[PATCH 009/111] DRVMGR: added driver manager to cpukit/libdrvmgr
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:38:11 UTC 2015
aclocal/enable-drvmgr.m4 | 12 +
c/src/aclocal/enable-drvmgr.m4 | 12 +
c/src/lib/libbsp/shared/bspdriverlevelhook.c | 16 +
c/src/lib/libbsp/shared/include/bootcard.h | 2 +
c/src/make/configure.ac | 1 +
configure.ac | 1 +
cpukit/Makefile.am | 7 +
cpukit/aclocal/enable-drvmgr.m4 | 12 +
cpukit/configure.ac | 7 +
cpukit/libdrvmgr/Makefile.am | 33 +
cpukit/libdrvmgr/README | 112 +++
cpukit/libdrvmgr/drvmgr.c | 643 +++++++++++++++++
cpukit/libdrvmgr/drvmgr.h | 965 ++++++++++++++++++++++++++
cpukit/libdrvmgr/drvmgr_by_id.c | 33 +
cpukit/libdrvmgr/drvmgr_by_name.c | 37 +
cpukit/libdrvmgr/drvmgr_confdefs.h | 86 +++
cpukit/libdrvmgr/drvmgr_dev_by_name.c | 34 +
cpukit/libdrvmgr/drvmgr_drvinf.c | 148 ++++
cpukit/libdrvmgr/drvmgr_for_each_dev.c | 104 +++
cpukit/libdrvmgr/drvmgr_for_each_list_dev.c | 44 ++
cpukit/libdrvmgr/drvmgr_func.c | 42 ++
cpukit/libdrvmgr/drvmgr_func_call.c | 21 +
cpukit/libdrvmgr/drvmgr_init.c | 26 +
cpukit/libdrvmgr/drvmgr_internal.h | 70 ++
cpukit/libdrvmgr/drvmgr_list.c | 67 ++
cpukit/libdrvmgr/drvmgr_list.h | 79 +++
cpukit/libdrvmgr/drvmgr_lock.c | 38 +
cpukit/libdrvmgr/drvmgr_print.c | 457 ++++++++++++
cpukit/libdrvmgr/drvmgr_res.c | 102 +++
cpukit/libdrvmgr/drvmgr_rw.c | 52 ++
cpukit/libdrvmgr/drvmgr_translate.c | 149 ++++
cpukit/libdrvmgr/drvmgr_translate_check.c | 35 +
cpukit/libdrvmgr/drvmgr_unregister.c | 186 +++++
cpukit/preinstall.am | 17 +
cpukit/sapi/include/confdefs.h | 11 +-
cpukit/sapi/src/exinit.c | 63 ++
cpukit/wrapup/Makefile.am | 3 +-
37 files changed, 3724 insertions(+), 3 deletions(-)
create mode 100644 aclocal/enable-drvmgr.m4
create mode 100644 c/src/aclocal/enable-drvmgr.m4
create mode 100644 c/src/lib/libbsp/shared/bspdriverlevelhook.c
create mode 100644 cpukit/aclocal/enable-drvmgr.m4
create mode 100644 cpukit/libdrvmgr/Makefile.am
create mode 100644 cpukit/libdrvmgr/README
create mode 100644 cpukit/libdrvmgr/drvmgr.c
create mode 100644 cpukit/libdrvmgr/drvmgr.h
create mode 100644 cpukit/libdrvmgr/drvmgr_by_id.c
create mode 100644 cpukit/libdrvmgr/drvmgr_by_name.c
create mode 100644 cpukit/libdrvmgr/drvmgr_confdefs.h
create mode 100644 cpukit/libdrvmgr/drvmgr_dev_by_name.c
create mode 100644 cpukit/libdrvmgr/drvmgr_drvinf.c
create mode 100644 cpukit/libdrvmgr/drvmgr_for_each_dev.c
create mode 100644 cpukit/libdrvmgr/drvmgr_for_each_list_dev.c
create mode 100644 cpukit/libdrvmgr/drvmgr_func.c
create mode 100644 cpukit/libdrvmgr/drvmgr_func_call.c
create mode 100644 cpukit/libdrvmgr/drvmgr_init.c
create mode 100644 cpukit/libdrvmgr/drvmgr_internal.h
create mode 100644 cpukit/libdrvmgr/drvmgr_list.c
create mode 100644 cpukit/libdrvmgr/drvmgr_list.h
create mode 100644 cpukit/libdrvmgr/drvmgr_lock.c
create mode 100644 cpukit/libdrvmgr/drvmgr_print.c
create mode 100644 cpukit/libdrvmgr/drvmgr_res.c
create mode 100644 cpukit/libdrvmgr/drvmgr_rw.c
create mode 100644 cpukit/libdrvmgr/drvmgr_translate.c
create mode 100644 cpukit/libdrvmgr/drvmgr_translate_check.c
create mode 100644 cpukit/libdrvmgr/drvmgr_unregister.c
diff --git a/aclocal/enable-drvmgr.m4 b/aclocal/enable-drvmgr.m4
new file mode 100644
index 0000000..489f60e
--- /dev/null
+++ b/aclocal/enable-drvmgr.m4
@@ -0,0 +1,12 @@
+AC_DEFUN([RTEMS_ENABLE_DRVMGR],
+## AC_BEFORE([$0], [RTEMS_CHECK_DRVMGR_STARTUP])dnl
+AC_ARG_ENABLE(drvmgr,
+[AS_HELP_STRING([--enable-drvmgr],[enable Driver Manager at Startup])],
+[case "${enableval}" in
+ yes) RTEMS_DRVMGR_STARTUP=yes ;;
+ no) RTEMS_DRVMGR_STARTUP=no ;;
+ *) AC_MSG_ERROR(bad value ${enableval} for enable-drvmgr option) ;;
+esac],[RTEMS_DRVMGR_STARTUP=yes])
diff --git a/c/src/aclocal/enable-drvmgr.m4 b/c/src/aclocal/enable-drvmgr.m4
--- /dev/null
+++ b/c/src/aclocal/enable-drvmgr.m4
@@ -0,0 +1,12 @@
diff --git a/c/src/lib/libbsp/shared/bspdriverlevelhook.c b/c/src/lib/libbsp/shared/bspdriverlevelhook.c
index 0000000..93406f9
--- /dev/null
+++ b/c/src/lib/libbsp/shared/bspdriverlevelhook.c
@@ -0,0 +1,16 @@
+ * This is a dummy bsp_driver_level_hook routine.
+ * COPYRIGHT (c) 2015.
+ * Cobham Gaisler.
+#include <bsp/bootcard.h>
+void bsp_driver_level_hook( int level )
diff --git a/c/src/lib/libbsp/shared/include/bootcard.h b/c/src/lib/libbsp/shared/include/bootcard.h
index 5e31fcf..c394602 100644
--- a/c/src/lib/libbsp/shared/include/bootcard.h
+++ b/c/src/lib/libbsp/shared/include/bootcard.h
@@ -57,6 +57,8 @@ void bsp_pretasking_hook(void);
void bsp_predriver_hook(void);
+void bsp_driver_level_hook( int level );
void bsp_postdriver_hook(void);
void bsp_reset(void);
diff --git a/c/src/make/configure.ac b/c/src/make/configure.ac
index 08f8c8b..10c47a0 100644
--- a/c/src/make/configure.ac
+++ b/c/src/make/configure.ac
@@ -20,6 +20,7 @@ RTEMS_ENABLE_MULTIPROCESSING
RTEMS_ENABLE_POSIX
RTEMS_ENABLE_NETWORKING
RTEMS_ENABLE_CXX
+RTEMS_ENABLE_DRVMGR
RTEMS_ENV_RTEMSBSP
diff --git a/configure.ac b/configure.ac
index 4d6cd56..61e0eda 100644
--- a/configure.ac
+++ b/configure.ac
@@ -28,6 +28,7 @@ RTEMS_ENABLE_RTEMS_DEBUG
RTEMS_ENABLE_RTEMSBSP
RTEMS_ENABLE_MULTILIB
RTEMS_ENABLE_PARAVIRT
AC_ARG_ENABLE([docs],
[AS_HELP_STRING([--enable-docs],[enable building documentation
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 0364bf1..4f98978 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -8,6 +8,7 @@ SUBDIRS = . score rtems sapi posix
SUBDIRS += dev
SUBDIRS += libcrypt
SUBDIRS += libcsupport libblock libfs
+SUBDIRS += libdrvmgr
SUBDIRS += libnetworking librpc
SUBDIRS += libpci
SUBDIRS += libi2c
@@ -230,6 +231,12 @@ include_rtems_HEADERS += libmisc/untar/untar.h
## fsmount
include_rtems_HEADERS += libmisc/fsmount/fsmount.h
+## Driver manager
+include_drvmgrdir = $(includedir)/drvmgr
+include_drvmgr_HEADERS = libdrvmgr/drvmgr.h
+include_drvmgr_HEADERS += libdrvmgr/drvmgr_confdefs.h
+include_drvmgr_HEADERS += libdrvmgr/drvmgr_list.h
## HACK: doxygen filter.
EXTRA_DIST = doxy-filter
diff --git a/cpukit/aclocal/enable-drvmgr.m4 b/cpukit/aclocal/enable-drvmgr.m4
index 0000000..a9da288
--- /dev/null
+++ b/cpukit/aclocal/enable-drvmgr.m4
@@ -0,0 +1,12 @@
+dnl $Id: enable-drvmgr.m4,v 1.0
+AS_HELP_STRING(--enable-drvmgr,enable drvmgr at startup),
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index 8042c35..81bbc89 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -17,6 +17,7 @@ RTEMS_ENABLE_RTEMS_DEBUG
RTEMS_ENABLE_PROFILING
RTEMS_ENV_RTEMSCPU
RTEMS_CHECK_RTEMS_DEBUG
@@ -226,6 +227,11 @@ RTEMS_CPUOPT([RTEMS_NETWORKING],
[1],
[if networking is enabled])
+RTEMS_CPUOPT([RTEMS_DRVMGR_STARTUP],
+ [test x"$enable_drvmgr" = xyes],
+ [1],
+ [if driver manager api is supported])
RTEMS_CPUOPT([RTEMS_VERSION],
[true],
["]_RTEMS_VERSION["],
@@ -428,6 +434,7 @@ score/cpu/v850/Makefile
score/cpu/no_cpu/Makefile
posix/Makefile
libblock/Makefile
+libdrvmgr/Makefile
libfs/Makefile
libfs/src/nfsclient/Makefile
libgnat/Makefile
diff --git a/cpukit/libdrvmgr/Makefile.am b/cpukit/libdrvmgr/Makefile.am
index 0000000..d93854a
--- /dev/null
+++ b/cpukit/libdrvmgr/Makefile.am
@@ -0,0 +1,33 @@
+## $Id: Makefile.am
+include $(top_srcdir)/automake/compile.am
+EXTRA_DIST=
+noinst_LIBRARIES = libdrvmgr.a
+libdrvmgr_a_SOURCES = drvmgr.c
+libdrvmgr_a_SOURCES += drvmgr.h
+libdrvmgr_a_SOURCES += drvmgr_by_name.c
+libdrvmgr_a_SOURCES += drvmgr_by_id.c
+libdrvmgr_a_SOURCES += drvmgr_dev_by_name.c
+libdrvmgr_a_SOURCES += drvmgr_drvinf.c
+libdrvmgr_a_SOURCES += drvmgr_init.c
+libdrvmgr_a_SOURCES += drvmgr_confdefs.h
+libdrvmgr_a_SOURCES += drvmgr_for_each_dev.c
+libdrvmgr_a_SOURCES += drvmgr_for_each_list_dev.c
+libdrvmgr_a_SOURCES += drvmgr_func.c
+libdrvmgr_a_SOURCES += drvmgr_func_call.c
+libdrvmgr_a_SOURCES += drvmgr_list.c
+libdrvmgr_a_SOURCES += drvmgr_list.h
+libdrvmgr_a_SOURCES += drvmgr_lock.c
+libdrvmgr_a_SOURCES += drvmgr_print.c
+libdrvmgr_a_SOURCES += drvmgr_res.c
+libdrvmgr_a_SOURCES += drvmgr_rw.c
+libdrvmgr_a_SOURCES += drvmgr_translate.c
+libdrvmgr_a_SOURCES += drvmgr_translate_check.c
+libdrvmgr_a_SOURCES += drvmgr_unregister.c
+include $(top_srcdir)/automake/local.am
diff --git a/cpukit/libdrvmgr/README b/cpukit/libdrvmgr/README
index 0000000..6e55370
--- /dev/null
+++ b/cpukit/libdrvmgr/README
@@ -0,0 +1,112 @@
+DRIVER MANAGER
+See documentation in Aeroflex Gaisler Driver manual.
+INITIALIZATION
+The Driver Manager can be intialized in two different ways:
+ 1. during RTEMS startup
+ 2. started by user, typically in the Init task
+The driver manager is initalized during RTEMS startup in the
+rtems_initialize_device_drivers() function when RTEMS is
+configured with driver manager support.
+When RTEMS is not configured with the driver manager, the manager
+may still be initialized by the user after system startup, typically
+from the Init() task.
+The main difference between the two ways is when interrupt
+is enabled. Interrupt is enabled for the first time by RTEMS when
+the Init task is started. This means, for the first case, that
+drivers can not use interrupt services until after the
+initialization phase is over and the user request services from
+the drivers. For the second case of initialization, this means
+that driver must take extra care during initalization when interrupt
+is enabled so that spurious interrupts are not generated and that the
+system does not hang in an infinite IRQ loop.
+Most of the problems above are solved for the two methods by
+specifying in which initialization levels IRQ handling is done.
+See Level 1 and Level 2 below.
+Other differences is that IRQ, System Clock Timer, debug Console
+and Console can be initalized by the help of the driver manager
+when initialized during start up. Between Level0 and Level1 the
+RTEMS I/O Manager drivers are initialized. The LEON3 BSP has
+therefore two different versions of the basic drivers.
+LEVEL0
+The level of uninitialized devices that have been united with a
+driver.
+LEVEL1 - FIND/RESET/IRQ Clear
+The driver is for the first time informed of the presence of a
+device. Only basic initialization.
+- Find all hardware needed for IRQ, Console, Timer and hardware
+ that need to be reset.
+- Reset hardware, so that interrupts are not generated by mistake
+ when enabled later on.
+- Init low level non-interrupt (polling-mode) services needed by
+ drivers init LEVEL2 and onwards, such as
+ * Debug UART console for printk()
+ * Timer API (non-IRQ)
+ * GPIO (non-IRQ)
+ * Special non-main memory configuration, washing
+- Register IRQ controller at BSP IRQ library
+- Register Timer for system clock
+- Register Console UART
+During this intialization level interrupts may not be registered,
+enabled or disabled at the IRQ controller. But, all IRQ sources
+should be cleared to avoid spurious interrupts later on.
+AFTER LEVEL1 - if initialized during startup
+The statically configured drivers are initialized as normally by RTEMS. The
+hardware was found in LEVEL1.
+CONFIGURE_BSP_PREREQUISITE_DRIVERS may initialize IRQ driver, or
+IRQ lib initialized when IRQ controller was registered during LEVEL1.
+LEVEL2
+Initialize other device drivers than IRQ, Timer, console:
+- ISR can be registered, enabled, disabled at IRQ controller
+ (IRQ is still masked by CPU interrupt level if initialized during
+ RTEMS startup)
+- Timer API that does not require IRQ can be used
+- printf() can be used
+For standard peripherals this is the first initialization.
