c/src/lib/libbsp/powerpc/beatnik/irq/irq_test_app.c b/c/src/lib/libbsp/powerpc/beatnik/irq/irq_test_app.c
index 72a43fa..cb9ff14 100644
--- a/c/src/lib/libbsp/powerpc/beatnik/irq/irq_test_app.c
+++ b/c/src/lib/libbsp/powerpc/beatnik/irq/irq_test_app.c
@@ -36,7 +36,6 @@ rtems_task Init(
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_TASKS 1
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#define CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
#include <confdefs.h>
diff --git a/cpukit/libfs/Makefile.am b/cpukit/libfs/Makefile.am
index 3c454e7..802dfdb 100644
--- a/cpukit/libfs/Makefile.am
+++ b/cpukit/libfs/Makefile.am
@@ -41,7 +41,7 @@ noinst_LIBRARIES += libimfs.a
libimfs_a_SOURCES =
libimfs_a_SOURCES += src/imfs/deviceio.c \
- src/imfs/fifoimfs_init.c src/imfs/imfs_chown.c src/imfs/imfs_config.c \
+ src/imfs/imfs_chown.c src/imfs/imfs_config.c \
src/imfs/imfs_creat.c src/imfs/imfs_directory.c \
src/imfs/imfs_eval.c src/imfs/imfs_fchmod.c \
src/imfs/imfs_fifo.c \
@@ -56,7 +56,7 @@ libimfs_a_SOURCES += src/imfs/deviceio.c \
src/imfs/imfs_rename.c src/imfs/imfs_rmnod.c \
src/imfs/imfs_stat.c src/imfs/imfs_stat_file.c src/imfs/imfs_symlink.c \
src/imfs/imfs_unmount.c src/imfs/imfs_utime.c src/imfs/ioman.c \
- src/imfs/imfs_memfile.c src/imfs/miniimfs_init.c src/imfs/imfs.h
+ src/imfs/imfs_memfile.c src/imfs/imfs.h
# POSIX FIFO/pipe
libimfs_a_SOURCES += src/pipe/fifo.c src/pipe/pipe.c src/pipe/pipe.h
diff --git a/cpukit/libfs/src/imfs/fifoimfs_init.c b/cpukit/libfs/src/imfs/fifoimfs_init.c
deleted file mode 100644
index 4063557..0000000
--- a/cpukit/libfs/src/imfs/fifoimfs_init.c
+++ /dev/null
@@ -1,78 +0,0 @@
- * @file
- * @ingroup LibFSIMFS
- * @brief IMFS without fifo support initialization.
- * Copyright (c) 2010
- * embedded brains GmbH
- * Obere Lagerstr. 30
- * D-82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
- #include "config.h"
-#endif
-#include "imfs.h"
-#include <stdlib.h>
-#include <rtems/seterr.h>
-const rtems_filesystem_operations_table fifoIMFS_ops = {
- .lock_h = rtems_filesystem_default_lock,
- .unlock_h = rtems_filesystem_default_unlock,
- .eval_path_h = IMFS_eval_path,
- .link_h = IMFS_link,
- .are_nodes_equal_h = rtems_filesystem_default_are_nodes_equal,
- .mknod_h = IMFS_mknod,
- .rmnod_h = IMFS_rmnod,
- .fchmod_h = IMFS_fchmod,
- .chown_h = IMFS_chown,
- .clonenod_h = IMFS_node_clone,
- .freenod_h = IMFS_node_free,
- .mount_h = IMFS_mount,
- .unmount_h = IMFS_unmount,
- .fsunmount_me_h = IMFS_fsunmount,
- .utime_h = IMFS_utime,
- .symlink_h = IMFS_symlink,
- .readlink_h = IMFS_readlink,
- .rename_h = IMFS_rename,
- .statvfs_h = rtems_filesystem_default_statvfs
-static const IMFS_mknod_controls IMFS_fifo_mknod_controls = {
- .directory = &IMFS_mknod_control_directory,
- .device = &IMFS_mknod_control_device,
- .file = &IMFS_mknod_control_memfile,
- .fifo = &IMFS_mknod_control_fifo
-int fifoIMFS_initialize(
- rtems_filesystem_mount_table_entry_t *mt_entry,
- const void *data
