[PATCH 010/111] LIBPCI: added DRVMGR model for PCI bus
Daniel Hellstrom daniel at gaisler.com
Thu Feb 26 16:38:12 UTC 2015
 cpukit/libpci/Makefile.am   |    5 +
 cpukit/libpci/pci_bus.c     |  567 +++++++++++++++++++++++++++++++++++++++++++
 cpukit/libpci/pci_bus.h     |  159 ++++++++++++
 cpukit/libpci/preinstall.am |    9 +
 4 files changed, 740 insertions(+), 0 deletions(-)
 create mode 100644 cpukit/libpci/pci_bus.c
 create mode 100644 cpukit/libpci/pci_bus.h
diff --git a/cpukit/libpci/Makefile.am b/cpukit/libpci/Makefile.am
index fd42a6f..d7ca5cc 100644
--- a/cpukit/libpci/Makefile.am
+++ b/cpukit/libpci/Makefile.am
@@ -40,6 +40,11 @@ libpci_a_SOURCES += pci_get_dev.c
 libpci_a_SOURCES += pci_irq.c
 libpci_a_SOURCES += pci_print.c
+# Driver manager PCI bus
+libpci_a_SOURCES += pci_bus.c
+include_drvmgrdir = $(includedir)/drvmgr
+include_drvmgr_HEADERS = pci_bus.h
 endif
 include $(srcdir)/preinstall.am
diff --git a/cpukit/libpci/pci_bus.c b/cpukit/libpci/pci_bus.c
new file mode 100644
index 0000000..ea30dfa
--- /dev/null
+++ b/cpukit/libpci/pci_bus.c
@@ -0,0 +1,567 @@
+/*  PCI bus driver.
+ *  COPYRIGHT (c) 2008.
+ *  Cobham Gaisler AB.
+ *  General part of PCI Bus driver. The driver is typically
+ *  initialized from the PCI host driver separating the host
+ *  driver from the common parts in PCI drivers.
+ *  The PCI library must be initialized before starting the
+ *  PCI bus driver. The PCI library have set up BARs and
+ *  assigned system IRQs for targets.
+ *  This PCI bus driver rely on the PCI library (pci.c) for
+ *  interrupt registeration (pci_interrupt_register) and PCI
+ *  target set up.
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+ *  2008-12-03, Daniel Hellstrom <daniel at gaisler.com>
+ *    Created
+/* Use PCI Configuration libarary pci_hb RAM device structure to find devices,
+ * undefine to access PCI configuration space directly.
+#define USE_PCI_CFG_LIB
+/* On small systems undefine PCIBUS_INFO to avoid sprintf get dragged in */
+#define PCIBUS_INFO
+#include <stdlib.h>
+#include <stdio.h>
+#include <string.h>
+#include <pci.h>
+#ifdef USE_PCI_CFG_LIB
+#include <pci/cfg.h>
+#endif
+#include <pci/irq.h>
+#include <drvmgr/drvmgr.h>
+#include <drvmgr/pci_bus.h>
+#ifdef DEBUG
+#define DBG(args...) printk(args)
+#else
+#endif
+int pcibus_bus_init1(struct drvmgr_bus *bus);
+int pcibus_unite(struct drvmgr_drv *drv, struct drvmgr_dev *dev);
+int pcibus_int_register(
+	struct drvmgr_dev *dev,
+	int index,
+	const char *info,
+	drvmgr_isr isr,
+	void *arg);
+int pcibus_int_unregister(
+	int index,
+	drvmgr_isr isr,
+	void *arg);
+int pcibus_int_clear(
+	int index);
+int pcibus_freq_get(
