[PATCH v2] ARM: Add BSP_START_NEEDS_REGISTER_INITIALIZATION
Martin Galvan martin.galvan at tallertechnologies.com
Thu Feb 26 15:39:52 UTC 2015
On Thu, Feb 26, 2015 at 12:03 PM, Sebastian Huber
> On 26/02/15 15:54, Martin Galvan wrote:
>> On Thu, Feb 26, 2015 at 11:47 AM, Sebastian Huber
>>> >Hello Martin,
>>> >sorry, I should have look at your bsp-start-init-registers.s earlier.
>>> > This
>>> >stuff looks so generic, that it should go directly into start.S. I guess
>>> > the
>>> >TMS570 will not remain the only ARM core with a lockstep feature.
>> Thanks for the feedback. So that means I should discard the
>> BSP_START_NEEDS_REGISTER_INITIALIZATION symbol altogether and
>> unconditionally call the bsp_start_init_registers routines in
>> arm/shared/start/start.S?
> No, the define is fine, since we need this code sequence only in certain
> cases.
>> I still think the routines themselves should be kept on a separate .S
>> file, though, if only to keep start.S as short and clean as possible.
> If you want to keep them in a separate file, then please move the file to
> the shared folder. I don't think this stuff is really BSP specific.
Got it. Will move it to arm/shared and send patch v3. Thanks a lot!
Martín Galván
Software Engineer
Taller Technologies Argentina
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone: 54 351 4217888 / +54 351 4218211