+LEVEL3
+Initialize drivers that require features/APIs provided by drivers
+in LEVEL2.
+Such features may involve services that require IRQ to be implemented.
+LEVEL4
+Unused extra level.
+LEVEL INACTIVE - NOT ENABLED DEVICES
+List of devices that experienced:
+ - no driver found for device (not united)
+ - ignored (not united with a driver, forced by user)
+ - an error was reported by device driver during initialization
diff --git a/cpukit/libdrvmgr/drvmgr.c b/cpukit/libdrvmgr/drvmgr.c
index 0000000..0471865
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr.c
@@ -0,0 +1,643 @@
+/* Driver Manager Interface Implementation.
+ * COPYRIGHT (c) 2009.
+ * Cobham Gaisler AB.
+ * http://www.rtems.com/license/LICENSE.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <drvmgr/drvmgr.h>
+#include <drvmgr/drvmgr_confdefs.h>
+#include "drvmgr_internal.h"
+/* Enable debugging */
+/*#define DEBUG 1*/
+#ifdef DEBUG
+#define DBG(x...) printk(x)
+#else
+#define DBG(x...)
+#endif
+struct rtems_driver_manager drv_mgr = {
+ .level = 0,
+ .initializing_objs = 0,
+ .lock = 0,
+ .root_dev = {0},
+ .root_drv = NULL,
+ .drivers = LIST_INITIALIZER(struct drvmgr_drv, next),
+ .buses = {
+ LIST_INITIALIZER(struct drvmgr_bus, next),
+ .buses_inactive = LIST_INITIALIZER(struct drvmgr_bus, next),
+ .devices = {
+ LIST_INITIALIZER(struct drvmgr_dev, next),
+ .devices_inactive = LIST_INITIALIZER(struct drvmgr_dev, next),
+static int do_bus_init(
+ struct rtems_driver_manager *mgr,
+ struct drvmgr_bus *bus,
+ int level);
+static int do_dev_init(
+ struct drvmgr_dev *dev,
+ int level);
+/* DRIVER MANAGER */
+void _DRV_Manager_init_level(int level)
+ struct rtems_driver_manager *mgr = &drv_mgr;
+ if (mgr->level >= level)
+ return;
+ /* Set new Level */
+ mgr->level = level;
+ /* Initialize buses and devices into this new level */
+ drvmgr_init_update();
+/* Initialize Data structures of the driver manager and call driver
+ * register functions configured by the user.
+void _DRV_Manager_initialization(void)
+ struct drvmgr_drv_reg_func *drvreg;
+ /* drv_mgr is already initialized statically by compiler except
+ * the lock
+ DRVMGR_LOCK_INIT();
+ /* Call driver register functions. */
+ drvreg = &drvmgr_drivers[0];
+ while (drvreg->drv_reg) {
+ /* Make driver register */
+ drvreg->drv_reg();
+ drvreg++;
+/* Take ready devices and buses into the correct init level step by step.
+ * Once a bus or a device has been registered there is no turning
+ * back - they are taken to the level of the driver manager.
+void drvmgr_init_update(void)
+ struct drvmgr_bus *bus;
+ struct drvmgr_dev *dev;
+ int bus_might_been_registered;
+ int level;
+ /* "Lock" to make sure we don't use up the stack and that the lists
+ * remain consistent.
+ DRVMGR_LOCK_WRITE();
+ if (mgr->initializing_objs || (mgr->level == 0))
+ goto out;
+ mgr->initializing_objs = 1;
+init_registered_buses:
+ /* Take all buses and devices ready into the same stage
+ * as the driver manager global level.
+ for (level = 0; level < mgr->level; level++) {
+ bus_might_been_registered = 0;
+ /* Take buses into next level */
+ while ((bus = BUS_LIST_HEAD(&mgr->buses[level])) != NULL) {
+ /* Remove first in the list (will be inserted in
+ * appropriate list by do_bus_init())
+ drvmgr_list_remove_head(&mgr->buses[level]);
+ DRVMGR_UNLOCK();
+ /* Initialize Bus, this will register devices on
+ * the bus. Take bus into next level.
+ do_bus_init(mgr, bus, level+1);
+ /* Take devices into next level */
+ while ((dev = DEV_LIST_HEAD(&mgr->devices[level])) != NULL) {
+ /* Always process first in list */
+ dev = DEV_LIST_HEAD(&mgr->devices[level]);
+ * appropriate list by do_dev_init())
+ drvmgr_list_remove_head(&mgr->devices[level]);
+ DRVMGR_UNLOCK();
+ /* Initialize Device, this may register a new bus */
+ do_dev_init(mgr, dev, level+1);
+ bus_might_been_registered = 1;
+ /* Make sure all buses registered and ready are taken at
+ * the same time into init level N.
+ if (bus_might_been_registered)
+ goto init_registered_buses;
+ /* Release bus/device initialization "Lock" */
+ mgr->initializing_objs = 0;
+out:
+ DRVMGR_UNLOCK();
+/* Take bus into next level */
+ int level)
+ int (*init)(struct drvmgr_bus *);
+ /* If bridge device has failed during initialization, the bus is not
+ * initialized further.
+ if (bus->dev->state & DEV_STATE_INIT_FAILED) {
+ bus->state |= BUS_STATE_DEPEND_FAILED;
+ goto inactivate_out;
+ if (bus->ops && (init = bus->ops->init[level-1])) {
+ /* Note: This init1 function may register new devices */
+ bus->error = init(bus);
+ if (bus->error != DRVMGR_OK) {
+ /* An error of some kind during bus initialization.
+ * Child devices and their buses are not inactived
+ * directly here, instead they will all be catched by
+ * do_dev_init() and do_bus_init() by checking if
+ * parent or bridge-device failed. We know that
+ * initialization will happen later for those devices.
+ /* Bus taken into the new level */
+ bus->level = level;
+ /* Put bus into list of buses reached level 'level'.
+ * Put at end of bus list so that init[N+1]() calls comes
+ * in the same order as init[N]()
+ drvmgr_list_add_tail(&mgr->buses[level], bus);
+ DRVMGR_UNLOCK();
+ return 0;
+inactivate_out:
+ bus->state |= BUS_STATE_INIT_FAILED;
+ bus->state |= BUS_STATE_LIST_INACTIVE;
+ drvmgr_list_add_head(&mgr->buses_inactive, bus);
+ DRVMGR_UNLOCK();
+ DBG("do_bus_init(%d): (DEV: %s) failed\n", level, bus->dev->name);
+ return 1;
+/* Take device to initialization level 1 */
+ int level)
+ int (*init)(struct drvmgr_dev *);
+ /* Try to allocate Private Device Structure for driver if driver
+ * requests for this feature.
+ if (dev->drv && dev->drv->dev_priv_size && !dev->priv) {
+ dev->priv = malloc(dev->drv->dev_priv_size);
+ memset(dev->priv, 0, dev->drv->dev_priv_size);
+ /* If parent bus has failed during initialization,
+ * the device is not initialized further.
+ if (dev->parent && (dev->parent->state & BUS_STATE_INIT_FAILED)) {
+ dev->state |= DEV_STATE_DEPEND_FAILED;
+ /* Call Driver's Init Routine */
+ if (dev->drv && (init = dev->drv->ops->init[level-1])) {
+ /* Note: This init function may register new devices */
+ dev->error = init(dev);
+ if (dev->error != DRVMGR_OK) {
+ /* An error of some kind has occured in the
+ * driver/device, the failed device is put into the
+ * inactive list, this way Init2,3 and/or 4 will not
+ * be called for this device.
+ * The device is not removed from the bus (not
+ * unregistered). The driver can be used to find
+ * device information and debugging for example even
+ * if device initialization failed.
+ * Child buses and their devices are not inactived
+ /* Dev taken into new level */
+ dev->level = level;
+ /* Put at end of device list so that init[N+1]() calls comes
+ drvmgr_list_add_tail(&mgr->devices[level], dev);
+ DRVMGR_UNLOCK();
+ return 0;
+inactivate_out:
+ dev->state |= DEV_STATE_INIT_FAILED;
+ dev->state |= DEV_STATE_LIST_INACTIVE;
+ drvmgr_list_add_head(&mgr->devices_inactive, dev);
+ DRVMGR_UNLOCK();
+ DBG("do_dev_init(%d): DRV: %s (DEV: %s) failed\n",
+ level, dev->drv->name, dev->name);
+ return 1; /* Failed to take device into requested level */
+/* Register Root device driver */
+int drvmgr_root_drv_register(struct drvmgr_drv *drv)
+ struct drvmgr_dev *root = &mgr->root_dev;
+ if (mgr->root_drv) {
+ /* Only possible to register root device once */
+ return DRVMGR_FAIL;
+ /* Set root device driver */
+ drv->next = NULL;
+ mgr->root_drv = drv;
+ /* Init root device non-NULL fields */
+ root->minor_drv = -1;
+ root->minor_bus = 0;
+ root->businfo = mgr;
+ root->name = "root bus";
+ /* Custom Driver association */
+ root->drv = mgr->root_drv;
+ /* This registers the root device and a bus */
+ drvmgr_dev_register(root);
+ return DRVMGR_OK;
+/* Register a driver */
+int drvmgr_drv_register(struct drvmgr_drv *drv)
+ /* All drivers must have been registered before start of init,
+ * because the manager does not scan all existing devices to find
+ * suitable hardware for this driver, and it is not protected with
+ * a lock therefore.
+ if (mgr->level > 0)
+ return -1;
+ drv->obj_type = DRVMGR_OBJ_DRV;
+ /* Put driver into list of registered drivers */
+ drvmgr_list_add_head(&mgr->drivers, drv);
+ /* TODO: we could scan for devices that this new driver has support
+ * for. However, at this stage we assume that all drivers are
+ * registered before devices are registered.
+ * LOCK: From the same assumsion locking the driver list is not needed
+ * either.
+ return 0;
+/* Insert a device into a driver's device list and assign a driver minor number
+ * to the device.
+ * The devices are ordered by their minor number (sorted linked list of devices)
+ * the minor number is found by looking for a gap or at the end.
+static void drvmgr_insert_dev_into_drv(
+ struct drvmgr_drv *drv,
+ struct drvmgr_dev *dev)
+ struct drvmgr_dev *curr, **pprevnext;
+ int minor;
+ minor = 0;
+ pprevnext = &drv->dev;
+ curr = drv->dev;
+ while (curr) {
+ if (minor < curr->minor_drv) {
+ /* Found a gap. Insert new device between prev
+ * and curr. */
+ break;
+ minor++;
+ pprevnext = &curr->next_in_drv;
+ curr = curr->next_in_drv;
+ dev->next_in_drv = curr;
+ *pprevnext = dev;
+ /* Set minor */
+ dev->minor_drv = minor;
+ drv->dev_cnt++;
+/* Insert a device into a bus device list and assign a bus minor number to the
+ * device.
+ * and by their registeration order if not using the same driver.
+ * The minor number is found by looking for a gap or at the end.
+static void drvmgr_insert_dev_into_bus(
+ int minor;
+ minor = 0;
+ pprevnext = &bus->children;
+ curr = bus->children;
+ while (curr) {
+ if (dev->drv && (dev->drv == curr->drv)) {
+ if (minor < curr->minor_bus) {
+ * and curr. */
+ break;
+ minor++;
+ pprevnext = &curr->next_in_bus;
+ curr = curr->next_in_bus;
+ dev->next_in_bus = curr;
+ *pprevnext = dev;
+ /* Set minor. Devices without driver are given -1 */
+ if (dev->drv == NULL)
+ minor = -1;
+ dev->minor_bus = minor;
+ bus->dev_cnt++;
+/* Try to find a driver for a device (unite a device with driver).
+ * a device with a driver
+static struct drvmgr_drv *drvmgr_dev_find_drv(
+ struct drvmgr_drv *drv;
+ /* NOTE: No locking is needed here since Driver list is supposed to be
+ * initialized once during startup, we treat it as a static
+ * read-only list
+ /* Try to find a driver that can handle this device */
+ for (drv = DRV_LIST_HEAD(&mgr->drivers); drv; drv = drv->next)
+ if (dev->parent->ops->unite(drv, dev) == 1)
+ break;
+ return drv;
+/* Register a device */
+int drvmgr_dev_register(struct drvmgr_dev *dev)
+ struct drvmgr_bus *bus = dev->parent;
+ struct drvmgr_key *keys;
+ struct drvmgr_list *init_list = &mgr->devices_inactive;
+ DBG("DEV_REG: %s at bus \"%s\"\n", dev->name,
+ bus && bus->dev && bus->dev->name ? bus->dev->name : "UNKNOWN");
+ /* Custom driver assocation? */
+ if (dev->drv) {
+ drv = dev->drv;
+ DBG("CUSTOM ASSOCIATION (%s to %s)\n", dev->name, drv->name);
+ } else {
+ dev->drv = drv = drvmgr_dev_find_drv(dev);
+ /* Assign Bus Minor number and put into bus device list
+ * unless root device.
+ if (bus)
+ drvmgr_insert_dev_into_bus(bus, dev);
+ if (!drv) {
+ /* No driver found that can handle this device, put into
+ * inactive list
+ dev->minor_drv = -1;
+ } else {
+ /* United device with driver.
+ * Put the device on the registered device list
+ dev->state |= DEV_STATE_UNITED;
+ /* Check if user want to skip this core. This is not a
+ * normal request, however in a multi-processor system
+ * the two(or more) RTEMS instances must not use the same
+ * devices in a system, not reporting a device to
+ * it's driver will effectively accomplish this. In a
+ * non Plug & Play system one can easily avoid this
+ * problem by not report the core, but in a Plug & Play
+ * system the bus driver will report all found cores.
+ * To stop the two RTEMS instances from using the same
+ * device the user can simply define a resource entry
+ * for a certain device but set the keys field to NULL.
+ if (drvmgr_keys_get(dev, &keys) == 0 && keys == NULL) {
+ /* Found Driver resource entry point
+ * for this device, it was NULL, this
+ * indicates to skip the core.
+ * We put it into the inactive list
+ * marking it as ignored.
+ dev->state |= DEV_STATE_IGNORED;
+ } else {
+ /* Assign Driver Minor number and put into driver's
+ * device list
+ drvmgr_insert_dev_into_drv(drv, dev);
+ /* Just register device, it will be initialized
+ * later together with bus.