+	int options,
+	unsigned int *freq_hz);
+int pcibus_get_params(struct drvmgr_dev *dev, struct drvmgr_bus_params *params);
+void pcibus_dev_info(
+	void (*print_line)(void *p, char *str),
+	void *p);
+struct drvmgr_bus_ops pcibus_ops = {
+	.init = {
+		pcibus_bus_init1,
+		NULL,
+		NULL,
+		NULL
+	.remove		= NULL,
+	.unite		= pcibus_unite,
+	.int_register	= pcibus_int_register,
+	.int_unregister	= pcibus_int_unregister,
+#if 0
+	.int_enable	= pcibus_int_enable,
+	.int_disable	= pcibus_int_disable,
+#endif
+	.int_clear	= pcibus_int_clear,
+	.int_mask	= NULL,
+	.int_unmask	= NULL,
+	.get_params	= pcibus_get_params,
+	.freq_get	= pcibus_freq_get,
+#ifdef PCIBUS_INFO
+	.info_dev	= pcibus_dev_info,
+#endif
+struct drvmgr_func pcibus_funcs[] = {
+	DRVMGR_FUNC(PCI_FUNC_MREG_R8, NULL),
+	DRVMGR_FUNC(PCI_FUNC_MREG_R16, NULL),
+	DRVMGR_FUNC(PCI_FUNC_MREG_R32, NULL),
+	DRVMGR_FUNC(PCI_FUNC_MREG_W8, NULL),
+	DRVMGR_FUNC(PCI_FUNC_MREG_W16, NULL),
+	DRVMGR_FUNC(PCI_FUNC_MREG_W32, NULL),
+	DRVMGR_FUNC_END
+/* Driver resources configuration for the PCI bus. It is declared weak so that
+ * the user may override it from the project file, if the default settings are
+ * not enough.
+struct drvmgr_bus_res pcibus_drv_resources __attribute__((weak)) = {
+	.next = NULL,
+	.resource = {
+		RES_EMPTY,
+struct pcibus_priv {
+	struct drvmgr_dev	*dev;
+static int compatible(struct pci_dev_id *id, struct pci_dev_id_match *drv)
+	if (((drv->vendor==PCI_ID_ANY) || (id->vendor==drv->vendor)) &&
+	    ((drv->device==PCI_ID_ANY) || (id->device==drv->device)) &&
+	    ((drv->subvendor==PCI_ID_ANY) || (id->subvendor==drv->subvendor)) &&
+	    ((drv->subdevice==PCI_ID_ANY) || (id->subdevice==drv->subdevice)) &&
+	    ((id->class & drv->class_mask) == drv->class))
+		return 1;
+	else
+		return 0;
+			struct drvmgr_dev *dev)
+	struct pci_drv_info *pdrv;
+	struct pci_dev_id_match *drvid;
+	struct pci_dev_info *pci;
+	if (!drv || !dev || !dev->parent)
+		return 0;
+	if ((drv->bus_type != DRVMGR_BUS_TYPE_PCI) ||
+	     (dev->parent->bus_type != DRVMGR_BUS_TYPE_PCI))
+		return 0;
+	pci = (struct pci_dev_info *)dev->businfo;
+	if (!pci)
+		return 0;
+	pdrv = (struct pci_drv_info *)drv;
+	drvid = pdrv->ids;
+	if (!drvid)
+		return 0;
+	while (drvid->vendor != 0) {
+		if (compatible(&pci->id, drvid)) {
+			/* Unite device and driver */
+			DBG("DRV %p and DEV %p united\n", drv, dev);
+			return 1;
+		drvid++;
+	return 0;
+static int pcibus_int_get(struct drvmgr_dev *dev, int index)
+	int irq;
+	/* Relative (positive) or absolute (negative) IRQ number */
+	if (index > 0) {
+		/* PCI devices only have one IRQ per function */
+		return -1;
+	} else if (index == 0) {
