RSB - How to checkout a branch from a repo and build from it
Hesham ALMatary heshamelmatary at gmail.com
Tue Feb 24 19:41:31 UTC 2015
On Tue, Feb 24, 2015 at 7:31 PM, Gedare Bloom <gedare at rtems.org> wrote:
> It looks like you can specify a branch in the %source command, e.g.
> config/tools/rtems-binutils-git-1.cfg has
>  %source set binutils
> git://sourceware.org/git/binutils-gdb.git?fetch?reset=hard?branch=master?checkout=%{binutils_version}
Thanks!
> -Gedare
> On Tue, Feb 24, 2015 at 7:30 AM, Hesham Moustafa
> <heshamelmatary at gmail.com> wrote:
>> Hi,
>> I am wondering how can I checkout a github repo, and from RSB change
>> to another branch, and build from their. For example this repo [1] has
>> master branch called "epiphany-binutils-2.23" which is not stable,
>> instead it has another stable branch called
>> "epiphany-binutils-2.23-software-cache" which I want to build from.
>> [1] https://github.com/adapteva/epiphany-binutils
>> Hesham
>> devel mailing list
>> devel at rtems.org
Hesham