- IMFS_fs_info_t *fs_info = calloc( 1, sizeof( *fs_info ) );
- IMFS_mount_data mount_data = {
- .fs_info = fs_info,
- .ops = &fifoIMFS_ops,
- .mknod_controls = &IMFS_fifo_mknod_controls
- if ( fs_info == NULL ) {
- rtems_set_errno_and_return_minus_one( ENOMEM );
- return IMFS_initialize_support( mt_entry, &mount_data );
diff --git a/cpukit/libfs/src/imfs/imfs.h b/cpukit/libfs/src/imfs/imfs.h
index 00fc179..c03257a 100644
--- a/cpukit/libfs/src/imfs/imfs.h
+++ b/cpukit/libfs/src/imfs/imfs.h
@@ -391,10 +391,6 @@ extern const IMFS_node_control IMFS_node_control_linfile;
extern const IMFS_mknod_control IMFS_mknod_control_fifo;
extern const IMFS_mknod_control IMFS_mknod_control_enosys;
-extern const rtems_filesystem_operations_table miniIMFS_ops;
-extern const rtems_filesystem_operations_table IMFS_ops;
-extern const rtems_filesystem_operations_table fifoIMFS_ops;
extern const rtems_filesystem_limits_and_options_t IMFS_LIMITS_AND_OPTIONS;
@@ -406,16 +402,6 @@ extern int IMFS_initialize(
const void *data
-extern int fifoIMFS_initialize(
- const void *data
-extern int miniIMFS_initialize(
- const void *data
extern int IMFS_initialize_support(
const void *data
@@ -586,9 +572,12 @@ extern IMFS_jnode_t *IMFS_create_node(
void *arg
-extern bool IMFS_is_imfs_instance(
+static inline bool IMFS_is_imfs_instance(
const rtems_filesystem_location_info_t *loc
+ return loc->mt_entry->ops->clonenod_h == IMFS_node_clone;
diff --git a/cpukit/libfs/src/imfs/imfs_init.c b/cpukit/libfs/src/imfs/imfs_init.c
index e82490f..bbab2cb 100644
--- a/cpukit/libfs/src/imfs/imfs_init.c
+++ b/cpukit/libfs/src/imfs/imfs_init.c
@@ -25,7 +25,7 @@
-const rtems_filesystem_operations_table IMFS_ops = {
+static const rtems_filesystem_operations_table IMFS_ops = {
diff --git a/cpukit/libfs/src/imfs/imfs_load_tar.c b/cpukit/libfs/src/imfs/imfs_load_tar.c
index d303cd2..7228978 100644
--- a/cpukit/libfs/src/imfs/imfs_load_tar.c
+++ b/cpukit/libfs/src/imfs/imfs_load_tar.c
@@ -58,10 +58,7 @@ int rtems_tarfs_load(
RTEMS_FS_MAKE | RTEMS_FS_EXCLUSIVE
- if (
- rootloc.mt_entry->ops != &IMFS_ops
- && rootloc.mt_entry->ops != &fifoIMFS_ops
+ if ( !IMFS_is_imfs_instance( &rootloc ) ) {
rv = -1;
diff --git a/cpukit/libfs/src/imfs/imfs_make_generic_node.c b/cpukit/libfs/src/imfs/imfs_make_generic_node.c
index f302dda..aef21c9 100644
--- a/cpukit/libfs/src/imfs/imfs_make_generic_node.c
+++ b/cpukit/libfs/src/imfs/imfs_make_generic_node.c
@@ -39,16 +39,6 @@ IMFS_jnode_t *IMFS_node_initialize_generic(
return node;
-bool IMFS_is_imfs_instance(
- const rtems_filesystem_location_info_t *loc
- const char *type = loc->mt_entry->type;
- return strcmp(type, RTEMS_FILESYSTEM_TYPE_IMFS) == 0
- || strcmp(type, RTEMS_FILESYSTEM_TYPE_MINIIMFS) == 0;
int IMFS_make_generic_node(
const char *path,
mode_t mode,
diff --git a/cpukit/libfs/src/imfs/miniimfs_init.c b/cpukit/libfs/src/imfs/miniimfs_init.c
index 7451c5e..0000000
--- a/cpukit/libfs/src/imfs/miniimfs_init.c
+++ /dev/null
@@ -1,74 +0,0 @@
- * @file
- * @brief Mini-IMFS initialization.