+		/* IRQ Index relative to Cores base IRQ */
+		/* Get Base IRQ */
+		irq = ((struct pci_dev_info *)dev->businfo)->irq;
+		if (irq <= 0)
+			return -1;
+	} else {
+		/* Absolute IRQ number */
+		irq = -index;
+	return irq;
+/* Use standard PCI facility to register interrupt handler */
+	int index,
+	const char *info,
+	drvmgr_isr isr,
+	void *arg)
+#ifdef DEBUG
+	struct drvmgr_dev *busdev = dev->parent->dev;
+#endif
+	int irq;
+	/* Get IRQ number from index and device information */
+	irq = pcibus_int_get(dev, index);
+	if (irq < 0)
+		return -1;
+	DBG("Register PCI interrupt on %p for dev %p (IRQ: %d)\n",
+		busdev, dev, irq);
+	return pci_interrupt_register(irq, info, isr, arg);
+/* Use standard PCI facility to unregister interrupt handler */
+	int index,
+	drvmgr_isr isr,
+	void *arg)
+#ifdef DEBUG
+#endif
+	int irq;
+	if (irq < 0)
+		return -1;
+	DBG("Unregister PCI interrupt on %p for dev %p (IRQ: %d)\n",
+	return pci_interrupt_unregister(irq, isr, arg);
+/* Use standard PCI facility to clear interrupt */
+	int index)
+	int irq;
+	if (irq < 0)
+		return -1;
+	pci_interrupt_clear(irq);
+	return 0;
+	int options,
+	/* Standard PCI Bus frequency */
+	*freq_hz = 33000000;
+	return 0;
+	/* No device prefix */
+	params->dev_prefix = NULL;
+	return 0;
+#ifdef PCIBUS_INFO
+	void *p)
+	struct pci_dev_info *devinfo;
+	struct pcibus_res *pcibusres;
+	struct pci_res *res;
+	char buf[64];
+	int i;
+	char *str1, *res_types[3] = {" IO16", "MEMIO", "  MEM"};
+	uint32_t pcistart;
+	if (!dev)
+		return;
+	devinfo = (struct pci_dev_info *)dev->businfo;
+	if (!devinfo)
+		return;
+	if ((devinfo->id.class >> 8) == PCI_CLASS_BRIDGE_PCI)
+		print_line(p, "PCI BRIDGE DEVICE");
+	else
+		print_line(p, "PCI DEVICE");
+	sprintf(buf, "LOCATION:    BUS:SLOT:FUNCTION [%x:%x:%x]",
+			PCI_DEV_EXPAND(devinfo->pcidev));
+	print_line(p, buf);
+	sprintf(buf, "PCIID        0x%lx", (uint32_t)devinfo->pcidev);
+	sprintf(buf, "VENDOR ID:   %04x", devinfo->id.vendor);
+	sprintf(buf, "DEVICE ID:   %04x", devinfo->id.device);
+	sprintf(buf, "SUBVEN ID:   %04x", devinfo->id.subvendor);
+	sprintf(buf, "SUBDEV ID:   %04x", devinfo->id.subdevice);
+	sprintf(buf, "CLASS:       %lx", devinfo->id.class);
+	sprintf(buf, "REVISION:    %x", devinfo->rev);
+	sprintf(buf, "IRQ:         %d", devinfo->irq);
+	sprintf(buf, "PCIDEV ptr:  %p", devinfo->pci_device);
+	/* List Resources */
+	print_line(p, "RESOURCES");
+	for (i = 0; i < PCIDEV_RES_CNT; i++) {
+		pcibusres = &devinfo->resources[i];
+		str1 = "  RES";
+		pcistart = -1;
+		res = pcibusres->res;
+		if (res && (res->flags & PCI_RES_TYPE_MASK)) {
+			str1 = res_types[(res->flags & PCI_RES_TYPE_MASK) - 1];
