[Openrisc] Tutorial for running RTEMS on OpenRISC
Gedare Bloom
gedare at rtems.org
Mon Feb 23 14:31:27 UTC 2015
That is interesting! I recommend opening a ticket on Trac so we don't
lose track of the idea.
Thanks for the tutorial.
Gedare
On Mon, Feb 23, 2015 at 3:40 AM, Hesham Moustafa
<heshamelmatary at gmail.com> wrote:
> Hi,
> Found out there is a Javascript online simulator (jor1k) that can run
> or1ksim binaries (hello, ticker and capture run there perfectly). I am
> not sure if this simulator can be embedded to RTEMS Project Webpage
> [1]
> [1] https://devel.rtems.org/wiki/Projects/GSoC/OpenRISC
> Regards,
> Hesham
> ---------- Forwarded message ----------
> From: Sebastian Macke <sebastian at macke.de>
> Date: Sun, Feb 22, 2015 at 8:28 PM
> Subject: Re: [Openrisc] Tutorial for running RTEMS on OpenRISC
> To: Hesham Moustafa <heshamelmatary at gmail.com>
> Cc: "openrisc at lists.opencores.org" <openrisc at lists.opencores.org>
> Hi,
> take a look at:
> https://github.com/s-macke/jor1k
> I have added the RTEMS website and a simple demo.
> You are free to link to the github site
> or directly to the RTEMS demo site
> http://s-macke.github.io/jor1k/demos/rtems.html
> You can send me a new website design if you want.
> Sebastian
> Am 2/22/2015 um 8:48 PM schrieb Hesham Moustafa:
>> On Sun, Feb 22, 2015 at 7:43 PM, Sebastian Macke <sebastian at macke.de> wrote:
>>> My emulator doesn't support timer modes other than continuous. I removed the
>>> check. Seems to work now.
>> Totally working. That's great. Can you create some entry for jor1k
>> RTEMS there? I'd pass a long the link to RTEMS community and maybe
>> update the tutorial with jor1k info.
>>> Am 2/22/2015 um 7:30 PM schrieb Hesham Moustafa:
>>>> On Sun, Feb 22, 2015 at 6:23 PM, Sebastian Macke <sebastian at macke.de>
>>>> wrote:
>>>>> Hi Mesham,
>>>>> I have hacked something together, which works for me for the binary hello
>>>>> program
>>>>> http://jor1k.com/jor1k/demos/simple2.html
>>>>> Just click on the symbol to upload a binary image. (128 MB images allowed
>>>>> for now).
>>>> Thanks for providing the link.
>>>> hello is working but the other two are not, not sure why. Any way to
>>>> debug?
>>>>> The other two .exe files are not working for some reason.
>>>>> I don't like to use 128MB in the web browser. I get too often out of
>>>>> memory
>>>>> errors then. Also it won't work anymore on mobile devices.
>>>>> 16-31MB should be fine in the end for the examples I hope.
>>>>> Sebastian
>>>>> Am 2/22/2015 um 6:35 PM schrieb Hesham Moustafa:
>>>>>> Hi Sebastian,
>>>>>> On Sun, Feb 22, 2015 at 5:17 PM, Sebastian Macke <sebastian at macke.de>
>>>>>> wrote:
>>>>>>> Hi Mesham,
>>>>>>> it works somehow,
>>>>>>> I had to generate a binary image via "or1k-linux-musl-objcopy -O binary
>>>>>>> hello.exe vmlinux.bin"
>>>>>>> Then I had to increase the memory to 128MB
>>>>>>> Now I get an output, which you can find here:
>>>>>>> jor1k.com/jor1k/demos/main.html?cpu=safe
>>>>>>> "Fatal Error 5.0 halted"
>>>>>>> Do you know, what this means?
>>>>>> Yes that's perfectly fine, it means that the program terminates
>>>>>> normally (on simulators). Great to know it works!
>>>>>>> Can you provide me an image which uses only <= 31MB (not 32MB) of
>>>>>>> memory?
>>>>>>> 16MB would be fine I think.
>>>>>> I hacked the source and got it for you. Attached are three samples you
>>>>>> can try < 16 MB. I'd appreciate you provide me with some demo links.
>>>>>> Can users upload, run/debug their own or1k samples their there?
>>>>>> https://drive.google.com/folderview?id=0B_dTGAP_ygMvfnFzOHZkZ0w3Q1hrNV9SX3ZKS0Vza3U5d2ljbDROSlNQLUprUXFsNUtUelU&usp=sharing
>>>>>>> Sebastian
>>>>>>> Am 2/22/2015 um 5:40 PM schrieb Hesham Moustafa:
>>>>>>>> Hi Sebastian,
>>>>>>>> Thanks for you reply.
>>>>>>>> If I am understanding correctly, you need a snapshot binary for RTEMS
>>>>>>>> app (i.e, hello.exe). [1] It's ELF. Let me know if that works for you.
>>>>>>>> [1]
>>>>>>>> https://drive.google.com/file/d/0B_dTGAP_ygMvcmZ3U3g1S2k4UTA/view?usp=sharing
>>>>>>>> Thanks,
>>>>>>>> Hesham
>>>>>>>> On Sun, Feb 22, 2015 at 4:32 PM, Sebastian Macke <sebastian at macke.de>
>>>>>>>> wrote:
>>>>>>>>> Hi Heshma,
>>>>>>>>> Great! Do you have a link of a working QEMU image? I can try to run
>>>>>>>>> it
>>>>>>>>> in
>>>>>>>>> jor1k.
>>>>>>>>> Sebastian
>>>>>>>>> Am 2/22/2015 um 4:51 PM schrieb Hesham Moustafa:
>>>>>>>>> Hi all,
>>>>>>>>> In case some of you don't know, I have ported RTEMS to OpenRISC last
>>>>>>>>> year
>>>>>>>>> during GSoC. All the code is now upstream and works fine. I wrote a
>>>>>>>>> tutorial
>>>>>>>>> describing how to get RTEMS running on OpenRISC simulators (or1ksim
>>>>>>>>> and
>>>>>>>>> QEMU) totally from scratch [1].
>>>>>>>>> [1] http://heshamelmatary.blogspot.co.uk/p/howto-rtems.html
>>>>>>>>> Best,
>>>>>>>>> Hesham
>>>>>>>>> _______________________________________________
>>>>>>>>> Openrisc mailing list
>>>>>>>>> Openrisc at lists.opencores.org
>>>>>>>>> http://lists.opencores.org/listinfo/openrisc
> devel mailing list
> devel at rtems.org