- * COPYRIGHT (c) 1989-1999.
- * On-Line Applications Research Corporation (OAR).
-#if HAVE_CONFIG_H
-#endif
-#include "imfs.h"
-const rtems_filesystem_operations_table miniIMFS_ops = {
- .link_h = rtems_filesystem_default_link,
- .fchmod_h = rtems_filesystem_default_fchmod,
- .chown_h = rtems_filesystem_default_chown,
- .unmount_h = rtems_filesystem_default_unmount,
- .fsunmount_me_h = rtems_filesystem_default_fsunmount,
- .utime_h = rtems_filesystem_default_utime,
- .symlink_h = rtems_filesystem_default_symlink,
- .readlink_h = rtems_filesystem_default_readlink,
- .rename_h = rtems_filesystem_default_rename,
-static const IMFS_mknod_controls IMFS_mini_mknod_controls = {
- .fifo = &IMFS_mknod_control_enosys
-int miniIMFS_initialize(
- const void *data
- .ops = &miniIMFS_ops,
- .mknod_controls = &IMFS_mini_mknod_controls
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 211c6bc..6fb0951 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -125,14 +125,6 @@ const rtems_libio_helper rtems_fs_init_helper =
#endif
#endif
- * If the application disables the filesystem, they will not need
- * a mount table, so do not produce one.
-#ifdef CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
- #define CONFIGURE_HAS_OWN_MOUNT_TABLE
-#endif
* This macro defines the number of POSIX file descriptors allocated
* and managed by libio. These are the "integer" file descriptors that
@@ -257,7 +249,6 @@ const rtems_libio_helper rtems_fs_init_helper =
* Add file filesystems to the default filesystem table.
* List of available file systems. You can define as many as you like:
- * CONFIGURE_FILESYSTEM_MINIIMFS - MiniIMFS, use DEVFS now
* CONFIGURE_FILESYSTEM_IMFS - In Memory File System (IMFS)
* CONFIGURE_FILESYSTEM_DEVFS - Device File System (DSVFS)
* CONFIGURE_FILESYSTEM_TFTPFS - TFTP File System, networking enabled
@@ -271,10 +262,10 @@ const rtems_libio_helper rtems_fs_init_helper =
* - If nothing is defined the base file system is the IMFS.
- * - If CONFIGURE_APPLICATION_DISABLE_FILESYSTEM is defined all filesystem
- * are disabled by force and an empty DEVFS is created.
+ * - If CONFIGURE_APPLICATION_DISABLE_FILESYSTEM is defined all filesystems
+ * are disabled by force.
- * - If CONFIGURE_USE_DEV_AS_BASE_FILESYSTEM is defined all filesystem
+ * - If CONFIGURE_USE_DEV_AS_BASE_FILESYSTEM is defined all filesystems
* are disabled by force and DEVFS is defined.
@@ -285,7 +276,6 @@ const rtems_libio_helper rtems_fs_init_helper =
* been disabled.
#ifdef CONFIGURE_FILESYSTEM_ALL
- #define CONFIGURE_FILESYSTEM_MINIIMFS
#define CONFIGURE_FILESYSTEM_IMFS
#define CONFIGURE_FILESYSTEM_DEVFS
#define CONFIGURE_FILESYSTEM_TFTPFS
@@ -301,23 +291,19 @@ const rtems_libio_helper rtems_fs_init_helper =
* configured other filesystem parameters.
#if defined(CONFIGURE_APPLICATION_DISABLE_FILESYSTEM)
- #if defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM) || \
- defined(CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM)
- #error "Filesystem disabled but a base filesystem configured."
+ #if defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM)
+ #error "Filesystem disabled and a base filesystem configured."
#endif
- #if defined(CONFIGURE_FILESYSTEM_MINIIMFS) || \
- defined(CONFIGURE_FILESYSTEM_IMFS) || \
- defined(CONFIGURE_FILESYSTEM_DEVFS) || \
- defined(CONFIGURE_FILESYSTEM_TFTPFS) || \
- defined(CONFIGURE_FILESYSTEM_FTPFS) || \
- defined(CONFIGURE_FILESYSTEM_NFS) || \
- defined(CONFIGURE_FILESYSTEM_DOSFS) || \
- defined(CONFIGURE_FILESYSTEM_RFS) || \
- defined(CONFIGURE_FILESYSTEM_JFFS2)
- #error "Configured filesystems but root filesystem was not IMFS!"
