[PATCH v2] ARM: Add BSP_START_NEEDS_REGISTER_INITIALIZATION
Martin Galvan martin.galvan at tallertechnologies.com
Thu Feb 26 14:54:51 UTC 2015
On Thu, Feb 26, 2015 at 11:47 AM, Sebastian Huber
> Hello Martin,
> sorry, I should have look at your bsp-start-init-registers.s earlier. This
> stuff looks so generic, that it should go directly into start.S. I guess the
> TMS570 will not remain the only ARM core with a lockstep feature.
Thanks for the feedback. So that means I should discard the
BSP_START_NEEDS_REGISTER_INITIALIZATION symbol altogether and
unconditionally call the bsp_start_init_registers routines in
arm/shared/start/start.S?
I still think the routines themselves should be kept on a separate .S
file, though, if only to keep start.S as short and clean as possible.
> You don't have to save and restore the r0 in a function since its a volatile
> register.
> On 26/02/15 15:38, Martin Galvan wrote:
>> Changes from v1:
>>      * Add bsp_start_* prefixes.
>>      * Add *_banked_fiq suffixes to make it clear it's referring to the
>> FIQ mode banked regs.
>> Follow-up from here:
>> https://lists.rtems.org/pipermail/devel/2015-February/009974.html
>> This patch adds the macro BSP_START_NEEDS_REGISTER_INITIALIZATION and
>> three hooks for BSP-specific register init code to arm/shared/start.S. Said
>> hooks are bsp_start_init_registers_core (intended for initializing the ARM
>> core registers), bsp_start_init_registers_banked_fiq (for the FIQ mode
>> banked registers) and bsp_start_init_registers_vfp (for the FPU registers).
>> BSP_START_NEEDS_REGISTER_INITIALIZATION would be defined in a BSP's
>> configure.ac (so that it appears in its bspopts.h).
>> This patch also adds the register init code required by the TMS570. We've
>> tested it with the tms570ls3137_hdk.cfg config and it works fine.
Martín Galván
Software Engineer
Taller Technologies Argentina
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone: 54 351 4217888 / +54 351 4218211
