[PATCH v2] ARM: Add BSP_START_NEEDS_REGISTER_INITIALIZATION
Thu Feb 26 15:03:08 UTC 2015
On 26/02/15 15:54, Martin Galvan wrote:
> On Thu, Feb 26, 2015 at 11:47 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de>  wrote:
>> >Hello Martin,
>> >sorry, I should have look at your bsp-start-init-registers.s earlier. This
>> >stuff looks so generic, that it should go directly into start.S. I guess the
>> >TMS570 will not remain the only ARM core with a lockstep feature.
> Thanks for the feedback. So that means I should discard the
> BSP_START_NEEDS_REGISTER_INITIALIZATION symbol altogether and
> unconditionally call the bsp_start_init_registers routines in
> arm/shared/start/start.S?
No, the define is fine, since we need this code sequence only in certain
cases.
> I still think the routines themselves should be kept on a separate .S
> file, though, if only to keep start.S as short and clean as possible.
If you want to keep them in a separate file, then please move the file
to the shared folder. I don't think this stuff is really BSP specific.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