- #error "Filesystems could be disabled, DEVFS is root, or"
- #error " miniIMFS is root!"
+ #if defined(CONFIGURE_FILESYSTEM_IMFS) || \
+ defined(CONFIGURE_FILESYSTEM_DEVFS) || \
+ defined(CONFIGURE_FILESYSTEM_TFTPFS) || \
+ defined(CONFIGURE_FILESYSTEM_FTPFS) || \
+ defined(CONFIGURE_FILESYSTEM_NFS) || \
+ defined(CONFIGURE_FILESYSTEM_DOSFS) || \
+ defined(CONFIGURE_FILESYSTEM_RFS) || \
+ defined(CONFIGURE_FILESYSTEM_JFFS2)
+ #error "Filesystem disabled and a filesystem configured."
#endif
#endif
@@ -328,10 +314,6 @@ const rtems_libio_helper rtems_fs_init_helper =
#if !defined(CONFIGURE_APPLICATION_DISABLE_FILESYSTEM)
- #elif defined(CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM)
- #elif !defined(CONFIGURE_FILESYSTEM_IMFS)
- #define CONFIGURE_FILESYSTEM_IMFS
#endif
#endif
@@ -355,28 +337,12 @@ const rtems_libio_helper rtems_fs_init_helper =
#endif
- * This defines the miniIMFS file system table entry.
-#if !defined(CONFIGURE_FILESYSTEM_ENTRY_miniIMFS) && \
- defined(CONFIGURE_FILESYSTEM_MINIIMFS)
- #define CONFIGURE_FILESYSTEM_ENTRY_miniIMFS \
- { RTEMS_FILESYSTEM_TYPE_MINIIMFS, miniIMFS_initialize }
-#endif
-#endif
-#ifndef RTEMS_SCHEDSIM
* This defines the IMFS file system table entry.
#if !defined(CONFIGURE_FILESYSTEM_ENTRY_IMFS) && \
- #if CONFIGURE_MAXIMUM_FIFOS > 0 || CONFIGURE_MAXIMUM_PIPES > 0
- #define CONFIGURE_FILESYSTEM_ENTRY_IMFS \
- { RTEMS_FILESYSTEM_TYPE_IMFS, fifoIMFS_initialize }
- #else
- { RTEMS_FILESYSTEM_TYPE_IMFS, IMFS_initialize }
- #endif
+ defined(CONFIGURE_FILESYSTEM_IMFS)
+ #define CONFIGURE_FILESYSTEM_ENTRY_IMFS \
+ { RTEMS_FILESYSTEM_TYPE_IMFS, IMFS_initialize }
#endif
#endif
@@ -506,28 +472,27 @@ const rtems_libio_helper rtems_fs_init_helper =
#include <rtems/devfs.h>
#endif
- #if defined(CONFIGURE_FILESYSTEM_IMFS) || \
- int imfs_rq_memfile_bytes_per_block = CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK;
- #endif
-#endif
* Table termination record.
#define CONFIGURE_FILESYSTEM_NULL { NULL, NULL }
+ #if !defined(CONFIGURE_APPLICATION_DISABLE_FILESYSTEM) && \
+ !defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM)
+ int imfs_rq_memfile_bytes_per_block =
+ CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK;
+ #endif
* The default file system table. Must be terminated with the NULL entry if
* you provide your own.
