[PATCH] ARM: Prevent _ARMV4_Exception_fiq_default from re-enabling FIQs.
Sebastian Huber
Thu Feb 26 08:26:56 UTC 2015
Looks good, can you please send a patch.
On 25/02/15 20:57, Martin Galvan wrote:
> Follow-up from here:
> https://lists.rtems.org/pipermail/devel/2015-February/009974.html
> When talking to Sebastian Huber about the behavior of _ARMV4_Exception_fiq_default, he mentioned that it shouldn't re-enable FIQs again. This patch sets the F bit of the SPSR so that when it gets loaded back to the CPSR in save_more_context it won't enable the FIQs.
> So far I've tested it on the TMS570 and it seems to be working fine (we were getting endless FIQs before, now we end up in bsp_reset). However, I'm not sure if there are other BSPs out there that rely on the previous behavior.
> diff --git a/cpukit/score/cpu/arm/armv4-exception-default.S b/cpukit/score/cpu/arm/armv4-exception-default.S
> index a0ee46c..a10de30 100644
> --- a/cpukit/score/cpu/arm/armv4-exception-default.S
> +++ b/cpukit/score/cpu/arm/armv4-exception-default.S
> @@ -99,6 +99,14 @@ _ARMV4_Exception_fiq_default:
> stmdb sp!, {r0-r12}
> mov r4, #7
> + * Don't enable FIQs yet. Set the FIQ disable bit in the SPSR
> + * (which we'll load into the CPSR in save_more_context).
> + mrs r2, spsr
> + orr r2, #ARM_PSR_F
> + msr spsr_c, r2
> save_more_context:
> /* Save more context */
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
