RTEMS for ARM Cortex-M1 ?
Sat Feb 14 16:46:21 UTC 2015
On February 14, 2015 10:38:13 AM CST, Alan Cudmore <alan.cudmore at gmail.com> wrote:
>Thanks for the info.. so it sounds like a new BSP and some changes to
>the ARMV7-M code in score.
I wouldn't think there is a lot of work. Just tweaks to avoid instructions not available.
>The project will also look at some other fpga based cpus. I'm glad to
>see the openrisc and microblaze work going on.
OpenRISC should be in good shape but your board may have more peripherals.
Hesham has been making progress on Microblaze. He can update us.
>Alan
>On Feb 14, 2015 8:29 AM, "Sebastian Huber"
><sebastian.huber at embedded-brains.de> wrote:
>On 14/02/15 14:27, Sebastian Huber wrote:
>On 14/02/15 12:48, Daniel Gutson wrote:
>We're developing support for the
>cortex M 4 so we can let you know once we commit the patches so you can
>have a starting point in case an emulator is also needed.
>The Cortex-M4 is already supported including the FPU (e.g. LPC4088).
>Hm, I should read more carefully.  You added a Cortex-M4 support for
>Qemu including the FPU?
>Sebastian Huber, embedded brains GmbH
>Address : Dornierstr. 4, D-82178 Puchheim, Germany
>Phone   : +49 89 189 47 41-16
>Fax     : +49 89 189 47 41-09
>E-Mail  : sebastian.huber at embedded-brains.de
>PGP     : Public key available on request.
>Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>_______________________________________________
>devel mailing list
>devel at rtems.org
>http://lists.rtems.org/mailman/listinfo/devel
--joel