+			if (res->flags & PCI_RES_IO32)
+				str1 = " IO32";
+			pcistart = res->start;
+		if (res && (res->flags & PCI_RES_FAIL)) {
+			sprintf(buf, " %s[%d]:  NOT ASSIGNED", str1, i);
+			continue;
+		if (!pcibusres->size)
+			continue;
+		sprintf(buf, " %s[%d]:  %08lx-%08lx [PCIADR %lx]",
+			str1, i, pcibusres->address,
+			pcibusres->address + pcibusres->size - 1, pcistart);
+#endif
+static int pcibus_dev_register(struct pci_dev *dev, void *arg)
+	struct drvmgr_bus *pcibus = arg;
+	struct drvmgr_dev *newdev;
+	struct pci_dev_info *pciinfo;
+	int i, type;
+	struct pci_res *pcires;
+	pci_dev_t pcidev = dev->busdevfun;
+	DBG("PCI DEV REGISTER: %x:%x:%x\n", PCI_DEV_EXPAND(pcidev));
+	/* Allocate a device */
+	drvmgr_alloc_dev(&newdev, 24 + sizeof(struct pci_dev_info));
+	newdev->next = NULL;
+	newdev->parent = pcibus; /* Ourselfs */
+	newdev->minor_drv = 0;
+	newdev->minor_bus = 0;
+	newdev->priv = NULL;
+	newdev->drv = NULL;
+	newdev->name = (char *)(newdev + 1);
+	newdev->next_in_drv = NULL;
+	newdev->bus = NULL;
+	/* Init PnP information, Assign Core interfaces with this device */
+	pciinfo = (struct pci_dev_info *)((char *)(newdev + 1) + 24);
+	/* Read Device and Vendor */
+	pciinfo->id.vendor = dev->vendor;
+	pciinfo->id.device = dev->device;
+	pciinfo->id.subvendor = dev->subvendor;
+	pciinfo->id.subdevice = dev->subdevice;
+	pciinfo->rev = dev->classrev & 0xff;
+	pciinfo->id.class = (dev->classrev >> 8) & 0xffffff;
+	/* Read IRQ information set by PCI layer */
+	pciinfo->irq = dev->sysirq;
+	/* Save Location on PCI bus */
+	pciinfo->pcidev = pcidev;
+	/* Connect device with PCI data structure */
+	pciinfo->pci_device = dev;
+	/* Build resources so that PCI device drivers doesn't have to scan
+	 * configuration space themselves, also the address is translated
+	 * into CPU accessible addresses.
+		pcibusres = &pciinfo->resources[i];
+		pcires = &dev->resources[i];
+		type = pcires->flags & PCI_RES_TYPE_MASK;
+		if (type == 0 || (pcires->flags & PCI_RES_FAIL))
+			continue; /* size=0 */
+		pcibusres->address = pcires->start;
+		if (pci_pci2cpu(&pcibusres->address, type))
+		pcibusres->res = pcires;
+		pcibusres->size = pcires->end - pcires->start;
+	/* Connect device with PCI information */
+	newdev->businfo = (void *)pciinfo;
+	/* Create Device Name */
+	sprintf(newdev->name, "PCI_%x:%x:%x_%04x:%04x",
+		PCI_DEV_BUS(pcidev), PCI_DEV_SLOT(pcidev), PCI_DEV_FUNC(pcidev),
+		pciinfo->id.vendor, pciinfo->id.device);
+	/* Register New Device */
+	drvmgr_dev_register(newdev);
+	return 0;
+#else
+static int pcibus_dev_register(pci_dev_t pcidev, void *arg)
+	pci_cfg_r16(pcidev, PCI_VENDOR_ID, &pciinfo->id.vendor);