+ * At the end of the list (breadth first search)
+ init_list = &mgr->devices[0];
+ DBG("Registered %s (DRV: %s) on %s\n",
+ dev->name, drv->name,
+ bus ? bus->dev->name : "NO PARENT");
+ drvmgr_list_add_tail(init_list, dev);
+ DRVMGR_UNLOCK();
+ /* Trigger Device initialization if not root device and
+ * has a driver
+ if (bus && dev->drv)
+ return 0;
+/* Register a bus */
+int drvmgr_bus_register(struct drvmgr_bus *bus)
+ struct drvmgr_bus *bus_up;
+ /* Get bus architecture depth - the distance from root bus */
+ bus->depth = 0;
+ bus_up = bus->dev->parent;
+ while (bus_up) {
+ bus->depth++;
+ bus_up = bus_up->dev->parent;
+ /* Put driver into list of found buses */
+ drvmgr_list_add_tail(&mgr->buses[0], bus);
+ DRVMGR_UNLOCK();
+ /* Take bus into level1 and so on */
+ return 0;
+/* Allocate memory for a Device structure */
+int drvmgr_alloc_dev(struct drvmgr_dev **pdev, int extra)
+ int size;
+ size = ((sizeof(struct drvmgr_dev) + 3) & ~0x3) + extra;
+ dev = (struct drvmgr_dev *)calloc(size, 1);
+ if (!dev) {
+ /* Failed to allocate device structure - critical error */
+ rtems_fatal_error_occurred(RTEMS_NO_MEMORY);
+ *pdev = dev;
+ dev->obj_type = DRVMGR_OBJ_DEV;
+ return 0;
+/* Allocate memory for a Bus structure */
+int drvmgr_alloc_bus(struct drvmgr_bus **pbus, int extra)
+ int size;
+ size = ((sizeof(struct drvmgr_bus) + 3) & ~0x3) + extra;
+ bus = (struct drvmgr_bus *)calloc(size, 1);
+ if (!bus) {
+ *pbus = bus;
+ bus->obj_type = DRVMGR_OBJ_BUS;
+ return 0;
+/* Add driver resources to a bus instance */
+void drvmgr_bus_res_add(struct drvmgr_bus *bus,
+ struct drvmgr_bus_res *bres)
+ /* insert first in bus resource list. Locking isn't needed since
+ * resources can only be added before resource requests are made.
+ * When bus has been registered resources are considered a read-only
+ * tree.
+ bres->next = bus->reslist;
+ bus->reslist = bres;
diff --git a/cpukit/libdrvmgr/drvmgr.h b/cpukit/libdrvmgr/drvmgr.h
index 0000000..f091728
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr.h
@@ -0,0 +1,965 @@
+/* Driver Manager Interface.
+#ifndef _DRIVER_MANAGER_H_
+#define _DRIVER_MANAGER_H_
+#include <rtems.h>
+#include <drvmgr/drvmgr_list.h>
+#include <stdint.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+/*** Configure Driver manager ***/
+/* Define the number of initialization levels of device drivers */
+#define DRVMGR_LEVEL_MAX 4
+/* Default to use semahpores for protection. Initialization works without
+ * locks and after initialization too if devices are not removed.
+#ifndef DRVMGR_USE_LOCKS
+#define DRVMGR_USE_LOCKS 1
+#endif
+struct drvmgr_dev; /* Device */
+struct drvmgr_bus; /* Bus */
+struct drvmgr_drv; /* Driver */
+/*** List Interface shortcuts ***/
+#define BUS_LIST_HEAD(list) LIST_HEAD(list, struct drvmgr_bus)
+#define BUS_LIST_TAIL(list) LIST_TAIL(list, struct drvmgr_bus)
+#define DEV_LIST_HEAD(list) LIST_HEAD(list, struct drvmgr_dev)
+#define DEV_LIST_TAIL(list) LIST_TAIL(list, struct drvmgr_dev)
+#define DRV_LIST_HEAD(list) LIST_HEAD(list, struct drvmgr_drv)
+#define DRV_LIST_TAIL(list) LIST_TAIL(list, struct drvmgr_drv)
+/*** Bus indentification ***/
+#define DRVMGR_BUS_TYPE_NONE 0 /* Not a valid bus */
+#define DRVMGR_BUS_TYPE_ROOT 1 /* Hard coded bus */
+#define DRVMGR_BUS_TYPE_PCI 2 /* PCI bus */
+#define DRVMGR_BUS_TYPE_AMBAPP 3 /* AMBA Plug & Play bus */
+#define DRVMGR_BUS_TYPE_LEON2_AMBA 4 /* LEON2 hardcoded bus */
+#define DRVMGR_BUS_TYPE_AMBAPP_DIST 5 /* Distibuted AMBA Plug & Play bus accessed using a communication interface */
+#define DRVMGR_BUS_TYPE_SPW_RMAP 6 /* SpaceWire Network bus */
+#define DRVMGR_BUS_TYPE_AMBAPP_RMAP 7 /* SpaceWire RMAP accessed AMBA Plug & Play bus */
+enum {
+ DRVMGR_OBJ_NONE = 0,
+ DRVMGR_OBJ_DRV = 1,
+ DRVMGR_OBJ_BUS = 2,
+ DRVMGR_OBJ_DEV = 3,
+/*** Driver indentification ***
+ * 64-bit identification integer definition
+ * * Bus ID 8-bit [7..0]
+ * * Reserved 8-bit field [63..56]
+ * * Device ID specific for bus type 48-bit [55..8] (Different buses have
+ * different unique identifications for hardware/driver.)
+ * ID Rules
+ * * A root bus driver must always have device ID set to 0. There can only by
+ * one root bus driver for a certain bus type.
+ * * A Driver ID must identify a unique hardware core
+/* Bus ID Mask */
+#define DRIVER_ID_BUS_MASK 0x00000000000000FFULL
+/* Reserved Mask for future use */
+#define DRIVER_ID_RSV_MASK 0xFF00000000000000ULL
+#define DRIVER_ID_DEV_MASK 0x00FFFFFFFFFFFF00ULL
+/* Set Bus ID Mask. */
+#define DRIVER_ID(busid, devid) ((unsigned long long) \
+ ((((unsigned long long)(devid) << 8) & DRIVER_ID_DEV_MASK) | \
+ ((unsigned long long)(busid) & DRIVER_ID_BUS_MASK)))
+/* Get IDs */
+#define DRIVER_BUSID_GET(id) ((unsigned long long)(id) & DRIVER_ID_BUS_MASK)
+#define DRIVER_DEVID_GET(id) (((unsigned long long)(id) & DRIVER_ID_DEV_MASK) >> 8)
+#define DRIVER_ROOTBUS_ID(bus_type) DRIVER_ID(bus_type, 0)
+/*** Root Bus drivers ***/
+/* Generic Hard coded Root bus: Driver ID */
+#define DRIVER_ROOT_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_ROOT)
+/* PCI Plug & Play bus: Driver ID */
+#define DRIVER_PCIBUS_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_PCI)
+/* AMBA Plug & Play bus: Driver ID */
+#define DRIVER_GRLIB_AMBAPP_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_AMBAPP)
+/* AMBA Hard coded bus: Driver ID */
+#define DRIVER_LEON2_AMBA_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_LEON2_AMBA)
+/* Distributed AMBA Plug & Play bus: Driver ID */
+#define DRIVER_AMBAPP_DIST_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_AMBAPP_DIST)
+/*! Bus parameters used by driver interface functions to aquire information
+ * about bus. All Bus drivers should implement the operation 'get_params' so
+ * that the driver interface routines can access bus dependent information in
+ * an non-dependent way.
+struct drvmgr_bus_params {
+ char *dev_prefix; /*!< Optional name prefix */
+/* Interrupt Service Routine (ISR) */
+typedef void (*drvmgr_isr)(void *arg);
+/*! Bus operations */
+struct drvmgr_bus_ops {
+ /* Functions used internally within driver manager */
+ int (*init[DRVMGR_LEVEL_MAX])(struct drvmgr_bus *);
+ int (*remove)(struct drvmgr_bus *);
+ int (*unite)(struct drvmgr_drv *, struct drvmgr_dev *); /*!< Unite Hardware Device with Driver */
+ /* Functions called indirectly from drivers */
+ int (*int_register)(struct drvmgr_dev *, int index, const char *info, drvmgr_isr isr, void *arg);
+ int (*int_unregister)(struct drvmgr_dev *, int index, drvmgr_isr isr, void *arg);
+ int (*int_clear)(struct drvmgr_dev *, int index);
+ int (*int_mask)(struct drvmgr_dev *, int index);
+ int (*int_unmask)(struct drvmgr_dev *, int index);
+ /* Get Parameters */
+ int (*get_params)(struct drvmgr_dev *, struct drvmgr_bus_params *);
+ /* Get Frequency of Bus */
+ int (*freq_get)(struct drvmgr_dev*, int, unsigned int*);
+ /*! Function called to request information about a device. The bus
+ * driver interpret the bus-specific information about the device.
+ void (*info_dev)(struct drvmgr_dev *, void (*print)(void *p, char *str), void *p);
+#define BUS_OPS_NUM (sizeof(struct drvmgr_bus_ops)/sizeof(void (*)(void)))
+struct drvmgr_func {
+ int funcid;
+ void *func;
+#define DRVMGR_FUNC(_ID_, _FUNC_) {(int)(_ID_), (void *)(_FUNC_)}
+#define DRVMGR_FUNC_END {0, NULL}
+/*** Resource definitions ***
+ * Overview of structures:
+ * All bus resources entries (_bus_res) are linked together per bus
+ * (bus_info->reslist). One bus resource entry has a pointer to an array of
+ * driver resources (_drv_res). One driver resouces is made out of an array
+ * of keys (drvmgr_key). All keys belongs to the same driver and harwdare
+ * device. Each key has a Name, Type ID and Data interpreted differently
+ * depending on the Type ID (union drvmgr_key_value).
+/* Key Data Types */
+#define KEY_TYPE_NONE 0
+#define KEY_TYPE_INT 1
+#define KEY_TYPE_STRING 2
+#define KEY_TYPE_POINTER 3
+#define KEY_EMPTY {NULL, KEY_TYPE_NONE, {0}}
+#define RES_EMPTY {0, 0, NULL}
+#define MMAP_EMPTY {0, 0, 0}
+/*! Union of different values */
+union drvmgr_key_value {
+ unsigned int i; /*!< Key data type UNSIGNED INTEGER */
+ char *str; /*!< Key data type STRING */
+ void *ptr; /*!< Key data type ADDRESS/POINTER */
+/* One key. One Value. Holding information relevant to the driver. */
+struct drvmgr_key {
+ char *key_name; /* Name of key */
+ int key_type; /* How to interpret key_value */
+ union drvmgr_key_value key_value; /* The value or pointer to value */
+/*! Driver resource entry, Driver resources for a certain device instance,
+ * containing a number of keys where each key hold the data of interest.
+struct drvmgr_drv_res {
+ uint64_t drv_id; /*!< Identifies the driver this resource is aiming */
+ int minor_bus; /*!< Indentifies a specfic device */
+ struct drvmgr_key *keys; /*!< First key in key array, ended with KEY_EMPTY */
+/*! Bus resource list node */
+struct drvmgr_bus_res {
+ struct drvmgr_bus_res *next; /*!< Next resource node in list */
+ struct drvmgr_drv_res resource[]; /*!< Array of resources, one per device instance */
+/*! MAP entry. Describes an linear address space translation. Untranslated
+ * Start, Translated Start and length.
+ * Used by bus drivers to describe the address translation needed for
+ * the translation driver interface.
+struct drvmgr_map_entry {
+ char *name; /*!< Map Name */
+ unsigned int size; /*!< Size of map window */
+ char *from_adr; /*!< Start address of access window used
+ * to reach into remote bus */
+ char *to_adr; /*!< Start address of remote system
+ * address range */
+#define DRVMGR_TRANSLATE_ONE2ONE NULL
+#define DRVMGR_TRANSLATE_NO_BRIDGE ((void *)1) /* No bridge, error */
+/*! Bus information. Describes a bus. */
+struct drvmgr_bus {
+ int obj_type; /*!< DRVMGR_OBJ_BUS */
+ unsigned char bus_type; /*!< Type of bus */
+ unsigned char depth; /*!< Bus level distance from root bus */
+ struct drvmgr_bus *next; /*!< Next Bus */
+ struct drvmgr_dev *dev; /*!< Bus device, the hardware... */
+ void *priv; /*!< Private data structure used by BUS driver */
+ struct drvmgr_dev *children; /*!< Hardware devices on this bus */
+ struct drvmgr_bus_ops *ops; /*!< Bus operations supported by this bus driver */
+ struct drvmgr_func *funcs; /*!< Extra operations */
+ int dev_cnt; /*!< Number of devices this bus has */
+ struct drvmgr_bus_res *reslist; /*!< Bus resources, head of a linked list of resources. */
+ struct drvmgr_map_entry *maps_up; /*!< Map Translation, array of address spaces upstreams to CPU */
+ struct drvmgr_map_entry *maps_down; /*!< Map Translation, array of address spaces downstreams to Hardware */
+ /* Bus status */
+ int level; /*!< Initialization Level of Bus */
+ int state; /*!< Init State of Bus, BUS_STATE_* */
+ int error; /*!< Return code from bus->ops->initN() */
+/* States of a bus */
+#define BUS_STATE_INIT_FAILED 0x00000001 /* Initialization Failed */
+#define BUS_STATE_LIST_INACTIVE 0x00001000 /* In inactive bus list */
+#define BUS_STATE_DEPEND_FAILED 0x00000004 /* Device init failed */
+/* States of a device */
+#define DEV_STATE_INIT_FAILED 0x00000001 /* Initialization Failed */
+#define DEV_STATE_INIT_DONE 0x00000002 /* All init levels completed */
+#define DEV_STATE_DEPEND_FAILED 0x00000004 /* Parent Bus init failed */
+#define DEV_STATE_UNITED 0x00000100 /* Device United with Device Driver */
+#define DEV_STATE_REMOVED 0x00000200 /* Device has been removed (unregistered) */
+#define DEV_STATE_IGNORED 0x00000400 /* Device was ignored according to user's request, the device
+ * was never reported to it's driver (as expected).
+#define DEV_STATE_LIST_INACTIVE 0x00001000 /* In inactive device list */
+/*! Device information */
+struct drvmgr_dev {
+ int obj_type; /*!< DRVMGR_OBJ_DEV */
+ struct drvmgr_dev *next; /*!< Next device */
+ struct drvmgr_dev *next_in_bus; /*!< Next device on the same bus */
+ struct drvmgr_dev *next_in_drv; /*!< Next device using the same driver */
+ struct drvmgr_drv *drv; /*!< The driver owning this device */
+ struct drvmgr_bus *parent; /*!< Bus that this device resides on */
+ short minor_drv; /*!< Device number within driver */
+ short minor_bus; /*!< Device number on bus (for device separation) */
+ char *name; /*!< Name of Device Hardware */
+ void *priv; /*!< Pointer to driver private device structure */
+ void *businfo; /*!< Host bus specific information */
+ struct drvmgr_bus *bus; /*!< Pointer to bus, set only if this is a bridge */
+ /* Device Status */
+ unsigned int state; /*!< State of device, see DEV_STATE_* */
+ int level; /*!< Init Level */
+ int error; /*!< Error state returned by driver */
+/*! Driver operations, function pointers. */
+struct drvmgr_drv_ops {
+ int (*init[DRVMGR_LEVEL_MAX])(struct drvmgr_dev *); /*! Function doing Init Stage 1 of a hardware device */
+ int (*remove)(struct drvmgr_dev *); /*! Function called when device instance is to be removed */
+ int (*info)(struct drvmgr_dev *, void (*print)(void *p, char *str), void *p, int, char *argv[]);/*! Function called to request information about a device or driver */
+#define DRV_OPS_NUM (sizeof(struct drvmgr_drv_ops)/sizeof(void (*)(void)))
+/*! Device driver description */
+struct drvmgr_drv {
+ int obj_type; /*!< DRVMGR_OBJ_DRV */
+ struct drvmgr_drv *next; /*!< Next Driver */
+ struct drvmgr_dev *dev; /*!< Devices using this driver */
+ uint64_t drv_id; /*!< Unique Driver ID */
+ char *name; /*!< Name of Driver */
+ int bus_type; /*!< Type of Bus this driver supports */
+ struct drvmgr_drv_ops *ops; /*!< Driver operations */
+ struct drvmgr_func *funcs; /*!< Extra Operations */
+ unsigned int dev_cnt; /*!< Number of devices in dev */
+ unsigned int dev_priv_size; /*!< If non-zero DRVMGR will allocate memory for dev->priv */
+/*! Structure defines a function pointer called when driver manager is ready
+ * for drivers to register themselfs. Used to select drivers available to the
+ * driver manager.