- #ifndef CONFIGURE_HAS_OWN_FILESYSTEM_TABLE
+ #if !defined(CONFIGURE_HAS_OWN_FILESYSTEM_TABLE) && \
+ !defined(CONFIGURE_APPLICATION_DISABLE_FILESYSTEM)
const rtems_filesystem_table_t rtems_filesystem_table[] = {
- #if defined(CONFIGURE_FILESYSTEM_MINIIMFS) && \
- defined(CONFIGURE_FILESYSTEM_ENTRY_miniIMFS)
- CONFIGURE_FILESYSTEM_ENTRY_miniIMFS,
+ #if !defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM)
+ { "/", IMFS_initialize_support },
#endif
#if defined(CONFIGURE_FILESYSTEM_IMFS) && \
@@ -565,30 +530,115 @@ const rtems_libio_helper rtems_fs_init_helper =
#endif
- #ifndef CONFIGURE_HAS_OWN_MOUNT_TABLE
+ #if !defined(CONFIGURE_HAS_OWN_MOUNT_TABLE) && \
static devFS_node devFS_root_filesystem_nodes [CONFIGURE_MAXIMUM_DEVICES];
static const devFS_data devFS_root_filesystem_data = {
devFS_root_filesystem_nodes,
+ #else
+ static IMFS_fs_info_t _Configure_IMFS_fs_info;
+ static const rtems_filesystem_operations_table _Configure_IMFS_ops = {
+ rtems_filesystem_default_lock,
+ rtems_filesystem_default_unlock,
+ IMFS_eval_path,
+ #ifdef CONFIGURE_IMFS_DISABLE_LINK
+ rtems_filesystem_default_link,
+ #else
+ IMFS_link,
+ #endif
+ rtems_filesystem_default_are_nodes_equal,
+ #ifdef CONFIGURE_IMFS_DISABLE_MKNOD
+ rtems_filesystem_default_mknod,
+ #else
+ IMFS_mknod,
+ #endif
+ #ifdef CONFIGURE_IMFS_DISABLE_RMNOD
+ rtems_filesystem_default_rmnod,
+ #else
+ IMFS_rmnod,
+ #endif
+ #ifdef CONFIGURE_IMFS_DISABLE_FCHMOD
+ rtems_filesystem_default_fchmod,
+ #else
+ IMFS_fchmod,
+ #endif
+ #ifdef CONFIGURE_IMFS_DISABLE_CHOWN
+ rtems_filesystem_default_chown,
+ #else
+ IMFS_chown,
+ #endif
+ IMFS_node_clone,
+ IMFS_node_free,
+ #ifdef CONFIGURE_IMFS_DISABLE_MOUNT
+ rtems_filesystem_default_mount,
+ #else
+ IMFS_mount,
+ #endif
+ #ifdef CONFIGURE_IMFS_DISABLE_UNMOUNT
+ rtems_filesystem_default_unmount,
+ #else
+ IMFS_unmount,
+ #endif
+ rtems_filesystem_default_fsunmount,
+ #ifdef CONFIGURE_IMFS_DISABLE_UTIME
+ rtems_filesystem_default_utime,
+ #else
+ IMFS_utime,
+ #endif
+ #ifdef CONFIGURE_IMFS_DISABLE_SYMLINK
+ rtems_filesystem_default_symlink,
+ #else
+ IMFS_symlink,
+ #endif
+ #ifdef CONFIGURE_IMFS_DISABLE_READLINK
+ rtems_filesystem_default_readlink,
+ #else
+ IMFS_readlink,
+ #endif
+ #ifdef CONFIGURE_IMFS_DISABLE_RENAME
+ rtems_filesystem_default_rename,
+ #else
+ IMFS_rename,
+ #endif
+ rtems_filesystem_default_statvfs
+ static const IMFS_mknod_controls _Configure_IMFS_mknod_controls = {
+ &IMFS_mknod_control_directory,
+ &IMFS_mknod_control_device,
+ &IMFS_mknod_control_memfile,
+ #if CONFIGURE_MAXIMUM_FIFOS > 0 || CONFIGURE_MAXIMUM_PIPES > 0
+ &IMFS_mknod_control_fifo
+ #else
+ &IMFS_mknod_control_enosys
+ #endif
+ static const IMFS_mount_data _Configure_IMFS_mount_data = {
+ &_Configure_IMFS_fs_info,
+ &_Configure_IMFS_ops,
+ &_Configure_IMFS_mknod_controls
#endif
const rtems_filesystem_mount_configuration
rtems_filesystem_root_configuration = {
NULL,
NULL,
RTEMS_FILESYSTEM_TYPE_DEVFS,
- RTEMS_FILESYSTEM_TYPE_MINIIMFS,
#else
- RTEMS_FILESYSTEM_TYPE_IMFS,
#endif
RTEMS_FILESYSTEM_READ_WRITE,
&devFS_root_filesystem_data
#else
- NULL
+ &_Configure_IMFS_mount_data
#endif
#endif
diff --git a/doc/user/conf.t b/doc/user/conf.t
index 7afe09c..fd986e2 100644
--- a/doc/user/conf.t
+++ b/doc/user/conf.t
@@ -2577,40 +2577,6 @@ None.
