[Openrisc] Tutorial for running RTEMS on OpenRISC
Hesham Moustafa heshamelmatary at gmail.com
Mon Feb 23 14:40:27 UTC 2015
On Mon, Feb 23, 2015 at 2:31 PM, Gedare Bloom <gedare at rtems.org> wrote:
> That is interesting! I recommend opening a ticket on Trac so we don't
> lose track of the idea.
That's it https://devel.rtems.org/ticket/2276#ticket
> Thanks for the tutorial.
> Gedare
> On Mon, Feb 23, 2015 at 3:40 AM, Hesham Moustafa
> <heshamelmatary at gmail.com> wrote:
>> Hi,
>> Found out there is a Javascript online simulator (jor1k) that can run
>> or1ksim binaries (hello, ticker and capture run there perfectly). I am
>> not sure if this simulator can be embedded to RTEMS Project Webpage
>> [1]
>> [1] https://devel.rtems.org/wiki/Projects/GSoC/OpenRISC
>> Regards,
>> Hesham
>> ---------- Forwarded message ----------
>> From: Sebastian Macke <sebastian at macke.de>
>> Date: Sun, Feb 22, 2015 at 8:28 PM
>> Subject: Re: [Openrisc] Tutorial for running RTEMS on OpenRISC
>> To: Hesham Moustafa <heshamelmatary at gmail.com>
>> Cc: "openrisc at lists.opencores.org" <openrisc at lists.opencores.org>
>> Hi,
>> take a look at:
>> https://github.com/s-macke/jor1k
>> I have added the RTEMS website and a simple demo.
>> You are free to link to the github site
>> or directly to the RTEMS demo site
>> http://s-macke.github.io/jor1k/demos/rtems.html
>> You can send me a new website design if you want.
>> Sebastian
>> Am 2/22/2015 um 8:48 PM schrieb Hesham Moustafa:
>>> On Sun, Feb 22, 2015 at 7:43 PM, Sebastian Macke <sebastian at macke.de> wrote:
>>>> My emulator doesn't support timer modes other than continuous. I removed the
>>>> check. Seems to work now.
>>> Totally working. That's great. Can you create some entry for jor1k
>>> RTEMS there? I'd pass a long the link to RTEMS community and maybe
>>> update the tutorial with jor1k info.
>>>> Am 2/22/2015 um 7:30 PM schrieb Hesham Moustafa:
>>>>> On Sun, Feb 22, 2015 at 6:23 PM, Sebastian Macke <sebastian at macke.de>
>>>>> wrote:
>>>>>> Hi Mesham,
>>>>>> I have hacked something together, which works for me for the binary hello
>>>>>> program
>>>>>> http://jor1k.com/jor1k/demos/simple2.html
>>>>>> Just click on the symbol to upload a binary image. (128 MB images allowed
>>>>>> for now).
>>>>> Thanks for providing the link.
>>>>> hello is working but the other two are not, not sure why. Any way to
>>>>> debug?
>>>>>> The other two .exe files are not working for some reason.
>>>>>> I don't like to use 128MB in the web browser. I get too often out of
>>>>>> memory
>>>>>> errors then. Also it won't work anymore on mobile devices.
>>>>>> 16-31MB should be fine in the end for the examples I hope.
>>>>>> Sebastian
>>>>>> Am 2/22/2015 um 6:35 PM schrieb Hesham Moustafa:
>>>>>>> Hi Sebastian,
>>>>>>> On Sun, Feb 22, 2015 at 5:17 PM, Sebastian Macke <sebastian at macke.de>
>>>>>>> wrote:
>>>>>>>> Hi Mesham,
>>>>>>>> it works somehow,
>>>>>>>> I had to generate a binary image via "or1k-linux-musl-objcopy -O binary
>>>>>>>> hello.exe vmlinux.bin"
>>>>>>>> Then I had to increase the memory to 128MB
>>>>>>>> Now I get an output, which you can find here:
>>>>>>>> jor1k.com/jor1k/demos/main.html?cpu=safe
>>>>>>>> "Fatal Error 5.0 halted"
>>>>>>>> Do you know, what this means?
>>>>>>> Yes that's perfectly fine, it means that the program terminates
>>>>>>> normally (on simulators). Great to know it works!
>>>>>>>> Can you provide me an image which uses only <= 31MB (not 32MB) of
>>>>>>>> memory?
>>>>>>>> 16MB would be fine I think.
>>>>>>> I hacked the source and got it for you. Attached are three samples you
>>>>>>> can try < 16 MB. I'd appreciate you provide me with some demo links.
>>>>>>> Can users upload, run/debug their own or1k samples their there?
>>>>>>> https://drive.google.com/folderview?id=0B_dTGAP_ygMvfnFzOHZkZ0w3Q1hrNV9SX3ZKS0Vza3U5d2ljbDROSlNQLUprUXFsNUtUelU&usp=sharing
>>>>>>>> Sebastian
>>>>>>>> Am 2/22/2015 um 5:40 PM schrieb Hesham Moustafa:
>>>>>>>>> Hi Sebastian,
>>>>>>>>> Thanks for you reply.
>>>>>>>>> If I am understanding correctly, you need a snapshot binary for RTEMS
>>>>>>>>> app (i.e, hello.exe). [1] It's ELF. Let me know if that works for you.
>>>>>>>>> [1]
>>>>>>>>> https://drive.google.com/file/d/0B_dTGAP_ygMvcmZ3U3g1S2k4UTA/view?usp=sharing
>>>>>>>>> Thanks,
>>>>>>>>> Hesham
>>>>>>>>> On Sun, Feb 22, 2015 at 4:32 PM, Sebastian Macke <sebastian at macke.de>
>>>>>>>>> wrote:
>>>>>>>>>> Hi Heshma,
>>>>>>>>>> Great! Do you have a link of a working QEMU image? I can try to run
>>>>>>>>>> it
>>>>>>>>>> in
>>>>>>>>>> jor1k.
>>>>>>>>>> Sebastian
>>>>>>>>>> Am 2/22/2015 um 4:51 PM schrieb Hesham Moustafa:
>>>>>>>>>> Hi all,
>>>>>>>>>> In case some of you don't know, I have ported RTEMS to OpenRISC last
>>>>>>>>>> year
>>>>>>>>>> during GSoC. All the code is now upstream and works fine. I wrote a
>>>>>>>>>> tutorial
>>>>>>>>>> describing how to get RTEMS running on OpenRISC simulators (or1ksim
>>>>>>>>>> and
>>>>>>>>>> QEMU) totally from scratch [1].
>>>>>>>>>> [1] http://heshamelmatary.blogspot.co.uk/p/howto-rtems.html
>>>>>>>>>> Best,
>>>>>>>>>> Hesham
>>>>>>>>>> _______________________________________________
>>>>>>>>>> Openrisc mailing list
>>>>>>>>>> Openrisc at lists.opencores.org
>>>>>>>>>> http://lists.opencores.org/listinfo/openrisc
>> devel mailing list
>> devel at rtems.org