+	pci_cfg_r16(pcidev, PCI_DEVICE_ID, &pciinfo->id.device);
+	pci_cfg_r32(pcidev, PCI_CLASS_REVISION, &pciinfo->id.class);
+	pciinfo->rev = pciinfo->id.class & 0xff;
+	pciinfo->id.class = pciinfo->id.class >> 8;
+	/* Devices have subsytem device and vendor ID */
+	if ((pciinfo->id.class >> 8) != PCI_CLASS_BRIDGE_PCI) {
+		pci_cfg_r16(pcidev, PCI_SUBSYSTEM_VENDOR_ID,
+							&pciinfo->id.subvendor);
+		pci_cfg_r16(pcidev, PCI_SUBSYSTEM_ID, &pciinfo->id.subdevice);
+	} else {
+		pciinfo->id.subvendor = 0;
+		pciinfo->id.subdevice = 0;
+	pci_cfg_r8(pcidev, PCI_INTERRUPT_LINE, &pciinfo->irq);
+	/* Save Location */
+	/* There is no way we can know this information this way */
+	pciinfo->pci_device = NULL;
+	sprintf(newdev->name, "PCI_%d:%d:%d_%04x:%04x",
+	return 0;
+#endif
+/* Register all AMBA devices available on the AMBAPP bus */
+static int pcibus_devs_register(struct drvmgr_bus *bus)
+	/* return value 0=DRVMGR_OK works with pci_for_each/pci_for_each_dev */
+	/* Walk the PCI device tree in RAM */
+	return pci_for_each_dev(pcibus_dev_register, bus);
+#else
+	/* Scan PCI Configuration space */
+	return pci_for_each(pcibus_dev_register, bus);
+#endif
+/*** DEVICE FUNCTIONS ***/
+int pcibus_register(struct drvmgr_dev *dev, struct pcibus_config *config)
+	struct pcibus_priv *priv;
+	int i, fid, rc;
+	DBG("PCI BUS: initializing\n");
+	/* Create BUS */
+	drvmgr_alloc_bus(&dev->bus, sizeof(struct pcibus_priv));
+	dev->bus->bus_type = DRVMGR_BUS_TYPE_PCI;
+	dev->bus->next = NULL;
+	dev->bus->dev = dev;
+	dev->bus->children = NULL;
+	dev->bus->ops = &pcibus_ops;
+	dev->bus->dev_cnt = 0;
+	dev->bus->reslist = NULL;
+	dev->bus->maps_up = config->maps_up;
+	dev->bus->maps_down = config->maps_down;
+	dev->bus->funcs = &pcibus_funcs[0];
+	/* Copy function definitions from PCI Layer */
+	for (i=0; i<6; i++) {
+		fid = pcibus_funcs[i].funcid;
+		rc = pci_access_func(RW_DIR(fid), RW_SIZE(fid),
+				&pcibus_funcs[i].func, PCI_LITTLE_ENDIAN, 3);
+		if (rc != 0)
+			DBG("PCI BUS: MEMREG 0x%x function not defined\n", fid);
+	/* Add resource configuration if user overrided the default empty cfg */
+	if (pcibus_drv_resources.resource[0].drv_id != 0)
+		drvmgr_bus_res_add(dev->bus, &pcibus_drv_resources);
+	/* Init BUS private structures */
+	priv = (struct pcibus_priv *)(dev->bus + 1);
+	dev->bus->priv = priv;
+	/* Register BUS */
+	drvmgr_bus_register(dev->bus);
+	return DRVMGR_OK;
+/*** BUS INITIALIZE FUNCTIONS ***/
+	return pcibus_devs_register(bus);
diff --git a/cpukit/libpci/pci_bus.h b/cpukit/libpci/pci_bus.h
index 0000000..f96631f
--- /dev/null
+++ b/cpukit/libpci/pci_bus.h
@@ -0,0 +1,159 @@
+/*  PCI bus driver Interface.
+ *  target set up.