@c XXX - Please provide an example
@c
- at c === CONFIGURE_USE_MINIIMFS_AS_BASE_SYSTEM ===
- at c
- at subsection Configure miniIMFS as Root File System
- at findex CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
- at table @b
- at item CONSTANT:
- at code{CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM}
- at item DATA TYPE:
-Boolean feature macro.
- at item RANGE:
-Defined or undefined.
- at item DEFAULT VALUE:
-This is not defined by default. If no other root file system
-configuration parameters are specified, the IMFS will be used as the
-root file system.
- at end table
- at subheading DESCRIPTION:
-This configuration parameter is defined if the application wishes to use
-the reduced functionality miniIMFS as the root filesystem. This reduced
-version of the full IMFS does not include the capability to mount other
-file system types, but it does support directories, device nodes, and
-symbolic links.
- at subheading NOTES:
-The miniIMFS nodes and is smaller in executable code size than the full IMFS.
- at c
@c === CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM ===
@c
@subsection Configure devFS as Root File System
@@ -2711,6 +2677,292 @@ infrastructure necessary to support @code{printf()}.
None.
@c
+ at c === CONFIGURE_IMFS_DISABLE_CHOWN ===
+ at c
+ at subsection Disable change owner support of root IMFS
+ at findex CONFIGURE_IMFS_DISABLE_CHOWN
+ at table @b
+ at item CONSTANT:
+ at code{CONFIGURE_IMFS_DISABLE_CHOWN}
+ at item DATA TYPE:
+Boolean feature macro.
+ at item RANGE:
+Defined or undefined.
+ at item DEFAULT VALUE:
+This is not defined by default.
+ at end table
+ at subheading DESCRIPTION:
+In case this configuration option is defined, then the support to change the
+owner is disabled in the root IMFS.
+ at c
+ at c === CONFIGURE_IMFS_DISABLE_FCHMOD ===
+ at c
+ at subsection Disable change mode support of root IMFS
+ at findex CONFIGURE_IMFS_DISABLE_FCHMOD
+ at table @b
+ at item CONSTANT:
+ at code{CONFIGURE_IMFS_DISABLE_FCHMOD}
+ at item RANGE:
+ at end table
+mode is disabled in the root IMFS.
+ at c
+ at c === CONFIGURE_IMFS_DISABLE_UTIME ===
+ at c
+ at subsection Disable change times support of root IMFS
+ at findex CONFIGURE_IMFS_DISABLE_UTIME
+ at table @b
+ at item CONSTANT:
+ at code{CONFIGURE_IMFS_DISABLE_UTIME}
+ at item RANGE:
+ at end table
+In case this configuration option is defined, then the support to change times
+is disabled in the root IMFS.
+ at c
+ at c === CONFIGURE_IMFS_DISABLE_LINK ===
+ at c
+ at subsection Disable create hard link support of root IMFS
+ at findex CONFIGURE_IMFS_DISABLE_LINK
+ at table @b
+ at item CONSTANT:
+ at code{CONFIGURE_IMFS_DISABLE_LINK}
+ at item RANGE:
+ at end table
+In case this configuration option is defined, then the support to create hard
+links is disabled in the root IMFS.
+ at c
+ at c === CONFIGURE_IMFS_DISABLE_SYMLINK ===
+ at c
+ at subsection Disable create symbolic link support of root IMFS
+ at findex CONFIGURE_IMFS_DISABLE_SYMLINK
+ at table @b
+ at item CONSTANT:
+ at code{CONFIGURE_IMFS_DISABLE_SYMLINK}
+ at item RANGE:
+ at end table
+symbolic links is disabled in the root IMFS.