+struct drvmgr_drv_reg_func {
+ void (*drv_reg)(void);
+/*** DRIVER | DEVICE | BUS FUNCTIONS ***/
+/* Return Codes */
+enum {
+ DRVMGR_OK = 0, /* Sucess */
+ DRVMGR_NOMEM = 1, /* Memory allocation error */
+ DRVMGR_EIO = 2, /* I/O error */
+ DRVMGR_EINVAL = 3, /* Invalid parameter */
+ DRVMGR_ENOSYS = 4,
+ DRVMGR_TIMEDOUT = 5, /* Operation timeout error */
+ DRVMGR_EBUSY = 6,
+ DRVMGR_ENORES = 7, /* Not enough resources */
+ DRVMGR_FAIL = -1 /* Unspecified failure */
+/*! Initialize data structures of the driver management system.
+ * Calls predefined register driver functions so that drivers can
+ * register themselves.
+extern void _DRV_Manager_initialization(void);
+/*! Take all devices into init level 'level', all devices registered later
+ * will directly be taken into this level as well, ensuring that all
+ * registerd devices has been taken into the level.
+extern void _DRV_Manager_init_level(int level);
+/*! This function must be defined by the BSP when the driver manager is enabled
+ * and initialized during BSP initialization. The function is called after a
+ * init level is reached the first time by the driver manager.
+extern void bsp_driver_level_hook(int level);
+/*! Init driver manager all in one go, will call _DRV_Manager_initialization(),
+ * then _DRV_Manager_init_level([1..DRVMGR_LEVEL_MAX]).
+ * Typically called from Init task when user wants to initilize driver
+ * manager after startup, otherwise not used.
+extern int drvmgr_init(void);
+/* Take registered buses and devices into the correct init level,
+ * this function is called from _init_level() so normally
+ * we don't need to call it directly.
+extern void drvmgr_init_update(void);
+/*! Register Root Bus device driver */
+extern int drvmgr_root_drv_register(struct drvmgr_drv *drv);
+/*! Register a driver */
+extern int drvmgr_drv_register(struct drvmgr_drv *drv);
+/*! Register a device */
+extern int drvmgr_dev_register(struct drvmgr_dev *dev);
+/*! Remove a device, and all its children devices if device is a bus device. The
+ * device driver will be requested to remove the device and once gone from bus,
+ * device and driver list the device is put into a inactive list for debugging
+ * (this is optional by using remove argument).
+ * Removing the Root Bus Device is not supported.
+ * \param remove If non-zero the device will be deallocated, and not put into
+ * the inacitve list.
+extern int drvmgr_dev_unregister(struct drvmgr_dev *dev);
+/*! Register a bus */
+extern int drvmgr_bus_register(struct drvmgr_bus *bus);
+/*! Unregister a bus */
+extern int drvmgr_bus_unregister(struct drvmgr_bus *bus);
+/*! Unregister all child devices of a bus.
+ * This function is called from the bus driver, from a "safe" state where
+ * devices will not be added or removed on this particular bus at this time
+extern int drvmgr_children_unregister(struct drvmgr_bus *bus);
+/* Separate a device from the driver it has been united with */
+extern int drvmgr_dev_drv_separate(struct drvmgr_dev *dev);
+/*! Allocate a device structure, if no memory available
+ * rtems_error_fatal_occurred is called.
+ * The 'extra' argment tells how many bytes extra space is to be allocated after
+ * the device structure, this is typically used for "businfo" structures. The extra
+ * space is always aligned to a 4-byte boundary.
+extern int drvmgr_alloc_dev(struct drvmgr_dev **pdev, int extra);
+/*! Allocate a bus structure, if no memory available rtems_error_fatal_occurred
+ * is called.
+ * extra space is always aligned to a 4-byte boundary.
+extern int drvmgr_alloc_bus(struct drvmgr_bus **pbus, int extra);
+/*** DRIVER RESOURCE FUNCTIONS ***/
+/*! Add resources to a bus, typically used by a bus driver.
+ * \param bus The Bus to add the resources to.
+ * \param res An array with Driver resources, all together are called bus
+ * resources.
+extern void drvmgr_bus_res_add(struct drvmgr_bus *bus,
+ struct drvmgr_bus_res *bres);
+/*! Find all the resource keys for a device among all driver resources on a
+ * bus. Typically used by a device driver to get configuration options.
+ * \param dev Device to find resources for
+ * \param key Location where the pointer to the driver resource array (drvmgr_drv_res->keys) is stored.
+extern int drvmgr_keys_get(struct drvmgr_dev *dev, struct drvmgr_key **keys);
+/*! Return the one key that matches key name from a driver keys array. The keys
+ * can be obtained using drvmgr_keys_get().
+ * \param keys An array of keys ended with KEY_EMPTY to search among.
+ * \param key_name Name of key to search for among the keys.
+extern struct drvmgr_key *drvmgr_key_get(struct drvmgr_key *keys, char *key_name);
+/*! Extract key value from the key in the keys array matching name and type.
+ * This function calls drvmgr_keys_get to get the key requested (from key
+ * name), then determines if the type is correct. A pointer to the key value
+ * is returned.
+ * \param key_type Data Type of value. INTEGER, ADDRESS, STRING.
+ * \return Returns NULL if no value found matching Key Name and Key
+ * Type.
+extern union drvmgr_key_value *drvmgr_key_val_get(
+ struct drvmgr_key *keys,
+ char *key_name,
+ int key_type);
+/*! Get key value from the bus resources matching [device, key name, key type]
+ * if no matching key is found NULL is returned.
+ * This is typically used by device drivers to find a particular device
+ * resource.
+ * \param dev The device to search resource for.
+ * \param key_name The key name to search for
+ * \param key_type The key type expected.
+ * Key Type was found for device.
+extern union drvmgr_key_value *drvmgr_dev_key_get(
+ char *key_name,
+ int key_type);
+/*** DRIVER INTERACE USED TO REQUEST INFORMATION/SERVICES FROM BUS DRIVER ***/
+/*! Get parent bus */
+static inline struct drvmgr_bus *drvmgr_get_parent(struct drvmgr_dev *dev)
+ if (dev)
+ return dev->parent;
+ else
+ return NULL;
+/*! Get Driver of device */
+static inline struct drvmgr_drv *drvmgr_get_drv(struct drvmgr_dev *dev)
+ if (dev)
+ return dev->drv;
+ else
+ return NULL;
+/*! Calls func() for every device found in the device tree, regardless of
+ * device state or if a driver is assigned. With the options argument the user
+ * can decide to do either a depth-first or a breadth-first search.
+ * If the function func() returns a non-zero value then for_each_dev will
+ * return imediatly with the same return value as func() returned.
+ * \param func Function called on each device
+ * \param arg Custom function argument
+ * \param options Search Options, see DRVMGR_FED_*
+#define DRVMGR_FED_BF 1 /* Breadth-first search */
+#define DRVMGR_FED_DF 0 /* Depth first search */
+extern int drvmgr_for_each_dev(
+ int (*func)(struct drvmgr_dev *dev, void *arg),
+ void *arg,
+ int options);
+/*! Get Device pointer from Driver and Driver minor number
+ * \param drv Driver the device is united with.
+ * \param minor Driver minor number assigned to device.
+ * \param pdev Location where the Device point will be stored.
+ * \return Zero on success. -1 on failure, when device was not
+ * found in driver device list.
+extern int drvmgr_get_dev(
+ int minor,
+ struct drvmgr_dev **pdev);
+/*! Get Bus frequency in Hertz. Frequency is stored into address of freq_hz.
+ * \param dev The Device to get Bus frequency for.
+ * \param options Bus-type specific options
+ * \param freq_hz Location where Bus Frequency will be stored.
+extern int drvmgr_freq_get(
+ int options,
+ unsigned int *freq_hz);
+/*! Return 0 if dev is not located on the root bus, 1 if on root bus */
+extern int drvmgr_on_rootbus(struct drvmgr_dev *dev);
+/*! Get device name prefix, this name can be used to register a unique name in
+ * the bus->error filesystem or to get an idea where the device is located.
+ * \param dev The Device to get the device Prefix for.
+ * \param dev_prefix Location where the prefix will be stored.
+extern int drvmgr_get_dev_prefix(struct drvmgr_dev *dev, char *dev_prefix);
+/*! Register a shared interrupt handler. Since this service is shared among
+ * interrupt drivers/handlers the handler[arg] must be installed before the
+ * interrupt can be cleared or disabled. The handler is by default disabled
+ * after registration.
+ * \param index Index is used to identify the IRQ number if hardware has
+ * multiple IRQ sources. Normally Index is set to 0 to
+ * indicated the first and only IRQ source.
+ * A negative index is interpreted as a absolute bus IRQ
+ * number.
+ * \param isr Interrupt Service Routine.
+ * \param arg Optional ISR argument.
+extern int drvmgr_interrupt_register(
+ int index,
+ const char *info,
+ drvmgr_isr isr,
+ void *arg);
+/*! Unregister an interrupt handler. This also disables the interrupt before
+ * unregistering the interrupt handler.
+ * number.
+ * \param isr Interrupt Service Routine, previously registered.
+ * \param arg Optional ISR argument, previously registered.
+extern int drvmgr_interrupt_unregister(
+ int index,
+ drvmgr_isr isr,
+ void *arg);
+/*! Clear (ACK) pending interrupt
+ * \param dev Device to clear interrupt for.
+ * \param index Index is used to identify the IRQ number if hardware has multiple IRQ sources.
+ * Normally Index is set to 0 to indicated the first and only IRQ source.
+ * A negative index is interpreted as a absolute bus IRQ number.
+extern int drvmgr_interrupt_clear(
+ int index);
+/*! Force unmasking/enableing an interrupt on the interrupt controller, this is not normally used,
+ * if used the caller has masked/disabled the interrupt just before.
+extern int drvmgr_interrupt_unmask(
+ int index);
+/*! Force masking/disable an interrupt on the interrupt controller, this is not normally performed
+ * since this will stop all other (shared) ISRs to be disabled until _unmask() is called.
+ * \param dev Device to mask interrupt for.
+extern int drvmgr_interrupt_mask(
+ int index);
+/*! drvmgr_translate() translation options */
+enum drvmgr_tr_opts {
+ /* Translate CPU RAM Address (input) to DMA unit accessible address
+ * (output), this is an upstreams translation in reverse order.
+ * Typical Usage:
+ * It is common to translate a CPU accessible RAM address to an
+ * address that DMA units can access over bridges.
+ CPUMEM_TO_DMA = 0x0,
+ /* Translate DMA Unit Accessible address mapped to CPU RAM (input) to
+ * CPU accessible address (output). This is an upstreams translation.
+ * Typical Usage (not often used):
+ * The DMA unit descriptors contain pointers to DMA buffers located at
+ * CPU RAM addresses that the DMA unit can access, the CPU processes
+ * the descriptors and want to access the data but a translation back
+ * to CPU address is required.
+ CPUMEM_FROM_DMA = 0x1,
+ /* Translate DMA Memory Address (input) to CPU accessible address
+ * (output), this is a downstreams translation in reverse order.
+ * Typical Usage:
+ * A PCI network card puts packets into its memory not doing DMA over
+ * PCI, in order for the CPU to access them the PCI address must be
+ * translated.
+ DMAMEM_TO_CPU = 0x2,
+ /* Translate CPU accessible address (input) mapped to DMA Memory Address
+ * to DMA Unit accessible address (output). This is a downstreams
+ * translation.
+ DMAMEM_FROM_CPU = 0x3,
+#define DRVMGR_TR_REVERSE 0x1 /* do reverse translation direction order */
+#define DRVMGR_TR_PATH 0x2 /* 0x0=down-stream 0x2=up-stream address path */
+/*! Translate an address on one bus to an address on another bus.
+ * The device determines source or destination bus, the root bus is always
+ * the other bus. It is assumed that the CPU is located on the root bus or
+ * that it can access it without address translation (mapped 1:1). The CPU
+ * is thus assumed to be located on level 0 top most in the bus hierarchy.
+ * If no map is present in the bus driver src_address is translated 1:1
+ * (just copied).
+ * Addresses are typically converted up-streams from the DMA unit towards the
+ * CPU (DMAMEM_TO_CPU) or down-streams towards DMA hardware from the CPU
+ * (CPUMEM_TO_DMA) over one or multiple bridges depending on bus architecture.
+ * See 'enum drvmgr_tr_opts' for other translation direction options.
+ * For example:
+ * Two common operations is to translate a CPU accessible RAM address to an
+ * address that DMA units can access (dev=DMA-unit, CPUMEM_TO_DMA,
+ * src_address=CPU-RAM-ADR) and to translate an address of a PCI resource for
+ * example RAM mapped into a PCI BAR to an CPU accessible address
+ * (dev=PCI-device, DMAMEM_TO_CPU, src_address=PCI-BAR-ADR).
+ * Source address is translated and the result is put into *dst_address, if
+ * the address is not accessible on the other bus -1 is returned.
+ * \param dev Device to translate addresses for
+ * \param options Tanslation direction options, see enum drvmgr_tr_opts
+ * \param src_address Address to translate
+ * \param dst_address Location where translated address is stored
+ * Returns 0 if unable to translate. The remaining length from the given
+ * address of the map is returned on success, for example if a map starts
+ * at 0x40000000 of size 0x100000 the result will be 0x40000 if the address
+ * was translated into 0x400C0000.
+ * If dev is on root-bus no translation is performed 0xffffffff is returned
+ * and src_address is stored in *dst_address.
+extern unsigned int drvmgr_translate(
+ unsigned int options,
+ void *src_address,
+ void **dst_address);
+/* Translate addresses between buses, used internally to implement
+ * drvmgr_translate. Function is not limited to translate from/to root bus
+ * where CPU is resident, however buses must be on a straight path relative
+ * to each other (parent of parent of parent and so on).
+ * \param from src_address is given for this bus
+ * \param to src_address is translated to this bus
+ * \param reverse Selects translation method, if map entries are used in
+ * the reverse order (map_up->to is used as map_up->from)
+ * \param src_address Address to be translated
+ * \param dst_address Translated address is stored here on success (return=0)
+ * address of the map is returned on success and the result is stored into
+ * *dst_address. For example if a map starts at 0x40000000 of size 0x100000
+ * the result will be 0x40000 if the address was translated into 0x400C0000.
+ * If dev is on root-bus no translation is performed 0xffffffff is returned.
+extern unsigned int drvmgr_translate_bus(
+ struct drvmgr_bus *from,
+ struct drvmgr_bus *to,
+ int reverse,
+/* Calls drvmgr_translate() to translate an address range and checks the result,
+ * a printout is generated if the check fails. All parameters are passed on to
+ * drvmgr_translate() except for size, see paramters of drvmgr_translate().
+ * If size=0 only the starting address is not checked.
+ * If mapping failes a non-zero result is returned.
+extern int drvmgr_translate_check(
+ void **dst_address,
+ unsigned int size);
+/*! Get function pointer from Device Driver or Bus Driver.
+ * Returns 0 if function is available
+extern int drvmgr_func_get(void *obj, int funcid, void **func);
+/*! Lookup function and call it directly with the four optional arguments */
+extern int drvmgr_func_call(void *obj, int funcid, void *a, void *b, void *c, void *d);
+/* Builds a Function ID.