+#ifndef __PCI_BUS_H__
+#define __PCI_BUS_H__
+#include <pci.h>
+#include <pci/access.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* PCI Driver ID generation (VENDOR: 16-bit, DEVICE: 16-bit) */
+#define DRIVER_PCI_ID(vendor, device) \
+	DRIVER_ID(DRVMGR_BUS_TYPE_PCI, \
+		((((vendor) & 0xffff) << 16) | ((device) & 0xffff)))
+/* PCI Driver ID generation (CLASS: 24-bit) */
+#define DRIVER_PCI_CLASS(class) \
+	DRIVER_ID(DRVMGR_BUS_TYPE_PCI, ((1 << 32) | ((class) & 0xffffff)))
+/* PCI driver IDs  (DRIVER_PCI_VENDOR_DEVICE or DRIVER_PCI_CLASS_NAME) */
+#define DRIVER_PCI_GAISLER_RASTAIO_ID		DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_IO)
+#define DRIVER_PCI_GAISLER_RASTATMTC_ID		DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_TMTC)
+#define DRIVER_PCI_GAISLER_GR701_ID		DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_701)
+#define DRIVER_PCI_GAISLER_RASTAADCDAC_ID	DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_ADCDAC)
+#define DRIVER_PCI_GAISLER_TMTC_1553_ID		DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_TMTC_1553)
+#define DRIVER_PCI_GAISLER_RASTA_SPW_ROUTER_ID	DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_SPW_RTR)
+struct pci_dev_id {
+	uint16_t		vendor;
+	uint16_t		device;
+	uint16_t		subvendor;
+	uint16_t		subdevice;
+	uint32_t		class; /* 24 lower bits */
+struct pci_dev_id_match {
+	uint16_t		vendor;
+	uint16_t		device;
+	uint32_t		class_mask; /* 24 lower bits */
+#define PCIID_DEVVEND(vendor, device) \
+	{vendor, device, PCI_ID_ANY, PCI_ID_ANY, 0, 0}
+#define PCIID_END_TABLE {0, 0, 0, 0, 0, 0}
+enum {
+	/* A Device has up to 6 BARs and an optional ROM BAR */
+	PCIDEV_RES_BAR1 = 0,
+	PCIDEV_RES_BAR2 = 1,
+	PCIDEV_RES_BAR3 = 2,
+	PCIDEV_RES_BAR4 = 3,
+	PCIDEV_RES_BAR5 = 4,
+	PCIDEV_RES_BAR6 = 5,
+	PCIDEV_RES_ROM  = 6,
+/* Maximum Number of Resources of a device */
+#define PCIDEV_RES_CNT (PCIDEV_RES_ROM + 1)
+/* IO, MEMIO or MEM resource. Can be BAR, ROM or Bridge Window */
+struct pcibus_res {
+	uint32_t		address; /* Base Address, CPU accessible */
+	uint32_t		size;    /* 0=Unimplemented, 0!=Resource Size */
+	struct pci_res		*res;    /* PCI-layer resource */
+struct pci_dev_info {
+	struct pci_dev_id	id;
+	uint8_t			rev;
+	uint8_t			irq; /* 0 = NO IRQ */
+	pci_dev_t		pcidev;
+	struct pcibus_res	resources[PCIDEV_RES_CNT];
+	struct pci_dev		*pci_device;
+struct pci_drv_info {
+	struct drvmgr_drv	general;	/* General bus info */
+	/* PCI specific bus information */
+	struct pci_dev_id_match		*ids;		/* Supported hardware */
+/* Access routines */
+struct pcibus_regmem_ops {
+	drvmgr_r8 r8;
+	drvmgr_r16 r16;
+	drvmgr_r32 r32;
+	drvmgr_r64 r64;
+	drvmgr_w8 w8;
+	drvmgr_w16 w16;
+	drvmgr_w32 w32;
+	drvmgr_w64 w64;
+/* Let driver configure PCI bus driver */
+struct pcibus_config {