+ at c
+ at c === CONFIGURE_IMFS_DISABLE_READLINK ===
+ at c
+ at subsection Disable read symbolic link support of root IMFS
+ at findex CONFIGURE_IMFS_DISABLE_READLINK
+ at table @b
+ at item CONSTANT:
+ at code{CONFIGURE_IMFS_DISABLE_READLINK}
+ at item RANGE:
+ at end table
+In case this configuration option is defined, then the support to read symbolic
+ at c
+ at c === CONFIGURE_IMFS_DISABLE_RENAME ===
+ at c
+ at subsection Disable rename support of root IMFS
+ at findex CONFIGURE_IMFS_DISABLE_RENAME
+ at table @b
+ at item CONSTANT:
+ at code{CONFIGURE_IMFS_DISABLE_RENAME}
+ at item RANGE:
+ at end table
+In case this configuration option is defined, then the support to rename nodes
+ at c
+ at c === CONFIGURE_IMFS_DISABLE_MOUNT ===
+ at c
+ at subsection Disable mount support of root IMFS
+ at findex CONFIGURE_IMFS_DISABLE_MOUNT
+ at table @b
+ at item CONSTANT:
+ at code{CONFIGURE_IMFS_DISABLE_MOUNT}
+ at item RANGE:
+ at end table
+In case this configuration option is defined, then the support to mount other
+file systems is disabled in the root IMFS.
+ at c
+ at c === CONFIGURE_IMFS_DISABLE_UNMOUNT ===
+ at c
+ at subsection Disable unmount support of root IMFS
+ at findex CONFIGURE_IMFS_DISABLE_UNMOUNT
+ at table @b
+ at item CONSTANT:
+ at code{CONFIGURE_IMFS_DISABLE_UNMOUNT}
+ at item RANGE:
+ at end table
+In case this configuration option is defined, then the support to unmount file
+systems is disabled in the root IMFS.
+ at c
+ at c === CONFIGURE_IMFS_DISABLE_MKNOD ===
+ at c
+ at subsection Disable make nodes support of root IMFS
+ at findex CONFIGURE_IMFS_DISABLE_MKNOD
+ at table @b
+ at item CONSTANT:
+ at code{CONFIGURE_IMFS_DISABLE_MKNOD}
+ at item RANGE:
+ at end table
+In case this configuration option is defined, then the support to make
+directories, devices, regular files and FIFOs is disabled in the root IMFS.
+ at c
+ at c === CONFIGURE_IMFS_DISABLE_RMNOD ===
+ at c
+ at subsection Disable remove nodes support of root IMFS
+ at findex CONFIGURE_IMFS_DISABLE_RMNOD
+ at table @b
+ at item CONSTANT:
+ at code{CONFIGURE_IMFS_DISABLE_RMNOD}
+ at item RANGE:
+ at end table
+In case this configuration option is defined, then the support to remove nodes
+ at c
@c === Block Device Cache Configuration ===
@c
@section Block Device Cache Configuration
diff --git a/testsuites/fstests/fsimfsgeneric01/init.c b/testsuites/fstests/fsimfsgeneric01/init.c
index 44d75c5..6cc6c15 100644
--- a/testsuites/fstests/fsimfsgeneric01/init.c
+++ b/testsuites/fstests/fsimfsgeneric01/init.c
@@ -396,6 +396,13 @@ static const IMFS_node_control node_initialization_error_control = {
.node_destroy = node_destroy_inhibited
+static const rtems_filesystem_operations_table *imfs_ops;
+static int other_clone(rtems_filesystem_location_info_t *loc)
+ return (*imfs_ops->clonenod_h)(loc);
static void test_imfs_make_generic_node_errors(void)
int rv = 0;
@@ -403,7 +410,7 @@ static void test_imfs_make_generic_node_errors(void)
rtems_chain_control *chain = &rtems_filesystem_mount_table;
rtems_filesystem_mount_table_entry_t *mt_entry =
(rtems_filesystem_mount_table_entry_t *) rtems_chain_first(chain);
- const char *type = mt_entry->type;
+ rtems_filesystem_operations_table other_ops;
void *opaque = NULL;
rtems_resource_snapshot before;
@@ -421,14 +428,17 @@ static void test_imfs_make_generic_node_errors(void)
rtems_test_assert(rtems_resource_snapshot_check(&before));
errno = 0;
- mt_entry->type = "XXX";
+ imfs_ops = mt_entry->ops;
+ other_ops = *imfs_ops;
+ other_ops.clonenod_h = other_clone;
+ mt_entry->ops = &other_ops;
rv = IMFS_make_generic_node(
path,
S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO,