+ * Used to request optional functions by a bus or device driver
+#define DRVMGR_FUNCID(major, minor) ((((major) & 0xfff) << 20) | ((minor) & 0xfffff))
+#define DRVMGR_FUNCID_NONE 0
+#define DRVMGR_FUNCID_END DRVMGR_FUNCID(DRVMGR_FUNCID_NONE, 0)
+/* Major Function ID. Most significant 12-bits. */
+enum {
+ FUNCID_NONE = 0x000,
+ FUNCID_RW = 0x001, /* Read/Write functions */
+/* Select Sub-Function Read/Write function by ID */
+#define RW_SIZE_1 0x00001 /* Access Size */
+#define RW_SIZE_2 0x00002
+#define RW_SIZE_4 0x00004
+#define RW_SIZE_8 0x00008
+#define RW_SIZE_ANY 0x00000
+#define RW_SIZE(id) ((unsigned int)(id) & 0xf)
+#define RW_DIR_ANY 0x00000 /* Access Direction */
+#define RW_READ 0x00000 /* Read */
+#define RW_WRITE 0x00010 /* Write */
+#define RW_SET 0x00020 /* Write with same value (memset) */
+#define RW_DIR(id) (((unsigned int)(id) >> 4) & 0x3)
+#define RW_RAW 0x00000 /* Raw access - no swapping (machine default) */
+#define RW_LITTLE 0x00040 /* Little Endian */
+#define RW_BIG 0x00080 /* Big Endian */
+#define RW_ENDIAN(id) (((unsigned int)(id) >> 6) & 0x3)
+#define RW_TYPE_ANY 0x00000 /* Access type */
+#define RW_REG 0x00100
+#define RW_MEM 0x00200
+#define RW_MEMREG 0x00300
+#define RW_CFG 0x00400
+#define RW_TYPE(id) (((unsigned int)(id) >> 8) & 0xf)
+#define RW_ARG 0x01000 /* Optional Argument */
+#define RW_ERR 0x02000 /* Optional Error Handler */
+/* Build a Read/Write function ID */
+#define DRVMGR_RWFUNC(minor) DRVMGR_FUNCID(FUNCID_RW, minor)
+/* Argument to Read/Write functions, the "void *arg" pointer is returned by
+ * RW_ARG. If NULL is returned no argument is needed.
+struct drvmgr_rw_arg {
+ void *arg;
+/* Standard Read/Write function types */
+typedef uint8_t (*drvmgr_r8)(uint8_t *srcadr);
+typedef uint16_t (*drvmgr_r16)(uint16_t *srcadr);
+typedef uint32_t (*drvmgr_r32)(uint32_t *srcadr);
+typedef uint64_t (*drvmgr_r64)(uint64_t *srcadr);
+typedef void (*drvmgr_w8)(uint8_t *dstadr, uint8_t data);
+typedef void (*drvmgr_w16)(uint16_t *dstadr, uint16_t data);
+typedef void (*drvmgr_w32)(uint32_t *dstadr, uint32_t data);
+typedef void (*drvmgr_w64)(uint64_t *dstadr, uint64_t data);
+/* READ/COPY a memory area located on bus into CPU memory.
+ * From 'src' (remote) to the destination 'dest' (local), n=number of bytes
+typedef int (*drvmgr_rmem)(void *dest, const void *src, int n);
+/* WRITE/COPY a user buffer located in CPU memory to a location on the bus.
+ * From 'src' (local) to the destination 'dest' (remote), n=number of bytes
+typedef int (*drvmgr_wmem)(void *dest, const void *src, int n);
+/* Set a memory area to the byte value given in c, see LIBC memset(). Memset is
+ * implemented by calling wmem() multiple times with a "large" buffer.
+typedef int (*drvmgr_memset)(void *dstadr, int c, size_t n);
+/* Read/Write function types with additional argument */
+typedef uint8_t (*drvmgr_r8_arg)(uint8_t *srcadr, void *a);
+typedef uint16_t (*drvmgr_r16_arg)(uint16_t *srcadr, void *a);
+typedef uint32_t (*drvmgr_r32_arg)(uint32_t *srcadr, void *a);
+typedef uint64_t (*drvmgr_r64_arg)(uint64_t *srcadr, void *a);
+typedef void (*drvmgr_w8_arg)(uint8_t *dstadr, uint8_t data, void *a);
+typedef void (*drvmgr_w16_arg)(uint16_t *dstadr, uint16_t data, void *a);
+typedef void (*drvmgr_w32_arg)(uint32_t *dstadr, uint32_t data, void *a);
+typedef void (*drvmgr_w64_arg)(uint64_t *dstadr, uint64_t data, void *a);
+typedef int (*drvmgr_rmem_arg)(void *dest, const void *src, int n, void *a);
+typedef int (*drvmgr_wmem_arg)(void *dest, const void *src, int n, void *a);
+typedef int (*drvmgr_memset_arg)(void *dstadr, int c, size_t n, void *a);
+/* Report an error to the parent bus of the device */
+typedef void (*drvmgr_rw_err)(struct drvmgr_rw_arg *a, struct drvmgr_bus *bus,
+ int funcid, void *adr);
+/* Helper function for buses that implement the memset() over wmem() */
+extern void drvmgr_rw_memset(
+ void *dstadr,
+ int c,
+ size_t n,
+ void *a,
+ drvmgr_wmem_arg wmem
+/*** PRINT INFORMATION ABOUT DRIVER MANAGER ***/
+/*! Calls func() for every device found matching the search requirements of
+ * set_mask and clr_mask. Each bit set in set_mask must be set in the
+ * device state bit mask (dev->state), and Each bit in the clr_mask must
+ * be cleared in the device state bit mask (dev->state). There are three
+ * special cases:
+ * 1. If state_set_mask and state_clr_mask are zero the state bits are
+ * ignored and all cores are treated as a match.
+ * 2. If state_set_mask is zero the function func will not be called due to
+ * a bit being set in the state mask.
+ * 3. If state_clr_mask is zero the function func will not be called due to
+ * a bit being cleared in the state mask.
+ * \param devlist The list to iterate though searching for devices.
+ * \param state_set_mask Defines the bits that must be set in dev->state
+ * \param state_clr_mask Defines the bits that must be cleared in dev->state
+extern int drvmgr_for_each_listdev(
+ struct drvmgr_list *devlist,
+ unsigned int state_set_mask,
+ unsigned int state_clr_mask,
+ void *arg);
+/* Print all devices */
+#define PRINT_DEVS_FAILED 0x01 /* Failed during initialization */
+#define PRINT_DEVS_ASSIGNED 0x02 /* Driver assigned */
+#define PRINT_DEVS_UNASSIGNED 0x04 /* Driver not assigned */
+#define PRINT_DEVS_IGNORED 0x08 /* Device ignored on user's request */
+#define PRINT_DEVS_ALL (PRINT_DEVS_FAILED | \
+ PRINT_DEVS_ASSIGNED | \
+ PRINT_DEVS_UNASSIGNED |\
+ PRINT_DEVS_IGNORED)
+/*! Print number of devices, buses and drivers */
+extern void drvmgr_summary(void);
+/*! Print devices with certain condictions met according to 'options' */
+extern void drvmgr_print_devs(unsigned int options);
+/*! Print device/bus topology */
+extern void drvmgr_print_topo(void);
+/*! Print the memory usage
+ * Only accounts for data structures. Not for the text size.
+extern void drvmgr_print_mem(void);
+#define OPTION_DEV_GENINFO 0x00000001
+#define OPTION_DEV_BUSINFO 0x00000002
+#define OPTION_DEV_DRVINFO 0x00000004
+#define OPTION_DRV_DEVS 0x00000100
+#define OPTION_BUS_DEVS 0x00010000
+#define OPTION_RECURSIVE 0x01000000
+#define OPTION_INFO_ALL 0xffffffff
+/*! Print information about a driver manager object (device, driver, bus) */
+extern void drvmgr_info(void *id, unsigned int options);
+/*! Get information about a device */
+extern void drvmgr_info_dev(struct drvmgr_dev *dev, unsigned int options);
+/*! Get information about a bus */
+extern void drvmgr_info_bus(struct drvmgr_bus *bus, unsigned int options);
+/*! Get information about a driver */
+extern void drvmgr_info_drv(struct drvmgr_drv *drv, unsigned int options);
+/*! Get information about all devices on a bus */
+extern void drvmgr_info_devs_on_bus(struct drvmgr_bus *bus, unsigned int options);
+/*! Get information about all devices in the system (on all buses) */
+extern void drvmgr_info_devs(unsigned int options);
+/*! Get information about all drivers in the system */
+extern void drvmgr_info_drvs(unsigned int options);
+/*! Get information about all buses in the system */
+extern void drvmgr_info_buses(unsigned int options);
+/*! Get Driver by Driver ID */
+extern struct drvmgr_drv *drvmgr_drv_by_id(uint64_t id);
+/*! Get Driver by Driver Name */
+extern struct drvmgr_drv *drvmgr_drv_by_name(const char *name);
+/*! Get Device by Device Name */
+extern struct drvmgr_dev *drvmgr_dev_by_name(const char *name);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/libdrvmgr/drvmgr_by_id.c b/cpukit/libdrvmgr/drvmgr_by_id.c
index 0000000..7a0ea42
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_by_id.c
@@ -0,0 +1,33 @@
+/* Find driver by driver-ID
+ * COPYRIGHT (c) 2011.
+/* Get driver from driver name */
+struct drvmgr_drv *drvmgr_drv_by_id(uint64_t id)
+ struct drvmgr_drv *drv = NULL;
+ * read-only list
+ drv = DRV_LIST_HEAD(&mgr->drivers);
+ while (drv) {
+ if (drv->drv_id == id)
+ break;
+ drv = drv->next;
+ return drv;
diff --git a/cpukit/libdrvmgr/drvmgr_by_name.c b/cpukit/libdrvmgr/drvmgr_by_name.c
index 0000000..2ae527a
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_by_name.c
@@ -0,0 +1,37 @@
+/* Find driver by driver-name
+struct drvmgr_drv *drvmgr_drv_by_name(const char *name)
+ if (!name)
+ return NULL;
+ * read-only list
+ while (drv) {
+ if (drv->name && (strcmp(drv->name, name) == 0))
+ break;
+ drv = drv->next;
+ return drv;
diff --git a/cpukit/libdrvmgr/drvmgr_confdefs.h b/cpukit/libdrvmgr/drvmgr_confdefs.h
index 0000000..23affe9
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_confdefs.h
@@ -0,0 +1,86 @@
+/* Driver Manager Configuration file.
+ * The configuration consist of an array with function pointers that
+ * register one or more drivers that will be used by the Driver Manger.
+ * The Functions are called in the order they are declared.
+#ifndef _DRIVER_MANAGER_CONFDEFS_H_
+#define _DRIVER_MANAGER_CONFDEFS_H_
+#include "drvmgr.h"
+#ifdef __cplusplus
+extern "C" {
+#endif
+extern struct drvmgr_drv_reg_func drvmgr_drivers[];
+#ifdef CONFIGURE_INIT
+#if 0 /* EXAMPLE: GPTIMER driver definition */
+#define DRIVER_AMBAPP_GAISLER_GPTIMER_REG {gptimer_register_drv}
+extern void gptimer_register_drv(void);
+#endif
+/* CONFIGURE DRIVER MANAGER */
+struct drvmgr_drv_reg_func drvmgr_drivers[] = {
+#if 0 /* EXAMPLE: GPTIMER Driver registration */
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GPTIMER
+ DRIVER_AMBAPP_GAISLER_GPTIMER_REG,
+#endif
+#endif
+/* Macros for adding custom drivers without needing to recompile
+ * kernel.
+#ifdef CONFIGURE_DRIVER_CUSTOM1
+ DRIVER_CUSTOM1_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_CUSTOM2
+ DRIVER_CUSTOM2_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_CUSTOM3
+ DRIVER_CUSTOM3_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_CUSTOM4
+ DRIVER_CUSTOM4_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_CUSTOM5
+ DRIVER_CUSTOM5_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_CUSTOM6
+ DRIVER_CUSTOM6_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_CUSTOM7
+ DRIVER_CUSTOM7_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_CUSTOM8
+ DRIVER_CUSTOM8_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_CUSTOM9
+ DRIVER_CUSTOM9_REG,
+#endif
+ /* End array with NULL */
+ {NULL}
+#endif /* CONFIGURE_INIT */
+#ifdef __cplusplus
+#endif
+#endif /* _DRIVER_MANAGER_CONFDEFS_H_ */
diff --git a/cpukit/libdrvmgr/drvmgr_dev_by_name.c b/cpukit/libdrvmgr/drvmgr_dev_by_name.c
index 0000000..f5a99ee
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_dev_by_name.c
@@ -0,0 +1,34 @@
+/* Find device by device name
+static int dev_name_compare(struct drvmgr_dev *dev, void *arg)
+ const char *name = arg;
+ if (dev->name && (strcmp(dev->name, name) == 0))
+ return (int)dev;
+ else
+ return 0;
+/* Get device by device name or bus name */
+struct drvmgr_dev *drvmgr_dev_by_name(const char *name)
+ if (!name)
+ return NULL;
+ return (struct drvmgr_dev *)
+ drvmgr_for_each_dev(dev_name_compare, (void *)name, 0);
diff --git a/cpukit/libdrvmgr/drvmgr_drvinf.c b/cpukit/libdrvmgr/drvmgr_drvinf.c
new file mode 100644
index 0000000..9f7c7a5
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_drvinf.c
@@ -0,0 +1,148 @@
+/* Driver Manager Driver Interface Implementation.
+ * This is the part the device driver API, the functions rely on that the
+ * parent bus driver has implemented the neccessary operations correctly.
