[PATCH v2] ARM: Add BSP_START_NEEDS_REGISTER_INITIALIZATION
Sebastian Huber
Thu Feb 26 14:47:59 UTC 2015
Hello Martin,
sorry, I should have look at your bsp-start-init-registers.s earlier.
This stuff looks so generic, that it should go directly into start.S. I
guess the TMS570 will not remain the only ARM core with a lockstep feature.
You don't have to save and restore the r0 in a function since its a
volatile register.
On 26/02/15 15:38, Martin Galvan wrote:
> Changes from v1:
> * Add bsp_start_* prefixes.
> * Add *_banked_fiq suffixes to make it clear it's referring to the FIQ mode banked regs.
> Follow-up from here:
> https://lists.rtems.org/pipermail/devel/2015-February/009974.html
> This patch adds the macro BSP_START_NEEDS_REGISTER_INITIALIZATION and three hooks for BSP-specific register init code to arm/shared/start.S. Said hooks are bsp_start_init_registers_core (intended for initializing the ARM core registers), bsp_start_init_registers_banked_fiq (for the FIQ mode banked registers) and bsp_start_init_registers_vfp (for the FPU registers). BSP_START_NEEDS_REGISTER_INITIALIZATION would be defined in a BSP's configure.ac (so that it appears in its bspopts.h).
> This patch also adds the register init code required by the TMS570. We've tested it with the tms570ls3137_hdk.cfg config and it works fine.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
