RTEMS for ARM Cortex-M1 ?
Alan Cudmore alan.cudmore at gmail.com
Sat Feb 14 16:38:13 UTC 2015
Thanks for the info.. so it sounds like a new BSP and some changes to the
ARMV7-M code in score.
The project will also look at some other fpga based cpus. I'm glad to see
the openrisc and microblaze work going on.
Alan
On Feb 14, 2015 8:29 AM, "Sebastian Huber" <
> On 14/02/15 14:27, Sebastian Huber wrote:
>> On 14/02/15 12:48, Daniel Gutson wrote:
>>> We're developing support for the
>>> cortex M 4 so we can let you know once we commit the patches so you can
>>> have a starting point in case an emulator is also needed.
>> The Cortex-M4 is already supported including the FPU (e.g. LPC4088).
> Hm, I should read more carefully.  You added a Cortex-M4 support for Qemu
> including the FPU?
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150214/f0deb455/attachment-0002.html>