+	struct drvmgr_map_entry		*maps_up;
+	struct drvmgr_map_entry		*maps_down;
+/* PCI Configuration Space Access - Not implemented (use PCI Lib directly) */
+#define PCI_FUNC_CFG_R8    DRVMGR_RWFUNC(RW_SIZE_1|RW_READ|RW_CFG)
+#define PCI_FUNC_CFG_R16   DRVMGR_RWFUNC(RW_SIZE_2|RW_READ|RW_CFG)
+#define PCI_FUNC_CFG_R32   DRVMGR_RWFUNC(RW_SIZE_4|RW_READ|RW_CFG)
+#define PCI_FUNC_CFG_W8    DRVMGR_RWFUNC(RW_SIZE_1|RW_WRITE|RW_CFG)
+#define PCI_FUNC_CFG_W16   DRVMGR_RWFUNC(RW_SIZE_2|RW_WRITE|RW_CFG)
+#define PCI_FUNC_CFG_W32   DRVMGR_RWFUNC(RW_SIZE_4|RW_WRITE|RW_CFG)
+/* PCI I/O Register Access - Not implemented (use PCI Lib directly) */
+#define PCI_FUNC_IO_R8    DRVMGR_RWFUNC(RW_SIZE_1|RW_READ|RW_IO)
+#define PCI_FUNC_IO_R16   DRVMGR_RWFUNC(RW_SIZE_2|RW_READ|RW_IO)
+#define PCI_FUNC_IO_R32   DRVMGR_RWFUNC(RW_SIZE_4|RW_READ|RW_IO)
+#define PCI_FUNC_IO_W8    DRVMGR_RWFUNC(RW_SIZE_1|RW_WRITE|RW_IO)
+#define PCI_FUNC_IO_W16   DRVMGR_RWFUNC(RW_SIZE_2|RW_WRITE|RW_IO)
+#define PCI_FUNC_IO_W32   DRVMGR_RWFUNC(RW_SIZE_4|RW_WRITE|RW_IO)
+/* PCI Register Access over Memory Space (Little Endian) */
+#define PCI_FUNC_MREG_R8   DRVMGR_RWFUNC(RW_SIZE_1|RW_READ|RW_MEMREG)
+#define PCI_FUNC_MREG_R16  DRVMGR_RWFUNC(RW_SIZE_2|RW_READ|RW_MEMREG|RW_LITTLE)
+#define PCI_FUNC_MREG_R32  DRVMGR_RWFUNC(RW_SIZE_4|RW_READ|RW_MEMREG|RW_LITTLE)
+#define PCI_FUNC_MREG_W8   DRVMGR_RWFUNC(RW_SIZE_1|RW_WRITE|RW_MEMREG)
+#define PCI_FUNC_MREG_W16  DRVMGR_RWFUNC(RW_SIZE_2|RW_WRITE|RW_MEMREG|RW_LITTLE)
+#define PCI_FUNC_MREG_W32  DRVMGR_RWFUNC(RW_SIZE_4|RW_WRITE|RW_MEMREG|RW_LITTLE)
+/* Weak default PCI driver resources, override this from project configuration
+ * to set PCI Bus resources used to configure PCI device drivers.
+extern struct drvmgr_bus_res pcibus_drv_resources;
+/* Attach a PCI bus on top of a PCI Host device */
+extern int pcibus_register(struct drvmgr_dev *dev, struct pcibus_config *cfg);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/libpci/preinstall.am b/cpukit/libpci/preinstall.am
index b19d288..c762825 100644
--- a/cpukit/libpci/preinstall.am
+++ b/cpukit/libpci/preinstall.am
@@ -63,4 +63,13 @@ PREINSTALL_FILES += $(PROJECT_INCLUDE)/pci/ids_extra.h
 $(PROJECT_INCLUDE)/pci/irq.h: pci/irq.h $(PROJECT_INCLUDE)/pci/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/pci/irq.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/pci/irq.h
+$(PROJECT_INCLUDE)/drvmgr/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/drvmgr
+	@: > $(PROJECT_INCLUDE)/drvmgr/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/drvmgr/$(dirstamp)
+$(PROJECT_INCLUDE)/drvmgr/pci_bus.h: pci_bus.h $(PROJECT_INCLUDE)/drvmgr/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/drvmgr/pci_bus.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/drvmgr/pci_bus.h
 endif
1.7.0.4