+#include <stdio.h>
+/* Get device pointer from knowing the Driver and the Driver minor
+ * that was assigned to it
+int drvmgr_get_dev(
+ int minor,
+ if (!drv)
+ return -1;
+ DRVMGR_LOCK_READ();
+ dev = drv->dev;
+ while (dev) {
+ if (dev->minor_drv == minor)
+ break;
+ dev = dev->next_in_drv;
+ DRVMGR_UNLOCK();
+ if (!dev)
+ return -1;
+ if (pdev)
+ *pdev = dev;
+ return 0;
+/* Get Bus frequency in HZ from bus driver */
+int drvmgr_freq_get(
+ int options,
+ if (!dev || !dev->parent || !dev->parent->ops->freq_get)
+ return -1;
+ return dev->parent->ops->freq_get(dev, options, freq_hz);
+/* Get driver prefix */
+int drvmgr_get_dev_prefix(struct drvmgr_dev *dev, char *dev_prefix)
+ struct drvmgr_bus_params params;
+ if (!dev || !dev->parent || !dev->parent->ops->get_params)
+ return -1;
+ dev->parent->ops->get_params(dev, ¶ms);
+ if (!params.dev_prefix)
+ return -1;
+ if (dev_prefix)
+ strcpy(dev_prefix, params.dev_prefix);
+ return 0;
+/* Register an interrupt */
+int drvmgr_interrupt_register(
+ int index,
+ const char *info,
+ drvmgr_isr isr,
+ void *arg)
+ if (!dev || !dev->parent || !dev->parent->ops->int_register)
+ return -1;
+ if (!isr)
+ return -1;
+ return dev->parent->ops->int_register(dev, index, info, isr, arg);
+/* Unregister an interrupt */
+int drvmgr_interrupt_unregister(
+ int index,
+ drvmgr_isr isr,
+ void *arg)
+ if (!dev || !dev->parent || !dev->parent->ops->int_unregister)
+ return -1;
+ if (!isr)
+ return -1;
+ return dev->parent->ops->int_unregister(dev, index, isr, arg);
+int drvmgr_interrupt_clear(
+ int index)
+ if (!dev || !dev->parent || !dev->parent->ops->int_clear)
+ return -1;
+ return dev->parent->ops->int_clear(dev, index);
+int drvmgr_interrupt_unmask(
+ int index)
+ if (!dev || !dev->parent || !dev->parent->ops->int_unmask)
+ return -1;
+ return dev->parent->ops->int_unmask(dev, index);
+int drvmgr_interrupt_mask(
+ int index)
+ if (!dev || !dev->parent || !dev->parent->ops->int_mask)
+ return -1;
+ return dev->parent->ops->int_mask(dev, index);
+int drvmgr_on_rootbus(struct drvmgr_dev *dev)
+ if (dev->parent && dev->parent->dev && dev->parent->dev->parent)
+ return 0;
+ else
+ return 1;
diff --git a/cpukit/libdrvmgr/drvmgr_for_each_dev.c b/cpukit/libdrvmgr/drvmgr_for_each_dev.c
index 0000000..a3e63ec
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_for_each_dev.c
@@ -0,0 +1,104 @@
+/* Iterate over device tree topology, breadth or depth-first
+/* Traverse device tree breadth-first. Supports up to 31 buses */
+static int drvmgr_for_each_dev_breadth(
+ void *arg
+ int ret = 0, i, pos;
+ struct drvmgr_bus *bus, *buses[32];
+ pos = 0;
+ memset(&buses[0], 0, sizeof(buses));
+ buses[pos++] = drv_mgr.root_dev.bus; /* Get root bus */
+ for (i = 0, bus = buses[0]; buses[i]; i++, bus = buses[i]) {
+ dev = bus->children;
+ while (dev) {
+ ret = func(dev, arg);
+ if (ret != 0)
+ break;
+ if (dev->bus && pos < 31)
+ buses[pos++] = dev->bus;
+ dev = dev->next_in_bus;
+ return ret;
+/* Traverse device tree depth-first. */
+static int drvmgr_for_each_dev_depth(
+ void *arg
+ int ret = 0;
+ /* Get first device */
+ dev = drv_mgr.root_dev.bus->children;
+ while (dev) {
+ if (ret != 0)
+ break;
+ if (dev->bus && dev->bus->children) {
+ dev = dev->bus->children;
+ } else {
+next_dev:
+ if (dev->next_in_bus == NULL) {
+ /* Step up one level... back to parent bus */
+ dev = dev->parent->dev;
+ if (dev == &drv_mgr.root_dev)
+ break;
+ goto next_dev;
+ } else {
+ return ret;
+/* Traverse device tree depth-first or breadth-first */
+int drvmgr_for_each_dev(
+ void *arg,
+ int options
+ int ret;
+ /* Get Root Device */
+ if (drv_mgr.root_dev.bus->children != NULL) {
+ if (options & DRVMGR_FED_BF)
+ ret = drvmgr_for_each_dev_breadth(func, arg);
+ else
+ ret = drvmgr_for_each_dev_depth(func, arg);
+ } else
+ ret = 0;
+ DRVMGR_UNLOCK();
+ return ret;
diff --git a/cpukit/libdrvmgr/drvmgr_for_each_list_dev.c b/cpukit/libdrvmgr/drvmgr_for_each_list_dev.c
index 0000000..9e1b95b
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_for_each_list_dev.c
@@ -0,0 +1,44 @@
+/* Iterate over one list of devices used internally by driver manager
+int drvmgr_for_each_listdev(
+ void *arg
+ int ret = 0;
+ /* Get First Device */
+ dev = DEV_LIST_HEAD(devlist);
+ while (dev) {
+ if (((state_set_mask != 0) && ((dev->state & state_set_mask) == state_set_mask)) ||
+ ((state_clr_mask != 0) && ((dev->state & state_clr_mask) == 0)) ||
+ ((state_set_mask == 0) && (state_clr_mask == 0))) {
+ if (ret != 0)
+ break;
+ dev = dev->next;
+ DRVMGR_UNLOCK();
+ return ret;
diff --git a/cpukit/libdrvmgr/drvmgr_func.c b/cpukit/libdrvmgr/drvmgr_func.c
index 0000000..e02a444
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_func.c
@@ -0,0 +1,42 @@
+/* Driver Manager optional dynamic function interface
+/* Get Function from Function ID */
+int drvmgr_func_get(void *obj, int funcid, void **func)
+ int objtype;
+ struct drvmgr_func *f;
+ if (!obj)
+ objtype = *(int *)obj;
+ if (objtype == DRVMGR_OBJ_BUS)
+ f = ((struct drvmgr_bus *)obj)->funcs;
+ else if (objtype == DRVMGR_OBJ_DRV)
+ f = ((struct drvmgr_drv *)obj)->funcs;
+ else
+ if (f == NULL)
+ while (f->funcid != DRVMGR_FUNCID_NONE) {
+ if (f->funcid == funcid) {
+ *func = f->func;
+ return DRVMGR_OK;
+ f++;
diff --git a/cpukit/libdrvmgr/drvmgr_func_call.c b/cpukit/libdrvmgr/drvmgr_func_call.c
index 0000000..75836c3
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_func_call.c
@@ -0,0 +1,21 @@
+/* Lookup function from function ID and call it using given arguments */
+int drvmgr_func_call(void *obj, int funcid, void *a, void *b, void *c, void *d)
+ int (*func)(void *arg1, void *arg2, void *arg3, void *arg4) = NULL;
+ if (drvmgr_func_get(obj, funcid, (void *)&func) != DRVMGR_OK)
+ return func(a, b, c, d);
diff --git a/cpukit/libdrvmgr/drvmgr_init.c b/cpukit/libdrvmgr/drvmgr_init.c
index 0000000..b8a738f
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_init.c
@@ -0,0 +1,26 @@
+/* Driver Manager Initialization
+/* Init driver manager - all in one go. Typically called from Init task when
+ * user wants to initilize driver manager after startup, otherwise not used.
+int drvmgr_init(void)
+ int level;
+ _DRV_Manager_initialization();
+ for (level = 1; level <= DRVMGR_LEVEL_MAX; level++)
+ _DRV_Manager_init_level(level);
+ return 0;
diff --git a/cpukit/libdrvmgr/drvmgr_internal.h b/cpukit/libdrvmgr/drvmgr_internal.h
index 0000000..b459455
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_internal.h
@@ -0,0 +1,70 @@
+/* Private driver manager declarations
+/* Structure hold all information the driver manager needs to know of. Used
+ * internally by Driver Manager routines.
+struct rtems_driver_manager {
+ int level;
+ int initializing_objs;
+ /* Device tree Lock */
+ rtems_id lock;
+ /* The first device - The root device and it's driver */
+ struct drvmgr_drv *root_drv;
+ struct drvmgr_dev root_dev;
+ /*!< Linked list of all registered drivers */
+ struct drvmgr_list drivers;
+ /* Buses that reached a certain initialization level.
+ * Lists by Level:
+ * N=0 - Not intialized, just registered
+ * N=1..MAX-1 - Reached init level N
+ * N=MAX - Successfully initialized bus
+ struct drvmgr_list buses[DRVMGR_LEVEL_MAX+1];
+ /* Buses failed to initialize or has been removed by not freed */
+ struct drvmgr_list buses_inactive;
+ /* Devices that reached a certain initialization level.
+ * Lists by Level:
+ * N=MAX - Successfully initialized device
+ struct drvmgr_list devices[DRVMGR_LEVEL_MAX+1];
+ /*!< Devices failed to initialize, removed, ignored, no driver */
+ struct drvmgr_list devices_inactive;
+extern struct rtems_driver_manager drv_mgr;
+extern void _DRV_Manager_Lock(void);
+extern void _DRV_Manager_Unlock(void);
+extern int _DRV_Manager_Init_Lock(void);
+/* The best solution is to implement the locking with a RW lock, however there
+ * is no such API available. Care must be taken so that dead-lock isn't created
+ * for example in recursive functions.
+#if defined(DRVMGR_USE_LOCKS) && (DRVMGR_USE_LOCKS == 1)
+ #define DRVMGR_LOCK_INIT() _DRV_Manager_Init_Lock()
+ #define DRVMGR_LOCK_WRITE() _DRV_Manager_Lock()
+ #define DRVMGR_LOCK_READ() _DRV_Manager_Lock()
+ #define DRVMGR_UNLOCK() _DRV_Manager_Unlock()
+#else
+ /* no locking */
+#endif
diff --git a/cpukit/libdrvmgr/drvmgr_list.c b/cpukit/libdrvmgr/drvmgr_list.c
index 0000000..dc1665f
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_list.c
@@ -0,0 +1,67 @@
+/* Driver Manager List Interface Implementation.
+ * COPYRIGHT (c) 2009.
+ * Cobham Gaisler AB.
+ * http://www.rtems.com/license/LICENSE.
+#include <stdlib.h>
+/* LIST interface */
+void drvmgr_list_init(struct drvmgr_list *list, int offset)
+ list->head = list->tail = NULL;
+ list->ofs = offset;
+void drvmgr_list_empty(struct drvmgr_list *list)
+void drvmgr_list_add_head(struct drvmgr_list *list, void *entry)
+ LIST_FIELD(list, entry) = list->head;
+ if (list->head == NULL)
+ list->tail = entry;
+ list->head = entry;
+void drvmgr_list_add_tail(struct drvmgr_list *list, void *entry)
+ if (list->tail == NULL)
+ else
+ LIST_FIELD(list, list->tail) = entry;
+ LIST_FIELD(list, entry) = NULL;
+void drvmgr_list_remove_head(struct drvmgr_list *list)
+ list->head = LIST_FIELD(list, list->head);
+ list->tail = NULL;
+void drvmgr_list_remove(struct drvmgr_list *list, void *entry)
+ void **prevptr = &list->head;
+ void *curr, *prev;
+ prev = NULL;
+ curr = list->head;
+ while (curr != entry) {
+ prev = curr;
+ prevptr = &LIST_FIELD(list, curr);
+ curr = LIST_FIELD(list, curr);
+ *prevptr = LIST_FIELD(list, entry);
+ if (list->tail == entry)
+ list->tail = prev;
diff --git a/cpukit/libdrvmgr/drvmgr_list.h b/cpukit/libdrvmgr/drvmgr_list.h
index 0000000..6f4b98e
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_list.h
@@ -0,0 +1,79 @@
+/* Linked list help functions used by driver manager.
+ * Help functions for the Driver Manager. Implements a singly linked list
+ * with head and tail pointers for fast insertions/deletions to head and
+ * tail in list.
+#ifndef _DRVIVER_MANAGER_LIST_H_
+#define _DRVIVER_MANAGER_LIST_H_
+#ifdef __cplusplus
+extern "C" {
+#endif
+/*! List description, Singly link list with head and tail pointers. */
+struct drvmgr_list {
+ void *head; /*!< First entry in queue */
+ void *tail; /*!< Last entry in queue */
+ int ofs; /*!< Offset into head and tail to find next field */
+/* Static initialization of list */
+#define LIST_INITIALIZER(type, field) {NULL, NULL, offsetof(type, field)}
+/* Return the first element in list */
+#define LIST_HEAD(list, type) ((type *)(list)->head)
+/* Return the last element in list */
+#define LIST_TAIL(list, type) ((type *)(list)->tail)
+/* Get the next pointer of an entry */
+#define LIST_FIELD(list, entry) (*(void **)((char *)(entry) + (list)->ofs))
+/* Return the next emlement in list */
+#define LIST_NEXT(list, entry, type) ((type *)(LIST_FIELD(list, entry)))
+/* Iterate through all entries in list */
+#define LIST_FOR_EACH(list, entry, type) \
+ for (entry = LIST_HEAD(list, type); \
+ entry; \
+ entry = LIST_NEXT(list, entry, type))
+/*! Initialize a list during runtime
+ * \param list The list to initialize
+ * \param offset The number of bytes into the entry structure the next pointer
+ * is found
+extern void drvmgr_list_init(struct drvmgr_list *list, int offset);
+/*! Clear list */
+extern void drvmgr_list_empty(struct drvmgr_list *list);
+/*! Add entry to front of list */
+extern void drvmgr_list_add_head(struct drvmgr_list *list, void *entry);
+/*! Add entry to end of list */
+extern void drvmgr_list_add_tail(struct drvmgr_list *list, void *entry);
+/*! Remove entry from front of list */
+extern void drvmgr_list_remove_head(struct drvmgr_list *list);
+/*! Remove entry from anywhere in list */
+extern void drvmgr_list_remove(struct drvmgr_list *list, void *entry);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/libdrvmgr/drvmgr_lock.c b/cpukit/libdrvmgr/drvmgr_lock.c
index 0000000..d6601d3
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_lock.c
@@ -0,0 +1,38 @@
+/* Driver Manager Internal locking implementation
+#include <rtems.h>
+#include <drvmgr/drvmgr.h>
+#include "drvmgr_internal.h"
+void _DRV_Manager_Lock(void)
+ rtems_semaphore_obtain(drv_mgr.lock, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+void _DRV_Manager_Unlock(void)
+ rtems_semaphore_release(drv_mgr.lock);
+int _DRV_Manager_Init_Lock(void)
+ int rc;
+ rc = rtems_semaphore_create(
+ rtems_build_name('D', 'R', 'V', 'M'),
+ 1,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ 0,
+ &drv_mgr.lock);
+ if (rc != RTEMS_SUCCESSFUL)
+ return -1;
+ return 0;
diff --git a/cpukit/libdrvmgr/drvmgr_print.c b/cpukit/libdrvmgr/drvmgr_print.c
index 0000000..c36abfe
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_print.c
@@ -0,0 +1,457 @@
+/* Driver Manager Information printing Interface Implementation
+ * These functions print stuff about the driver manager, what devices were
+ * found and were united with a driver, the Bus topology, memory taken, etc.