&node_control,
NULL
- mt_entry->type = type;
+ mt_entry->ops = imfs_ops;
rtems_test_assert(rv == -1);
rtems_test_assert(errno == ENOTSUP);
diff --git a/testsuites/fstests/mimfs_support/fs_support.c b/testsuites/fstests/mimfs_support/fs_support.c
index 849d856..29ccfd3 100644
--- a/testsuites/fstests/mimfs_support/fs_support.c
+++ b/testsuites/fstests/mimfs_support/fs_support.c
@@ -64,5 +64,7 @@ test_shutdown_filesystem (void)
#define CONFIGURE_INIT_TASK_STACK_SIZE (16 * 1024)
#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS 1
+#define CONFIGURE_FILESYSTEM_IMFS
#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/tar03/init.c b/testsuites/libtests/tar03/init.c
index 3e2b5d3..72e95ec 100644
--- a/testsuites/libtests/tar03/init.c
+++ b/testsuites/libtests/tar03/init.c
@@ -34,13 +34,6 @@ void test_tarfs_error(void)
printf ("error: untar failed returned %d\n", sc);
rtems_test_exit(1);
- puts("Loading tarfs image with miniIMFS as root filesystem - ERROR");
- sc = rtems_tarfs_load("/",(void *)rtems_task_create, 72);
- if (sc != -1) {
- printf ("error: untar failed returned %d\n", sc);
- rtems_test_exit(1);
rtems_task Init(
@@ -65,8 +58,6 @@ rtems_task Init(
/* end of file */
diff --git a/testsuites/psxtests/psxfile01/main.c b/testsuites/psxtests/psxfile01/main.c
index a6ad029..554f8e9 100644
--- a/testsuites/psxtests/psxfile01/main.c
+++ b/testsuites/psxtests/psxfile01/main.c
@@ -35,6 +35,8 @@ rtems_task Init(
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 6
#define CONFIGURE_INIT_TASK_STACK_SIZE (2 * RTEMS_MINIMUM_STACK_SIZE)
diff --git a/testsuites/psxtests/psximfs02/init.c b/testsuites/psxtests/psximfs02/init.c
index 00a171f..d372a6f 100644
--- a/testsuites/psxtests/psximfs02/init.c
+++ b/testsuites/psxtests/psximfs02/init.c
@@ -208,6 +208,8 @@ rtems_task Init(
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK 15
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 4
diff --git a/testsuites/psxtests/psxmount/main.c b/testsuites/psxtests/psxmount/main.c
index 2e32a29..a723b87 100644
--- a/testsuites/psxtests/psxmount/main.c
+++ b/testsuites/psxtests/psxmount/main.c
@@ -33,6 +33,8 @@ rtems_task Init(
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
diff --git a/testsuites/psxtests/psxreaddir/main.c b/testsuites/psxtests/psxreaddir/main.c
index 90880b0..176d264 100644
--- a/testsuites/psxtests/psxreaddir/main.c
+++ b/testsuites/psxtests/psxreaddir/main.c
@@ -31,6 +31,8 @@ rtems_task Init(
#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
diff --git a/testsuites/psxtests/psxstat/main.c b/testsuites/psxtests/psxstat/main.c
index 19ed8d4..07fde7f 100644
--- a/testsuites/psxtests/psxstat/main.c
+++ b/testsuites/psxtests/psxstat/main.c
diff --git a/testsuites/samples/iostream/system.h b/testsuites/samples/iostream/system.h
index 7256f8f..62f7d53 100644
--- a/testsuites/samples/iostream/system.h
+++ b/testsuites/samples/iostream/system.h
@@ -31,9 +31,6 @@
#define CONFIGURE_INIT_TASK_STACK_SIZE (RTEMS_MINIMUM_STACK_SIZE * 2)
#define CONFIGURE_EXTRA_TASK_STACKS RTEMS_MINIMUM_STACK_SIZE
-/* Only remove when this macro is removed from confdefs.h. It tests it. */
diff --git a/testsuites/sptests/sp47/init.c b/testsuites/sptests/sp47/init.c
index 1a0d569..5d28303 100644
--- a/testsuites/sptests/sp47/init.c
+++ b/testsuites/sptests/sp47/init.c
@@ -74,7 +74,5 @@ rtems_task Init(rtems_task_argument ignored)
diff --git a/testsuites/sptests/sp48/init.c b/testsuites/sptests/sp48/init.c
index 701aa17..53d8245 100644
--- a/testsuites/sptests/sp48/init.c
+++ b/testsuites/sptests/sp48/init.c
@@ -102,7 +102,5 @@ rtems_task Init(rtems_task_argument ignored)
2.1.4
