[PATCH] ARM: Prevent _ARMV4_Exception_fiq_default from re-enabling FIQs.
    Martin Galvan
    martin.galvan at tallertechnologies.com
    Thu Feb 26 13:10:06 UTC 2015
Patch attached.
On Thu, Feb 26, 2015 at 5:26 AM, Sebastian Huber
> Looks good, can you please send a patch.
> On 25/02/15 20:57, Martin Galvan wrote:
>> Follow-up from here:
>> https://lists.rtems.org/pipermail/devel/2015-February/009974.html
>> When talking to Sebastian Huber about the behavior of
>> _ARMV4_Exception_fiq_default, he mentioned that it shouldn't re-enable FIQs
>> again. This patch sets the F bit of the SPSR so that when it gets loaded
>> back to the CPSR in save_more_context it won't enable the FIQs.
>> So far I've tested it on the TMS570 and it seems to be working fine (we
>> were getting endless FIQs before, now we end up in bsp_reset). However, I'm
>> not sure if there are other BSPs out there that rely on the previous
>> behavior.
>> diff --git a/cpukit/score/cpu/arm/armv4-exception-default.S
>> b/cpukit/score/cpu/arm/armv4-exception-default.S
>> index a0ee46c..a10de30 100644
>> --- a/cpukit/score/cpu/arm/armv4-exception-default.S
>> +++ b/cpukit/score/cpu/arm/armv4-exception-default.S
>> @@ -99,6 +99,14 @@ _ARMV4_Exception_fiq_default:
>>         stmdb   sp!, {r0-r12}
>>         mov     r4, #7
>> +        * Don't enable FIQs yet. Set the FIQ disable bit in the SPSR
>> +        * (which we'll load into the CPSR in save_more_context).
>> +       mrs r2, spsr
>> +       orr r2, #ARM_PSR_F
>> +       msr spsr_c, r2
>>   save_more_context:
>>         /* Save more context */
Martín Galván
Software Engineer
Taller Technologies Argentina
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone: 54 351 4217888 / +54 351 4218211
Type: text/x-diff
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150226/a787f523/attachment-0002.bin>