+#include <stdio.h>
+#include <string.h>
+typedef void (*fun_ptr)(void);
+static int print_dev_found(struct drvmgr_dev *dev, void *arg)
+ char **pparg = arg;
+ if (pparg && *pparg) {
+ printf(*pparg);
+ *pparg = NULL;
+ printf(" DEV %p %s on bus %p\n", dev,
+ dev->name ? dev->name : "NO_NAME", dev->parent);
+ return 0; /* Continue to next device */
+void drvmgr_print_devs(unsigned int options)
+ struct rtems_driver_manager *mgr = &drv_mgr;
+ char *parg;
+ /* Print Drivers */
+ if (options & PRINT_DEVS_ASSIGNED) {
+ parg = " --- DEVICES ASSIGNED TO DRIVER ---\n";
+ drvmgr_for_each_listdev(&mgr->devices[DRVMGR_LEVEL_MAX],
+ DEV_STATE_UNITED, 0, print_dev_found, &parg);
+ if (parg != NULL)
+ printf("\n NO DEVICES WERE ASSIGNED A DRIVER\n");
+ if (options & PRINT_DEVS_UNASSIGNED) {
+ parg = "\n --- DEVICES WITHOUT DRIVER ---\n";
+ drvmgr_for_each_listdev(&mgr->devices_inactive, 0,
+ DEV_STATE_UNITED, print_dev_found, &parg);
+ if (parg != NULL)
+ printf("\n NO DEVICES WERE WITHOUT DRIVER\n");
+ if (options & PRINT_DEVS_FAILED) {
+ parg = "\n --- DEVICES FAILED TO INITIALIZE ---\n";
+ DEV_STATE_INIT_FAILED, 0, print_dev_found, &parg);
+ if (parg != NULL)
+ printf("\n NO DEVICES FAILED TO INITIALIZE\n");
+ if (options & PRINT_DEVS_IGNORED) {
+ parg = "\n --- DEVICES IGNORED ---\n";
+ DEV_STATE_IGNORED, 0, print_dev_found, &parg);
+ if (parg != NULL)
+ printf("\n NO DEVICES WERE IGNORED\n");
+ printf("\n\n");
+static int drvmgr_topo_func(struct drvmgr_dev *dev, void *arg)
+ char prefix[32];
+ int depth = dev->parent->depth;
+ if (depth > 30)
+ return 0; /* depth more than 30 not supported */
+ memset(prefix, ' ', depth + 1);
+ prefix[depth + 1] = '\0';
+ printf(" %s|-> DEV %p %s\n", prefix, dev,
+ dev->name ? dev->name : "NO_NAME");
+ return 0;
+void drvmgr_print_topo(void)
+ /* Print Bus topology */
+ printf(" --- BUS TOPOLOGY ---\n");
+ drvmgr_for_each_dev(drvmgr_topo_func, NULL, DRVMGR_FED_DF);
+ printf("\n\n");
+/* Print the memory usage */
+void drvmgr_print_mem(void)
+ struct drvmgr_bus_res *node;
+ struct drvmgr_drv_res *res;
+ struct drvmgr_key *key;
+ unsigned int busmem = 0;
+ unsigned int devmem = 0;
+ unsigned int drvmem = 0;
+ unsigned int resmem = 0;
+ unsigned int devprivmem = 0;
+ bus = BUS_LIST_HEAD(&mgr->buses[DRVMGR_LEVEL_MAX]);
+ while (bus) {
+ busmem += sizeof(struct drvmgr_bus);
+ /* Get size of resources on this bus */
+ node = bus->reslist;
+ while (node) {
+ resmem += sizeof(struct drvmgr_bus_res);
+ res = node->resource;
+ while (res->keys) {
+ resmem += sizeof(struct drvmgr_drv_res);
+ key = res->keys;
+ while (key->key_type != KEY_TYPE_NONE) {
+ resmem += sizeof
+ (struct drvmgr_key);
+ key++;
+ resmem += sizeof(struct drvmgr_key);
+ res++;
+ node = node->next;
+ bus = bus->next;
+ while (drv) {
+ drvmem += sizeof(struct drvmgr_drv);
+ drv = drv->next;
+ dev = DEV_LIST_HEAD(&mgr->devices[DRVMGR_LEVEL_MAX]);
+ while (dev) {
+ devmem += sizeof(struct drvmgr_dev);
+ if (dev->drv && dev->drv->dev_priv_size > 0)
+ devprivmem += dev->drv->dev_priv_size;
+ dev = dev->next;
+ DRVMGR_UNLOCK();
+ printf(" --- MEMORY USAGE ---\n");
+ printf(" BUS: %d bytes\n", busmem);
+ printf(" DRV: %d bytes\n", drvmem);
+ printf(" DEV: %d bytes\n", devmem);
+ printf(" DEV private: %d bytes\n", devprivmem);
+ printf(" RES: %d bytes\n", resmem);
+ printf(" TOTAL: %d bytes\n",
+ busmem + drvmem + devmem + devprivmem + resmem);
+ printf("\n\n");
+void drvmgr_summary(void)
+ int i, buscnt = 0, devcnt = 0, drvcnt = 0;
+ printf(" --- SUMMARY ---\n");
+ while (drv) {
+ drvcnt++;
+ drv = drv->next;
+ printf(" NUMBER OF DRIVERS: %d\n", drvcnt);
+ for (i = 0; i <= DRVMGR_LEVEL_MAX; i++) {
+ buscnt = 0;
+ bus = BUS_LIST_HEAD(&mgr->buses[i]);
+ while (bus) {
+ buscnt++;
+ bus = bus->next;
+ if (buscnt > 0) {
+ printf(" NUMBER OF BUSES IN LEVEL[%d]: %d\n",
+ i, buscnt);
+ devcnt = 0;
+ dev = DEV_LIST_HEAD(&mgr->devices[i]);
+ while (dev) {
+ devcnt++;
+ dev = dev->next;
+ if (devcnt > 0) {
+ printf(" NUMBER OF DEVS IN LEVEL[%d]: %d\n",
+ i, devcnt);
+ DRVMGR_UNLOCK();
+ printf("\n\n");
+static void print_info(void *p, char *str)
+ printf(" ");
+ puts(str);
+void drvmgr_info_dev(struct drvmgr_dev *dev, unsigned int options)
+ if (!dev)
+ return;
+ printf(" -- DEVICE %p --\n", dev);
+ if (options & OPTION_DEV_GENINFO) {
+ printf(" PARENT BUS: %p\n", dev->parent);
+ printf(" NAME: %s\n", dev->name ? dev->name : "NO_NAME");
+ printf(" STATE: 0x%08x\n", dev->state);
+ if (dev->bus)
+ printf(" BRIDGE TO: %p\n", dev->bus);
+ printf(" INIT LEVEL: %d\n", dev->level);
+ printf(" ERROR: %d\n", dev->error);
+ printf(" MINOR BUS: %d\n", dev->minor_bus);
+ if (dev->drv) {
+ printf(" MINOR DRV: %d\n", dev->minor_drv);
+ printf(" DRIVER: %p (%s)\n", dev->drv,
+ dev->drv->name ? dev->drv->name : "NO_NAME");
+ printf(" PRIVATE: %p\n", dev->priv);
+ if (options & OPTION_DEV_BUSINFO) {
+ printf(" --- DEVICE INFO FROM BUS DRIVER ---\n");
+ if (!dev->parent)
+ printf(" !! device has no parent bus !!\n");
+ else if (dev->parent->ops->info_dev)
+ dev->parent->ops->info_dev(dev, print_info, NULL);
+ else
+ printf(" Bus doesn't implement info_dev func\n");
+ if (options & OPTION_DEV_DRVINFO) {
+ if (dev->drv) {
+ printf(" --- DEVICE INFO FROM DEVICE DRIVER ---\n");
+ if (dev->drv->ops->info)
+ dev->drv->ops->info(dev, print_info, NULL, 0, 0);
+ else
+ printf(" Driver doesn't implement info func\n");
+static void drvmgr_info_bus_map(struct drvmgr_map_entry *map)
+ if (map == NULL)
+ printf(" Addresses mapped 1:1\n");
+ else if (map == DRVMGR_TRANSLATE_NO_BRIDGE)
+ printf(" No bridge in this direction\n");
+ else {
+ while (map->size != 0) {
+ printf(" 0x%08lx-0x%08lx => 0x%08lx-0x%08lx %s\n",
+ (unsigned long)map->from_adr,
+ (unsigned long)(map->from_adr + map->size - 1),
+ (unsigned long)map->to_adr,
+ (unsigned long)(map->to_adr + map->size - 1),
+ map->name ? map->name : "no label");
+ map++;
+void drvmgr_info_bus(struct drvmgr_bus *bus, unsigned int options)
+ /* Print Driver */
+ printf("-- BUS %p --\n", bus);
+ printf(" BUS TYPE: %d\n", bus->bus_type);
+ printf(" DEVICE: %p (%s)\n", bus->dev,
+ bus->dev->name ? bus->dev->name : "NO_NAME");
+ printf(" OPS: %p\n", bus->ops);
+ printf(" CHILDREN: %d devices\n", bus->dev_cnt);
+ printf(" LEVEL: %d\n", bus->level);
+ printf(" STATE: 0x%08x\n", bus->state);
+ printf(" ERROR: %d\n", bus->error);
+ /* Print address mappings up- (to parent) and down- (from parent to
+ * this bus) stream the bridge of this bus
+ printf(" DOWN STREAMS BRIDGE MAPPINGS (from parent to this bus)\n");
+ drvmgr_info_bus_map(bus->maps_down);
+ printf(" UP STREAMS BRIDGE MAPPINGS (from this bus to parent)\n");
+ drvmgr_info_bus_map(bus->maps_up);
+ /* Print Devices on this bus? */
+ if (options & OPTION_BUS_DEVS) {
+ printf(" CHILDREN:\n");
+ while (dev) {
+ printf(" |- DEV[%02d]: %p %s\n", dev->minor_bus,
+ dev, dev->name ? dev->name : "NO_NAME");
+ DRVMGR_UNLOCK();
+char *drv_ops_names[DRV_OPS_NUM] = {
+ "init[1]:",
+ "init[2]:",
+ "init[3]:",
+ "init[4]:",
+ "remove: ",
+ "info: "
+void drvmgr_info_drv(struct drvmgr_drv *drv, unsigned int options)
+ fun_ptr *ppfunc;
+ int i;
+ printf(" -- DRIVER %p --\n", drv);
+ printf(" DRIVER ID: 0x%llx\n", drv->drv_id);
+ printf(" NAME: %s\n", drv->name ? drv->name : "NO_NAME");
+ printf(" BUS TYPE: %d\n", drv->bus_type);
+ printf(" OPERATIONS:\n");
+ for (i = 0, ppfunc = (fun_ptr *)&drv->ops->init[0]; i<DRV_OPS_NUM; i++)
+ printf(" %s %p\n", drv_ops_names[i], ppfunc[i]);
+ printf(" NO. DEVICES: %d\n", drv->dev_cnt);
+ /* Print devices united with this driver? */
+ if (options & OPTION_DRV_DEVS) {
+ dev = drv->dev;
+ while (dev) {
+ printf(" DEV[%02d]: %p %s\n", dev->minor_drv,
+ DRVMGR_UNLOCK();
+void (*info_obj[3])(void *obj, unsigned int) = {
+ /* DRVMGR_OBJ_DRV */ (void (*)(void *, unsigned int))drvmgr_info_drv,
+ /* DRVMGR_OBJ_BUS */ (void (*)(void *, unsigned int))drvmgr_info_bus,
+ /* DRVMGR_OBJ_DEV */ (void (*)(void *, unsigned int))drvmgr_info_dev,
+/* Get information about a device/bus/driver */
+void drvmgr_info(void *id, unsigned int options)
+ int obj_type;
+ void (*func)(void *, unsigned int);
+ if (!id)
+ return;
+ obj_type = *(int *)id;
+ if ((obj_type < DRVMGR_OBJ_DRV) || (obj_type > DRVMGR_OBJ_DEV))
+ return;
+ func = info_obj[obj_type - 1];
+ func(id, options);
+void drvmgr_info_devs_on_bus(struct drvmgr_bus *bus, unsigned int options)
+ /* Print All Devices on Bus */
+ printf("\n\n -= All Devices on BUS %p =-\n\n", bus);
+ while (dev) {
+ drvmgr_info_dev(dev, options);
+ puts("");
+ if ((options & OPTION_RECURSIVE) == 0)
+ return;
+ /* This device provides a bus, print the bus */
+ while (dev) {
+ if (dev->bus)
+ drvmgr_info_devs_on_bus(dev->bus, options);
+void drvmgr_info_devs(unsigned int options)
+ /* Print device information of all devices and their child devices */
+ dev = &mgr->root_dev;
+ printf("\n\n");
+void drvmgr_info_drvs(unsigned int options)
+ while (drv) {
+ drvmgr_info_drv(drv, options);
+ puts("\n");
+ drv = drv->next;
+void drvmgr_info_buses(unsigned int options)
+ while (bus) {
+ drvmgr_info_bus(bus, options);
+ puts("\n");
+ bus = bus->next;
diff --git a/cpukit/libdrvmgr/drvmgr_res.c b/cpukit/libdrvmgr/drvmgr_res.c
index 0000000..5f8598b
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_res.c
@@ -0,0 +1,102 @@
+/* Driver Manager Driver Resource Interface Implementation.
+/* Find all the resource keys for a device among all bus resources */
+int drvmgr_keys_get(struct drvmgr_dev *dev, struct drvmgr_key **keys)
+ uint64_t drv_id;
+ bus = dev->parent;
+ if (!bus || !dev->drv)
+ return -1;
+ drv_id = dev->drv->drv_id;
+ /* Loop all resource arrays */
+ while (node) {
+ /* Find driver ID in resource array */
+ res = &node->resource[0];
+ while (res->drv_id) {
+ if (res->drv_id == drv_id) {
+ /* Found resource matching driver, now check
+ * that this resource is for this device.
+ if (dev->minor_bus == res->minor_bus) {
+ /* Matching driver and core number */
+ if (keys)
+ *keys = res->keys;
+ return 0;
+ res++;
+ if (keys)
+ *keys = NULL;
+ return 1;
+/* Return key that matches key name */
+struct drvmgr_key *drvmgr_key_get(
+ char *key_name)
+ if (!keys)
+ return NULL;
+ key = keys;
+ if (strcmp(key_name, key->key_name) == 0)
+ return key;
+ key++;
+ return NULL;
+union drvmgr_key_value *drvmgr_key_val_get(
+ char *key_name,
+ int key_type)
+ struct drvmgr_key *key_match;
+ key_match = drvmgr_key_get(keys, key_name);
+ if (key_match) {
+ /* Found key, put pointer to value into */
+ if ((key_type == -1) || (key_match->key_type == key_type))
+ return &key_match->key_value;
+ return NULL;
+union drvmgr_key_value *drvmgr_dev_key_get(
+ struct drvmgr_dev *dev,
+ char *key_name,
+ int key_type)
+ struct drvmgr_key *keys = NULL;
+ /* Find first entry in key array for the device */
+ if (drvmgr_keys_get(dev, &keys))
+ return NULL;
+ /* Find a specific key among the device keys */
+ return drvmgr_key_val_get(keys, key_name, key_type);
diff --git a/cpukit/libdrvmgr/drvmgr_rw.c b/cpukit/libdrvmgr/drvmgr_rw.c
index 0000000..6530cdd
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_rw.c
@@ -0,0 +1,52 @@
+/* Driver Manager Read/Write Interface Implementation.
+/* Set a range of memory in 128 byte chunks.
+ * This call will take 128 bytes for buffer on stack
+void drvmgr_rw_memset(
+ void *dstadr,
+ int c,
+ size_t n,
+ void *a,
+ unsigned long long buf[16+1]; /* Extra bytes after data are reserved
+ * for optimizations by write_mem */
+ int txlen;
+ char *adr;
+ if (n <= 0)
+ return;
+ if (n > sizeof(unsigned long long)*16)
+ txlen = sizeof(unsigned long long)*16;
+ else
+ txlen = n;
+ memset(buf, c, txlen);
+ adr = dstadr;
+ do {
+ wmem(adr, (const void *)&buf[0], txlen, a);
+ adr += txlen;
+ n -= txlen;
+ /* next length to transmitt */
+ if (n > 16*sizeof(unsigned long long))
+ txlen = 16*sizeof(unsigned long long);
+ else
+ txlen = n;
+ } while (n > 0);
diff --git a/cpukit/libdrvmgr/drvmgr_translate.c b/cpukit/libdrvmgr/drvmgr_translate.c
index 0000000..7febf77
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_translate.c
@@ -0,0 +1,149 @@
+/* Driver Manager Driver Translate Interface Implementation
+ * COPYRIGHT (c) 2010.
+ * Used by device drivers. The functions rely on that the parent bus driver
+ * has implemented the neccessary operations correctly.
+ * The translate functions are used to translate addresses between buses
+ * for DMA cores located on a "remote" bus, or for memory-mapped obtaining
+ * an address that can be used to access an remote bus.
+ * For example, PCI I/O might be memory-mapped at the PCI Host bridge,
+ * say address 0xfff10000-0xfff1ffff is mapped to the PCI I/O address
+ * of 0x00000000-0x0000ffff. The PCI Host bridge driver may then set up
+ * a map so that a driver that get PCI address 0x100 can translate that
+ * into 0xfff10100.
+#include <stdio.h>
+unsigned int drvmgr_translate_bus(
+ int reverse,
+ struct drvmgr_bus *path[16];
+ int dir, levels, i;
+ void *dst, *from_adr, *to_adr;
+ struct drvmgr_map_entry *map;
+ unsigned int sz;
+ struct drvmgr_bus *bus_bot, *bus_top;
+ dst = src_address;
+ sz = 0xffffffff;
+ if (from == to) /* no need translating addresses when on same bus */
+ goto out;
+ /* Always find translation path from remote bus towards root bus. All
+ * buses have root bus has parent at some level
+ if (from->depth > to->depth) {
+ bus_bot = from;
+ bus_top = to;
+ dir = 0;
+ } else {
+ bus_bot = to;
+ bus_top = from;
+ dir = 1;
+ levels = bus_bot->depth - bus_top->depth;
+ if (levels >= 16)
+ return 0; /* Does not support such a big depth */
+ i = 0;
+ while ((bus_bot != NULL) && bus_bot != bus_top) {
+ if (dir)
+ path[(levels - 1) - i] = bus_bot;
+ else
+ path[i] = bus_bot;
+ i++;
+ bus_bot = bus_bot->dev->parent;
+ if (bus_bot == NULL)
+ return 0; /* from -> to is not linearly connected */
+ for (i = 0; i < levels; i++) {
+ bus = path[i];
+ if ((dir && reverse) || (!dir && !reverse))
+ map = bus->maps_up;
+ else
+ map = bus->maps_down;
+ if (map == NULL)
+ continue; /* No translation needed - 1:1 mapping */
+ if (map == DRVMGR_TRANSLATE_NO_BRIDGE) {
+ sz = 0;
+ break; /* No bridge interface in this direction */
+ if (reverse) {
+ /* Opposite direction */
+ from_adr = map->to_adr;
+ to_adr = map->from_adr;
+ } else {
+ from_adr = map->from_adr;
+ to_adr = map->to_adr;
+ if ((dst >= from_adr) &&
+ (dst <= (from_adr + (map->size - 1)))) {
+ if (((from_adr + (map->size - 1)) - dst) < sz)
+ sz = (from_adr + (map->size - 1)) - dst;
+ dst = (dst - from_adr) + to_adr;
+ break;
+ map++;
+ /* quit if no matching translation information */
+ if (map->size == 0) {
+ sz = 0;
+ break;
+out:
+ if (dst_address)
+ *dst_address = dst;
+ return sz;
+unsigned int drvmgr_translate(
+ struct drvmgr_bus *to, *from;
+ int rev = 0;
+ rev = (~options) & 1;
+ if ((options == CPUMEM_TO_DMA) || (options == DMAMEM_FROM_CPU)) {
+ from = drv_mgr.root_dev.bus;
+ to = dev->parent;
+ } else { /* CPUMEM_FROM_DMA || DMAMEM_TO_CPU */
+ from = dev->parent;
+ to = drv_mgr.root_dev.bus;
+ return drvmgr_translate_bus(from, to, rev, src_address, dst_address);
diff --git a/cpukit/libdrvmgr/drvmgr_translate_check.c b/cpukit/libdrvmgr/drvmgr_translate_check.c
index 0000000..c882b88
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_translate_check.c
@@ -0,0 +1,35 @@
+/* Calls drvmgr_translate() to translate an address range and check the result,
+ * a printout is generated if the check fails. See paramters of
+ * drvmgr_translate().
+int drvmgr_translate_check(
+ unsigned int max;
+ max = drvmgr_translate(dev, options, src_address, dst_address);
+ if (max == 0 || (max < size && (size != 0))) {
+ printk(" ### dev %p (%s) failed mapping %p\n",
+ dev, dev->name ? dev->name : "unnamed", src_address);
+ return -1;
+ return 0;
diff --git a/cpukit/libdrvmgr/drvmgr_unregister.c b/cpukit/libdrvmgr/drvmgr_unregister.c
index 0000000..ef5260a
--- /dev/null
+++ b/cpukit/libdrvmgr/drvmgr_unregister.c
@@ -0,0 +1,186 @@
+/* Driver Manager Device Unregister (removal) implementation
+#include <drvmgr/drvmgr_list.h>
+/* Unregister all children on a bus.
+int drvmgr_children_unregister(struct drvmgr_bus *bus)
+ int err;
+ while (bus->children != NULL) {
+ err = drvmgr_dev_unregister(bus->children);
+ if (err != DRVMGR_OK) {
+ /* An error occured */
+ bus->children->error = err;
+ return err;
+ return DRVMGR_OK;
+/* Unregister a BUS and all it's devices.
+ * It is up to the bus driver to remove all it's devices, either manually
+ * one by one calling drvmgr_dev_unregister(), or by letting the driver
+ * manager unregister all children by calling drvmgr_children_unregister().
+int drvmgr_bus_unregister(struct drvmgr_bus *bus)
+ struct drvmgr_list *list;
+ if (bus->ops->remove == NULL)
+ return DRVMGR_ENOSYS;
+ /* Call Bus driver to clean things up, it must remove all children */
+ bus->error = bus->ops->remove(bus);
+ if (bus->error != DRVMGR_OK)
+ return bus->error;
+ /* Check that bus driver has done its job and removed all children */
+ if (bus->children != NULL)
+ return DRVMGR_FAIL;
+ /* Remove References to bus */
+ bus->dev->bus = NULL;
+ DRVMGR_LOCK_WRITE();
+ /* Remove bus from bus-list */
+ if (bus->state & BUS_STATE_LIST_INACTIVE)
+ list = &mgr->buses_inactive;
+ else
+ list = &mgr->buses[bus->level];
+ drvmgr_list_remove(list, bus);
+ DRVMGR_UNLOCK();
+ /* All references to this bus has been removed at this point */
+ free(bus);
+ return DRVMGR_OK;
+/* Separate Driver and Device from each other */
+int drvmgr_dev_drv_separate(struct drvmgr_dev *dev)
+ struct drvmgr_dev *subdev, **pprev;
+ int rc;
+ /* Remove children if this device exports a bus of devices. All
+ * children must be removed first as they depend upon the bus
+ * services this bridge provide.
+ if (dev->bus) {
+ rc = drvmgr_bus_unregister(dev->bus);
+ if (rc != DRVMGR_OK)
+ return rc;
+ if (dev->drv == NULL)
+ return DRVMGR_OK;
+ /* Remove device by letting assigned driver take care of hardware
+ * issues
+ if (!dev->drv->ops->remove) {
+ /* No remove function is considered severe when someone
+ * is trying to remove the device
+ dev->error = dev->drv->ops->remove(dev);
+ if (dev->error != DRVMGR_OK)
+ /* Delete device from driver's device list */
+ pprev = &dev->drv->dev;
+ subdev = dev->drv->dev;
+ while (subdev != dev) {
+ pprev = &subdev->next_in_drv;
+ subdev = subdev->next_in_drv;
+ *pprev = subdev->next_in_drv;
+ dev->drv->dev_cnt--;
+ /* Move device to inactive list */
+ drvmgr_list_remove(&mgr->devices[dev->level], dev);
+ dev->level = 0;
+ dev->state &= ~(DEV_STATE_UNITED|DEV_STATE_INIT_DONE);
+ dev->state |= DEV_STATE_LIST_INACTIVE;
+ drvmgr_list_add_tail(&mgr->devices_inactive, dev);
+ DRVMGR_UNLOCK();
+ /* Free Device Driver Private memory if allocated previously by
+ * Driver manager.
+ if (dev->drv->dev_priv_size && dev->priv) {
+ free(dev->priv);
+ dev->priv = NULL;
+ dev->drv = NULL;
+ return DRVMGR_OK;
+/* Unregister device,
+ * - let assigned driver handle deletion
+ * - remove from device list
+ * - remove from driver list
+ * - remove from bus list
+int drvmgr_dev_unregister(struct drvmgr_dev *dev)
+ int err;
+ /* Separate device from driver, if the device is united with a driver.
+ * If this device is a bridge all child buses/devices are also removed.
+ err = drvmgr_dev_drv_separate(dev);
+ return err;
+ /* Remove it from inactive list */
+ drvmgr_list_remove(&mgr->devices_inactive, dev);
+ /* Remove device from parent bus list (no check if dev not in list) */
+ pprev = &dev->parent->children;
+ subdev = dev->parent->children;
+ pprev = &subdev->next_in_bus;
+ subdev = subdev->next_in_bus;
+ *pprev = subdev->next_in_bus;
+ dev->parent->dev_cnt--;
+ DRVMGR_UNLOCK();
+ /* All references to this device has been removed at this point */
+ free(dev);
+ return DRVMGR_OK;
diff --git a/cpukit/preinstall.am b/cpukit/preinstall.am
index b125b2f..806e4bc 100644
--- a/cpukit/preinstall.am
+++ b/cpukit/preinstall.am
@@ -514,3 +514,20 @@ $(PROJECT_INCLUDE)/rtems/fsmount.h: libmisc/fsmount/fsmount.h $(PROJECT_INCLUDE)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/fsmount.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/fsmount.h
+$(PROJECT_INCLUDE)/drvmgr/$(dirstamp):
+ @$(MKDIR_P) $(PROJECT_INCLUDE)/drvmgr
+ @: > $(PROJECT_INCLUDE)/drvmgr/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/drvmgr/$(dirstamp)
+$(PROJECT_INCLUDE)/drvmgr/drvmgr.h: libdrvmgr/drvmgr.h $(PROJECT_INCLUDE)/drvmgr/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/drvmgr/drvmgr.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/drvmgr/drvmgr.h
+$(PROJECT_INCLUDE)/drvmgr/drvmgr_confdefs.h: libdrvmgr/drvmgr_confdefs.h $(PROJECT_INCLUDE)/drvmgr/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/drvmgr/drvmgr_confdefs.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/drvmgr/drvmgr_confdefs.h
+$(PROJECT_INCLUDE)/drvmgr/drvmgr_list.h: libdrvmgr/drvmgr_list.h $(PROJECT_INCLUDE)/drvmgr/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/drvmgr/drvmgr_list.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/drvmgr/drvmgr_list.h
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index cce961c..1bb630b 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -144,6 +144,15 @@ const rtems_libio_helper rtems_fs_init_helper =
#define CONFIGURE_LIBIO_POSIX_KEYS 1
+ * Driver Manager Configuration
+#ifdef RTEMS_DRVMGR_STARTUP
+ #define CONFIGURE_DRVMGR_SEMAPHORES 1
+#else
+ #define CONFIGURE_DRVMGR_SEMAPHORES 0
+#endif
rtems_libio_t rtems_libio_iops[CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS];
@@ -1863,7 +1872,7 @@ const rtems_libio_helper rtems_fs_init_helper =
(CONFIGURE_MAXIMUM_SEMAPHORES + CONFIGURE_LIBIO_SEMAPHORES + \
CONFIGURE_TERMIOS_SEMAPHORES + CONFIGURE_LIBBLOCK_SEMAPHORES + \
CONFIGURE_SEMAPHORES_FOR_FILE_SYSTEMS + \
- CONFIGURE_NETWORKING_SEMAPHORES)
+ CONFIGURE_NETWORKING_SEMAPHORES + CONFIGURE_DRVMGR_SEMAPHORES)
#if !defined(RTEMS_SMP) || \
!defined(CONFIGURE_MAXIMUM_MRSP_SEMAPHORES)
diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
index 235ba77..ba71ec4 100644
--- a/cpukit/sapi/src/exinit.c
+++ b/cpukit/sapi/src/exinit.c
@@ -56,6 +56,10 @@
#include <rtems/rtems/rtemsapi.h>
#include <rtems/posix/posixapi.h>
+ #include <drvmgr/drvmgr.h>
+#endif
Objects_Information *_Internal_Objects[ OBJECTS_INTERNAL_CLASSES_LAST + 1 ];
void rtems_initialize_data_structures(void)
@@ -161,6 +165,9 @@ void rtems_initialize_data_structures(void)
void rtems_initialize_before_drivers(void)
+ #ifdef RTEMS_DRVMGR_STARTUP
+ #endif
#if defined(RTEMS_MULTIPROCESSING)
_MPCI_Create_server();
@@ -182,8 +189,64 @@ void rtems_initialize_device_drivers(void)
* NOTE: The MPCI may be build upon a device driver.
+ /* BSPs has already registered their "root bus" driver in the
+ * bsp_predriver hook or so.
+ * Init Drivers to Level 1, constraints:
+ * - Interrupts and system clock timer does not work.
+ * - malloc() work, however other memory services may not
+ * have been initialized yet.
+ * - initializes most basic stuff
+ * Typical setup in Level 1:
+ * - Find most devices in system, do PCI scan and configuration.
+ * - Reset hardware if needed.
+ * - Install IRQ driver
+ * - Install Timer driver
+ * - Install console driver and debug printk()
+ * - Install extra memory.
+ _DRV_Manager_init_level(1);
+ bsp_driver_level_hook(1);
+ #endif
+ /* Initialize I/O drivers.
+ * Driver Manager note:
+ * All drivers may not be registered yet. Drivers will dynamically
+ * be initialized when registered in level 2,3 and 4.
_IO_Initialize_all_drivers();
+ /* Init Drivers to Level 2, constraints:
+ * - Interrupts can be registered and enabled.
+ * - System Clock is running
+ * - Console may be used.
+ * This is typically where drivers are initialized
+ * for the first time.
+ _DRV_Manager_init_level(2);
+ bsp_driver_level_hook(2);
+ /* Init Drivers to Level 3
+ * This is typically where normal drivers are initialized
+ * for the second time, they may depend on other drivers
+ * API inited in level 2
+ _DRV_Manager_init_level(3);
+ bsp_driver_level_hook(3);
+ /* Init Drivers to Level 4,
+ * Init drivers that depend on services initialized in Level 3
+ _DRV_Manager_init_level(4);
+ bsp_driver_level_hook(4);
+ #endif
if ( _System_state_Is_multiprocessing ) {
_MPCI_Initialization();
diff --git a/cpukit/wrapup/Makefile.am b/cpukit/wrapup/Makefile.am
index c61ab05..7ae7d8a 100644
--- a/cpukit/wrapup/Makefile.am
+++ b/cpukit/wrapup/Makefile.am
@@ -62,10 +62,9 @@ TMP_LIBS += ../libmisc/libutf8proc.a
endif
TMP_LIBS += ../libmisc/libuuid.a
TMP_LIBS += ../libi2c/libi2c.a
TMP_LIBS += ../libpci/libpci.a
+TMP_LIBS += ../libdrvmgr/libdrvmgr.a
if LIBNETWORKING
TMP_LIBS += ../libnetworking/libnetworking.a
1.7.0.4
